VAS 5051 error codes
Loz
Admin
Moderator
FehlerCodeerror messages
000000000output end
000010001brake control unit
000020002transmission control
000030003control unit
000040004Control unit for gas operation-J659
000160010Servomotor Fu.raum- / defroster, rear right-V195
000170011Servomotor Fu.raum- / defroster, rear left-V196
000180012Servomotor cold flap-V197
000190013Servomotor hot flap-V198
000200014Servomotor butterfly valve Defrost and Manna Stromer Re.-V199
000210015Servomotor butterfly valve Defrost and Manna Stromer bend left-V200
000220016Servomotor hot flap rear center console right-V201
000230017Servomotor hot flap rear center console left-V202
000240018Servomotor cold flap rear center console right-V203
000250019Servomotor cold flap rear center console left-V204
00026001AServomotor Verteilklappe Defrost or Manna Stromer Re.-V205
00027001BServomotor Verteilklappe Defrost or Manna Stromer bend left-V206
00028001CServomotor design panel left-V207
00029001DServomotor center design panel-V208
00030001EServomotor design panel right-V209
00031001FDefrost button rear left-E299
000320020Defrost button rear right-E300
000330021Button Ausstromer front left-E301
000340022Button Ausstromer front center left-E302
000350023Button Ausstromer front middle right-E303
000360024Button Ausstromer front right-E304
000370025Button for temperature difference Fu.raum / headspace E305
000380026Button Ausstromer rear center console left-E306
000390027Button Ausstromer rear center console right-E307
000400028Button for child safety-E318
000410029Servomotor for indirect Beluftungsklappe-V213
00042002ALamp for left parking light-M43
00043002BLamp for right parking light-M44
00044002CActuator test group 1 by drove
00045002Dby drove actuator Test Group 2
00046002EEngine for Hubduse SRA, left-V248
00047002FEngine for Hubduse SRA, right-V249
000480030Temperature Sensor heat exchanger left-G306
000490031Temperature Sensor heat exchanger right-G307
000500032Temperature Sensor evaporator G308
000510033Temperature Sensor Fu.raum rear left-G309
000520034Temperature Sensor Fu.raum rear right-G310
000530035Temperature Sensor rear center console left-G311
000540036Temperature Sensor rear center console right-G312
000550037Engine for child safety rear left-V142
000560038Geblasemotor for Temperature Sensor indoor V210
000570039Servomotor butterfly valve B-pillar and Fu.raum right-V211
00058003ARelay for heating wiper rest-J582
00059003BTerminal 30 for interior lighting
00060003CLamps for front fog lamps
00061003DFu.raumleuchten
00062003EFunction request suspension
00063003FSwitch for rear view lights-F4
000640040Servomotor for butterfly valve B-pillar and Fu.raum left-V212
000650041Heating element in Fu.raum rear left-Z42
000660042Heating element in Fu.raum rear right-Z43
000670043consumer 1
000680044consumer 2
000690045Engine for child safety rear right-V143
000700046Voltage starter battery
000710047Switch for fog lamp E315
000720048Button for rear fog light-E314
000730049Button for the glove compartment-E316
00074004AFuse socket for 1-S184
00075004BFuse socket for 2-S185
00076004CFuse socket for 3-S281
00077004DLimit for wiper F229
00078004EIsolating relay 2.Batterie-J7
00079004FSwitch for interior lighting-E317
000800050Functional requirements sunroof
000810051Undervoltage shutdown seats
000820052Terminal 61 for generator
000830053Leading fuel pump
000840054Changeover relay for onboard power supply battery-J579
000850055Changeover relay for starter battery J580
000860056Relay for parallel battery-J581
000870057Terminal 30 for Start-up consumers
000880058Ladeuberwachung for starter battery
000890059Leitungsuberwachung for terminal 30 starter battery
00090005ASupply line terminal 30 starter battery
00091005BSignal ignition key inserted
00092005CTemperature Sensor starter battery-G331
00093005DTerminal 15 for Start-up consumers
00094005EMotor for central locking, rear left door, LOCK-V214
00095005FMotor for central locking, rear right door, LOCK-V215
000960060Motor for central locking, driver's door-SAVE-V161
000970061Motor for central locking, passenger door-SAVE-V162
000980062Motor for central locking, rear left door-SAVE-V163
000990063Motor for central locking, rear right door-SAVE-V164
001000064Button for interior locking, driver's side-E308
001010065Button for interior locking, passenger side-E309
001020066Button for interior locking, rear left-E310
001030067Button for interior locking, rear right-E311
001040068Button for Tankdeckelentriegelung-E319
001050069Signal Central SAVE / LOCK driver's side
00106006ASignal Central SAVE / LOCK passenger side
00107006BSignal Central SAVE / LOCK rear left
00108006CSignal Central SAVE / LOCK rear right
00109006DLamp for mirror turn signals, driver's side-L131
00110006ELamp for mirror turn signals front passenger side-L132
00111006FControl lamp for interior locking, driver's side-K174
001120070Control lamp for interior locking, passenger side-K175
001130071Control lamp for interior locking, rear left-K176
001140072Control lamp for interior locking, rear right-K177
001150073Button for telephone connection passenger side-E320
001160074Button for telephone connection rear left-E321
001170075Button for telephone connection rear right-E322
001180076Button for defrost driver's side-E323
001190077Button for defrost passenger side-E324
001200078Au.enwarnleuchte / Turausstiegsleuchte driver's side
001210079Au.enwarnleuchte / Turausstiegsleuchte passenger side
00122007AAu.enwarnleuchte / Turausstiegsleuchte rear left
00123007BAu.enwarnleuchte / Turausstiegsleuchte rear right
00124007CLine for communication Tursteuergerat-closing aid driver's side
00125007DLine for communication Tursteuergerat-closing aid passenger side
00126007ELine for communication Tursteuergerat-closing aid rear left
00127007FLine for communication Tursteuergerat-closing aid rear right
001280080Pilot light for telephone connection passenger side-K178
001290081Lighting street Turinnengriff rear left-L133
001300082Lighting street Turinnengriff rear right-L134
001310083Turau.engriffbeleuchtung / mirror light, driver's side
001320084Turau.engriffbeleuchtung / Mirror light passenger side
001330085Turau.engriffbeleuchtung / mirror light, rear left
001340086Turau.engriffbeleuchtung / mirror light, rear right
001350087Encoders for wheel acceleration front left-G337
001360088Encoders for wheel acceleration front right-G338
001370089Encoders for wheel acceleration rear left-G339
00138008AEncoders for wheel acceleration rear right-G340
00139008BDonors for body acceleration front left-G341
00140008CDonors for body acceleration front right-G342
00141008DDonors for body acceleration behind-G343
00142008EValve for Dampfungsverstellung front left-N336
00143008FValve for Dampfungsverstellung front right-N337
001440090Valve for Dampfungsverstellung rear left-N338
001450091Valve for Dampfungsverstellung rear right-N339
001460092Supply voltage for transmitter for acceleration front right / rear left
001470093Supply voltage for transmitter for acceleration front left / rear right
001480094Voltage converter for starter battery charge-A15
001490095No band end programming is done
001500096plausibility Bremskraftverstarkersystem
001510097Plausibility ADR system
001520098Control unit for wiper motor passenger side-J584
001530099Wiper motor driver's side-V216
00154009AWiper motor passenger side-V217
00155009BCommunication control units driver side passenger side
00156009CControl for windshield washer pump
00157009Dterminal X
00158009EFunctional requirements dimming level increase
00159009Freduce functional requirement dimming
0016000A0adaptation brake booster
0016100A1System Test brake booster
0016200A2not made adjustment control unit f.Bremskraftverstarkung
0016300A3Control unit for power-assisted braking learns operating points
0016400A4Control unit for Batterieuberwachung-J367 in emergency mode
0016500A5Switch for gearbox position P / N
0016600A6Switch for access and start authorization-E415
0016700A7Schlussel 5
0016800A8Schlussel 6
0016900A9Schlussel 7
0017000AASchlussel 8
0017100ABSchlussel one not learned
0017200ACSchlussel 2 not learned
0017300ADSchlussel 3 not learned
0017400AESchlussel 4 not learned
0017500AFSchlussel 5 not learned
0017600B0Schlussel 6 not learned
0017700B1Schlussel 7 not learned
0017800B2Schlussel 8 not learned
0017900B3Antenna driver side for access and start authorization-R134
0018000B4Antenna passenger side for access and start authorization-R135
0018100B5Antenna shock Fanger rear f.Zugang and Startberechtig.-R136
0018200B6Antenna trunk for access and start authorization-R137
0018300B7Antenna -1- interior for entry and start authorization-R138
0018400B8Control buttons for engine start / stop
0018500B9Control relay for voltage supply terminal 15
0018600BAControl relay for voltage supply terminal 15SV
0018700BBControl relay for voltage supply terminal 75X
0018800BCControl 1 Relay for voltage supply terminal 50
0018900BDControl 2 Relay for voltage supply terminal 50
0019000BESensor for Turau.engriffberuhrung driver's side-G415
0019100BFSensor for Turau.engriffberuhrung passenger side-G416
0019200C0Sensor for Turau.engriffberuhrung rear left-G417
0019300C1Sensor for Turau.engriffberuhrung rear right-G418
0019400C2Zundschlusselabzugssperre
0019500C3Power supply for potentiometer interior mirror
0019600C4Potentiometer horizontal for inside mirror-G353
0019700C5Pots vertically for interior mirror-G354
0019800C6EC mirror in the interior mirror-Y7
0019900C7Switch for interior light front-E326
0020000C8Button for interior lighting back-E327
0020100C9Button for reading light front-E328
0020200CAButton for reading light rear-E329
0020300CBSwitch for sunroof-E8
0020400CCButton for sliding-E325
0020500CDControl lamp for Garagentoroffner-K179
0020600CEDrive motors for interior mirrors
0020700CFHeating for donors for humidity-N340
0020800D0Terminal 30 for the glove box lighting
Reactions: mmi
0020900D1Terminal 30 for make-up mirrors
0021000D2Control for interior lights front
0021100D3Control for Rear courtesy lights
0021200D4Control for reading lights, front left
0021300D5Control for reading lights, front right
0021400D6Control for reading lights, rear left
0021500D7Control for reading lights, rear right
0021600D8Signal EC mirror fade in
0021700D9Supply voltage for transmitter for humidity
0021800DATransmitter for humidity-G355
0021900DBLoading level active
0022000DCConnection to the sunroof
0022100DDConnection to Innenraumuberwachung
0022200DEConnection to the rain sensor
0022300DFPilot light for donors for vehicle inclination-K188
0022400E0Tension ejector for rear lid lock
0022500E1relax ejector for rear lid lock
0022600E2Control lamp for Dampfungsverstellung-K189
0022700E3Button for Dampfungsverstellung-E387
0022800E4Button for level control-E388
0022900E5Refrigerant pressure
0023000E6Switch for gearbox position P F305
0023100E7incorrect motor data set
0023200E8incorrect transmission record
0023300E9blocked sensor for automatic distance control detection area
0023400EAadjusted sensor for automatic distance control
0023500EBButton for automatic distance control-E357
0023600ECAntenne2 for interior for entry and start authorization-R139
0023700EDSolenoid valve for ABS front left-N59
0023800EESolenoid valve for ABS front right-N58
0023900EFSolenoid valve for ABS rear left-N57
0024000F0Solenoid valve for ABS rear right-N56
0024100F1Pressure control valve for anti-slip-N238
0024200F2Valve for engine throttle-N237
0024300F3engine brake
0024400F4Supply voltage for ABS valves front right and rear left
0024500F5Supply voltage for ABS valves front left and rear right
0024600F6Mass for ABS valves front right and rear left
0024700F7Mass for ABS valves front left and rear right
0024800F8Switch for gear-E206
0024900F9Function jerk message controller for Umluftgeblase
0025000FASwitch for Gelandebetrieb-E207
0025100FB4 encoder for Fuel Storage G393
0025200FCSBBR light, rear left
0025300FDSBBR light, rear right
0025400FEAnti-slip setting is missing
0025500FFValves for ABS
002560100Donors for refrigerant pressure / temperature-G395
002570101Inlet valve ABS front left-N101
002580102Solenoid valve 1-N88
002590103Inlet valve ABS front right-N99
002600104Solenoid valve 2-N89
002610105Inlet valve ABS rear-N103
002620106Solenoid valve 3-N90
002630107transmission
002640108Solenoid valve 4-N91
002650109Exhaust valve ABS front left-N102
00266010ASolenoid valve 5-N92
00267010BExhaust valve ABS front right-N100
00268010CSolenoid valve 6-N93
00269010DExhaust valve ABS rear-N104
00270010ESolenoid valve 7-N94
00271010Fsee Repair Group 01
002720110Shutdown function by electromagnetic disturbances
002730111Inlet valve ABS rear right-N133
002740112Inlet valve ABS rear left-N134
002750113Exhaust valve ABS rear right-N135
002760114Exhaust valve ABS rear left-N136
002770115Input / exhaust valve ABS front left-N137
002780116Main valve ABS-N105
002790117Valve 1 for differential lock-N125
002800118Valve 2 for differential lock-N126
002810119Encoder for Speed-G68
00282011AThrottle-V60
00283011BDrehzahlfuhler front left-G47
00284011CInput / exhaust valve ABS front right-N138
00285011DDrehzahlfuhler front right-G45
00286011EInput / exhaust valve ABS rear left-N139
00287011FDrehzahlfuhler rear right-G44
002880120Actuator for Lenksaulenverriegelung-N360
002890121Input / exhaust valve ABS rear right-N140
002900122Drehzahlfuhler rear left-G46
002910123Pressure Switch F116 / F117 Warning Contact
002920124Hydraulic power pressure level
002930125Multifunction switch F125
002940126Pressure Switch 1 for gear Condition
002950127Pressure Switch 2 for gear Condition
002960128Kick-down switch F8
002970129Transmitter for transmission speed-G38
00298012ASwitch for differential lock-E121
00299012BProgram switch-E122
00300012CDonors for Getriebeoltemperatur-G93
00301012DRuckforderpumpe for ABS V39
00302012ERelay for solenoid valves ABS-J106
00303012FFunction switch-E91
003040130Control knob for Frischluftgeblase
003050131Fuel consumption indicator signal
003060132Secondary air injection cylinder row 1
003070133Secondary air injection cylinder in-line 2
003080134Supply voltage motors sliding roof / sunroof Rolo
003090135Dosing pump for cleaner-V135
003100136Temperature Sensor 1 for catalyst G20
003110137Tires full connection
003120138Temperature Sensor 2 for catalyst G132
003130139catalyst
00314013ATwo-way valve for exhaust gas recirculation-N161
00315013BConnection to Rolo for sunroof
00316013CLamps for rear lighting
00317013DControl unit for tailgate-J605
00318013ESupply voltage for control unit for tailgate
00319013FMotor for tailgate hydraulic-V241
003200140Valve for tailgate hydraulic N346
003210141Donors for tailgate hydraulic-G383
003220142Switch for deactivation Innenraumuberwachung-E267
003230143Donors for vehicle inclination-G384
003240144Button for deactivation giver for vehicle inclination-E360
003250145Button for Heckscheibenoffnung-E361
003260146Switches for emergency shut-theft alarm system E362
003270147open signal sunroof
003280148Control for unlocking rear window
003290149Control for unlocking tailgate
00330014AWiper signal interval
00331014BSignal rear wiper wiper washer
00332014CControl for fuel filler flap
00333014DControl for relay for closing aid
00334014EControl heated rear window Step 2
00335014FControl tail lights
003360150Rear lighting control
003370151Control lighting driver's door
003380152Control lighting passenger door
003390153Control lighting door rear left
003400154Control lighting door rear right
003410155Control the tailgate ON
003420156Control the tailgate TO
003430157Driving swing tailgate lock
003440158Swivel drive tailgate lock
003450159Unlock control tailgate lock
00346015Alock control tailgate lock
00347015BSolenoid valve 8-N281
00348015CSolenoid valve 9-N282
00349015DSolenoid valve 10-N283
00350015EMasseruckfuhrung modulation valves
00351015FEncoder for speed intermediate shaft-G265
003520160terminal 30A
003530161Function jerk message controller for Frischluftgeblase
003540162DC converter windshield heating-A18
003550163Servomotor for Manna Stromer front left-V237
003560164Servomotor for Manna Stromer front right-V238
003570165Control knob for Umluftgeblase
003580166Control for Kuhlmittelabsperrventil
003590167Temperature Sensor Manna Stromer front left-G385
003600168Temperature Sensor Manna Stromer front right-G386
003610169Heating element for additional heater-Z35
00362016AServomotor for air flow flap rear left-V239
00363016BServomotor for air quantity flap, right rear-V240
00364016CTerminal 15 slave
00365016DLine for communication Innenraumuberwachung input
00366016ELine for communication Innenraumuberwachung output
00367016FSteamer front left soft
003680170Steamer front left hard
003690171Steamer front soft right
003700172Steamer front right hard
003710173Steamer rear left soft
003720174Steamer left rear hard
003730175Steamer back right soft
003740176Steamer back right hard
003750177open control Hinged Left
003760178schlie.en control Hinged Left
003770179open Hinged control right
00378017AClose control right hinged window
00379017Bterminal 58s
00380017CControl unit for special vehicles-J608
00381017DBus instrument cluster
00382017EScale for head airbag rear, driver's side-N343
00383017FScale for head airbag rear passenger side-N344
003840180optical data bus
003850181Plus output audio channel for language / telephone
003860182Minus output audio channel for language / telephone
003870183Plus output audio channel for navigation announcements
003880184Minus output audio channel for navigation announcements
003890185Kopfhorerausgang 1, left channel
003900186Kopfhorerausgang 1, right channel
003910187Kopfhorerausgang 2, left channel
003920188Kopfhorerausgang 2, right channel
003930189Display Test, Black segments
00394018ADisplay Test, Wei.segmente
00395018BDisplay Test, Red segments
00396018CDisplay Test, Grunsegmente
00397018DDisplay Test, blue segments
00398018Elocator lighting
00399018FLighting function jerk message
004000190Turn signals, acoustic jerk message
004010191beeper
004020192Heating element for air auxiliary heater-Z35
004030193Motor for sliding roof V1
004040194Motor for sunroof, rear-V146
004050195Engine for blind sunroof-V260
004060196Hall sensors for engine for sunroof-G402
004070197Hall sensors for motor sunroof, rear-G403
004080198Hall sensors for engine for Rolo sun roof-G404
004090199F.Schiebedach switch, signal from the emergency switch is on permanently
00410019ACode signal for Schiebedachoffnung
00411019BSignal from the button for blind is to permanently
00412019CComfort CAN_L line
00413019DComfort CAN_H line
00414019ECAN_L line
00415019FCAN_H line
0041601A0Thermal protection Motor for sliding roof
0041701A1Medium-woofer front left-R101
0041801A2Medium-woofer front right-R102
0041901A3Mid-range speaker, front left-R103
0042001A4Mid-range speaker, front right-R104
0042101A5Mid-range speaker, rear left-R105
0042201A6Mid-range speaker, rear right-R106
0042301A7Thermal protection engine for Rolo sun roof
0042401A8Pull selection of donors for parking aid
0042501A9Function test of the displays for parking aid
0042601AAControl lamp for Stability Program-K155
0042701ABCabling test donors for parking aid
0042801ACFunctional testing of donors for parking aid
0042901ADDisplay for parking sensors front left-Y13
0043001AEDisplay for parking sensors front right-Y14
0043101AFDisplay for rear parking aid-Y15
0043201B0Supply voltage for display and buzzer parking aid
0043301B1Button for parking aid-E266
0043401B2Donors for parking sensors front left inside-G332
0043501B3Donors for parking sensors front right inside-G333
0043601B4Donors for rear parking aid inside left-G334
0043701B5Donors for rear parking assistance Right inner-G335
0043801B6Encoder 2 for Fuel Storage G169
0043901B7Encoder 3 for Fuel Storage G237
0044001B8Donors for Fuel Storage additional tank-G292
0044101B9Donors for fuel level Fuel Storage additional tank-G293
0044201BATerminal 87F fuel pump
0044301BBBackup fuel pump additional tank-S266
0044401BCControl fuel pump additional tank
0044501BDRefrigerant loss
0044601BEFunktionseinschrankung by undervoltage
0044701BFFunktionseinschrankung by overvoltage
0044801C0Precharge pump for Haldex-V181
0044901C1precharge to
0045001C2precharge from
0045101C3All-wheel coupling separately
0045201C4All-wheel coupling is closed
0045301C5Funktionseinschrankung by overtemperature
0045401C6Allraduberwachung
0045501C7Control unit f.Zugang u.Startberechtigung the comfort CAN-J518
0045601C8Control unit for access and start authorization-J518
0045701C9Control unit for vehicle electrical system J519
0045801CAControl unit for Batterieuberwachung-J367
0045901CBControl unit, display and control unit for information, forward-J523
0046001CCControl unit, display and control unit for information, rear-J524
0046101CDControl unit for seat adjustment with memory, co-J521
0046201CEControl unit for seat adjustment with memory, rear-J522
0046301CFControl unit for digital sound package-J525
0046401D0Control unit with display unit for radio and navigation J503
0046501D1Control unit for telephone / telematics J526
0046601D2Control unit for Lenksaulenelektronik-J527
0046701D3TV tuner R78
0046801D4CD-ROM drive R92
0046901D5Data bus infotainment Wire
0047001D6Group convenience data in Wire
0047101D7Control unit for EGD electronically controlled damping-J250
0047201D8Control unit for power-assisted braking-J539
0047301D9Control unit for electric parking / emergency brake-J540
0047401DAControl unit for immobilizer
0047501DBControl unit for sliding door-J558
0047601DCControl unit for fuel pump-J538
0047701DDContro., Display u.Bedieneinh.f.Inform.vo.-J523, on Komf.CAN
0047801DEContro., Display u.Bedieneinh.f.Inform.hi.-J524, on Komf.CAN
0047901DFControl unit for remote control central locking-J276
0048001E0Control unit in the dash panel insert J285, the Infotainment CAN
0048101E1Control unit for traffic-J559
0048201E2Display unit for TV and video, behind-R97
0048301E3Control unit for auxiliary air heater
0048401E4Control unit for vehicle location recognition-J603
