I have explained it numerous times throughout this thread - there is no contradiction at all. Read back through my posts. It is people's reading of it that leads them to say this. Provision of photographs for the build is a normal requirement for the companies that cover self-build vans, it used to be harder when you had to develop the film and print the photos!
@oldiebut goodie Can you please explain the apparent conflation of these two issues:
1. There is a list in the Guidance of "certain minimum requirements" for a conversion to be qualified as a motor caravan.
2. As a separate issue ("V5C Log Book"), DVLA will only register that motor caravan qualification on the V5C where the external appearance of the conversion is a motor home.
Is External appearance a "certain minimum requirement" for qualification as a motor caravan?
The conversion Guidance document is a Vehicle safety standards information sheet providing guidance on the required standards for vehicle safety, construction and use (
Vehicle safety standards information sheets). The "certain minimum requirements" have remained unchanged since the Guidance Document was first published in Jan 2011 (when it was called " Registering a DIY caravan" -
Registering a DIY caravan - Publications - GOV.UK).
The external appearance requirement for amendment of the V5C appears to have nothing to do with qualification as a motor caravan: it is not specified as a "certain mimimim requirement". It seems to be merely a DVLA policy decision on the contents of the V5C body type description and the DVLA vehicle database already contains a raft of information which is not published on the V5C.
Suggestion
The Guidance is misleading and DVLA says its amendment is being discussed with DfT. In the interim, perhaps people should refrain from asking DVLA to change the V5C body type classification (e.g. per the linked specimen letter in the Guidance
http://www.caravanwise.co.uk/Resources/reclass.rtf - which is not actually provided by DfT or DVLA, despite the Guidance statement "We have provided a letter...").
Maybe people could adopt an alternative approach, as illustrated:
1. Provide the required proof that the conversion meets the "certain minimum requirements" as specified in the Guidance
Convert a vehicle into a motorhome.
2. In the covering letter, request confirmation from DVLA that the conversion is qualified as a motor caravan, in accordance with the specified certain minimum requirements for vehicle safety, construction and use.
3. In the covering letter, ask DVLA to make an appropriate record of the qualification as a motor caravan, but make no request to amend the V5C body type description.
4. Depending on the content of the DVLA response, applicants hopefully may then have a DVLA letter confirming that the conversion is registered as a qualified motor caravan, or explaining why the conversion has not met the "certain minimum requirements" specified in the Guidance.
