paulo_1979
Will need the new V2 lead and latest software.
Can you recommend anywhere to buy said kit?
Would you mind to post this guide here?...
UK dealer who sent me a really comprehensive guide on how to do the ODIS update.
Can you also confirm that you have "Travel mode" option on your T6.1 infotainment configuration menu?...
they will set up the lights ready for European driving (in this case just a change to the LED lights to travel mode)
@dnoermannI have been informed that the LED front lights can be changed to alter their beam pattern for driving right hand drive in Europe. On the T6 it was set on a menu using 'travel mode'. Yet on the T6.1 it requires a visit to the workshop. My dealership should have done this for me and assured me it was a quick job with the VW laptop and OBD connected.
I've taken it to a VW workshop in Munich and they have not got a clue. Can any techies out there confirm it can be done - and if so how please?
Thanks in advance
That’s what I was thinking, VW have missed adding it to the list of options.Can you also confirm that you have "Travel mode" option on your T6.1 infotainment configuration menu?
Like this one below on Golf MK7.
And does it function the same as T6(see below)?
There is no menu option available. Dealer has confirmed this (just in case I was being an IT biff)As it's available in the Golf, I wonder if the ODIS work the dealer was trying to do was to enable the menu option, not change the lamps. Maybe this could be done with VCDS?
Will doWould you mind to post this guide here?
EDIT:
Alternatively email it to me or send it via PM.
Its worth noting
7E0998475 = T6 LED module and are not handed
7E0998475A = T6.1 LHD
7E0998475B = T6.1 RHD
Yes don’t see why not, I have ordered LHD headlights in the past without any problems, just takes a few more days as won’t be in stock in the UK
If you are in DE would prob be quicker/easier to order there ?
