Are you running 35 or 40 profile studley ?
My cogs are turning again
Great bit of information there @StudleyGlass
Equivalency table
Rim width Minimum tyre width Ideal tyre width Maximum tyre width
5,0 Inches 155 mm 165 or 175 mm 185 mm
5,5 Inches 165 mm 175 or 185 mm 195 mm
6,0 Inches 175 mm 185 or 195 mm 205 mm
6,5 Inches 185 mm 195 or 205 mm 215 mm
7,0 Inches 195 mm 205 or 215 mm 225 mm
7,5 Inches 205 mm 215 or 225 mm 235 mm
8,0 Inches 215 mm 225 or 235 mm 245 mm
8,5 Inches 225 mm 235 or 245 mm 255 mm
9,0 Inches 235 mm 245 or 255 mm 265 mm
9,5 Inches 245 mm 255 or 265 mm 275 mm
10,0 Inches 255 mm 265 or 275 mm 285 mm
10,5 Inches 265 mm 275 or 285 mm 295 mm
11,0 Inches 275 mm 285 or 295 mm 305 mm
11,5 Inches 285 mm 295 or 305 mm 315 mm
12,0 Inches 295 mm 305 or 315 mm 325 mm
12,5 Inches 305 mm 315 or 325 mm 335 mm
Sorry, not quite following why you'd tag me on that? I merely commented on the provision of a table that may be of use. I equally have 255 tyres on an 18" VW alloy.DaveyB
The chart shows that my 255/45/18 tyres fitted to my genuine VW 8j wheel straight off the production line is not compatible !!!!!!!!
Same goes for my Cayenne 295/35/21 on a 10 rim
I guess I will stick with the advice from the wheel specialist he does this day in day out after all
@YESBOY, I took no offence, just wondering why it linked back to me. No worries. Problem for us all is that it is a bit of a dark mess when it comes to getting wheels and tyres that are suitable for T32's, veiled in conjecture and uncertainty. We then have the dogged job of trying to match them, placing our hope in the honesty and integrity of those who exist only to sell their wares and part us with our hard earned money.Sorry DaveyB
Didn't read it properly I wasn't having a dig
At anybody
You lucky buggerI'm lucky that I found out that I don't need 860kg as my carevelle is only 1610kg front axle so found a nice set which are 815kg rated with a 102 tyre ......
Now just praying they fit nice with offset and chosen tyre, 2 weeks till they arrive fingers crossed
T32 is such hard work finding what you like
@StudleyGlass @YESBOY @DaveyB @BognorMotors question is will the 8.5j rim with 255/45/20s rub.....i know it all depends on the offset .....im just going to have to shut up and try and fit them.
You should be ok. This is a comparison of your fronts vs mine (mine orange, yours green) cursity of willtheyfit.com. Width wise your 10mm further away from hub and 10mm further out than mine (ET35 vs 25). Clearly yours are taller than mine with 20"s vs 19"s but plenty of people run 20s..... could you take the tyre down to a 40 profile?
