Van conversion plus ideas for winter
Hi, People on this site have been very generous with their support and have given me some great advice. It seems only fair to post a few pictures and relate my experience.
First some context: we had converted a T4 20 years ago and after 260,000 miles we felt it was time to move on (somewhat reluctantly)
We rather wanted to find someone who would build us the van we wanted, but that turned out to be difficult, understandably most independents were reluctant to get involved in a truly bespoke project. As a result, we decided to do it again. We would have the roof fitted and we reused our Variotech bed. Jerba did the roof we went for this as it has a 100kg load limit and we wanted to carry our sea kayaks. CMC Kent did the Variotech rails, floor, and Webasto. Originally I was going to do the floor and heater, but we got delayed by Covid and so it made sense to give them the job while the tank was down.
It is a conventional layout with a driver's side kitchen obviously the Variotech determines a lot of the design. Last time we built our own fridge using an evaporator plate and a compressor this time we went for a commercial toploader, we also opted for a gas box.
PB090012.JPGPB090015.JPGPB090018.JPGPB090017.JPGPB090020.JPGPB090021.JPGPB090027.JPGPB090026.JPGPB090025.JPG
We use our van all year and ski in the Alps in winter. I included pictures of the "pop-top" silver screens the roof jacks are for heavy snow loads. We have the Reimo roof bed which will fit, but I think I will hang on before fitting it, as the shelf shown in the picture is proving very useful. In the end, we may opt for three shelves that will stack at the end or go end to end to make a bed with a Thermarest. We also fitted a mains outlet on the back of the driver's seat, so a fan heater sits nicely between the front seats without trailing cables. I have already posted about the frustration of the driver's seat swivel in the end I fitted a handbrake lowering kit and that solved the problem. I am retired, so could pretty much work full-time it took 10 weeks to do the build. Hope that has been of interest thanks again for the advice. A couple of things you guys might have ideas about: the Fiamma bike rack is very high I want to lower the platform. I did this to a friend's T5 and he then used a trailer lightboard as the lights are obscured. Is the going rate for a fitted trailer socket £500? The tap works fine, but the water flow pulses. Set up is CAK underfloor tank, Shureflo pump, Dometic tap. I wonder if it could be air locking?
Lovely work. I'm open to correction on this, but I think £500 for a fitted trailer socket is a bit steep. Wires will be clipped underneath the length of the van, especially now furniture has been installed.
View attachment 91551View attachment 91552View attachment 91553View attachment 91554View attachment 91555View attachment 91556View attachment 91557View attachment 91558View attachment 91559
Did you make the pop top insulation? If so, nice work. I like your build. In my opinion, seats on rails create a load more flexibility.
Yep! Well, actually it was my other half who stitched up the liners. If you want additional info checkout Motorhome and Snow FB as I posted more detail on there. Thanks for your kind comments
Hi, We are just about to convert our T6 Kombi SWB and I would love to take it the Alps to snowboard for long weekends. Just about to have it insulated for sound and heat, lined, lights, electrics and heater fitted, swivels to front seats & Exploria Kombi Bed - set quite low so husband can sit up but still lots of space for snowboards. Not having cooker - planning on eating out or something simple with camping stove. Is there anything else you would recommend to cope with the cold? Should we have a water tank fitted? Do you just use thermo liners on the inside? Are they sufficient? Thank you very much