0048501E5Button f.Zentralverriegelung, Turau.engriff driver's side-E369
0048601E6Button f.Zentralverriegelung, Turau.engriff Beifahrers.-E370
0048701E7Button f.Zentralverriegelung, Turau.engriff rear left-E371
0048801E8Button f.Zentralverriegelung, Turau.engriff hi.rechts-E372
0048901E9Donors for Ausstromtemperatur rear left-G405
0049001EADonors for Ausstromtemperatur rear right-G406
0049101EBTESTING assignment of Drehzahlfuhler the control unit
0049201ECBody pitch angle from the control unit for level control
0049301EDESP sensor unit G419
0049401EEESP sensor unit incorrect component
0049501EFESP sensor unit supply voltage
0049601F0Timer for the front ride height
0049701F1Donors for vehicle level back
0049801F2Tachograph G24
0049901F3Display for on-board voltage-Y11
0050001F4Display for oil temperature-Y12
0050101F5Control lamp for oil level-K38
0050201F6Pilot light for immobilizer K115
0050301F7Control valves pump / nozzle
0050401F8Valve for the pump / nozzle cylinder 1 N240
0050501F9Valve for the pump / nozzle cylinder 2 N241
0050601FAValve for the pump / nozzle cylinder 3 N242
0050701FBValve for the pump / nozzle cylinder 4-N243
0050801FCValve for the pump / nozzle cylinder 5-N244
0050901FDValve for the pump / nozzle cylinder 6-N245
0051001FEMotor for wind deflector V252
0051101FFSelector lever-E313
005120200Hall sender not to reference mark
005130201Encoders for engine speed G28
005140202Donors for ignition timing-G4
005150203Hall sender G40
005160204Idle switch F60
005170205Full load switch-F81
005180206Throttle-G69
005190207Donors for intake manifold pressure-G71
005200208Air mass / flow meter-G70 / G19
005210209CO potentiometer-G74
00522020ADonors for coolant temperature-G62
00523020BDonors for intake-G42
00524020CKnock sensor 1-G61
00525020DLambda probe-G39
00526020EBrake light switch-F
00527020FDonors for intake manifold-G72
005280210High donor-F96
005290211Speed information missing
005300212Throttle / potentiometer-G88
005310213Air flow sensor reference voltage
005320214supply voltage
005330215Idle speed control
005340216Donors for oil temperature-G8
005350217First knock regulation
005360218Second knock control
005370219Lambda control
00538021Areference voltage
00539021BDonors for fuel temperature-G81
00540021CKnock sensor 2-G66
00541021DPotentiometer for spool-G99
00542021ETimer for needle lift-G80
00543021FSpeed after maximum exceeded
005440220exceeded maximum boost pressure by
005450221Motor / gearbox electrical connection
005460222Data line faulty
005470223Pressure controls for ABS-F137
005480224Power supply fault memory
005490225consumption signal
005500226Injection commencement control
005510227Catalyst overtemperature
005520228Potentiometer for air flow meter-G19
005530229Air flow sensor G70
00554022ALambda control 2
00555022BLambda sensor 2-G108
00556022CPotentiometer for exhaust gas recirculation-G212
00557022DPressure switch power steering-F88
00558022ESetting limit lean mixture control
00559022FSetting limit fat mixture control
005600230Abgasruckfuhrungssystem
005610231Fuel Trim
005620232Donors for oil level / temperature-G266
005630233Display for current fuel consumption-Y10
005640234selector lever
005650235Operating and display unit for Climatronic rear-E265
005660236Steering operation
005670237Control steering motor
005680238Position sensors in the steering motor
005690239Power steering motor
00570023ARelay for steering motor-J509
00571023Bsteering coupling
00572023CEncoders for steering position-G268
00573023DEncoders for steering torque-G269
00574023EA drive motor
00575023FIntake manifold pressure
005760240terminal 15
005770241Knock control cylinder 1
005780242Knock control cylinder 2
005790243Knock control cylinder 3
005800244Knock control cylinder 4
005810245Knock control cylinder 5
005820246Knock control cylinder 6
005830247Knock control cylinder 7
005840248Knock control cylinder 8
005850249Temperature Sensor exhaust gas recirculation-G98
00586024Acontrol Abgasruckfuhrungssystem
00587024BSetting limit mixture control
00588024CScale for airbag (driver's side) -N95
00589024DScale 1 for the airbag (passenger side) -N131
00590024EScale 2 for airbag (passenger side) -N132
00591024FSeat belt driver side-E24
005920250Seat belt passenger side-E25
005930251Seat contact switch passenger seat-F151
005940252Zundkreise airbag
005950253Crash data stored
005960254Short circuit between valve cables
005970255differing wheel speed
005980256Hydraulic- / mechanical fault
005990257Plausibility pressure / brake light switch
006000258Potentiometer control motor for temperature flap-G92
006010259Potentiometer control motor for central flap-G112
00602025APotentiometer control motor for Fu.raum- / defroster-G114
00603025BServomotor for Fu.raum- / defroster-V85
00604025CPotentiometer control motor for air flow flap-G113
00605025DTwo-way valve fresh / air recirculation flap-N63
00606025ETwo-way valve for Kuhlmittelabsperrventil-N147
00607025FOutside temperature indicator G106
006080260Donors for loading state-G119
006090261Zundausgang 1
006100262Zundausgang 2
006110263Zundausgang 3
006120264Zundausgang 4
006130265Zundausgang 5
006140266Zundausgang 6
006150267Zundausgang 7
006160268Zundausgang 8
006170269Timer for delay left airbag G104
00618026ATimer for delay right airbag G105
00619026BDonor supply left
00620026CSensor leads right
00621026DValve for pressure reduction-N155
00622026Edehydrate fuel filter
00623026FABS / transmission electrical connection
006240270Air compressor intervention
006250271speed signal
006260272Control lamp for Vorgluhzeit-K29
006270273Encoder for water level-G120
006280274Stellgro.enuberwachung
006290275Brake pedal switch F47
006300276Air conditioning turned on
006310277AC connection - Motronic
006320278Climatronic Combi Interface
006330279Lines scale / encoder for delay
00634027AResistor for EDS N159
00635027BHeating lambda probe upstream of the catalyst
00636027CDonors for acceleration front right-G121
00637027DDonors for acceleration rear left-G122
00638027EMotor / gearbox electrical connection 2
00639027FTimer for delay-G123
006400280Relay for Lambda probe heater-J278
006410281ATF temperature
006420282EDS changeover valve front right-N166
006430283EDS exhaust front right-N167
006440284EDS changeover valve front left-N168
006450285EDS exhaust front left-N169
006460286ABS-ASR / motor electrical connection 1
006470287ABS-ASR / motor electrical connection 2
006480288Heating lambda probe downstream of the catalyst
006490289Input / exhaust valve ABS rear-N160
00650028AClutch pedal switch F36
00651028BLines for Zundkreise
00652028CGanguberwachung
00653028DPlausibility selection lever / transmission
00654028EScale belt tensioner (driver's side) -N153
00655028FScale belt tensioner (passenger side) -N154
006560290Seat occupancy sensor (passenger side) -G128
006570291Servomotor for Mittenausstromer-V102
006580292operating unit
006590293self-test
006600294Kickdown switch / throttle
006610295temperature display
006620296Rev counter
006630297speedometer
006640298Fuel gauge
006650299Control lamp for belt warning-K19
00666029Agong
00667029BAu.entemperatursignal
00668029CBoard voltage terminal 30
00669029Dsecond error lamp-K97
00670029EDonors for Throttle-G127
00671029FSwitch for GRA-E45
0067202A0ABS hydraulic pump with series resistor
0067302A1actuate brake
0067402A2loose brake
0067502A3Evl: 0V Avl: blocked 0V Left front wheel
0067602A4Evl: U.sub.BAT Avl: 0V wheel locks, front left
0067702A5Evl: U.sub.BAT Avl: U.sub.BAT Left front wheel free
0067802A6Evl: U.sub.BAT Avl: 0V Left front wheel free
0067902A7Heating lambda probe upstream of the catalyst 2
0068002A8Evr: 0V AVR: 0V front right wheel blocked
0068102A9Evr: U.sub.BAT AVR: 0V front right wheel blocked
0068202AAEvr: U.sub.BAT AVR: U.sub.BAT front right wheel free
0068302ABEvr: U.sub.BAT AVR: 0V front right wheel free
0068402ACHeating lambda probe 2 after catalyst
0068502ADEhl: 0V Ahl: 0V wheel locks, rear left
0068602AEEhl: U.sub.BAT Ahl: 0V wheel locks, rear left
0068702AFEhl: U.sub.BAT Ahl: U.sub.BAT left rear wheel free
0068802B0Ehl: U.sub.BAT Ahl: 0V left rear wheel free
0068902B1False air in the intake system
0069002B2Ehr: 0V Ahr: 0V rear right wheel blocked
0069102B3Ehr: U.sub.BAT Ahr: 0V rear right wheel blocked
0069202B4Ehr: U.sub.BAT Ahr: U.sub.BAT right rear wheel free
0069302B5Ehr: U.sub.BAT Ahr: 0V right rear wheel free
0069402B6Lighting / switches and instruments
0069502B7EDS valves / hydraulic pump: U.sub.BAT wheel front left / front right blocked
0069602B8Valve for pressure reducer left-N170
0069702B9Valve for pressure reducer right-N171
0069802BAIncreased power consumption control unit
0069902BBLambda probe on the catalyst-G130
0070002BCLambda probe 2 after catalyst G131
0070102BDCoolant temperature-Uber Test
0070202BEDonors for fuel composition-G133
0070302BFIdle connection throttle / idle switch
0070402C0EDS valves / Hydr-P: UBAT Rader-blocked
0070502C1Relay for Kuhlerlufter Level 1-J279
0070602C2Relay for Kuhlerlufter Level 2-J513
0070702C3Valve for Mitteldusen-N236
0070802C4CAUTION Lufter is turned on
0070902C5Photosensor 2 for solar radiation-G134
0071002C6Servomotor for defrost flap-V107
0071102C7Servomotor for Fu.raumklappe left-V108
0071202C8Servomotor for Fu.raumklappe right-V109
0071302C9Servomotor for Mittenausstromer left-V110
0071402CAServomotor for Mittenausstromer right-V111
0071502CBServomotor for Fondausstromer-V112
0071602CCServomotor for air recirculation flap-V113
0071702CDServomotor for ACF flap-V114
0071802CESwitch for Duse top left-F179
0071902CFSwitch for Duse top right-F180
0072002D0Switch for Duse bottom left-F181
0072102D1Switch for Duse bottom right-F182
0072202D2Switch for Duse left center-F183
0072302D3Switch for Duse center right-F184
0072402D4Switch for Duse rear compartment left-F185
0072502D5Switch for Duse rear compartment right-F186
0072602D6Switch for Duse rear compartment center-F187
0072702D7Potentiometer in servomotor for defrost flap-G135
0072802D8Potentiometer in servomotor for Mittenausstromer left-G136
0072902D9Potentiometer in servomotor for Mittenausstromer right-G137
0073002DAPotentiometer in servomotor for Mittenausstromer-G138
0073102DBPotentiometer in servomotor for Fu.raumklappe left-G139
0073202DCPotentiometer in servomotor for Fu.raumklappe right-G140
0073302DDPotentiometer in servomotor for Fondausstromer-G141
0073402DEPotentiometer in Mittelduse-G142
0073502DFPotentiometer in servomotor for air recirculation flap-G143
0073602E0Potentiometer in servomotor for ACF flap-G144
0073702E1Valve for heating control left-N175
0073802E2Valve for heating control right-N176
0073902E3Pump for Kuhlmittelumlauf-V50
0074002E4Encoder for cylinder 1 recognition-G145
0074102E5Bremspedaluberwachung
0074202E6Driving battery-ventilation system
0074302E7Donors for Batteriebeluftung-G146
0074402E8Traction battery temperature control
0074502E9Isolationsuberwachung
0074602EATraction battery cell failure
0074702EBEncoder for battery temperature front-G52
0074802ECEncoder for battery temperature back-G53
0074902EDLuftungsklappe
0075002EEerror lamp
0075102EFKapazitatsanzeige traction battery
0075202F0Fan and battery heating
0075302F1Electrical connections wheel speed
0075402F2Hei.leuchte
0075502F3Control lamp for oil pressure-K3
0075602F4Donors for Ausstromtemperatur left-G150
0075702F5Donors for Ausstromtemperatur right-G151
0075802F6Secondary air injection
0075902F7Adjuster for Ausstromtemperatur left-G155
0076002F8Adjuster for Ausstromtemperatur right-G156
0076102F9Error stored in engine control unit
0076202FAInjector N181
0076302FBTransmitter for gas pressure (driver's side) -G147
0076402FCTransmitter for gas pressure (passenger side) -G148
0076502FDTransmitter for modulating piston movement sender-G149
0076602FEDonors for Ausstromtemperatur forward-G152
0076702FFDonors for evaporator temperature behind-G153
007680300Donors for heat exchanger temperature behind-G154
007690301Donors coolant temperature engine starting-G82
007700302Donors coolant temperature Kuhle output-G83
007710303Donors for fuel gauge-G
007720304Oeldruckschalter-F22
007730305Donors for Oilpressure G10
007740306Donors for vehicle level rear left-G76
007750307Donors for vehicle level rear right-G77
007760308Donors for vehicle level front left-G78
007770309Donors for accelerator pedal position-G79
00778030AEncoders for steering angle G85
00779030BTemperature Sensor outside temperature G17
00780030CDonors for vertical acceleration-G90
00781030DServomotor front left-V76
00782030EServomotor front right-V77
00783030FServomotor rear left-V78
007840310Servomotor rear right-V79
007850311Temperature Sensor Panel-G56
007860312Temperature Sensor roof-G86
007870313Temperature Sensor for fresh-G89
007880314Two-way valve Fu.raum-defroster-N118
007890315Switches for jerk attendant ride-F41
007900316Fresh / recirculated air flap
007910317Temperature switch for evaporator E33
007920318Pressure switches for air conditioning-F129
007930319Donors for brake pedal position-G100
00794031AEncoder for hydraulic pump-G101
00795031BDonors for vertical acceleration behind-G102
00796031CBlowers for Temperature Sensor-V42
00797031DPhotosensor for sunlight-G107
00798031Esegment test
00799031FDonors for coolant temperature-G110
008000320Temperature Sensor blower-G109
008010321High pressure switch magnetic coupling-F118
008020322Low pressure switch for air conditioning-F73
008030323Donors for travel, front right G116
008040324Donors for travel, front left G115
008050325Valve for spring strut front left-N148
008060326Valve for spring strut front right-N149
008070327Valve for strut rear left-N150
008080328Valve for strut rear right-N151
008090329ESP brake booster
00810032AEncoder 1.2 for brake pressure
00811032BSystem not ready query
00812032CContact switch for magnetic coil for brake pressure F84
00813032DEncoder 2 for brake pressure G214
00814032EMagnetic coil for brake pressure N247
00815032FSwitch for brake recognition-F238
008160330Sensor for steering-G250
008170331Power steering overtemperature protection
008180332Donors for Ausstromtemperatur evaporator G263
008190333High-pressure sender-G65
008200334Switch for brake recognition-F83
008210335Antenna 2 for radio-R93
008220336Connection from the digital sound package for Radio
008230337Line output left front
008240338Control lamp for ASR K86
008250339heated driver seat Z6
00826033Aheated passenger seat-Z8
00827033BRelay for Lufter for coolant-J26
00828033CRelay for 3-th stage Lufter coolant-J135
00829033DControl unit for heating-J162
00830033EControl unit for convertible top actuation-J256
00831033FControl unit for Lufter for coolant, stage 1 + 2 -J293
008320340Operating and display unit E87
008330341Signal for triggering heated windscreen
008340342Signal for triggering heated rear window
008350343Connection to the control unit for convertible top actuation
008360344Valve 1 for gear selection N284
008370345Valve 2 for gear selection N285
008380346Valve 3 for gear selection N286
008390347Valve 4 for gear selection N287
008400348Relay for hydraulic pump gear-J510
008410349Encoder for hydraulic pressure transmission G270
00842034AControl unit for electronic manual
00843034BPotentiometer for selector lever Forward / Back-G272
00844034CSwitch for gate recognition selector lever-F257
00845034DSwitch for N recognition selector lever-F258
00846034ESwitch stop recognition selector lever-F259
00847034FRelay for consumer shutdown-J511
008480350Switch for start / stop operation-E262
008490351S-contact at Zundanlassschalter-D
008500352Control output Aktivverstarker, on the radio
008510353speaker
008520354front speakers
008530355rear speaker
008540356Output radio display panel use
008550357Connection to the CD changer
008560358Antenna on the radio
008570359CD changer R41
00858035AConnection between the radio IF output Antennenverstarker
00859035BLine out front right
00860035CLine output rear left
00861035DConnection to the computer for navigation
00862035EAntenna for navigation (GPS) -R50 / R52
00863035FAntenna 1 for TV-R55
008640360Antenna 2 TV for R56
008650361Antenna 3 TV for R57
0086603624 antenna for TV-R58
008670363Connection to the ABS control unit
008680364Rotation angle sensor-G208
008690365Line output rear right
008700366Bass loudspeaker, front left R21
008710367Bass loudspeaker, front right R23
008720368Bass loudspeaker, rear left R15
008730369Bass loudspeaker, rear right R17
00874036ATweeter, front left-R20
00875036BTweeter, front right-R22
00876036CTweeter Left rear-R14
00877036DTweeter, rear right-R16
00878036EConnections to speakers, front left
00879036FConnections to speakers, front right
008800370Connections to speakers, rear left
008810371Connections to speakers, rear right
008820372Operating unit for program selection E200
008830373Zundanlassschalter-D (S terminal)
008840374Zundanlassschalter-D (X terminal)
008850375Zundanlassschalter-D (terminal 50)
008860376Turn signal switch-E2
008870377Button for warning light-E229
008880378Wiper switch for intermittent operation E22
008890379Horn actuation-H
00890037AButton for heated rear-E230
00891037BButton for remote unlocking, tailgate-E233
00892037CButton for unlocking / Heckklappenschliesszylinder-F248
00893037DButton for unlocking / tailgate handle-E234
00894037EButton for heating Outside Mirror E231
00895037FGRA / ADR panel-E45
008960380Schlie.einheit tailgate-F256
008970381Washer pump V5
008980382Control air compressor
008990383Fuse for wiper motor-S128
009000384Backup Bugle / Doppeltonhorn-S194
009010385Rearview lights
009020386Backup for remote unlocking, tailgate-S195
009030387Fuse for heating, exterior mirror-S196
009040388Securing magnet for selector lever lock-S197
009050389Fuse for rearview lights-S40
00906038AHorn / Doppeltonhorn-H1
00907038BMeshing load management
00908038CControl unit for wiper motor
00909038DWiper motor-V (step 1/2)
00910038EControl lamp for hazard warning lights-K6
00911038FIndicator light heated rear-K10
009120390Switches for power windows front left-E40
009130391Switch for front windows right, Driver-E81
009140392Switch for rear windows left, Driver-E53
009150393Switches for power windows, rear right, driver-E55
009160394Lock switch for rear windows-E39
009170395Regulators for intermittent wiper circuit
009180396terminal 31
009190397Engine for rear wiper V12
009200398heatable Au.enspiegel (Z4 / Z5)
009210399Indicator light heated Au.enspiegel-K153
00922039AWiper switch for intermittent operation E22 (Step 1)
00923039BWiper switch for intermittent operation E22 (Step 2)
00924039CRelay for headlight cleaning system-J39
00925039DFuse (30) for indoor light S261
00926039EClamp 30
00927039FTerminal 30 right
0092803A0Clamping unit for central locking, driver's side-F220
0092903A1Clamping for Central passenger side-F221
0093003A2Schlie.einheit for Central rear left-F222
0093103A3Schlie.einheit for Central rear right-F223
0093203A4Motor windows driver's side-V147
0093303A5Motor passenger side window-V148
0093403A6Motor windows rear left-V26
0093503A7Engine power windows, rear right-V27
0093603A8Window switch passenger side-E107
0093703A9Window switch, rear left-E52
0093803AAWindow switch, rear right-E54
0093903ABMotors mirror adjustment, driver's side-V149
0094003ACMotors mirror adjustment passenger side-V150
0094103ADMotor Spiegelanklappung driver's side-V121
0094203AEMotor Spiegelanklappung passenger side-V122
0094303AFHeated side mirrors, driver's side-Z4
0094403B0Heated side mirrors passenger side-Z5
0094503B1Crash Sensor G190
0094603B2Interior light-W
0094703B3Switch remote unlocking tailgate-E188
0094803B4schlie.en signal sunroof
0094903B5Motor for central locking tailgate-V53, LOCK
0095003B6Motor for central locking tailgate-V53 UNLOCK
0095103B7Relay for motor remote unlocking tailgate-J398
0095203B8Signal driver's door open
0095303B9Time limit indoor light
0095403BABlocking relay for starter-J433
0095503BBSchlussel 1
0095603BCSchlussel 2
0095703BDSchlussel 3
0095803BESchlussel 4
0095903BFCentral control lamp Safe-K133
0096003C0Central switch driver side-F59
0096103C1Central switch passenger side-F114
0096203C2Alarm by tilt sensor
0096303C3Signal line for tilt sensor
0096403C4Signal driver's door open; plus
0096503C5Fuse for alarm horn-S158
0096603C6Fuse for flashing lights-S151
0096703C7flashing lights left
0096803C8flashing lights right
0096903C9Fuse for heated rear-S41
0097103CBRelay for heated windscreen left-J410
0097203CCRelay for heated windscreen right-J411
0097303CDSwitch for heated rear-E15
0097403CESwitch for heated windscreen-E180
0097503CFheated rear-Z1
0097603D0Pilot light for heated windscreen-K122
0097703D1Low beam left + right
0097803D2Lamp for low beam headlights left-M29
0097903D3Lamp for low beam headlights right-M31
0098003D4Fuse for low beam left-S152
0098103D5Fuse for low beam right-S153
0098203D6Fuse for parking light left-S154
0098303D7Fuse for parking light right-S155
0098403D8Left-M4 lamp for tail light
0098503D9Lamp for bottom right-M2
0098603DAFuse for the brake lights-S156
0098703DBLamp for brake lights left-M9
0098803DCLamp for brake lights right-M10
0098903DDAssurance for consumers shutdown-S153
0099003DEconsumer shutdown
0099103DFinterior lighting
0099203E0Consumer disconnection active
0099303E1Consumer shutdown inactive
0099403E2Donors front height adjustment driver's seat G215
0099503E3Encoder rear height adjustment driver seat-G216
0099603E4Encoder height adjustment headrest driver's seat G217
0099703E5Motor for longitudinal adjustment driver seat V28
0099803E6Motor for backrest adjustment driver seat V45
0099903E7Engine front height adjustment driver seat V29
0100003E8Motor rear height adjustment driver seat V30
0100103E9Motor head Stutz adjustment driver seat-V103
0100203EAButton front height adjustment on driver's seat E208
0100303EBButton front height adjustment from, driver seat E209
0100403ECButton on rear height adjustment, driver's seat E210
0100503EDButton rear height adjustment from, driver seat E211
0100603EEButton long before adjustment, driver's seat E212
0100703EFButton longitudinal adjustment back, driver seat E213
0100803F0Note: Emergency stop actuated!
