This was inside my drivers door.View attachment 14182
Hi All
So my van’s had a full respray and there’s no info sticker on the b pillar regarding tyre pressures?
I’m running 255/45/18 103 W XL? I’ve seen a couple of posts relating to a T32/T30 but I’m wondering would my pressures be different as it’s a T28?
The reason I’m asking is the middle of my fronts has worn a fair bit more toll than the outer? I realise that wide tyres do wear a bit more in the middle than the outer but there’s a fairly big difference? If anyone could shed some light I’d be most grateful?
TIA
By my calculations that's about 508psi in old moneyI keep mine 35Bar front and rear fully loaded van. Drives nice
Noted and changed...........By my calculations that's about 508psi in old money
My van is a T28 and until this week I was running that same size tyre. As @CAB post above and the information sticker on the b pillar, I always keep them to 44psi on the fronts and 36psi on the rears as my van is ‘light’ and doesn’t carry any weight (such as a full camper conversion). My tyres have been on for just over a year and covered approximately 9000 miles and they have worn perfectly.Hi All
TIA
That's interesting as mine is a T28 fully loaded 99% of the time. Will look at putting more air in on next run out, see what ride is like.My van is a T28 and until this week I was running that same size tyre. As @CAB post above and the information sticker on the b pillar, I always keep them to 44psi on the fronts and 36psi on the rears as my van is ‘light’ and doesn’t carry any weight (such as a full camper conversion). My tyres have been on for just over a year and covered approximately 9000 miles and they have worn perfectly.
