mini_bear93
Recently fitted a set of 5Forty VanSlam coilovers last weekend. Got the dreaded knocking coming from the rear suspension...
It almost sounds like the spring is loose more so on the near side. This is happening on lower speeds and when cornering.
I have checked over all the corners and could not find anything obvious. Everything is tight. Had the lower shock mount off and slacked the top to try and re-seat the bushing in the mounts (done this with the van on the ground to seat the bushes correctly. Double checked the springs were sitting correctly also. No joy...
The springs are set 7mm from lowest setting so a drop of 63mm from standard.
Anyone else experiencing similar?
Have had a look about to see what everyone else has done, need to check over anti-roll bar bushes. Only other thing I could think it could be is the rubber that comes in the kit that sits between the top adjuster and body, looks very thin to me.
Another thing I have to try is swap out the new shocks with the old ones to rule the shocks out.
Any other ideas very much welcomed!!!