0100903F1Donors longitudinal adjustment, driver's seat G218
0101003F2Donor support adjustment, driver's seat G219
0101103F3Button head neck adjustment on driver's seat E214
0101203F4Button head neck adjustment from, driver seat E215
0101303F5C compressor load signal
0101403F6Amplifier for Lufterthermostat
0101503F7Kuhlerluftersteuerung
0101603F8Air release valve Gasfederdampfung-N106
0101703F9Compressor for Gasfederdampfung-V65
0101803FALufter for coolant-V7
0101903FBrelay
0102003FCWater pump-V36
0102103FDPilot light for differential lock-K81
0102203FEInterior light, composite image activated
0102303FFSummer / Gong H3
010240400Rain sensor-G213
010250401Control error lamp is broken
010260402Blowers for evaporator rear-V20
010270403Warmluftgeblase rear-V47
010280404Relay for blower-J323
010290405Relay for air conditioning-J32
010300406lock Schlusseltaster Central driver's side,
010310407Unlock Schlusseltaster Central driver's side,
010320408lock Schlusseltaster Central passenger side,
010330409Unlock Schlusseltaster Central passenger side,
01034040AWindows thermal protection active driver
01035040BWindows thermo protection active, passenger
01036040CWindows thermal protection active, rear left
01037040DWindows thermal protection active, rear right
01038040ECentral thermal protection
01039040FDonors for Kuhlmitteltemperaturanzeige-G2
010400410ABS / transmission electrical connection 2
010410411ASR function implausible
010420412uncoded control unit
010430413Control unit: incorrect software version
010440414Control unit incorrectly coded
010450415Switch for Tiptronic F189
010460416Warning light for brake pad K32
010470417Control lamp for dual circuit and hand brake system-K7
010480418Pilot light for diesel electronics K104
010490419Board voltage terminal 50
01050041AGluhkerzenuberwachung
01051041BServomotor fuel flow control-V117
01052041CPotentiometer for load signal G157
01053041DValve for commencement of injection-N182
01054041ERelay for voltage supply terminal 30-J317
01055041FDonors for fuel Order start-G158
010560420Function: Equalization
010570421Function: voltage constant charge
010580422Function: current-constant charge
010590423Encoders for rotor position-G159
010600424Donors for winding temperature groove bottom-G160
010610425Donors for winding temperature winding-G161
010620426Signal for battery power reduction
010630427Switch for E recognition selector lever-F271
010640428Terminal 58d - dimming interior light
010650429RNS connection to TV Antennenverstarker
01066042ADrive despite selector lever position N
01067042BValve for switching off the second heat exchanger-N317
01068042CRelay for hydraulic pump clutch actuator-J498
01069042DPressure system brake booster
01070042ERelay for Starter-J53
01071042FDonors for clutch travel-G162
010720430Vacuum valve for clutch actuator-N183
010730431Pressure clutch system
010740432Beluftungsventil for clutch actuator-N184
010750433Relay for vacuum pump-J318
010760434Relay for hydraulic pump clutch-J319
010770435Vacuum brake booster switch-F190
010780436Switch for gear actuation-F191
010790437Relay for steering hydraulic-J320
010800438Switch Servolenkungsunterstutzung-F192
010810439Priority switching valve N185
01082043AWarning light for low fuel-K105
01083043BPilot light for wash water deficiency K106
01084043CPilot light for temperature warning 0░C-K107
01085043DPilot light for temperature warning 4░C-K108
01086043EDonors for Speedometer G22
01087043Fnot carried out basic setting
010880440Fuel Trim 2
010890441Switch for Spannbugel stored-F204
010900442Switch for Spannbugel raised-F203
010910443Switch for top front-F202
010920444Switch for top stowed-F171
010930445Switch for top compartment lid above-F201
010940446Switch 3 box cover left-F195
010950447Switch 2 box cover left-F197
0109604481 switch box cover left-F199
010970449Switch for convertible top locked-F172
01098044ASwitch for tailgate to-F206
01099044BSwitch for luggage compartment locks
01100044CSwitches for trunk unlocked
01101044DSwitch for locking device-F205
01102044ESwitch 3 top compartment lid right-F196
01103044FSwitch 2 top compartment lid right-F198
011040450Switch 1 top compartment lid right-F200
011050451Solenoid valve 8-N186
011060452Relay for windows Lower-J291
011070453Indicator light for top-K98
011080454Relay for windows Raise-J292
011090455Relay for hydraulic pump-J321
011100456Magnetic locking device for-N187
011110457Servomotor 1 for trunk lock
011120458Power supply for servomotor 1 and 2
011130459Servomotor 2 for trunk lock
01114045ASwitch for handbrake control-F9
01115045B
#VALUE!​
01116045CServomotor for Verdeckentriegelung
01117045DLoad signal for alternator terminal DF
01118045EMotorvorwarmung
01119045FSignal for gear recognition
011200460Camshaft adjustment 1
011210461Camshaft adjustment 2
011220462Hall sender 2-G163
011230463control faulty
011240464Ladezeituberwachung
011250465Intake manifold
011260466Signal for engine speed
011270467Warning light for low fuel-K16
011280468Read coil for immobilizer-D2
011290469S-contact-H15
01130046AABS operation
01131046Bcontrol indicators
01132046CInfrared sensor front-G166
01133046DInfrared sensor behind-G167
01134046EAlarm horn H12
01135046FSensors for Innenraumuberwachung
011360470Starter interruption
011370471Switch for central locking; locking contacts
011380472Switch for central locking; driver's door unlocking
011390473Switch for central locking; Beifahretur release
011400474Switch for central locking; tailgate unlocking
011410475Switch for tailgate-E165
011420476Engines for Central; Driver's door and tank valve to
011430477Engines for Central; Driver's door and fuel valve
011440478Motor for central locking; open passenger door
011450479Engines for Central; open rear doors
01146047AEngines for Central; Passenger and rear doors to
01147047BMotor for tailgate lock-V120
01148047CActivating the safe securing doors
01149047DDeactivating the safe securing doors
01150047Eanalog displays
01151047FLock switch for diesel engine-F207
011520480Switch for Ganguberwachung-F209
011530481Switch for Ecomatic-E163
011540482Pressure switch for coupling system-F210
011550483clutch
011560484Switch for gear recognition-F208
011570485Supply voltage for alarm horn
011580486Supply voltage for turn signals
011590487Lines for safe backup
011600488Relay for glow plugs-coolant-J325
011610489Amplifier camshaft control valve
01162048Amisfiring
01163048BZunddurchschlag
01164048CESP operation
01165048DThrottle valve control unit J338
01166048ESignal for engine torque
01167048FValve for full load-N194
011680490Valve for idling speed boost-N177
011690491Turkontaktschalter driver's side-F2
011700492Donors for injection duration-G175
011710493Temperature Sensor passenger seat-G60
011720494Temperature Sensor driver's seat-G59
011730495Motor for longitudinal adjustment driver seat V28
011740496Motor for height adjustment driver's seat-V138
011750497Adjusters for heated driver seat E94
011760498Key
011770499engine control
01178049AData bus drive, bus inactivity
01179049BSchlusselprogrammierung wrong
01180049CMotor / C compressor shutdown electrical connection
01181049DInitialization: only learned two Schlussel
01182049Ehigh adaptation
01183049FControl lamp for catalyst-K72
0118404A0Donors for Ausstromtemperatur behind-G174
0118504A1Frischluftgeblase rear-V80
0118604A2Servomotor for air distribution, rear-V136
0118704A3Servomotor for temperature flap rear-V137
0118804A4Control unit / magnetic coupling electrical connection
0118904A5Servomotor for air distribution, front-V145
0119004A6Control unit / servomotors-electrical connection
0119104A7Motors for seat adjustment
0119204A8Clutch for Wandleruberbruckung
0119304A9Relay for low heating-J359
0119404AARelay for gro.e heating-J360
0119504ABTHE END
0119604ACMotor / gearbox - data bus
0119704ADData bus drive incorrect software version
0119804AEConvenience data incorrect software version
0119904AFEngine / ABS - electrical connection
0120004B0Supply voltage for ABS valves
0120104B1Supply voltage for ABS pump
0120204B2diagnostic line
0120304B3ABS / dash panel insert electrical connection
0120404B4Timer for motor temperature G27
0120504B5Relay for Climatronic J254
0120604B6Signal for ignition period of
0120704B7Control unit for auxiliary heating-J364
0120804B8Data sets changed in the control unit
0120904B9Speed signal generator clamp W
0121004BAControl unit learns adjustment
0121104BBScale for pretensioners rear, driver's side-N196
0121204BCScale for pretensioners rear passenger side-N197
0121304BDScale for belt tensioners, rear center-N198
0121404BECrash data stored pretensioners
0121504BFSeat occupancy sensor, rear, driver's side-G177
0121604C0Seat occupancy sensor rear passenger side-G178
0121704C1Scale Airbag driver-N199
0121804C2Scale side airbag passenger side-N200
0121904C3Scale rear side airbag, driver's side-N201
0122004C4Scale rear side airbag, front passenger side N202
0122104C5Crash sensor Airbag driver-G179
0122204C6Crash Sensor Side Airbag-G180
0122304C7open signal Central
0122404C8Control unit does not match the vehicle
0122504C9Radio receiver heater-R64
0122604CACrash data side airbag saved driver's side
0122704CBCrash data side airbag stored passenger side
0122804CCKey selector switch off airbag, passenger side E224
0122904CDTransmitter for humidity, air conditioning-G260
0123004CEDonors for Ausstromtemperatur Fu.raum left-G261
0123104CFDonors for Ausstromtemperatur Fu.raum right-G262
0123204D0Control valve for compressor, air-N280
0123304D1Shut-off valve for coolant, heating-N279
0123404D2Control unit for heated windscreen-J505
0123504D3Sekundarlufteinblasventil-N112
0123604D4Magnet for selector lever lock N110
0123704D5Fuel cut-N109
0123804D6Zundwinkelverstellung
0123904D7Beluftungsventil Throttle-N97
0124004D8Entluftungsventil Throttle-N117
0124104D9Solenoid 2 for Aktivkohlebehalter-N115
0124204DAPower amplifiers in the control unit
0124304DBValve Registersaugrohrumschaltung-N156
0124404DCControl unit oxygen sensor heater-J208
0124504DDPrinting plate-N73
0124604DERelay for Ansaugrohrvorwarmung-J81
0124704DFSolenoid valve 1 for Aktivkohlebehalter-N80
0124804E0Two-way valve-full-load enrichment-N54
0124904E1Injector cylinder 1-N30
0125004E2Injector cylinder 2-N31
0125104E3Injector cylinder 3 N32
0125204E4Injector cylinder 4-N33
0125304E5Injector cylinder 5-N83
0125404E6Injector cylinder 6-N84
0125504E7Injector cylinder 7-N85
0125604E8Injector cylinder 8-N86
0125704E9Valve for idle stabilization-N71
0125804EAVentilation flap-V63
0125904EBFuel pump relay J17
0126004ECValve for fuel cut-N65
0126104EDPulse valve for lambda control-N7
0126204EESolenoid valve charge pressure control-N75
0126304EFCold start valve N17
0126404F0Relay for secondary air pump-J299
0126504F1Valve for exhaust gas recirculation-N18
0126604F2Relay for glow plugs-J52
0126704F3Control unit for Gluhzeitautomatik-J179
0126804F4Quantity adjuster-N146
0126904F5Valve for commencement of injection-N108
0127004F6Magnetic coupling for air conditioning-N25
0127104F7Servomotor for temperature flap-V68
0127204F8Servomotor for central flap-V70
0127304F9Frischluftgeblase-V2
0127404FAServomotor for air flow flap-V71
0127504FBKey selector switch-off rear side airbags-E280
0127604FCHydraulic pump ABS-V64
0127704FDRelay for hydraulic pump ABS-J185
0127804FECut-off for EDS J263
0127904FFDonors for long-acceleration G251
012800500Airbag off
012810501Driver's side airbag off
012820502Over valve for intake manifold flap-N239
012830503Engine intake manifold for-V157
012840504Airbag driver switched off
012850505Side airbag front passenger side
012860506Driver's side pretensioner off
012870507Pretensioners front passenger side
012880508Terminal 30 power steering
012890509Terminal 15 power steering
01290050AReference voltage power steering
01291050BKey selector switch-off rear side airbag, driver's side-E295
01292050CKey selector switch-off rear side airbag, passenger side-E296
01293050DControl lamp for from side airbag, rear driver's side-K167
01294050EControl lamp for from side airbag, rear passenger side-K168
01295050FControl unit in dash panel insert incorrectly coded
012960510Donors for Ausstromtemperatur mid-G191
012970511Donors for Ausstromtemperatur Fu.raum-G192
012980512Pilot light test instrument cluster
012990513Diagnosis interface for data bus J533
013000514Control unit for navigation with CD drive J401
013010515Control unit for voice input J507
013020516Control unit for telematics J499
013030517Transmission and Empfangsgerat for telephone R36
013040518radio
013050519bus infotainment
01306051Afaster data display
01307051BFiber optic data display
01308051CControl unit for roof electronics J528
01309051DControl unit for steering-J500
01310051EControl unit for level control-J197
01311051FData bus information
013120520Data bus drive
013130521Data BUS drive in emergency operation
013140522engine control
013150523transmission control
013160524Bremsensteuergerat
013170525Control unit in the dash panel insert J285
013180526Control unit for injection pump-J399
013190527Control unit for distance control-J428
013200528Control unit for Climatronic J255
013210529Control unit for airbag J234
01322052AControl unit for multi-function unit-J501
01323052BControl unit for automatic clutch-J439
01324052CControl unit for four-wheel drive-J492
01325052DControl unit for tire pressure monitoring J502-
01326052EControl unit for multi-function steering wheel J453
01327052FControl unit for parking aid J446
013280530Data BUS Comfort
013290531Data BUS comfort in emergency operation
013300532Zentralsteuergerat for comfort system J393
013310533Tursteuergerat driver's side-J386
013320534Tursteuergerat passenger side-J387
013330535Tursteuergerat rear left-J388
013340536Tursteuergerat rear right-J389
013350537Control unit for seat / mirror position driver-J543
013360538Group convenience data
013370539Turinnengriffbeleuchtung
01338053ASignal doors not closed
01339053BExit warning light
01340053Cmirror adjustment
01341053DControl unit in the dash panel on comfort CAN-J285
01342053EEngine control unit 2 (Slave 1)
01343053FEngine control unit 3 (slave 2)
013440540Gas discharge lamp
013450541Zundmodul for gas discharge lamp-N195
013460542Line for Zundmodul
013470543Line to the gas discharge lamp
013480544Control lamp for Innenraumuberwachungsabschaltung-K162
013490545Alarm by sensor for DWA front
013500546Alarm by sensor for DWA back
013510547Line for communication to ground
013520548Line for forward clock signal 5V level
013530549Line for clock signal back 5V level
01354054AEnable signal immobilizer
01355054BSignal; open all windows
01356054CSignal; schlie.en all the windows and sunroof
01357054DMotor for tank cap locking-V155
01358054ESwitch for interior locking, driver's side-E150
01359054FSwitch for interior locking, passenger side-E198
013600550Switch for anti-theft alarm open
013610551schlie.en switch for anti-theft alarm
013620552Switch for tailgate schlie.en-F124
013630553Switch for central locking; Driver's door-F59
013640554Switch for central locking; Passenger door-F114
013650555Lock / Unlock switch / lock button inside
013660556Opening by crash signal
013670557Switching off the pump for Central
013680558Alarm by switch trunk
013690559Alarm by switches hood
01370055AAlarm by Innenraumuberwachung
01371055BAlarm by Turkontaktschalter driver's side
01372055CAlarm by Turkontaktschalter rear / front passenger side
01373055DAlarm by ground contact Radio
01374055EAlarm through Terminal 15
01375055FValves for engine mounting Step 1
013760560Speed signal for injection pump
013770561Ultrasonic sensor left for Car alarm-G170
013780562Ultrasonic sensor right for Car alarm-G171
013790563Switch for Innenraumuberwachung-E183
013800564Alarm by sensor for theft alarm system, rear left
013810565Alarm by sensor for theft alarm system, rear right
013820566Alarm by sensor for theft alarm system, front left
013830567Alarm by sensor for theft alarm system front right
013840568Alarm by glass breakage sensors
013850569Indicator light for alarm-K95
01386056Agenerate alarm draw
01387056BLine for power supply
01388056CLine for clock signal
01389056DSwitch for tailgate open-F124
01390056Eenable Innenraumuberwachung
01391056Fsimulate crash signal
013920570Closest actuator: - actuate>
013930571Transmitter for level control-G84
013940572Indicator light for level control-K134
013950573Engine for compressor-level control-V66
013960574Valves for strut h-N150 / 151
013970575Drain solenoid valve level control-N111
013980576Signal line from Central: doors on
013990577Relay for compressor-level control-J403
014000578level control
014010579
#VALUE!​
01402057AData line of navigation
01403057BGlass break sensors back
01404057CValves for engine mounting stage 2
01405057DValve 2 for exhaust gas recirculation-N213
01406057Eno flame
01407057Fflame aborted
014080580Under voltage lockout (fixed value)
014090581Repeated flame interruption
014100582HEATER overheated
014110583Temperature Sensor-G18
014120584Glow plug with Flammenuberwachung-Q8
014130585Metering pump-V54
014140586Verbrennungsluftgeblase V6
014150587Circulating pump-V55
014160588Signal for controlling Frischluftgeblase
014170589Signal for controlling water heating
01418058ASwitching valve 1 for vehicle dynamics control-N225
01419058BSwitching valve 2 for vehicle dynamics control-N226
