I recently purchased full LED headlight units to replace the factory headlights, which originally had H4 bulbs. These new headlights are advertised as plug-and-play, but the seller mentioned that programming might be necessary for the high beam if the factory units used H4 bulbs. To avoid any coding challenges , the seller offered an optional adaptor, which I decided to go for.
The lights arrived yesterday and they look great. However, I encountered a small issue - there were no instructions included for the adaptors. I've attached a picture of them for reference. They seem like they should be plugged in between the headlights and the original plug, with the little dongle connected to one of the loose ends (it only fits one of them).
I'm unsure if this setup is for programming purposes only and can be disconnected afterward, or if it's meant to stay permanently in place. I'd rather not take any chances and end up with loose wires in the car. I've contacted the seller by email, but since it's the weekend, I don't expect a response anytime soon.
Does anyone here have any information on this? Your help would be greatly appreciated. Thanks in advance!
