Hi, I’m trying to understand if this portable solar panel is as simple as connecting it together as shown by the diagram, which then can run my 12v fridge and lights off grid?
So basically, I connect the converter to the panel. Then the converter directly to the leisure battery via the crocodile clips - which allows me to easily run the fridge and use the lights? I have a split charge - will this impact that?
Do I need to install a fuse?
Would 200W be sufficient to run the fridge off grip for a long weekend?
As you can tell I know nothing about solar panels or electrics, so any advice would be appreciated!