01420058CHigh-pressure switching valve 1 for vehicle dynamics control-N227
01421058DHigh pressure switch valve 2 for vehicle dynamics control-N228
01422058EHydraulic pump for vehicle dynamics control-V156
01423058FSensor for lateral acceleration-G200
014240590Encoder for yaw rate-G202, reference line
014250591Encoder for yaw rate-G202, Power Line
014260592Operating unit in steering wheel E221
014270593radio louder
014280594radio down
014290595Scan radio stations aufwarts
014300596Scan radio stations abwarts
014310597phone memory
014320598of nearest phone memory
014330599Speaker phone / navigation-R39
01434059ARelay for Bremslichtunterdruckung ESP J508
01435059BSwitch 1 for brake pressure G201
01436059CBrake fluid level is too low
01437059Dnot learned control position
01438059EVehicle is raised
01439059FTESTING Schrag location
0144005A0Fuel fuel level signal
0144105A1Donors for lack of fuel-G210
0144205A2Dropouts by fuel shortage
0144305A3does not take place adaptation to battery
0144405A4Undervoltage shutdown (auto)
0144505A5Donors for longitudinal adjustment, driver's seat G227
0144605A6Donors for support adjustment, driver's seat G230
0144705A7Encoder for height adjustment, driver's seat G231
0144805A8Encoders for angle adjustment, driver's seat G232
0144905A9Switch for tilt adjustment driver's seat-back E222,
0145005AASwitch for tilt adjustment driver seat E222, before
0145105ABSwitch for Langs- and height adjustment-E61, on
0145205ACSwitch for Langs- and height adjustment-E61, from
0145305ADSwitch for Langs- and height adjustment-E61, before
0145405AESwitch for Langs- and height adjustment-E61 back,
0145505AFSwitch for backrest adjustment-E96, before
0145605B0Switch for backrest adjustment-E96 back,
0145705B1Signal for mirror position
0145805B2Signal from Central
0145905B3Button User 1 / memory seat-E218
0146005B4Button User 2 / Memory seat E219
0146105B5Button Driver 3 / memory seat-E220
0146205B6Ultrasonic sensor for anti-theft alarm-G209
0146305B7Alarm by sensor for theft alarm system
0146405B8Donors for brake pressure / lateral acceleration
0146505B9Signal line from the instrument cluster
0146605BASignal line to the instrument cluster
0146705BBSensor for Tire Pressure front left-G222
0146805BCSensor for Tire Pressure front right-G223
0146905BDSensor for Tire Pressure rear left-G224
0147005BESensor for Tire Pressure rear right-G225
0147105BFSensor for tire pressure spare-G226
0147205C0Antenna for tire pressure monitoring, front left-R59
0147305C1Antenna for tire pressure monitoring, front right-R60
0147405C2Antenna for tire pressure monitoring, rear left-R61
0147505C3Antenna for tire pressure monitoring, rear right-R62
0147605C4Tire pressure monitoring antenna spare-R63
0147705C5system shut down
0147805C6off monitoring spare
0147905C7Donors for head neck adjustment-G129
0148005C8Switch for head neck adjustment-E155, on
0148105C9Switch for head neck adjustment-E155, from
0148205CAEngines for Central
0148305CBcontrol Heckdeckelfernentriegelung
0148405CClock Schlusseltaster for Central
0148505CDUnlock Schlusseltaster for Central
0148605CESystem function test activated
0148705CFSystem function test
0148805D0Donors for coolant temperature heating-G241
0148905D1Ueberhitzungsfuhler-G189
0149005D2Flash Wachter-G64
0149105D3Glow plug for heating-Q9
0149205D4function lock
0149305D5Lamp flashing light for the front left-M5
0149405D6Lamp for parking light left-M1
0149505D7Lamp for high beam headlights left-M30
0149605D8Lamp for Left fog-L22
0149705D9Lamp for flashing front right-M7
0149805DALamp for parking light right-M3
0149905DBLamp for high beam headlights right-M32
0150005DCLamp for fog lights right L23
0150105DDLamp flashing light for rear left-M6
0150205DELamp for rear fog lamp left-L46
0150305DFLamp for high brake light-M25
0150405E0License plate light-X
0150505E1Lamp flashing light for rear right-M8
0150605E2Lamp for rear fog light right-L47
0150705E3Initialization failed
0150805E4Shutdown because not reached end position
0150905E5Spoiler not extended gro.er at speed warning threshold
0151005E6Spoiler not extended gro.er at speed alarm threshold
0151105E7process switch for rear spoiler
0151205E8Control unit for sunroof
0151305E9Schiebeaufstelldach can not lower
0151405EARegulator for sliding adjustment
0151505EBEnable signal from the comfort system
0151605ECTerminal 30 left
0151705EDControl unit for Anhangererkennung-J345
0151805EELamp for return fares light left-M16
0151905EFLamp for light return fares right-M17
0152005F0Sensor for rain and light detection-G397
0152105F1Sensor for tire pressure
0152205F2Bedienhorer for telephone R37
0152305F3Microphone for telephone R38
0152405F4Antenna for telephone
0152505F5Phone card for Telematics
0152605F6Button for emergency call-E276
0152705F7Button for breakdown call-E275
0152805F8Additional antenna for telematics R90
0152905F9Additional loudspeaker for telematics R91
0153005FAMute Radio
0153105FBemergency battery
0153205FCSignal line to the instrument cluster
0153305FDTerminal 56 (spotlight)
0153405FEControl for servomotor headlamp leveling Left-V48
0153505FFControl for servomotor headlamp leveling Right-V49
015360600Vehicle is lowered
015370601Donors for vehicle level supply voltage
015380602Servomotors for headlamp leveling-V48 / V49
015390603Headlights were not adjusted
015400604Headlights are lowered
015410605Headlights are raised
015420606Encoder for yaw rate-G202
015430607Buzzer for parking aid H15
015440608Pilot light for parking assistance-K136
015450609Donors for parking aid rear left-G203
01546060ADonors for parking aid rear left mid-G204
01547060BDonors for parking assistance, rear right mid-G205
01548060CDonors for parking aid rear right-G206
01549060DSupply voltage for encoder parking aid
01550060ESignal for reverse gear
01551060FSignal to the central Schlie.en
015520610Engine for Central-driver's door-V56, LOCK
015530611Engine for Central-passenger door-V57, LOCK
015540612Engines for Central-doors back LOCK
015550613Engines for Central SAVE
015560614Motors for central locking, UNLOCK
015570615Contact switch in the driver's side Schlie.zylinder-F241 open,
015580616Contact switch in the driver's side Schlie.zylinder-F241 schlie.en,
015590617Drivers door
015600618passenger door
015610619Door in the back left
01562061ADoor rear right
01563061BSwitch for internal locking driver side-E150, LOCK
01564061CSwitch for internal locking driver side-E150, UNLOCK
01565061DBoot light-W3
01566061EEnable signal for Innenraumuberwachung
01567061FContact switch for anti-theft alarm-F120
015680620Signal for Komfortoffnung
015690621Signal for Komfortschlie.ung
015700622Abschaltverzogerung terminal 15
015710623Signal for seat memory
015720624Alarm by Turkontaktschalter passenger side
015730625Alarm by Turkontaktschalter rear left
015740626Alarm by Turkontaktschalter rear right
015750627off control
015760628Thermal protection Motor for wind deflector
015770629Shutdown due to overtemperature
01578062AControl lamp for from airbag, passenger side-K145
01579062BSignal seat occupancy sensor passenger side-G128
01580062COccupancy sensor child seat, passenger side-G211
01581062Dincorrect component detected
01582062ESignal for coolant temperature
01583062FLeak detected in the system
015840630launched vehicle too deep, pumping
015850631Contact switch Schlie.zylinder passenger side-F242 open,
015860632schlie.en contact switch Schlie.zylinder passenger side-F242,
0158706332 scale for Driver's airbag-N250
015880634Scale for head airbag driver's side-N251
015890635Zunderkopf Airbag-N252
015900636Scale for interruption battery N253
015910637Airbag indicator light in driver's side-K144
015920638Sensor for air Good-G238
015930639Heated windscreen-Z2
01594063ARelay for connecting the generator-J442
01595063BSwitch for tire pressure monitor-E226
01596063CServomotor for fresh air / recirculation damper-V154
01597063DPrecharge circuit driving battery
01598063EVoltage traction battery
01599063FMain relay for electric drive-J437
016000640Throttle signal from the engine control
016010641Encoders for rotor position in the electric motor
016020642Traction motor for electric drive-V141
016030643Inverter-C21
016040644Potentiometer 1 for gear recognition-G239
016050645Potentiometer 2 for gear recognition-G240
016060646Signal from Batterieuberwachung
016070647Overcurrent shutdown
016080648Control lamp test
016090649Lufter in the control unit
01610064ASwitch for Power-E228
01611064Bprovide duo switch to electric drive
01612064CValve for clutch actuator-N255
01613064DRelay for pump Kraftstoffkuhlung-J445
01614064EOf capacity traction battery
01615064FSwitch for remote release fuel door-E204
016160650Signal line for Innenraumuberwachung
016170651Please read fault memory of Innenraumuberwachung
016180652Valve for automatic top-N272
016190653Multiple engines for storage behind
016200654Button for convertible top actuation-E137
016210655Mains plug the mounting au.erhalb
016220656Voltage converter (264V / 12V) -A13
016230657Signal generator for charging
016240658Switch for Power-E228, Home Plate
016250659Buzzer for assistance front-H22
01626065ADonors for parking sensors front right-G252
01627065BDonors for parking aid, front right mid-G253
01628065CDonors for parking aid, front left mid-G254
01629065DDonors for parking sensors front left-G255
01630065EAdditional scale Airbag driver-N277
01631065FScale additional side airbag passenger side-N278
016320660loss Hochstromkapazitat
016330661Failure thermal management
016340662Scale for interrupting the battery switched off,
016350663Crash data scale for interruption stored battery
016360664Scale for pretensioners rear driver's side-N196
016370665Scale for pretensioners rear passenger side-N198
016380666Crash sensor for rear side airbag driver's side-G256
016390667Crash sensor for side airbag rear passenger side-G257
016400668Seat belt rear driver's side-E258
016410669Seat belt rear passenger side-E259
01642066ASeat occupancy sensor, rear driver's side-G177
01643066BSeat occupancy sensor, rear passenger side-G178
01644066CRear side airbag off driver's side
01645066DRear side airbag off passenger side
01646066EHead driver's side airbag off
01647066FHead Airbag off
016480670off belt tensioner rear driver's side
016490671off belt tensioner rear passenger side
016500672Crash data for Airbag driver behind locked
016510673Crash data for side airbag passenger side rear locked
016520674Key selector Driver
016530675Warning lamp Driver disabled
016540676Seat belt warning light
016550677Child seat switch
016560678crash signal
016570679Switch for child seat recognition left-F263
01658067ASwitch for child seat recognition right-F264
01659067BCrash exceeded threshold pretensioners
01660067CCrash emerging US airbag exceeded
01661067DCrash threshold RDW airbag exceeded
01662067ESwitch for internal locking passenger side-E198, LOCK
01663067FSwitch for internal locking passenger side-E198, UNLOCK
016640680Switch for internal locking rear left-E273, LOCK
016650681Switch for internal locking rear left-E273, UNLOCK
016660682Switch for internal locking rear right-E274, LOCK
016670683Switch for internal locking rear right-E274, UNLOCK
016680684Probe driver 4 / memory seat-E282
016690685Button for memory, driver seat E283
016700686Signal line from control unit for Garagentoroffnung-E284
016710687Sensor for distance control, left-G258
016720688Sensor for distance control, right-G259
016730689Potentiometer for diaphragm travel in the brake booster
01674068AADR-contact switches in the brake booster
01675068BADR-contact switches / potentiometer for diaphragm travel
01676068CADR-contact Switches / pressure in the brake booster
01677068DValve for ADR brake intervention
01678068ESwitch for distance choice ADR E260
01679068FSpeed signal for the left front wheel ABS
016800690Speed signal for the right front wheel ABS
016810691Speed signal for the left rear wheel ABS
016820692Speed signal for the ABS rear right wheel
016830693Wheel speed / speed
016840694Control unit 2 for diesel direct-J494
016850695Air mass meter two-G246
016860696Control unit for Kuhlerlufternachlauf-J138
016870697Solenoid 2 for charge pressure control-N274
016880698Relay for Kuhlmittelpumpe-J235
016890699Valves for transmission mounting
01690069ADonors for fuel pressure G247
01691069BRegulator for fuel pressure N276
01692069CRelay for Kuhlmittelzusatzpumpe-J496
01693069DValve for throttle-N211
01694069ESignal line from the airbag
01695069FEncoder 2 for fuel temperature-G248
0169606A0Fu.raumleuchte rear left-W45
0169706A1Fu.raumleuchte rear right-W46
0169806A2Enable signal for windows
0169906A3Motor for central locking, tailgate-V53
0170006A4Bugle for DWA-H8
0170106A5Dimming for interior light
0170206A6Fu.raumleuchte left-W9
0170306A7Fu.raumleuchte right-W10
0170406A8Terminal 58 (Bleuchtungsdimmung)
0170506A9Switch for mirror adjustment-E48
0170606AASwitch for mirror adjustment-E43
0170706ABTurkontaktschalter for passenger side-F3
0170806ACTurkontaktschalter rear left-F10
0170906ADTurkontaktschalter rear right-F11
0171006AEMotors for central locking, driver's side
0171106AFMotors for central locking, passenger side
0171206B0Motors for central locking, rear left
0171306B1Motors for central locking, rear right
0171406B2Switching Audio / Phone
0171506B3Gesprachsfunktion phone
0171606B4Control GRA reuptake / Speed
0171706B5Control GRA-saving / reduction
0171806B6GRA-off control
0171906B7Donors for longitudinal adjustment, front seat-G278
0172006B8Donors for backrest adjustment, passenger seat-G279
0172106B9Donors for rear height adjustment, front seat-G280
0172206BATimer for front height adjustment, front seat-G281
0172306BBEncoder for height adjustment headrest, front seat-G282
0172406BCSwitch for longitudinal adjustment, front seat-E64, before
0172506BDSwitch for longitudinal adjustment, passenger seat back E64,
0172606BESwitch for backrest adjustment, passenger seat E98, before
0172706BFSwitch for backrest adjustment, passenger seat back E98,
0172806C0Switch for rear height adjustment passenger seat E66 on
0172906C1Switch for rear height adjustment passenger seat E66, from
0173006C2Switch for front passenger seat height adjustment E65 on
0173106C3Switch for front passenger seat height adjustment E65, from
0173206C4Switch for head neck adjustment passenger seat E170, on
0173306C5Switch for head neck adjustment passenger seat E170, from
0173406C6Potentiometer for mirror adjustment horizontal, driver's side
0173506C7Potentiometer f.Spiegelverstellung horizontal, passenger side
0173606C8Potentiometer for mirror adjustment vertically, driver's side
0173706C9Potentiometer for mirror adjustment vertically, passenger side
0173806CACrash sensor for front airbag, driver's side-G283
0173906CBCrash sensor for front airbag, passenger side-G284
0174006CCScale for belt tensioners-2, driver side N297
0174106CDScale for belt tightening 2-, passenger side-N298
0174206CETinder for knee airbag, driver's side-N295
0174306CFTinder for knee airbag, front passenger side N296
0174406D0Zundanlassschalter-D (terminal P)
0174506D1Button for Sprechfunkgerat-E76
0174606D2Switch for alarm-E75
0174706D3Donors for heated steering wheel-Z36
0174806D4Switch for Tiptronic in the steering wheel, high-E438
0174906D5Switch for Tiptronic in the steering wheel, down-E439
0175006D6Multifunction buttons on the steering wheel, the left-E440
0175106D7Multifunction buttons on the steering wheel, right-E441
0175206D8heated steering wheel-Z36
0175306D9Wiper motor-V, Step 1
0175406DAWiper motor-V, Step 2
0175506DBLight switch E1, standlight
0175606DCSwitch for fog lamps and -schlu.leuchte-E23, fog lights
0175706DDPump for headlight cleaning system-V11
0175806DELamps for brake lights
0175906DFRelay for Doppeltonhorn
0176006E0Control unit power steering J500 no communication with engine control
0176106E1Magnet for rollover protection, driver side N309
0176206E2Magnet for rollover protection, front passenger side N310
0176306E3Roll over protection structure too many draws
0176406E4Warning: top must be opened. Roll over protection structure is activated.
0176506E5Engine control - control difference
0176606E6Bremsensteuergerat - control difference
0176706E7Donors for vehicle level left-supply voltage
0176806E8Donors for vehicle level right supply voltage
0176906E9Donors for vehicle level front right-G289
0177006EADonors for compressor temperature level control-G290
0177106EBControl unit for headlight range control-J431
0177206ECSignal line from pressure transducer leveling-G291
0177306EDValve for pressure storage level control-N311
0177406EEControl unit f.Leuchtweitenregelung-J431, supply voltage
0177506EFSignal line to control unit for headlight range control-J431
0177606F0Operating unit for level control-E281
0177706F1Redundant signal path from the operating unit for level control-E281
0177806F2Tow signal
0177906F3Signal theft alarm system activation: Innenraumuberwachung active
0178006F4Donors for vehicle level
0178106F5extreme vehicle inconsistency
0178206F6Vehicle is brought to a normal level
0178306F7Control of the LEDТs in the control unit for level control
0178406F8Lowers the vehicle left front
0178506F9Lowers the vehicle front right
0178606FALowers the vehicle rear left
0178706FBLowers the vehicle rear right
0178806FCPressure accumulator is filled and emptied
0178906FDTest I.O.
0179006FETest n.i.O.
