Upper Lashing points
Paynewright
T6 Legend
I’ve removed the R3 bench seat from the van along with the seatbelts. I found some eye bolts I forgot I had which are usually used for motorsport harness attachment and are the same thread as the seat belt bolt.
The idea bulb appeared above my head and I’ve put them in the old upper seatbelt bosses. Finishes off the holes and useable as load anchors. I uses a fibre washer between the eye bolt and paintwork.
