read this for ideas. vag-com upgrades so far (what have you had done?)[QUOTE = "Pauly, posta adresi: 80271, üye: 1"] O halde yapılamıyor, bu değişiklikleri yapmak için katlanır aynaların olması gerekiyor [/ QUOTE]
hangi özellikleri açabilirim? katlanır aynadan başka.
Just run into this same problem myself - what access code was provided to you in VCDS?Stop/Start turned off
You can't do it with VCDS but you can with VCPJust run into this same problem myself - what access code was provided to you in VCDS?
I'm really struggling - I've tried heaps of codes & am running out of ideas now!
Thanks for confirming!You can't do it with VCDS but you can with VCP
Thanks @Pauly very helpful.It’s easy as it’s an OCF (one click function)
From the home screen click OCF, then select start/stop deactivation from the list on the right hand side (you may need to select engine section first can’t remember ?)
This will give you a pop out menu to select vehicle so choose T6 at the very bottom and click go, it will warn you not to have the engine running etc and 30 secs later no more start stop
Shouldn't be a problem. I think all are well documented in the Forum. Just a note that there are two paths to change things: coding and adaptation. I think the coming home function is on the adaptations, the others probably only on the codings.Got my vcds cable from Gendan on Friday Managed to have a wee play with it yesterday. So far I've got my Tailgate closing with the button on the key fob (why it's not like that from the factory I don't know) and I've also adjusted the high beam assist speed settings.
Going to have another go today I want to stop the cornering fog light function, increase the home coming time and set the drls to dim when indicating. Are these straight forward enough to do?
Ian
Great thank you!Shouldn't be a problem. I think all are well documented in the Forum. Just a note that there are two paths to change things: coding and adaptation. I think the coming home function is on the adaptations, the others probably only on the codings.
Could you guide a newbie like me to where I can do that.I've got my Tailgate closing with the button on the key fob
I found a video guide on you tube for this, I'm sure there's a guide on here that @Loz posted too but I can't seem to find it.Could you guide a newbie like me to where I can do that.
So annoying....!
I don't know why it's not like that that from the factory either! Even my old Hyundai could close the boot with the keyfob!