0179106FFVacuum pump-V22
017920700Vacuum pump-V22 Control Plus
017930701Vacuum pump-V22, control Minus
017940702Control unit incorrect chassis number
017950703Vacuum system brake
017960704Telematics SIM card
017970705Valve for hydraulic pressure power steering N315
017980706Switch for internal locking rear center-E286, LOCK
017990707Switch for internal locking rear center-E286, UNLOCK
018000708Light switch-E1
018010709Turwarnleuchte, driver's side-W30
01802070ATurwarnleuchte, passenger side-W36
01803070BTurwarnleuchte, rear left-W37
01804070CTurwarnleuchte, rear right-W38
01805070DEntry light, driver's side
01806070EEntry light, passenger's side
01807070FEntry light, rear left-W33
018080710Entry light, rear right-W34
018090711Servomotor for temperature flap left-V158
018100712Servomotor for temperature flap right-V159
018110713Supply voltage for Tursteuergerat driver's side-J386
018120714Supply voltage for Tursteuergerat passenger side-J387
018130715Supply voltage for Tursteuergerat rear left-J388
018140716Supply voltage for Tursteuergerat rear right-J389
018150717Switch for alarm system off E217
018160718Turau.engriffschalter in driver's door-F272
018170719Turau.engriffschalter in passenger door-F273
01818071ATurau.engriffschalter in Tur rear left-F274
01819071BTurau.engriffschalter in Tur rear right-F275
01820071CTurinnengriffschalter in driver's door-F276
01821071DTurinnengriffschalter in passenger door-F277
01822071ETurinnengriffschalter in Tur rear left-F278
01823071FTurinnengriffschalter in Tur rear right-F279
018240720Control lamp for airbags in the rear of-K164
018250721Accumulator is tested
018260722Encoders for steering angle G85, power supply KL30
018270723Control unit in the dash panel insert J285, wheel circumference implausible
018280724Lamp for tail light left
018290725Lamp for tail light right
018300726Lamps for rear fog lamps
018310727Switches for power windows, front and rear-E154
018320728Antenna for tire pressure monitoring, front-R95
018330729Antenna for tire pressure monitoring, rear-R96
01834072ALamp for Seitenblinkleuchte left-M18
01835072BLamp for Seitenblinkleuchte right-M19
01836072Ccompressor off
01837072DReading device for chip card R99
01838072ESend / receive module for 2 Innenraumuberwachung-G305
01839072FSend / receive module 1 for Innenraumuberwachung-G303
018400730Antennas for tire pressure monitoring
018410731Potentiometer control motor for temperature flap left-G220
018420732Potentiometer control motor for temperature flap right-G221
018430733Solar cell C20
018440734Control unit for Frischluftgeblase-J126
018450735Switch for rear blind-E149
018460736Supply Sensor for rain and light detector
018470737heated rear seat left-Z10
018480738heated rear seat right-Z12
018490739Temperature Sensor rear seat left-G94
01850073ATemperature Sensor Right Rear Seat-G95
01851073BPotentiometer control motor butterfly valve Manna Stromer right-G317
01852073CPotentiometer control motor butterfly valve Manna Stromer left-G318
01853073Dheated seats front left-Z45
01854073Eheated seats front right-Z46
01855073FTemperature Sensor for front left seat-G344
018560740Temperature Sensor for front right seat-G345
018570741Donors for Duse center left-G347
018580742Donors for Duse middle right-G348
018590743Airbag back off driver's side
018600744Airbag rear passenger side off
018610745Pilot light for telephone connection rear left-K172
018620746Pilot light for telephone connection rear right-K173
018630747Servomotor for Ausstromer rear left-V218
018640748Servomotor for Ausstromer rear right-V219
018650749Potentiometer for servo motor for Ausstromer rear left-G349
01866074APotentiometer for servo motor for Ausstromer rear right-G350
01867074BServomotor for hot / cold flap Ausstromer rear left-V220
01868074CServomotor for hot / cold flap Ausstromer rear right-V221
01869074DPoti for servomotor hot / cold flap Ausstromer rear left-G351
01870074EPoti for servomotor hot / cold flap Ausstromer rear right-G352
01871074FSwitch for Tiptronic in steering wheel E389
018720750Operating unit for memory driver seat E97
018730751Operating unit for front passenger seat memory-E277
018740752Button for backrest head adjustment-E332, on
018750753Button for backrest head adjustment-E332, from
018760754Button for Gurthohenverstellung-E333, on
018770755Button for Gurthohenverstellung-E333, from
018780756Button for tilt adjustment passenger seat E334, before
018790757Button for tilt adjustment passenger seat-back E334,
018800758Button for Lordosenhohenverstellung-E335, on
018810759Button for Lordosenhohenverstellung-E335, from
01882075AButton for Lordosenlangsverstellung-E336, Vorwarts
01883075BButton for Lordosenlangsverstellung-E336, backwards
01884075CButton for massage E337
01885075DButton for memory position 1 and 2-E338
01886075EButton for memory position 3 and 4-E339
01887075FButton for memory, front seat-E340
018880760Lufter control for seat cushion
018890761Supply voltage Lufter for seat cushion
018900762Lufter drive for seat back
018910763Supply voltage for Lufter seatback
018920764Temperature Sensor for seat back-G371
018930765Potentiometer for Gurthohenverstellung-G372
018940766Potentiometer for Lordosenhohenverstellung-G373
018950767Motor for Lenksaulenverstellung, vertically-V123
018960768Motor for Lenksaulenverstellung axially-V124
018970769Donors for Lenksaulenverstellung, vertically-G357
01898076ADonors for Lenksaulenverstellung axially-G358
01899076BSupply voltage transmitter for Lenksaulenverstellung
01900076CMotor for longitudinal adjustment passenger seat-V31
01901076DEngine for Lordosenhohenverstellung-V229
01902076EEngine for Lordosenlangsverstellung-V230
01903076FMotor for seat tilt adjustment-V231
019040770Motor for backrest adjustment passenger seat-V46
019050771heated driver seat-Z7
019060772heated front passenger seat-Z9
019070773Cheeks heating, driver's seat-Z31
019080774Cheeks heating, driver's seat back-Z32
019090775Cheeks heating, front seat-Z33
019100776Cheeks heating, front passenger seat-Z34
019110777Motor for backrest head adjustment-V232
019120778Motor head Stutz adjustment passenger seat-V104
019130779Engine for Gurthohenverstellung-V233
01914077AEncoders for angle adjustment, front seat-G359
01915077BDonors for Lordosenhohenverstellung-G374
01916077CDonors for Lordosenlangsverstellung-G375
01917077DSupply voltage switch for rear seat adjustment
01918077ESwitch for longitudinal adjustment rear seat left-E145, Vorwarts
01919077FSwitch for longitudinal adjustment rear seat left-E145, backwards
019200780Switch for longitudinal adjustment rear seat right-E147, Vorwarts
019210781Switch for longitudinal adjustment rear seat right-E147, backwards
019220782Button for tilt adjustment rear seat left-E341, on
019230783Button for tilt adjustment rear seat left-E341, from
019240784Button for tilt adjustment rear seat right-E342, on
019250785Button for tilt adjustment rear seat right-E342, from
019260786Button for head neck adjustment, rear seat left-E171, on
019270787Button for head neck adjustment, rear seat left-E171, from
019280788Button for head neck adjustment, rear seat right-E172, on
019290789Button for head neck adjustment, rear seat right-E172, from
01930078AButton for Lordosenhohenverstellung Left Rear Seat-E343, on
01931078BButton for Lordosenhohenverstellung Left Rear Seat-E343, from
01932078CButton for Lordosenhohenverstellung Right Rear Seat-E344, on
01933078DButton for Lordosenhohenverstellung Right Rear Seat-E344, from
01934078EButton for Lordosenlangsverst. Left Rear Seat-E345, backwards
01935078FButton f.Lordosenlangsverst. Right Rear Seat-E346, backwards
019360790Button for memory, rear seats-E347
019370791Button for memory position 1 and 2, rear seat left-E348
019380792Button for memory position 1 and 2, the rear seat right-E349
019390793Lufter control for rear seat left
019400794Supply voltage Lufter for rear seat left
019410795Lufter control for rear seat right
019420796Supply voltage for Lufter Right Rear Seat
019430797Engine for head neck adjustment, rear seat left-V133
019440798Engine for head neck adjustment, rear seat right-V134
019450799Donors for head neck adjustment, rear seat right-G360
01946079APotentiometer for Lordosenhohenverstellung rear seat left-G361
01947079BPotentiometer for Lordosenhohenverstellung rear seat right-G362
01948079CDonors for Lordosenlangsverstellung rear seat left-G363
01949079DDonors for Lordosenlangsverstellung rear seat right-G364
01950079EMotor for longitudinal adjustment, rear seat left-V87
01951079FMotor for longitudinal adjustment, rear seat right-V88
0195207A0Engine for Lordosenlangsverstellung Left Rear Seat-V127
0195307A1Engine for Lordosenlangsverstellung Right Rear Seat-V128
0195407A2Engine for Lordosenhohenverstellung rear seat left-V225
0195507A3Engine for Lordosenhohenverstellung rear seat right-V226
0195607A4Motor for tilt adjustment rear seat left-V227
0195707A5Motor for tilt adjustment rear seat right-V228
0195807A6Encoders for angle adjustment rear seat left-G365
0195907A7Encoders for angle adjustment rear seat right-G366
0196007A8Donors for longitudinal adjustment rear seat left-G367
0196107A9Donors for longitudinal adjustment rear seat right-G368
0196207AADonors for Lordosenhohenverstellung rear seat left-G369
0196307ABDonors for Lordosenhohenverstellung rear seat right-G370
0196407ACControl unit for Sitzverst.mit Memory / Lenksaulenverst.-J136
0196507ADSwitch for height adjustment, driver's side-E289, Up
0196607AESwitch for height adjustment, driver's side-E289, down
0196707AFSwitch for height adjustment, passenger side-E290, Up
0196807B0Switch for height adjustment, passenger side-E290, down
0196907B1Button for seat depth adjustment-E350, Vorwarts
0197007B2Button for seat depth adjustment-E350, backwards
0197107B3Adjuster for Sitzbeluftung / heating-E399
0197207B4Supply potentiometer Sitzbeluftung / heating / Gurthohenverstellung
0197307B5Donors for seat depth adjustment-G378
0197407B6Donors for backrest head adjustment-G376
0197507B7Motor for height adjustment, front seat-V191
0197607B8Motor for seat depth adjustment-V234
0197707B9Lighting for makeup mirror rear-L135
0197807BAButton for remote passenger seat-E351
0197907BBSupply voltage seat occupancy sensor rear
0198007BCAdjuster for Sitzbeluftung / heating rear seat right-E414
0198107BDAdjuster for Sitzbeluftung / heating rear seat left-E413
0198207BEDonors for head neck adjustment, rear seat left-G381
0198307BFRelay 2 for hydraulic pump convertible top actuation-J588
0198407C0Valve 2 for automatic top-N341
0198507C1Valve 3 for automatic top-N342
0198607C2Donors for Spannbugelposition top-G356
0198707C3Button for convertible top actuation -E137 open,
0198807C4Button for convertible top actuation -E137 schlie.en,
0198907C5Switch for hardtop detection-F255
0199007C6Switch for top compartment lid locked-F200 / F199
0199107C7Switch for top compartment lid-F290 / F291
0199207C8Switch for closure top compartment lid unlocked-F293
0199307C9Motor for closing the convertible top compartment lid-V222
0199407CASwitch for position top compartment pan-F292
0199507CBSwitch for top lock closed-F295
0199607CCSwitch for top lock open-F294
0199707CDEngine for top lock-V223
0199807CECheeks heating, rear seat left-Z48
0199907CFCheeks heating, rear seat right-Z49
0200007D0switch position
0200107D1Bus distance control
0200207D2Heating for sensor distance control-Z47
0200307D3Control unit for driver identification-J589
0200407D4Switch for Gesprachsende, Telematics USA-E331
0200507D5Codierpin
0200607D6Engine for the glove compartment lock-V224
0200707D7Switch for roof luggage rack recognition-F296
0200807D8Hazard warning lights on
0200907D9Control lamp for telematics K186
0201007DAControl unit for easy entry, driver side J572
0201107DBControl unit for easy entry, front passenger side J573
0201207DCSafety shutdown of ADR
0201307DDSwitch for backrest locking, driver's side-F211
0201407DESwitch for backrest locking, passenger side-F212
0201507DFButton for easy entry driver's side-E358, before
0201607E0Button for easy entry driver's side-E358 back,
0201707E1Button for easy entry front passenger side-E359, before
0201807E2Button for easy entry front passenger side-E359 back,
0201907E3Supply voltage for SG heated windscreen
0202007E4Supply voltage heating element in the rear left Fu.raum
0202107E5Supply voltage heating element in the rear right Fu.raum
0202207E6Supply voltage control unit for Frischluftgeblase
0202307E7terminal 87
0202407E8Adaptation by lead
0202507E9Supply voltage for external components
0202607EAPower supply 2 for external components
0202707EBuser 1
0202807ECuser 2
0202907EDuser 3
0203007EEuser 4
0203107EFSwitch for Lenksaulenverstellung-E167
0203207F0Button for Information Services E450
0203307F1Potentiometer 2 for transfer case G482
0203407F2Motor power supply
0203507F3Hall sender 1
0203607F4Hall sender 2
0203707F5Sensors transfer case
0203807F6Supply voltage for sensors
0203907F7Potentiometer transfer case G398
0204007F8Motor transfer case Plus Conn.
0204107F9Motor transfer case, minus Conn.
0204207FAControl for motor transfer case
0204307FBMotor transfer case
0204407FCSwitching time transfer case too long
0204507FDLED for normal operation for the operating unit transfer case
0204607FELED f.Gelandeuntersetzung in Control Head f.Verteilergetriebe
0204707FFLED f.Langssperre activated in the control unit f.Verteilergetr.
020480800Rear LED for cross lock is on, for in the keypad transfer case
020490801LED for cross lock front enabled for the operating unit transfer case
020500802Transfer Case
020510803Automatic incorrect software version
020520804Function switched off by excess temperature in the control unit
020530805Control unit for transfer case-J646
020540806Control unit for cross lock J647
020550807Engine for transverse lock, plus connection
020560808Engine for transverse lock, minus connection
020570809Brake lock for motor plus terminal
02058080ABrake lock for motor minus terminal
02059080BTemperature Sensor for engine-G407
02060080CSupply voltage Temperature Sensor for engine
02061080DOltemperaturfuhler
02062080Edifferential lock
02063080FSolenoid switched off for rollover protection, driver's side
020640810Solenoid switched off for roll over protection structure passenger side
020650811Control unit for Sprachverstarkung-J656
020660812Optical data bus attenuation is too large.
020670813Optical data bus illicit wake-up request
020680814An optical data bus system is shut down
020690815Timer for the front parking aid
020700816Donors for rear parking aid
020710817local data bus
020720818Control unit for power management J644
020730819defective optical data bus control unit for system startup
02074081AControl unit, display and control unit f.Information, hl-J648
02075081BControl unit, display and control unit f.Information, hr-J649
02076081CMedia Player Position 1 -R118
02077081DMedia Player Position 2 -R119
02078081EMedia Player Position 3 -R120
02079081FMedia Player Position 4 -R121
020800820Uberprufung adjustment
020810821horizontal adjustment
020820822vertical adjustment
020830823Embassy for Verzogerungsanforderung
020840824component protection
020850825Incorrect control unit fitted
020860826Lamp for headlights left-L148
020870827Lamp for headlights right-L149
020880828Lamps for additional high beam
020890829Control lamp for hazard lights / Fkt.anford.Fahrwerk o.Umschaltrelais f.Batt.
02090082ARelay for SRA or supply rain sensor
02091082BRear window washer pump V13
02092082CRelease seat heating
02093082DEmergency signal
02094082EButton for central switch-off interior light-E390
02095082FComponent protection active
020960830Ring fault diagnosis
020970831steamed ring break diagnosis
020980832Control for Verstarkergeblase left
020990833Control for Verstarkergeblase right
021000834Servomotor for Fu.raumklappe-V261
021010835Servomotor for Seitenanstromer-V262
021020836Fuhler for pinch tailgate-G408
021030837Control unit 2 for on-board power-J520
021040838Sensor for detecting light-G399
021050839Voltage supply for the sensor for light detection
02106083AEngine for rear blind-V91
02107083BMotor for electric Heckklappenoffnung-V254
02108083CLufter control for the front left seat
02109083DLufter control for the front right seat
02110083ESwitches for windows
02111083FEngine for windows
021120840Windows thermal protection active
021130841Switch for internal locking
021140842Schlusseltaster Central-E391
021150843Schlie.einheit for Central
021160844Motor for mirror adjustment
021170845Engine for Spiegelanklappung
021180846Potentiometer for horizontal mirror adjustment
021190847Potentiometer for mirror adjustment vertically
021200848Button for memory, positions 1 and 2
021210849Button for memory, position 3 and 4
02122084AButton for Memory
02123084BTurwarnleuchte / Entry light
02124084CTurau.engriffschalter
02125084DTurinnengriffschalter
02126084EButton for central locking, Turau.engriff
02127084FTurau.engriffbeleuchtung / Mirror light
021280850Control unit for closing aid-J657
021290851automatically dimming Au.enspiegel
021300852Turinnenbeleuchtung
021310853Engine for child safety
021320854Lighting for make-up mirror, front left
021330855Lighting for make-up mirrors, front right
021340856Lighting for make-up mirrors, rear left
021350857Lighting for make-up mirrors, rear right
021360858reading lights
021370859Relay for battery shutdown-J655
02138085AControl for interior lighting, front right
02139085BControl for interior lighting, front left
02140085CControl for illuminated vanity mirror left front
02141085DControl for illuminated vanity mirror front right
02142085EControl for illuminated vanity mirrors, rear left
02143085FControl for illuminated vanity mirrors, rear right
021440860Switch for interior light front-E326, ON
021450861Switch for interior light front-E326, AUTO
021460862Switch for interior light front E326, AUS
021470863Button for reading light front-E328, left
021480864Button for reading light front-E328, right
021490865Button 1 for Garagentoroffner-E392
021500866Button 2 for Garagentoroffner-E393
021510867Button 3 for Garagentoroffner-E394
021520868Button for sliding-E325, on
021530869Button for sliding-E325 to
02154086ASupply voltage for switch for sunroof
02155086BButton for side blind rear left-E383
02156086CButton for side blind, rear right-E384
02157086DSupply voltage. for interior mirror / sensor for light detection
02158086ESupply voltage for encoder for seat adjustment
02159086FSwitch on the back for rear blind-E385
021600870Lamp for lighting, switch for sunroof-L65
021610871Lighting switch back roof module
021620872Pilot light for switch for interior lighting back-K190
021630873Button for dimming interior mirror-E386
021640874Control lamp for abblendbarem interior mirror-K187
021650875Windscreen temperature signal
021660876Reference signal for windshield temperature signal
021670877Control unit for tilt / anti-theft J529
021680878Microphone front left-R140
021690879Microphone front right-R141
02170087AMicrophone middle left-R142
02171087BMicrophone middle right-R143
02172087CMicrophone rear left-R144
02173087DMicrophone rear right-R145
02174087EAnalog / Digital Clock
02175087FEngine for Lordosenlangsverstellung, driver seat-V125
021760880Engine for Lordosenlangsverstellung, front seat-V126
021770881Engine for Lordosenhohenverstellung, driver seat-V129
021780882Engine for Lordosenhohenverstellung, front seat-V130
021790883Engine front height adjustment passenger seat-V32
021800884Motor for seat depth adjustment, driver-V256
021810885Motor for seat depth adjustment, passenger-V257
021820886Motor for backrest head adjustment, driver-V258
021830887Motor for backrest head adjustment, passenger-V259
021840888Engine for Gurthohenverstellung, driver seat V74 / V75
021850889Engine for Gurthohenverstellung, front seat-V74 / V75
02186088AMotor-ADR Interface
02187088BRadar reception disturbed
02188088Clighting
02189088DTest mirror functions
02190088EAmbient lighting
02191088Fshutdown windows
021920890boot windows
021930891Power supply controller for Frischluftgeblase
021940892Power supply controller for Umluftgeblase
021950893Controller for lighting - switches and instruments-E20
021960894Backup f.Steuergerat f.Bordnetz onboard power supply battery-S287
021970895Regulators for Fu.raumleuchten-E398
021980896Lamp for tail light 2, left-M49
021990897Lamp for tail light 2, right-M50
022000898Communication line to tail lights
022010899Closing aid for the trunk, unlocked position-F332
02202089AClosing aid for the trunk, locked position-F333
02203089BAudio / Video input 1
02204089CAudio / video input 2
02205089DMotor for backrest head adjustment rear left-V266
02206089EButton for backrest head adjustment, rear left, front-E401
02207089FButton for backrest head adjustment, rear left, back-E402
0220808A0Potentiometer for backrest head adjustment rear left-G413
0220908A1Motor for backrest head adjustment rear right-V267
0221008A2Button for backrest head adjustment, rear right, front-E403
0221108A3Button for backrest head adjustment, rear right, back-E404
0221208A4Potentiometer for backrest head adjustment rear right-G414
0221308A5Functional cut-off by brake temperature
0221408A6Tire pressure warning
0221508A7Control unlocking spare
0221608A8Button for unlocking spare-E405
0221708A9Roll over protection structure
0221808AASatellite Radio R146
0221908ABWake-up line diagnostics interface / combi, unberecht.Wecken
0222008ACAmbient lighting, interior
0222108ADPilot light for parental control left
0222208AEPilot light for parental control right
0222308AFControl lamp for Innenraumuberwachung
0222408B0Pilot light for tilt sensor
0222508B1Pilot light for Central
0222608B2Engine control unit 2, Wegfahrsperrendaten not adjusted
0222708B3Engine control unit 3, Wegfahrsperrendaten not adjusted
0222808B4Engine control unit 4, Wegfahrsperrendaten not adjusted
0222908B5not adjusted transmission control, Wegfahrsperrendaten
0223008B6Digital radio tuner
0223108B7Stoplight request from the control unit for ABS
0223208B8Approaching Auslieferposition
0223308B9Power module left headlight-J667
0223408BAPower module headlights right-J668
0223508BBstatic cornering light left-M51
0223608BCstatic cornering light right-M52
0223708BDstatic cornering light
0223808BEStepper motors LWR
0223908BFAudio / Video output 1
0224008C0Audio / Video Output 2
0224108C1not adapted engine control, Wegfahrsperrendaten
0224208C2Button for Schlie.ung tailgate in the trunk-E406
0224308C3Display and control unit for auxiliary heating-E407
0224408C4Button on the control panel clamps
0224508C5Connection remote control
0224608C6speaker center
0224708C7Subwoofer R148
0224808C8Valve opening degree control for the clutch-N373
0224908C9Donors for oil pressure / OltemperaturG437
0225008CAFunction shutdown Ventileinschaltdauer
0225108CBHEATER locked
0225208CCgenerator
0225308CDGenerator Hochtemperaturabregelung
0225408CEInterface to the generator
0225508CFVoltage measurement cable from battery positive
0225608D0quiescent current
0225708D1remote control receiver
0225808D2Transmission unit Garagentoroffner
0225908D3F.Steuerger.Anz. display unit and control unit the front-J685
0226008D4Display unit temperature error
0226108D5Data transmitter-R118
0226208D6Display unit extend twist mechanism
0226308D7Retract display unit twist mechanism
0226408D8Servotronic full Lenkunterstutzung
0226508D9Servotronic no Lenkunterstutzung
0226608DAControl relay for headlight cleaning systems pump
0226708DBControl relay for wash water heating
0226808DCexit button display unit
0226908DDLimit display unit exit-no jerk message
0227008DELimit display unit retract-jerk no message
0227108DFEngine display unit Open / close, thermal protection active
0227208E0Quiescent current level 1
0227308E1Quiescent current level 2
0227408E2Quiescent current level 3
0227508E3Quiescent current level 4
0227608E4Quiescent current level 5
0227708E5Quiescent current level 6
0227808E6Ambient lighting interior, rear
0227908E7EC mirror-Y7, dimming
0228008E8Connection motor for sunroof wind deflector to / Rolo
0228108E9Motor wind deflector sunroof, thermal protection active
0228208EASliding roof cover drive, stall detection
0228308EBVideo connection to Endgerat
0228408ECFuel sensor heater-G421
0228508EDExhaust gas sensor heater-G422
0228608EEShut-off valve for fuel, heater-N375
0228708EFFuel supply heater
0228908F1Control unit for driver's seat Lufter-J672
0229008F2Control unit for front passenger seat Lufter-J673
0229108F3Control unit f.Sitzbeluftung in the passenger compartment, driver's side-J674
0229208F4Control unit f.Sitzbeluftung in the passenger compartment Beifahrers.-J675
0229308F5Board voltage cl. 30 for driver seat control unit Lufter
0229408F6Board voltage cl. 30 for control unit passenger seat Lufter
0229508F7Board voltage terminal 30 f.Steuergerat back seat driver's side Lufter
0229608F8Board voltage terminal 30 f.Steuergerat back seat Lufter passenger.
