Mote365
I have a 4000mile old T6 Kombi with van slams, fitted from new. after 5-600 miles the rear end started knocking and it sounded like hitting bumps stops or shock toping out.
I spoke to van slam and they didn't give a damn.
I trimmed down the bump stops and this did not help (should have been trimmed by installer)
I tried all sorts to stop the knocking but last night after just getting fed up with it i sprayed the rear springs with lithium grease because i assumed the spring was catching and making the noise and i was right.
The van is now totally silent over the biggest fastest bumps!
So now i have to try and figure out why the spring is making a noise as it appears to be installed properly.
So I just tried this Lithium grease spray option, not having much faith given the sort of sound tbh, and IT WORKED!
You have saved my sanity!
I believe it’s the rubberised coating on the coil under pressure and moving slightly during use. It’s amplified by the spring I guess. The near side doesn’t do it, just the offside.
Regardless, it’s quite for the first time since fitting.
Thanks for posting this, really, I can sleep at night
