Yep, it's saying max pressure 44psi. Would a car have a load rating of 875kg though? We bought it from the local independent VW specialist (it was his personal van) so kind of assumed it would be pukka. Photos for reference:Hi.. So to understand is it printed/embossed on the tyre wall max pressure 44psi. ( on my Michelin tyres it states 50psi ) Photo would confirm…so id contact tyre dealer as you may be on car derived tyres and not van Xl tyres![]()
See my post above, the sticker is a guide based on OEM tyres, tyres from other manufacturers will differ in their construction and therefore are designed for different pressures at a specific load.As a guide VW supply tyre inflation stickers and recommend pressures For weight carried…. Assuming the tyre is able to withstand the highest pressure for a fully laden vehicle your deemed safe.. However if in this case the tyre has a max of 44psi your never going to comply with VW’s recommendations for a fully laden load …so in the case of this Michelin tyre…..
Your in compliance…..Your need to consult a tyre dealer to fully understand why a tyre that’s got a lower max pressure limit is fitted regardless of load rating and possibly your insurance company may want to know if investigating a accident why your not using a compliant tyre…this is probably a warning that not all tyres are equal…
Hi Gavinda,There's nothing wrong with the tyres!! They are rated to carry more weight than the max axle weights of the vehicle it really is that simple! I've explained about the pressure situation earlier.
36-40psi for a 20” 265/40 or 275/35.@BognorMotors will know, when I bought my T6.1 recently with 20 inch alloy wheels the pressures were set at 50psi front and 55psi rear and Bognor motors told me 38-40 psi which I’m now running my van on.
John.
I’ll get you the correct 18” tyre pressures when I get into the office this morningHi everyone! newly minted T6.1 owners with a new T32 Kombi for family adventures. We're lifelong car owners so we're excited at the adventures ahead.
The van's last owner installed some aftermarket wheels and tyres which are larger than the standard and the tyres are rated to 255/45ZR18 103W
Taken a look at the sticker in the door which says standard tyres are 215/60/R17C followed by 109/107T
I've taken a look around and cant find anything definitive that can give me figures for the tyre pressures I should. I'm planning on visiting the local tyre fitter I've used in the past, but wanted to ask the community 1st.
I’ve merged your thread in to one of several existing threads on tyre pressures for 255/45/18 - they’re an OEM size but not as common as 16” and 17”, which is probably why the pressures aren’t shown on your door sticker.Hi everyone! newly minted T6.1 owners with a new T32 Kombi for family adventures. We're lifelong car owners so we're excited at the adventures ahead.
Thanks for the replies. Much appreciated. Still learning the ropes on the forum so thanks also for merging my post.I’ve merged your thread in to one of several existing threads on tyre pressures for 255/45/18 - they’re an OEM size but not as common as 16” and 17”, which is probably why the pressures aren’t shown on your door sticker.
Here’s the definitive answer:
Hope this helps
Tyre pressures for 18" wheels
Hi guys, my first proper post apart from the new members forum so please go easy. I have looked through other posts and also trawled through the T5 forum but cannot find a definitive answer so hopefully I am not duplicating I took delivery of my T32 Kombi 4-Motion a few weeks ago but replaced...www.t6forum.com