0229708F9Supply voltage for seat Lufter driver's side
0229808FASupply voltage for seat passenger side Lufter
0229908FBSupply voltage for back seat driver's side Lufter
0230008FCSupply voltage for rear seat passenger side Lufter
0230108FDHeated back seat driver's side-Z52
0230208FEheated rear seat passenger side-Z53
0230308FFCheeks heating for back seat driver's side-Z54
023040900Cheeks heating for rear seat passenger side-Z55
023050901Temperature Sensor for back seat driver's side-G426
023060902Temperature Sensor for rear seat passenger side-G427
023070903Control for the driver's seat Lufter
023080904Control for front seat Lufter
023090905Control for rear seat Lufter driver's side
023100906Control for rear seat passenger side Lufter
023120908Button for massage function in the rear seat left-E409
023130909Button for massage function in the rear seat right-E410
02314090ASwitch for Gurthohenverstellung driver's side-E169
02315090BSwitch for Gurthohenverstellung passenger side-E178
02318090EPoti for lordosis High / Massage rear left-G424
02319090FPoti for lordosis High / Massage rear right-G425
023200910Button for rear head restraints lower-E411
023210911Button for headrests from center console Lower-E412
023220912Button for seat depth adjustment-E350
023230913Supply voltage for operating unit
023240914Button for seat longitudinal adjustment-E418
023250915Button for seat height adjustment front-E451
023260916Button for seat height adjustment back-E452
023270917Donors for seat height adjustment front-G438
023280918Donors for seat height adjustment back-G439
023290919Motor for seat height adjustment front-V296
02330091AMotor for seat height adjustment back-V285
02331091BButton for backrest adjustment-E425
02332091CDonors for backrest adjustment-G440
02333091DMotor for backrest adjustment-V286
02334091EButton for backrest head adjustment-E332
02335091FButton for height adjustment of the lumbar stop short-E335
023360920Button for longitudinal adjustment of the lumbar stop short-E336
023370921Button for Gurthohenverstellung-E333
023380922Button for head neck adjustment-E155
023390923Engine for head neck adjustment-V287
023400924Motor for seat longitudinal adjustment-V288
023410925Donors for seat longitudinal adjustment-G441
023420926Button for seat adjustment Quick-E445
023430927Switch for backrest lock-E446
023440928Button for seat position memory-E447
023450929Button for memory position 1-E218
02346092AButton for memory position 2-E219
02347092BButton for memory position 3-E220
02348092CButton for memory position four-E282
02349092DSwitches for the parking brake-F321
02350092ESliding door drive on
02351092FSliding door drive to
023520930closing aid to
023530931closing aid on
023540932Tread ride from
023550933Signal line to Zentralsteuergerat for comfort system
023560934Data transmission to the sliding door
023570935Button for treads deactivation-E444
023580936Button for Schiebeturbetatigung-E442
023590937Lighting of the button for Schiebeturbetatigung
023600938Button for Schiebeturdeaktivierung-E443
023610939Lighting of the button for Schiebeturdeaktivierung
02362093Aautomatic step
02363093BEngine for Schiebeturoffnung-V293
02364093Cclosing aid
02365093DEngine for Schiebeturzuziehhilfe-V324
02366093Epinch
02367093FHeating element for additional heater on
023680940Heating element for additional heating of
023690941Temperature sensor in the control unit
023700942Sliding roof cover drive, not initialized
023710943Current sensor 1A in the control unit
023720944Current sensor 100A in the control unit
023730945Current sensor -500A..100A in the control unit
023740946Generator, setpoint generator voltage 15,0V
023750947Generator, setpoint generator voltage 13.5V
023760948Generator, generator voltage target value 0.0V (deenergization)
023770949Wiper upper turning point
02378094AWiper lower turning point
02379094BServomotor for side registration Stromer left-V299
02380094CServomotor for side registration Stromer right-V300
02381094DWiper motor overloaded
02382094ESensor for detecting light-G399
02383094FWiper motor Fkt.einschrankung d. undervoltage
023840950Wiper motor Fkt.einschrankung by overvoltage
023850951Sens.f.Regen- u.Lichterk.Fkt.einschrankung d.Unterspannung
023860952Sens.f.Regen- u.Lichterk.Fkt.einschrankung d.Uberspannung
023870953Support for phone-R126
023880954Tread ride a
023890955Enable signal transmission, position P / N
023900956Regulators for perimeter lighting-E400
023910957Terminal 30 Reference
023920958Terminal 31 Reference
023930959control generator
02394095ALamp for parking light front left-M1
02395095BLamp for parking light front right-M3
02396095CLeft-M4 lamp for tail light
02397095DLamp for bottom right-M2
02398095EControl for rear window washer pump
02399095FControl Terminal 30 for interior lighting
024000960Control heated Au.enspiegel
024010961terminal 75x
024020962Control Terminal 15 for interior
024030963Terminal 15 interior
024040964Vehicle exterior lighting
024050965Aperture for low beam
024060966Send / receive module for 3 Innenraumuberwachung-G444
024070967Send / receive module for 4 Innenraumuberwachung-G445
024080968Solenoid for cross lock front-N383
024090969Brake lock for motor
02410096AFront differential lock
02411096BCenter differential lock
02412096CRear differential lock
02413096DSwitch for position P-locked F319
02414096EUnlocking unit for rear window
02415096FFlash programming is incorrect
024160970Lights turned on
024170971lights off
024180972LEDs turned on
024190973LEDs off
024200974Standardization run Schiebeausstelldach
024210975Transmission unit in the wheel f.Reifendruckkontr.vorn left-G431
024220976Transmission unit in the wheel f.Reifendruckkontr.vo.rechts-G432
024230977Transmission unit in the wheel f.Reifendruckkontr.hi.links-G433
024240978Transmission unit in the wheel f.Reifendruckkontr.hi.rechts-G434
024250979Transmission unit in the wheel well for tire pressure monitoring system
02426097ARear brake disc does not reach the left
02427097BRear brake disc does not reach the right
02428097CParking motor left clamping force not reached-V282
02429097DLocking motor right, clamping force not reached-V283
02430097EParking motor left schwergangig-V282
02431097FLocking motor right schwergangig-V283
024320980Detecting motor voltage supply to the left-V282
024330981Locking motor right power-V283
024340982Control unit left channel power supply
024350983Control unit right channel power supply
024360984Control unit left channel
024370985Control unit right channel
024380986Parking motor left Hall sensor
024390987Locking motor right Hall sensor
024400988Function display in the combination (P)
024410989yellow warning lamp in the dash
02442098AFunction lamp in the control panel
02443098Boperation part
02444098CDrive Load / Eject error
02445098Ddrive initialization
02446098EDrive mechanical failure
02447098FGPS receiver
024480990Rotation angle sensor
024490991terminal 58
024500992Magnetic switch for bi-xenon headlights, shading-F320
024510993Ejector rear lid lock
024520994Display unit rear left-Y22
024530995Display unit rear right-Y23
024540996Microphone unit in front roof module-R164
024550997Setting the reference transmitter for Radio
024560998Leitungsbefullung
024570999Speakers in rear shelf-R150
02458099ARelay 2 for starters-J695
02459099BSwitching power supply for Lufter
02460099CTimer for motor Linkage flap left-G442
02461099DTimer for motor Linkage flap right-G443
02462099EEngine for Linkage flap left-V289
02463099FEngine for Linkage flap right-V290
0246409A0Switch for top lock on the left-F323
0246509A1Switch for top lock left to-F324
0246609A2Switch for top lock right-F325
0246709A3Switch for top lock right to-F326
0246809A4Engine for top lock left-V291
0246909A5Engine for top lock right-V292
0247009A6Button for windows on-E448
0247109A7Buttons for power windows to-E449
0247209A8Switch for cover-F328
0247309A9Horer and transmission link with jerk message
0247409AASOS LED flash
0247509ABflashing LED Service
0247609ACCharging cradle for the phone back-R151
0247709ADAntenna for Bluetooth-R152
0247809AEGPS system test
0247909AFsome consumers disconnection active
0248009B0read history data
0248109B1emergency battery off
0248209B2Wake-up line diagnostics interface / combi
0248309B3Schlie.einheit for Central tailgate-F327
0248409B4Button height adjustment lumbar stop short rear seat bend left-E343
0248509B5MD driver-R153
0248609B6high beam
0248709B7Button height adjustment d.Lendenwirbelst.Rucksitze Re.-E344
0248809B8Button longitudinal adjustment d.Lendenwirbelst.Rucksitze bend left-E345
0248909B9Button longitudinal adjustment d.Lendenwirbelst.Rucksitze Re.-E346
0249009BAButton for head neck adjustment spinal seat left-E416
0249109BBButton for head neck adjustment spinal seat right-E417
0249209BCButton for seat longitudinal adjustment of the seat jerk left-E419
0249309BDButton for seat longitudinal adjustment of the seat jerk right-E420
0249509BFButton for tilt adjustment of the seat jerk left-E422
0249609C0Button for tilt adjustment of the seat jerk right-E423
0249709C1Button for seat height adjustment-E424
0249809C2Aperture for low beam left-V294
0249909C3Aperture for low beam right-V295
0250009C4turn antenna switch to emergency antenna
0250109C5turn antenna switch on the main antenna
0250209C6Signal phone
0250309C7Output line for radio
0250409C8Button for sunshade and sunroof-E437
0250509C9Supply voltage for Lufter in the seat cushion and seat back
0250609CASupply voltage for Lufter in rear seats
0250709CBControl for Kuhlmittelpumpe
0250809CCRefrigerant temperature sender-G454
0250909CDButton on remote control jammed
0251009CELenksaulenverstellung
0251109CFControl unit for seat occupancy detection-J706
0251209D0Pressure sensor for detecting seat occupancy-G452
0251309D1Belt force sensor for seat occupied recognition-G453
0251409D2retract towbar
0251509D3extend towbar
0251609D4Locator lighting switches for schwenkb. towbar
0251709D5Lamp switch for schwenkb. retract towbar
0251809D6Lamp switch for schwenkb. extend towbar
0251909D7Display unit roof-J702
0252009D8Boost Gauge-G30
0252109D9Lamp f.Beleuchtung d.Tasters f.Stabilisierungsprogramm-L115
0252209DASunroof cruise on
0252309DBSunroof drive to
0252409DCSunroof rear ride on
0252509DDSunroof rear ride to
0252609DESunroof blind ride on
0252709DFSunroof blind to ride
0252809E0Boost pressure control Bank 1
0252909E1Boost pressure control bank 2
0253009E2Engine for intake manifold flap bank 1 to ride
0253109E3Engine intake manifold for Bank 2 to ride
0253209E4Controlling glow plugs Bank 1
0253309E5Controlling glow plugs Bank 2
0253409E6Control Kuhlerlufter 1
0253509E7Control Kuhlerlufter 2
0253609E8Changeover valve for radiator of exhaust gas recirculation-N345
0253709E92 changeover valve for radiator of exhaust gas recirculation-N381
0253809EAFunktionseinschrankung by overstressing
0253909EBTerminal 30 of control unit
0254009ECSensor defect for driver identification or dirty-G455
0254109EDModule for air freshening-J707
0254209EERelay for motor for seat longitudinal adjustment-J739
0254309EFUnder pressure sensor in the brake booster-G483
0254409F0Potentiometer for Manna Stromer front left-G387
0254509F1Potentiometer for Manna Stromer front right-G388
0254609F2Steering end stop
0254709F3LED f.Anforder.Schaltstufenubern., In the control unit transfer box-K210
0254809F4Sensor for stabilizer decoupling the front-G484
0254909F5Sensor for stabilizer decoupling of the rear axle-G485
0255009F6Pressure sensor in the hydraulic unit for stabilizer decoupling-G486
0255109F7Button for Stabilizer decoupling-E484
0255209F8Indicator light stabilizers for decoupling-K221
0255309F9Schaltvent.f.Stabientkopplung Front, in hydraulic unit-N399
0255409FASchaltvent.f.Stabientkopplung rear axle, in hydraulic unit-N400
0255509FBPump motor f.Stabilisatorenentkopplung in hydraulic unit-V326
0255609FCVersorgungsspg.Pumpenmotor f.Stabientkoppl., I.Hydraulikeinh.
0255709FDInstallation position of the steering angle sensor
0255809FEMitteltieftonlautsprecher rear left-R159
0255909FFMitteltieftonlautsprecher rear right-R160
025600A00Mittelhochtonlautsprecher front left-R26
025610A01Mittelhochtonlautsprecher front right-R27
025620A02Lamps for the brake light on the trailer
025630A03Lamp for bottom right side of the trailer-M61
025640A04Lamp for bottom left of the trailer-M60
025650A05Flashing lights right at the trailer-M63
025660A06Flashing lights left on trailer-M62
025670A07Lamps for rear fog lights on the trailer-M64
025690A09Control unit for massage function-J740
025700A0AOutput for supplying the interior lights
025710A0BInput dimming interior light
025720A0CInput dimming Load compartment light / trunk light
025730A0Ddrive actuator left
025740A0EControl display and warning light
025750A0Fdrive actuator right
025760A10Actuator (s) open
025770A11Output for brake control
025780A12initialization Anhangersteuergerat
025790A13Lamps for the brake light on the trailer left-M65
025800A14Lamps for the brake light on the trailer right-M66
025810A15Pumps for massage function of the lumbar vertebrae neck
025820A16Donors for seat height adjustment-G503
025830A17Funktionseinschrankung by low temperature
025840A18Button for reading lamp driver side-E457
025850A19Button for reading light passenger side-E458
025860A1AButton for reading lamp rear left-E454
025870A1BButton for reading light rear right-E455
025880A1Cswiveling towbar
025890A1DLamp for additional high-beam left-M67
025900A1ELamp for additional high beam right-M68
025910A1FContact switch for bonnet-F266
025920A20Crash data stored Heck
025930A21off belt tensioner rear center
025940A22Knee Airbag driver switched off
025950A23Knee Airbag off
025960A24Rear brake pads worn
025970A25Servomotor of Manna Stromer rear left-V315
025980A26Servomotor of Manna Stromer rear right-V316
025990A27Servomotor temperature flap rear left-V313
026000A28Control motor temperature flap, right rear-V314
026010A29Fu.raumleuchte driver's side-W9
026020A2AFu.raumleuchte passenger side-W10
026030A2BEmbassy "voltage traction battery" v.Steuergerat f.Lenkhilfe
026040A2CEmbassy "Versorgungsspg.zu low" v.Steuerg.f.Lenkhilfe
026050A2DControl unit for side blind-J719
026060A2EControl for Verstarkergeblase
026070A2FControl unit for water auxiliary heating-J737
026080A30Schaltvent.f.Stabientkoppl.Vorderachse, clocking in hydraulic unit
026090A31Schaltvent.f.Stabientkoppl.Hinterachse, clocking in hydraulic unit
026100A32Schaltvent.Stabientkoppl.Vorder-u.Hinterachse in hydraulic unit
026110A33switch on motor
026120A34Audio cable adapter
026130A35Control unit for stabilizers-J736
026140A36steering gear
026150A37locking fuel filler flap
026160A38Unlock the fuel filler flap
026170A39Satellite antenna-R170
026180A3Adigital TV tuner
026190A3BCommunication line adapter
026200A3CControl for Massagesteuergerat
026210A3DDynamic cornering lights; Approaching Au.enposition
026220A3EDynamic cornering lights; Move to the inside position
026230A3FDynamic cornering lights; Move to the center position
026240A40Dynam. Headlights; Approach lenkwinkelabhangige target position
026250A41Headlight range adjustment Approach delivery position
026260A42Servomotor the dynamic cornering lights right-V319
026270A43Servomotor the dynamic cornering lights left-V318
026280A44Sensor for swivel module position, right
026290A45Sensor for swivel module position left
026300A46Power d.Sensors f.Schwenkmodulposition right
026310A47Voltage supply to the left d.Sensors f.Schwenkmodulposition
026320A48Headlight range control; Move to target position
026330A49Antenna for Satellite Tuner
026340A4AField strength too low
026350A4Bnot activated or activated Tuner
026360A4CSetting the lowest verfugbaren stations
026370A4DFunctional requirement by braking system
026380A4ERelease for Lenksaulenverriegelung
026390A4FAntenneneinleseeinheit f.schlussellose admission
026400A50Sender wheel for gearbox output speed
026410A51Button for electric swiveling towbar-E474
026420A52Motor for closing aid
026430A53Supply voltage pressure sensor
026440A54Supply voltage for transmitter for acceleration
026450A55Valves for level control
026460A56Plausibility level control
026470A57Donors for backrest head adjustment, rear left
026480A58Donors for backrest head adjustment, rear right
026490A59digital radio tuner
026500A5ACrash signal on CAN
026510A5BCrash signal to telematics
026520A5CUmschaltgerat for display and control unit-J728
026530A5DAntenna for traffic data-R173
026540A5EControl relay for magnetic coupling Air Compressor
026550A5FCalibration of the microphones
026560A60Power module left headlight-J667 uncoded
026570A61Power module headlights right-J668 uncoded
026580A62Power module left headlight-J667 incorrectly coded
026590A63Power module headlights right-J668 incorrectly coded
026600A64not trained remote control
026610A65Line for speed signal
026620A66Control for Komfortoffnen sunroof
026630A67Control for Komfortschlie.en sunroof
026640A68Roof sign lighting
026650A69Roof sign Alarm
026660A6AActivate handsfree
026670A6Bsupply Funk1
026680A6Csupply Funk2
026690A6DFlashing lights rear
026700A6EAdditional Left turn signal lamp
026710A6FAdditional flashing light right
026720A70Waffenkastenentriegelung
026730A71enable sound sequence
026740A72Control for windows front left high
026750A73Control for front windows left deep
026760A74Control for front windows right up
026770A75Control for front windows right deep
026780A76Control for windows, rear left high
026790A77Control for windows, rear left deep
026800A78Control for rear windows right up
026810A79Control for windows, rear right deep
026820A7Aflue
026830A7BIntercom
026840A7CFunk main activation
026850A7Dsiren
026860A7Eblue light
026870A7Fcentral locking system
026880A80Control unit f.Sitzbelegungserkennung-J706 not calibrated
026890A81Button for taxi alarm passive
026900A82Push-buttons for taxi alarm
026910A83Button for alarm from taxi
026920A84Button for taxi roof sign
026930A85Button for wireless speakerphone
026940A86Radio receiver for taxi alarm
026950A87Button for weapons box
026960A88Button for engine overrun
026970A89Button for wireless devices supply
026980A8ASwitch for pedal application passenger side
026990A8BButton for buzzer
027000A8CButton for Fu.raumbeleuchtung
027010A8DButton for engine start
027020A8EButtons for power windows front left deep
027030A8FButtons for power windows front left high
027040A90Buttons for power windows front right deep
027050A91Button for front windows right up
027060A92Button for intercom driver's side
027070A93for intercom passenger side button
027080A94Button for blue light
027090A95Button for special signal
027100A96Button for flue
027110A97Radio receiver for Fahrzeugentriegelung
027120A98Control lamp for roof sign button
027130A99Supply 1 for roof sign
027140A9ASupply 2 for roof sign
027150A9BIndicator light for interior lighting switch
027160A9CEnable signal conditioning tone sequence
027170A9DControl for weapons box
027180A9EIndicator light for motor running Next button
027190A9FIndicator light for button of the radio devices supply
027200AA0Indicator light for Fu.raumbeleuchtungstaster
027210AA1Indicator light for button of the buzzer
027220AA2Status for driver's side door contact
027230AA3Control relay for voltage supply terminal 50
027240AA4Indicator light for bus slave active
027250AA5Indicator light for intercom
027260AA6LED is not locked for doors
027270AA7Supply steering wheel remote control
027280AA8Control relay for fuel pump
027290AA9Line for enable signal sunroof
027300AAALamp for lighting of the operating button the driver's door
027310AABCD-read errors
027320AACButton for activating remote control
027330AADControl unit on the LIN bus
027340AAELamp for tail light 3, left
027350AAFLamp for tail light 3, right
027360AB0Lamp for tail light and fog light left
027370AB1Lamp for tail and fog light, right
027380AB2Lamp for brake and tail light left
027390AB3Lamp for brake and tail light right
027400AB4Lamp for brake and tail light 2, left
027410AB5Lamp for brake and tail light 2, right
027420AB6Lamp for stop and indicator light left
027430AB7Lamp for brake and turn signal right
027440AB8Reference voltage Klimabedienteil back
027450AB9Lamp for driving light left
027460ABALamp for driving light right
027470ABBMagnetic switch for bi-xenon headlights right
027480ABCMagnetic switch for bi-xenon headlight left
027490ABDControl unit for telephone operation unit J738
027500ABEButton for display unit
027510ABFControl unit for cornering lights and headlamp leveling-J745
027520AC0Engine for Handschuhfachentriegelung-V327
027530AC1Internal microphone R74
027540AC2Heating element for Kraftstoffvorwarmung-Z66
027550AC3Schaltvent.Stabilisatorentkop.Vorder-u.Hinterachse drive
027560AC4Redundant signal path f.Abschaltung airbag, Beifahrers.-E224
027570AC5Teach tire pressures
027580AC6Create brake pads
027590AC7Operating buttons for dash panel insert
027600AC8Indicator light for coolant temperature (too cold) -K43
027610AC9power display
027620ACAsystem reset
027630ACBPoti for servomotor indirect Beluftungsklappe-G330
027640ACCButton for access and start authorization
027650ACDPotentiometer for setting motor of the cold front cover-G315
027660ACECD access time
027670ACFactivate calibration
027680AD0control Lenksaulenverriegelung
027690AD1Swivel module left
027700AD2Swivel Module right
027710AD3Lamp for brake, indicator and tail light left-M69
027720AD4Lamp for brake, indicator and tail light right-M70
027730AD5Supply for Radio 1, driving to positive
027740AD6Supply for Radio 1, to ground control
027750AD7Supply for Radio 2, driving to positive
027760AD8Supply for Radio 2, to ground control
027770AD9Contact switch on handwheel F354
027780ADAContact switch on the locking pin-F355
027790ADBElectric parking brake data bus
027800ADCEDS system activated
027810ADDButton for TCS / ESP E256
027830ADFInternal GPS receiver
027840AE0Potentiometer for Manna Stromer front left-G387
027850AE1Potentiometer for Manna Stromer front right-G388
027860AE2Control unit 2 for tailgate-J756
027870AE3Buzzer for rear parking aid
027880AE4Internal communication error
027890AE5Privathorer
027900AE6Charging voltage for phone
027910AE7Bracket for mobile phone holder R126
027920AE8Search Bluetooth devices
027930AE9connect Bluetoothgerat
027940AEAOperating unit for mobile phone preparation-E508
027950AEBMotor for steering wheel vibration-V331
027960AECButton for lane departure-E517
027970AEDControl unit for lane departure-J759
027980AEEIndicator light for full load-K228
027990AEFIndicator light for Teilllastbetrieb-K229
028000AF0Warning light for tire pressure control-K230
028010AF1hard Warning 1
028020AF2Repossession of hard Warning
028030AF3soft warning
028040AF4Repossession of the soft warning
028050AF5Systemstorung
028060AF6Repossession of Systemstorung
028070AF7Funkstorung
028080AF8Repossession of Funkstorung
028090AF9Full load operation chosen
028100AFATeilllastbetrieb chosen
028110AFBControl unit f.ELV (electronic Lenksaulenverriegelung) -J764
028120AFCElektr.Lenksaulenverriegelung supply voltage terminal 30
028130AFDFunktionseinschrankung the ELV by undervoltage
028140AFEFunktionseinschrankung the ELV by overvoltage
028150AFFELV supply voltage for locking motor
028160B00ELV enable line from the diagnostic interface
028170B01ELV enable line from the steering wheel electronics
028180B02ELV release for Electronic ignition lock
028190B03Communication between ELV and electronic ignition lock
028200B04not trained electronic Lenksaulenverriegelung
028210B05Even switching off the electronic Lenksaulenverriegelung
028220B06Electronic Lenksaulenverriegelung Falschverbau
028230B07not met interlock conditions for ELV
028240B08Function lock the electronic Lenksaulenverriegelung
028250B09Motor Power supply for ELV
028260B0AEngine for ELV (Lenksaulenverriegelung) -V334
028270B0BWake-up request by ESP
028280B0CRelease of the ELV from the diagnostic interface
028290B0DRelease of the ELV from the electronic steering wheel
028300B0EControl CAN separation unit for driver assistance systems
028310B0FControl unit for driver's door-closing aid-J760
028320B10Control unit for passenger door-closing aid-J761
028330B11Control unit for closing aid rear left-J762
028340B12Control unit for closing aid rear right-J763
028350B13Communication ELV - Comfort System
028360B14Control unit for side blind rear left-J765
028370B15Control unit for side blind, rear right-J766
028380B16Solenoid valve for Servotronic N119
028390B17Wake-up line from the control unit for electric parking brake
028400B18Wake-up line from the control unit for comfort system
028410B19hydraulic unit
028420B1Ano straight-ahead performed
028430B1BBrake light is activated
028440B1CLamp for automatic parking function
028450B1DFunction display in the dash (!)
