Looks interesting.Try:
T5 / T6 double folding passenger seat conversion. M1 crash tested. Fits all models 2003 to 2024.
Our bestselling product with thousands of satisfied customers in the UK and Europe If you have a double passenger seat with a fixed backrest, this modification will allow the backrest to fold forward to a flat position. The seat can then be used as a flat surface or to make room for loading...www.vankraft.co.uk
Was it easy to fit the bracket? Also, did you tilt the base with the washers idea by Broadside? Do any of these mods affect the crash test credentials of the seat?Bought the vankraft seat bracket as I found the seat very uncomfortable .fitted it ,showed the missus who thought it was great that u can now fold the seat flat as well. Went out for the day on Sunday and she hated it being short she could no longer touch the floor and with the seat tilted further back she was now leaning on the pillar so had nowhere to rest her arm!! So stripped it out brought it to work today and remachined it back to original angle.Never mind at least the seat still folds ( Ps I thought it was a great position and a nice bit of kit ,bit pricey for what it is though)
Thanks. Did you fit it with the seat in the van?Hi @Pidsley bracket dead easy to fit an hour max, didn't try the washer method first,unfortunately didn't see the post till today .The vankraft info says it is fully crash tested .If you have a regular sized wife who finds the position uncomfortable it is probably a good buy!!
We have had double bench seat in our van for 5 years. I’m use to it now, but a few extra inches for pitch in depth sounds good. I’m not sure what you mean about putting “washers” on bolts under front lip?Putting some washers under the front lip of the bench seat base also makes a big difference by putting a bit more pitch on the whole seat base. Very easy to do putting a few washers on each of the 4 bolts and made a noticeable difference on ours.
Hi, I’m looking at doing this, what size washers do you need?The bench has 8 fixings to the floor, four across the front and four across the back. If you unbolt it and add an equal thickness of washers on the four front fixings, and bolt it back down, it has the effect of tilting the seat backwards.
Hi, After our first trip out, we realised the double bench seat is really uncomfortable. Apart from replacing it with a single, has anyone made any mods or added accessories which improve the comfort of the front passenger bench seat?