028460B1ESwitch for tire pressure monitor-E492
028470B1FDonors for braking pressure front left
028480B20Donors for braking pressure front right
028490B21Control unit for lane change assist - J769
028500B22Control unit 2 for lane change assist - J770
028510B23Button for lane change assist - E530
028520B24Indicator light for lane change assist - K232
028530B25Warning light lane change assistant Au.enspiegel Fahrers.-K233
028540B26Warning light Spurwechselassist.Au.enspiegel Beifahrers.-K234
028550B27Sensor area control unit 1 blocks
028560B28Sensor area control unit 2 blocked
028570B29Supply voltage d.Steuergerats 2 f.Spurwechselassistent
028580B2AHeated windscreen for Lane Departure - Z67
028590B2BControl unit for lane departure warning, eingeschrankte view
028600B2CSystem switched
028610B2DElectronic Lenksaulenverriegelung defective
028620B2EAudio input
028630B2FSensor for Turau.engriffberuhrung driver's side, Falschverbau
028640B30Sensor f.Turau.engriffberuhrung passenger side, Falschverbau
028650B31Sensor for Turau.engriffberuhrung rear left, Falschverbau
028660B32Sensor for Turau.engriffberuhrung rear right, Falschverbau
028670B33Antenna in the trunk right f.Zugang and start authorization
028680B34Antenna in the trunk left for access and start authorization
028690B35Speed sensor for steering motor
028700B36Funktionseinschrankung by broken record
028710B37emergency brake activated
028720B38Indicator light for DPF-K231
028730B39Control unit for rear view camera system J772
028740B3AZentralsteuergerat 2 for comfort system J773
028750B3BCD and DVD Kurztest
028760B3CCD and DVD random test
028770B3DDigital radio antenna-R183
028780B3EPotentiometer f.Stellmotor d.Absperrklappe in B-pillar u.Fu.raum right-G328
028790B3FPotentiometer f.Stellmotor d.Absperrklappe in B-pillar u.Fu.raum left-G329
028800B40Potentiometer for air flow flap rear left-G389
028810B41Potentiometer for air flow flap, right rear-G390
028820B42Potentiometer for temperature flap rear left-G391
028830B43Potentiometer for temperature flap, right rear-G392
028840B44Potentiometer f.Stellmotor f.Mannanstromer rear left-G521
028850B45Potentiometer f.Stellmotor f.Mannanstromer hi.rechts-G522
028860B46Control unit for Frischluftgeblase rear-J391
028870B47Potentiometer for setting motor of the side registration Stromer left-G164
028880B48Potentiometer f.Stellmotor the side registration Stromer right-G523
028890B49Button for special signal switching-E505
028900B4AControl for special signal switching
028910B4BRing break diagnosis line
028920B4Cbus chassis
028930B4DButton for valet-E536
028940B4EIndicator light for valet-K159
028950B4FSupply f.LED module left for daytime running lights and parking lights
028960B50Control module f.LED left f.Tagfahrlicht and parking light
028970B51Supply f.LED module f.Tagfahrlicht right parking light
028980B52Control f.LED module f.Tagfahrlicht right parking light
028990B53Komfortoffnen
029000B54comfort Close
029010B55Lamp for brake, indicator and tail light 2 left-M72
029020B56Lamp for brake, indicator and tail light 2 right-M73
029030B57hard Warning 2
029040B58hard Warning 3
029050B59hard Warning 4
029060B5AControl unit for tilting the back-J392
029070B5BControl unit for roof blind-J394
029080B5CControl unit for sliding thermal protection active
029090B5DControl unit for tilting back thermal protection active
029100B5EControl unit for roof blinds thermal protection active
029110B5FLamp for side marker light, rear left-M37
029120B60Lamp for side marker light, rear right-M38
029130B61Stow and interior lights in the back
029140B62Switch 1 for tailgate closed-G525
029150B63Encoder 2 for tailgate closed-G526
029160B64Standardization running sliding forward
029170B65Standardization running back sunroof
029180B66Standardization Running roof Rollo
029190B67front lift / sliding roof on
029200B68front lower sunroof to /
029210B69Sunroof lift back
029220B6Alower tilting back
029230B6BRoof blind on
029240B6CRoof blind to
029250B6DButton for steering wheel heating-E522
029260B6EDVD access time
029270B6FDVD read error
029280B70Functional requirements for rear spoiler
029290B71Servomotor d.Luftklappe f.Dachhimmel and side windows-V341
029300B72Control for brake light in the right side panel
029310B73Control for brake light in the left side panel
029320B74Control for brake light in the rear cover right
029330B75Control for brake light in the rear cover left
029340B76Control for the left tail light
029350B77Control for tail light right
029360B78Functional testing of video and audio connections
029370B79Left headlight is lowered
029380B7ALeft headlight is lifted
029390B7BRight headlight is lowered
029400B7CRight headlight is lifted
029410B7DDynamic cornering light is swung to the left
029420B7EDynamic cornering light is turned to the right
029430B7FLeft dynamic cornering light is swung to the left
029440B80Left dynamic cornering light is turned to the right
029450B81Right dynamic cornering light is turned to the left
029460B82Right dynamic cornering light is turned to the right
029470B83Left static cornering lights dim up
029480B84runterdimmen left static cornering light
029490B85Right static cornering lights dim up
029500B86runterdimmen right static cornering light
029510B87Control for indicator light for headlight range control
029520B88Control for warning light for cornering light
029530B89Freewheel clutches
029540B8ADriving the clutches
029550B8BClean the couplings
029560B8CLight in the rear cover left
029570B8DLight in the rear cover right
029580B8ELight in the left rear quarter panel
029590B8FLight back of the right side panel
029600B90Light in Sto.fanger rear left
029610B91Light in Sto.fanger rear right
029620B92Supply valve for Heckflugelverstellung in Normal High
029630B93Return flow valve for Heckflugelverstellung in Normal High
029640B94Supply valve for Heckflugelverstellung extended
029650B95Return flow valve for Heckflugelverstellung extended
029660B96Supply valve for Heckflugelverstellung retracted
029670B97Return flow valve for Heckflugelverstellung retracted
029680B98Supply valve f.Heckflugelverstellung for positive angular movement
029690B99Return flow valve f.Heckflugelverstellung for positive angular movement
029700B9ASupply valve f.Heckflugelverstellung for negative angular movement
029710B9BReturn flow valve f.Heckflugelverstellung for negative angular movement
029720B9C3/2 way valve for pressure equalization
029730B9DValve for Heckflugelspoiler
029740B9ESwitch 1 for Heckflugelwinkel
029750B9FEncoder 2 for Heckflugelwinkel
029760BA0Switch 1 for Heckflugelhohe
029770BA1Encoder 2 for Heckflugelhohe
029780BA2Encoder for hydraulic form
029790BA3Encoder for hydraulic pressure
029800BA4Level transmitter for Olvorratsbehalter
029810BA5Connection between the radio and impedance converter 1
029820BA6Connection between radio and impedance converter 2
029830BA7Impedance connection between the transducer 1 and glass antenna
029840BA8Connection between impedance converter 2 and glass antenna
029850BA9Control unit for tilting the back-J392 function abort
029860BAAControl unit for roof blind-J394 function abort
029870BABControl unit for sliding-J245 function abort
029880BACThe left / right switchover active
029890BADReduction Frischluftgebl.wegen critical onboard network state
029900BAEDonors for vehicle level, front left, supply voltage
029910BAFDonors for vehicle level, front right, supply voltage
029920BB0Donors for vehicle level rear left, supply voltage
029930BB1Donors for ride height, rear right, supply voltage
029940BB2Line output rear
029950BB3Denormalising sliding forward
029960BB4Denormalising tilting back
029970BB5Denormalising roof Rollo
029980BB6optical drive
029990BB7hard disk
030000BB8Amplifier for digital sound package R184
030030BBBShutdown low beam control unit for through Headlights
163443FD8control unit
163453FD9control unit
163463FDAcontrol unit
163473FDBcontrol unit
163483FDCcontrol unit
163493FDDcontrol unit
163503FDEcontrol unit
163513FDFcontrol unit
163523FE0control unit
163533FE1control unit
163543FE2control unit
163553FE3control unit
163563FE4control unit
163573FE5control unit
163583FE6control unit
163593FE7control unit
163603FE8control unit
163613FE9control unit
163623FEAcontrol unit
163633FEBcontrol unit
163643FECcontrol unit
163653FEDcontrol unit
163663FEEcontrol unit
163673FEFcontrol unit
163683FF0control unit
163693FF1control unit
16394400AP0010 Bank1, camshaft adjustment Malfunction
16395400BNot reached P0011 Bank1 Nockenwellenspatverstellung target
16396400CNot reached P0012 Bank1 Nockenwellenfruhverstellung target
16397400DP0013 Bank1, camshaft adjustment, outlet malfunction
16398400Enot reached P0014 Bank1, Nockenwellenspatverstellung, outlet target
16399400Fnot reached P0015 Bank1, Nockenwellenfruhverstellung, outlet target
164004010P0016 Bank1, Nockenwellenpos.-G40 / G28-Kurbelwellenpos.sensor misallocation
164014011P0017 Bank1, Nockenwellenpos.-G300 / Kurbelwellenpos.sens.-G28 misallocation
164024012P0018 Bank2, Nockenwellenpos.-G163 / Kurbelwellenpos.sensor-G28 misallocation
164034013P0019 Bank2, Nockenwellenpos.-G301 / Kurbelwellenpos.sens.-G28 misallocation
164044014P0020 Bank2, camshaft adjustment Malfunction
164054015Not reached P0021 Bank2 Nockenwellenspatverstellung target
164064016P0022 Bank2 not achieved Nockenwellenfruhverstellung target
164074017P0023 Bank2, camshaft adjustment, outlet malfunction
164084018not reached P0024 Bank2, Nockenwellenspatverstellung, outlet target
164094019not reached P0025 Bank2, Nockenwellenfruhverstellung, outlet target
16414401EP0030 Bank1-Probe 1, heating current interruption
16415401FP0031 Bank1-Probe 1, heating circuit Short circuit to ground
164164020P0032 Bank1-Probe 1, heating circuit Short circuit to positive
164174021P0033 air recirculation valve for turbocharger Electrical fault
164184022P0034 air recirculation valve for turbocharger short circuit to ground
164194023P0035 air recirculation valve for turbocharger
164204024P0036 Bank1-probe 2, heating current interruption
164214025P0037 Bank1-probe 2, heating circuit Short circuit to ground
164224026P0038 Bank1-probe 2, heating circuit Short circuit to positive
164234027P0039 air recirculation valve for turbocharger N249 implausible signal
164244028reversed P0040 Bank1-Probe 1 / Bank 2-Electrode1
164254029reversed P0041 Bank1-probe 2 / Bank 2-probe 2
16426402AP0042 Bank1-Sonde3, heating current interruption
16427402BP0043 Bank1-Sonde3, heating circuit Short circuit to ground
16428402CP0044 Bank1-Sonde3, heating circuit Short circuit to positive
164344032P0050 Bank2-Probe 1, heating circuit electrical fault
164354033P0051 Bank2-Probe 1, heating circuit Short circuit to ground
164364034P0052 Bank2-Probe 1, heating circuit Short circuit to positive
164404038P0056 Bank2-probe 2, heating circuit electrical fault
164414039P0057 Bank2-probe 2, heating circuit Short circuit to ground
16442403AP0058 Bank2-probe 2, heating circuit Short circuit to positive
164484040P0064 Bank2-Sonde3, heating circuit Short circuit to positive
164494041P0065 air control valve for injector N212 implausible signal
164504042P0066 air control valve for injector N212 short circuit to ground
164514043P0067 air control valve for injector N212 short circuit to positive
164524044P0068 Intake manifold pressure / air mass quantity <-> throttle angle deviation
164534045P0069 Intake manifold pressure <-> air pressure misallocation
164554047P0071 Temperature Sensor for Au.entemperatur -G17
164564048P0072 Temperature Sensor for Au.entemperatur -G17 signal too small
164574049P0073 Temperature Sensor for Au.entemperatur -G17 Signal too large.
16458404AP0074 Temperature Sensor for Au.entemperatur -G17, interruption
164734059P0089 valve for fuel metering implausible signal
16474405AP0090 valve for fuel metering electrical fault
16475405BP0091 valve for fuel metering short circuit to ground
16476405CP0092 valve for fuel metering short circuit to positive
164814061P0097 sender -2- for intake-G299 signal too small
164824062P0098 sender -2- for intake-G299 signal too large.
164834063P0099 sender -2- for intake-G299 no signal
164854065P0101 air mass meter-G70 Implausible signal
164864066P0102 air mass meter-G70 signal too small
164874067P0103 air mass meter-G70 signal too large.
164884068P0104 air mass meter-G70 no signal
164894069P0105 donors for intake manifold pressure G71-supply voltage
16490406AP0106 Intake manifold pressure / pressure => - G71 / -F96 Implausible signal
16491406BP0107 Intake manifold pressure / pressure => - G71 / -F96 Signal too low
16492406CP0108 Intake manifold pressure / pressure => - G71 / -F96 Signal too large.
16495406FP0111 donors for intake-G42 Implausible signal
164964070P0112 donors for intake-G42 signal too small
164974071P0113 donors for intake-G42 signal too large.
164984072P0114 donors for intake-G42 no signal
165004074P0116 donors for coolant temperature-G62 Implausible signal
165014075P0117 donors for coolant temperature-G62 signal too small
165024076P0118 donors for coolant temperature-G62 signal too large.
165044078P0120 Throttle-G69 electrical fault in the circuit
165054079P0121 Throttle-G69 Implausible signal
16506407AP0122 Throttle-G69 signal too small
16507407BP0123 Throttle-G69 signal too large.
16509407Dnot reached P0125 coolant temperature for lambda control
165124080P0128 valve for coolant circuit-N214 temperature below control range
165144082P0130 Bank1-Electrode1 electrical fault in the circuit
165154083P0131 Bank1-Electrode1 voltage too low
165164084P0132 Bank1-Electrode1 voltage too large.
165174085P0133 Bank1-Electrode1 signal too slow
165184086P0134 Bank1-Electrode1 no activity
165194087P0135 Bank1-Probe 1, heating circuit electrical fault
165204088P0136 Bank1-probe 2 Electrical fault in the circuit
165214089P0137 Bank1-probe 2 Voltage too low
16522408AP0138 Bank1-probe 2 Voltage too large.
16523408BP0139 bank 1-probe 2 signal too slow
16524408CP0140 Bank1-probe 2 No activity
16525408DP0141 Bank1-probe 2, heating circuit electrical fault
16526408EP0142 Bank1-Sonde3 elektr.Fehler in the circuit
16527408FP0143 Bank1-Sonde3 voltage too low
165284090P0144 Bank 1-Sonde3 voltage too high
165294091P0145 Bank 1-Sonde3 signal too slow
165304092P0146 Bank1-Sonde3 no activity
165314093P0147 Bank1-Sonde3, heating circuit elektr.Fehler
165334095P0149 fuel metering system (Bank 1) deviation of the injection time
165344096P0150 Bank2-Electrode1 electrical fault in the circuit
165354097P0151 Bank2-Electrode1 voltage too low
165364098P0152 Bank2-Electrode1 voltage too large.
165374099P0153 Bank2-Electrode1 signal too slow
16538409AP0154 Bank 2-Electrode1 no activity
16539409BP0155 Bank2-Probe 1, heating circuit electrical fault
16540409CP0156 Bank2-probe 2 Electrical fault in the circuit
16541409DP0157 Bank2-probe 2 Voltage too low
16542409EP0158 Bank2-probe 2 Voltage too large.
16543409FP0159 Bank2-probe 2 signal too slow
1654440A0P0160 Bank2-probe 2 No activity
1654540A1P0161 Bank2-probe 2, heating circuit electrical fault
1654640A2P0162 Bank2-Sonde3 elektr.Fehler in the circuit
1654740A3P0163 Bank2-Sonde3 voltage too low
1654840A4P0164 Bank2-Sonde3 voltage too high
1654940A5P0165 Bank 2-Sonde3 signal too slow
1655040A6P0166 Bank2-Sonde3 no activity
1655140A7P0167 Bank2-Sonde3, heating circuit elektr.Fehler
1655440AAP0170 Bank1, fuel metering system malfunction
1655540ABP0171 Bank1, fuel metering system System too lean
1655640ACP0172 Bank1, fuel metering system System too rich
1655740ADP0173 Bank2, fuel metering system malfunction
1655840AEP0174 Bank2, fuel metering system System too lean
1655940AFP0175 Bank2, fuel metering system System too rich
1656140B1P0177 donors for fuel quality G446 Implausible signal
1656240B2P0178 donors for fuel quality G446 falls below limit
1656340B3P0179 donors for fuel quality G446 exceeded limit
1656540B5P0181 donors for Kraftstofftemp.-G81 Implausible signal
1656640B6P0182 donors for fuel temperature G81 short circuit to ground
1656740B7P0183 donors for fuel temperature G81 interruption / short circuit to positive
1657040BAP0186 Encoder 2 for fuel temperature G248 Implausible signal
1657140BBP0187 Encoder 2 for fuel temperature G248 short circuit to ground
1657240BCP0188 Encoder 2 for fuel temperature-G248 Short circuit to positive
1657440BEP0190 donors for fuel pressure G247 electrical fault in the circuit
1657540BFP0191 donors for fuel pressure G247 Implausible signal
1657640C0P0192 donors for fuel pressure G247 short circuit to ground
1657740C1P0193 donors for fuel pressure G247 short circuit to positive
1657840C2P0194 encoder for fuel pressure interruption G247
1658040C4P0196 donors for oil temperature-G8 Implausible signal
1658140C5P0197 donors for oil temperature-G8 signal too small
1658240C6P0198 donors for oil temperature-G8 signal too large.
1658440C8P0200 injectors electrical fault in the circuit
1658540C9P0201 cylinder injection valve 1-N30 electrical fault in the circuit
1658640CAP0202 injector cylinder 2-N31 electrical fault in the circuit
1658740CBP0203 injector cylinder 3-N32 electrical fault in the circuit
1658840CCP0204 injection valve cylinder 4-N33 electrical fault in the circuit
1658940CDP0205 injector barrel 5-N83 electrical fault in the circuit
1659040CEP0206 injection valve cylinder 6-N84 electrical fault in the circuit
1659140CFP0207 cylinder injection valve 7-N85 electrical fault in the circuit
1659240D0P0208 injector cylinder 8-N86 electrical fault in the circuit
1659340D1P0209 injector cylinder 9-N299 electrical fault in the circuit
1659440D2P0210 injection valve cylinder 10 N300 electrical fault in the circuit
1659540D3P0211 injection valve cylinder 11-N301 electrical fault in the circuit
1659640D4P0212 injection valve cylinder 12 N302 electrical fault in the circuit
1659940D7P0215 fuel cut-N109 malfunction
1660040D8P0216 valve for commencement of injection-N108 malfunction
1660340DBexceeded P0219 maximum engine speed
1660540DDP0221 angle sensor 2 for DK-drive-G188 implausible signal
1660640DEP0222 angle sender 2 for DK-drive-G188 signal too small
1660740DFP0223 angle sender 2 for DK-drive-G188 signal too large.
1660940E1P0225 timer for pedal position G79 supply voltage
1661040E2P0226 Encoder 2.1 for pedal position G79 + G185 Implausible signal
1661140E3P0227 donors for accelerator pedal position-G79 signal too small
1661240E4P0228 donors for accelerator pedal position-G79 signal too large.
1661440E6P0230 fuel pump relay-J17 electrical fault in the circuit
1661840EAP0234 boost pressure control exceeded control limit
1661940EBP0235 boost pressure control Control limit exceeded
1662040ECP0236 donors for boost pressure implausible signal
1662140EDP0237 donors for boost pressure signal too small
1662240EEP0238 donors for boost pressure signal too large.
1662440F0P0240 Encoder 2 for boost pressure G447 Implausible signal
1662540F1P0241 Encoder 2 for boost pressure G447 signal too small
1662640F2P0242 Encoder 2 for boost pressure G447 signal too large.
1662740F3P0243 Solenoid valve for charge pressure control N75-open / short circuit to ground
1662940F5P0245 Solenoid valve for charge pressure control N75-short circuit to ground
1663040F6P0246 Solenoid valve for charge pressure control-N75 Short to positive
1663340F9P0249 solenoid valve 2 for charge pressure limitation-N274 short circuit to ground / interruption
1663440FAP0250 Solenoid 2 for charge pressure control-N274 short circuit to positive
1663540FBP0251 high-pressure pump defective
1663640FCP0252 Injection commencement control Control difference
166454105P0261 Injector cylinder 1-N30 Short circuit to ground
166464106P0262 Injector cylinder 1-N30 Short to positive
166474107P0263 differential injection amount cylinders 1
166484108P0264 Injector cylinder 2-N31 Short circuit to ground
166494109P0265 Injector cylinder 2-N31 Short to positive
16650410AP0266 differential injection amount cylinders 2
16651410BP0267 Injector cylinder 3-N32 Short circuit to ground
16652410CP0268 Injector cylinder 3-N32 Short to positive
16653410DP0269 differential injection amount cylinders 3
16654410EP0270 Injector cylinder 4-N33 Short circuit to ground
16655410FP0271 Injector cylinder 4-N33 Short to positive
166564110P0272 deviation injection quantity cylinder 4
166574111P0273 Injector cylinder 5-N83 Short circuit to ground
166584112P0274 Injector cylinder 5-N83 Short to positive
166594113P0275 differential injection amount Zyl.5
166604114P0276 Injector cylinder 6-N84 Short circuit to ground
166614115P0277 Injector cylinder 6-N84 Short to positive
166624116P0278 differential injection amount Zyl.6
166634117P0279 injection valve cylinder 7-N85 Short circuit to ground
166644118P0280 Injector cylinder 7-N85 Short to positive
166654119P0281 differential injection amount Zyl.7
16666411AP0282 injector cylinder 8 N86 short circuit to ground
16667411BP0283 Injector cylinder 8-N86 Short to positive
16668411CP0284 differential injection amount Zyl.8
16669411DP0285 Injector cylinder 9-N299 short circuit to ground
16670411EP0286 Injector cylinder 9-N299 short circuit to positive
166724120P0288 Injector cylinder 10-N300 short circuit to ground
166734121P0289 Injector cylinder 10-N300 short circuit to positive
166754123P0291 Injector cylinder 11-N301 short circuit to ground
166764124P0292 Injector cylinder 11-N301 short circuit to positive
166784126P0294 Injector cylinder 12-N302 short circuit to ground
166794127P0295 Injector cylinder 12-N302 short circuit to positive
16683412BP0299 boost pressure control Control limit exceeded
16684412CP0300 misfire detected
16685412DP0301 cylinder 1 misfire detected
16686412EP0302 cylinder 2 misfire detected
16687412FP0303 cylinder misfire detected 3
166884130P0304 Cylinder 4 misfires recognized
166894131P0305 cylinder 5 misfire detected
166904132P0306 cylinder 6 misfire detected
166914133P0307 cylinder misfire detected 7
166924134P0308 cylinder misfire detected 8
166934135P0309 cylinder 9 misfires recognized
166944136P0310 cylinder 10 misfires recognized
166954137P0311 cylinder misfire detected 11
166964138P0312 cylinder misfire detected 12
166974139P0313 misfire detected reason: lack of fuel
16698413AP0314 misfire single cylinder
16702413EP0318 Rough road info / motor target torque from ABS-SG electrical fault in the circuit
167054141P0321 donors for engine speed G28 Implausible signal
167064142P0322 donors for engine speed G28 no signal
167084144P0324 knock control malfunction
167094145P0325 knock sensor 1-G61 electrical fault in the circuit
167104146P0326 knock sensor 1 G61 implausible signal
167114147P0327 knock sensor 1 signal is too small G61
167124148P0328 knock sensor 1 G61 signal too large.
16715414BP0331 knock sensor 2-G66 implausible signal
16716414CP0332 knock sensor 2-G66 signal too small
16717414DP0333 Knock sensor 2-G66 signal too large.
16719414FP0335 donors for engine speed G28 malfunction
167204150P0336 donors for engine speed G28 missing tooth
167214151P0337 crankshaft position sensor => G4 encoder signal too small
167244154P0340 Camshaft position sensor malfunction
167254155P0341 Camshaft position sensor => donor-G40 Implausible signal
167264156P0342 Camshaft position sensor => donor-G40 signal too small
167274157P0343 Camshaft position sensor => donor-G40 signal too large.
167294159P0345 Camshaft position sensor => donor-G163 electrical fault
16730415AP0346 Camshaft position sensor => donor-G163 Implausible signal
16731415BP0347 Camshaft position sensor => donor-G163 short circuit to ground
16732415CP0348 Camshaft position sensor => donor-G163 Short circuit to positive
16735415FP0351 Zundansteuerung cylinder 1 malfunction
167364160P0352 Zundansteuerung cylinder 2 malfunction
167374161P0353 cylinder 3 Zundansteuerung malfunction
167384162P0354 Zundansteuerung cylinder 4 malfunction
167394163P0355 Zundansteuerung cylinder 5 malfunction
167404164P0356 Zundansteuerung cylinder 6 malfunction
167414165P0357 Zundansteuerung cylinder 7 malfunction
167424166P0358 Zundansteuerung cylinder 8 malfunction
167434167P0359 Zundansteuerung cylinder 9 malfunction
167444168P0360 Zundansteuerung cylinder 10 malfunction
167454169P0361 Zundansteuerung cylinder 11 malfunction
16746416AP0362 Zundansteuerung cylinder 12 malfunction
16749416DP0365 Camshaft position sensor => donor-G300 malfunction
16750416EP0366 Camshaft position sensor => donor-G300 Implausible signal
16751416FP0367 camshaft position sensor => donor-G300 signal too small
167524170P0368 Camshaft position sensor => donor-G300 signal too large.
16764417CP0380 glow plug-Q6 electrical fault in the circuit
167744186P0390 Camshaft position sensor => donor-G301 malfunction
167754187P0391 Camshaft position sensor => donor-G301 Implausible signal
167764188P0392 camshaft position sensor => donor-G301 signal too small
167774189P0393 camshaft position sensor => donor-G301 signal too large.
167844190P0400 Abgasruckfuhrungssystem malfunction
167854191P0401 Abgasruckfuhrungssystem throughput too small
167864192P0402 Abgasruckfuhrungssystem throughput too large.
167874193P0403 valve for exhaust gas recirculation-N18 malfunction
167884194P0404 Abgasruckfuhrungssystem control difference
167894195P0405 Temperature Sensor for exhaust gas recirculation-G98 signal too small
167904196P0406 Temperature Sensor for exhaust gas recirculation-G98 signal too large.
167914197P0407 potentiometer for exhaust gas recirculation-G212 signal too small
167924198P0408 potentiometer for exhaust gas recirculation-G212 signal too large.
16794419AP0410 secondary air injection malfunction
16795419BP0411 secondary air injection flow flawed
16796419CP0412 Sekundarlufteinblasventil-N112 electrical fault in the circuit
16797419DP0413 Sekundarlufteinblasventil-N112 interruption
16798419EP0414 Sekundarlufteinblasventil-N112 short circuit
16799419FP0415 Sekundarlufteinblasventil 2-N320 electrical fault in the circuit
1680041A0P0416 Sekundarlufteinblasventil 2-N320 interruption
1680141A1P0417 Sekundarlufteinblasventil 2-N320 short circuit
1680241A2P0418 relay for secondary air pump J299 malfunction
1680341A3P0419 relay for secondary air pump 2-J545 malfunction
1680441A4P0420 Bank1, catalyst system activity too low
1680541A5P0421 primary catalytic converter, bank 1 effect too low
1680641A6P0422 Bank1, main catalytic effect is too low
1681141ABP0427 Temperature Sensor 1 for Kat-G20 short circuit to ground
1681241ACP0428 Temperature Sensor 1 for Kat-G20 Open / short circuit to positive
1681441AEP0430 catalyst system Bank2 effect too low
1681541AFP0431 primary catalytic converter, bank 2 effect too low
1681641B0P0432 Bank 2, main catalytic effect is too low
1682041B4P0436 Temperature Sensor 2 for Kat-G132 Implausible signal
1682141B5P0437 Temperature Sensor 2 for Kat-G132 short circuit to ground
1682241B6P0438 Temperature Sensor 2 for Kat-G132 open / short circuit to positive
1682441B8P0440 Tankentluftungssystem malfunction
1682541B9P0441 Tankentluftungssystem throughput flawed
1682641BArecognized P0442 Tankentluftungssystem fine leak
1682741BBP0443 Tankentluftungsventil-N80 Electrical fault in the circuit
1682841BCP0444 Tankentluftungsventil-N80 interruption
1682941BDP0445 Tankentluftungsventil-N80 Short
1683341C1P0449 Tankentluftungssystem, solenoid valve 2 for activated carbon N115 electrical fault in the circuit
1683641C4P0452 pressure sensor for Tankentluftungssystem signal too small
1683741C5P0453 pressure sensor for Tankentluftungssystem signal too large.
1683941C7recognized P0455 Tankentluftungssystem major leak
1684041C8recognized P0456 Tankentluftungssystem Feinstleck
1684241CAP0458 Tankentluftungsventil-N80 Short circuit to ground
1684341CBP0459 Tankentluftungsventil-N80 Short to positive
1684541CDP0461 Fuel fuel level signal implausible signal
1684641CEP0462 donors for Fuel Storage G signal too small
1684741CFP0463 donors for Fuel Storage G signal too large.
1685441D6P0470 pressure sensor 1 for exhaust G450 interruption
1685541D7P0471 pressure sensor 1 for exhaust implausible signal-G450
1685641D8P0472 pressure sensor 1 for exhaust-G450 short circuit to ground
1685741D9P0473 pressure sensor 1 for exhaust-G450 Short circuit to positive
1686441E0P0480 Kuhlerlufteransteuerung 1 electrical fault
1686541E1P0481 Kuhlerlufteransteuerung electrical fault 2
1687341E9P0489 Abgasruckfuhrungssteuerung short circuit to ground
1687441EAP0490 Abgasruckfuhrungssteuerung short circuit to positive
1687541EBP0491 secondary air injection bank 1 Flow too low
1687641ECP0492 Bank2, secondary air injection malfunction
1688241F2P0498 Tankentluftungssystem, solenoid valve 2 for activated carbon N115 signal too small
1688341F3P0499 Tankentluftungssystem, solenoid valve 2 for activated carbon N115 signal too large.
1688541F5P0501 vehicle speed signal implausible signal
1688641F6P0502 vehicle speed signal signal-to-low
1688741F7P0503 vehicle speed signal signal too large.
1688941F9P0505 idle speed control malfunction
1689041FAP0506 idling control speed below setpoint
1689141FBP0507 idling control over speed setpoint
1689441FEP0510 Idle switch F60 malfunction
168974201P0513 Incorrect immobilizer
169154213P0531 load signal from the implausible signal conditioner compressor
169164214P0532 pressure sensor for air conditioning-G65 signal too small
169174215P0533 pressure sensor for air conditioning-G65 signal too large.
169284220P0544 sensor 1 for exhaust gas temperature-G235 electrical fault
169294221P0545 sensor 1 for exhaust gas temperature-G235 short circuit to ground
169304222P0546 sensor 1 for exhaust gas temperature-G235 Short circuit to positive
169314223P0547 sensor 1 for exhaust gas temperature bank 2-G236 electrical fault
169324224P0548 sensor 1 for exhaust gas temperature bank 2-G236 short circuit to ground
169334225P0549 sensor 1 for exhaust gas temperature bank 2-G236 Short circuit to positive
169344226P0550 Power Steering Pressure control electrical fault
169354227P0551 Pressure switch / power steering F88 implausible signal
169444230P0560 power supply implausible signal
169454231P0561 power supply unstable
169464232P0562 power supply voltage too low
169474233P0563 power supply voltage too big.
169524238P0568 switches for GRA-E45 implausible signal
16955423BP0571 stop lamp switch signal Funplausibles
169814255P0597 thermostat for map-controlled engine cooling-F265 interruption
169824256P0598 thermostat for map-controlled engine cooling-F265 Short circuit to ground
169834257P0599 thermostat for map-controlled engine cooling-F265 Short circuit to positive
169844258P0600 data bus drive missing message
169854259P0601 Control unit defective
16986425AP0602 control units programming malfunction
16987425BP0603 Control unit defective
16988425CP0604 Control unit defective
16989425DP0605 Control unit defective
16990425EP0606 Control unit defective
16991425FP0607 control module implausible
169924260P0608 supply voltage sensors / actuators
169934261P0609 supply voltage 2 sensors / actuators
169944262P0610 engine control incorrect coding
169974265P0613 processor defective transmission control
169984266P0614 transmission control Incorrect software version
169994267P0615 control starter relay interruption
170004268P0616 control starter relay short circuit to ground
170014269P0617 control starter relay short circuit to positive
170114273P0627 relay for electric fuel pump 1 electrical failure / interruption
170124274P0628 Relay for electric fuel pump 1 short circuit to ground
170134275P0629 Relay for electric fuel pump 1 short circuit to positive
17018427AP0634 control unit temperature shutdown
17022427EP0638 Throttle valve control unit J338 implausible signal
17023427FP0639 throttle valve control unit 2-J544 implausible signal
170254281P0641 encoder reference voltage interruption -A-
170264282P0642 encoder reference voltage -A- too small
170274283P0643 encoder reference voltage -A- too large.
170294285P0645 air conditioning input / output
17034428AP0650 error lamp for self-diagnosis-K83 electrical fault in the circuit
17035428BP0651 encoder reference voltage interruption -B-
17036428CP0652 encoder reference voltage -B- too small
17037428DP0653 encoder reference voltage -B- too large.
17038428EP0654 output for engine speed electrical fault in the circuit
170404290P0656 Fuel consumption signal electrical fault in the circuit
170414291P0657 supply for engine components interruption
170424292P0658 supply for engine components too small
170434293to Groa P0659 supply for engine components
170444294P0660 Registersaugrohrumschaltung electrical fault
170454295P0661 Registersaugrohrumschaltung short circuit to ground
170464296P0662 Registersaugrohrumschaltung short circuit to positive
17051429BP0667 Internal temperature sensor implausible signal
17052429CP0668 Internal temperature sensor voltage too low
17053429DP0669 Internal temperature sensor voltage is too large.
17054429EP0670 Gluhzeitsteuergerat 1, Gluhstromkreis electrical fault in the circuit
17055429FP0671 glow plug cylinder 1-Q10 electrical fault in the circuit
1705642A0P0672 glow plug cylinder 2 Q11 electrical fault in the circuit
1705742A1P0673 glow plug cylinder 3-Q12 electrical fault in the circuit
1705842A2P0674 glow plug cylinder 4-Q13 electrical fault in the circuit
1705942A3P0675 glow plug cylinders 5-Q14 electrical fault in the circuit
1706042A4P0676 glow plug cylinder 6-Q15 electrical fault in the circuit
1706142A5P0677 glow plug cylinder 7-Q16 electrical fault in the circuit
1706242A6P0678 glow plug cylinder 8-Q17 electrical fault in the circuit
1706342A7P0679 glow plug cylinder 9-Q18 electrical fault in the circuit
1706442A8P0680 glow plug cylinder 10 Q19 electrical fault in the circuit
1706542A9P0681 glow plug cylinder 11 Q20 electrical fault in the circuit
1706642AAP0682 glow plug cylinder 12 Q21 electrical fault in the circuit
1706842ACP0684 Gluhzeitsteuergerat 1 => - J179 implausible signal
1706942ADP0685 main relay => - J271 interruption
1707042AEEither p0686 main relay => - J271 short circuit to ground
1707142AFP0687 main relay => - J271 Short circuit to positive
1707242B0P0688 main relay, open load => - J271 interruption
1707542B3P0691 Kuhlerlufteransteuerung 1 short circuit to ground
1707642B4P0692 Kuhlerlufteransteuerung 1 Short circuit to positive
1707742B5P0693 Kuhlerlufteransteuerung 2 short circuit to ground
1707842B6P0694 Kuhlerlufteransteuerung 2 short circuit to positive
1708142B9P0697 encoder reference voltage interruption -C-
1708242BAP0698 encoder reference voltage -C- too small
1708342BBP0699 encoder reference voltage -C- too large.
1708442BCP0700 Control unit defective
1708542BDP0701 Control unit defective
1708642BEP0702 Control unit defective
1708742BFP0703 Brake light switch-F electrical fault in the circuit
1708842C0P0704 Clutch pedal switch F36 implausible signal
1708942C1P0705 speed steps sensor => - F125 electrical fault in the circuit
1709042C2P0706 speed steps sensor => - F125 implausible signal
1709142C3P0707 speed steps sensor => - F125 signal too small
1709242C4P0708 speed steps sensor => - F125 signal too large.
1709442C6P0710 donors for Getriebeoltemperatur-G93 electrical fault in the circuit
1709542C7P0711 donors for Getriebeoltemperatur-G93 Implausible signal
1709642C8P0712 donors for Getriebeoltemperatur-G93 signal too small
1709742C9P0713 donors for Getriebeoltemperatur-G93 signal too large.
1709842CAP0714 donors for Getriebeoltemperatur-G93 interruption
1709942CBP0715 transmitter for transmission input speed-G182 electrical fault in the circuit
1710042CCP0716 transmitter for transmission input speed-G182 Implausible signal
1710142CDP0717 transmitter for transmission input speed-G182 no signal
1710442D0P0720 transmitter for transmission output speed-G195 electrical fault in the circuit
1710542D1P0721 transmitter for transmission output speed-G195 Implausible signal
1710642D2P0722 transmitter for transmission output speed-G195 no signal
1710942D5P0725 speed signal from the engine control electrical fault in the circuit
1711042D6P0726 speed signal from the engine control Implausible signal
1711142D7P0727 speed signal from a signal engine control
1711342D9P0729 6th gear wrong Uebersetzungsverhaltnis
1711442DAP0730 Gear / Ubersetzungsuberwachung wrong gear ratio
1711542DBP0731 1st gear wrong gear ratio
1711642DCP0732 2nd gear wrong gear ratio
1711742DDP0733 3rd gear wrong gear ratio
1711842DEP0734 4th gear wrong gear ratio
1711942DFP0735 5th gear wrong gear ratio
1712042E0P0736 reverse gear wrong Uebersetzungsverhaltnis
1712442E4P0740 clutch for mechanical failure Wandleruberbruckung
1712542E5P0741 clutch for Wandleruberbruckung no engine power distribution
1712742E7P0743 coupling for electrical fault Wandleruberbruckung
1713042EAP0746 pressure regulating valve 1 open / short circuit to ground
1713142EBP0747 Pressure control valve 1 Short circuit to positive
1713242ECP0748 pressure regulating valve 1 electrical fault in the circuit
1713342EDP0749 pressure control valve 1 Interruption
1713442EEP0750 switching valve 1 => solenoid valve 1-N88 dysfunction
1713542EFP0751 switching valve 1 => solenoid valve 1-N88 open / short circuit to ground
1713642F0P0752 switching valve 1 => solenoid valve 1-N88 Short to positive
1713742F1P0753 switching valve 1 => solenoid valve 1-N88 Electrical fault in the circuit
1714042F4P0756 switching valve 2 => Solenoid valve 2-N89 open / short circuit to ground
1714142F5P0757 switching valve 2 => Solenoid valve 2-N89 Short to positive
1714242F6P0758 switching valve 2 => Solenoid valve 2-N89 Electrical fault in the circuit
1714542F9P0761 switching valve 3 => solenoid valve 3-N90 open / short circuit to ground
1714642FAP0762 switching valve 3 => solenoid valve 3-N90 Short to positive
1714742FBP0763 switching valve 3 => solenoid valve 3-N90 Electrical fault in the circuit
1715042FEP0766 switching valve 4 => solenoid valve 4-N91 open / short circuit to ground
171524300P0768 switching valve 4 => solenoid valve 4-N91 Electrical fault in the circuit
171554303P0771 switching valve 5 => solenoid valve 5-N92 open / short circuit to ground
171574305P0773 switching valve 5 => solenoid valve 5-N92 Electrical fault in the circuit
171604308P0776 pressure regulating valve 2 open / short circuit to ground
171614309P0777 Pressure control valve 2 short circuit to positive
17162430AP0778 pressure control valve 2 of electrical fault in the circuit
17163430BP0779 pressure control valve 2 Interruption
17164430CP0780 Schaltungsuberwachung
17165430DP0781 Schaltungsuberwachung 1-2
17166430EP0782 Schaltungsuberwachung 2-3
17167430FP0783 Schaltungsuberwachung 3-4
171684310P0784 Schaltungsuberwachung 4-5
171694311P0785 magnetic switching time
171744316P0790 program switch-E122 electrical fault in the circuit
171754317P0791 Speed Sensor "" A "" for intermediate shaft Electrical fault
17180431CP0796 pressure control valve 3 open / short circuit to ground
17181431DP0797 pressure control valve 3 short circuit to positive
17182431EP0798 pressure regulating valve 3 of electrical fault in the circuit
17183431FP0799 pressure control valve 3 Interruption
17195432BP0811 strong clutch slip
17199432FP0815 switches for Tiptronic, high-F189 electrical fault in the circuit
172004330P0816 switches for Tiptronic, back-F189 electrical fault in the circuit
172014331P0817 starter interlock signal
172044334P0820 message of change lever and emergency operation
17213433DP0829 Schaltungsuberwachung 5-6
172244348P0840 encoder 1 for hydraulic pressure transmission electrical fault in the circuit
172254349P0841 encoder 1 for hydraulic pressure transmission implausible signal
17226434AP0842 encoder 1 for hydraulic pressure transmission Short circuit to ground
17227434BP0843 encoder 1 for hydraulic pressure transmission short circuit to positive
17228434CP0844 encoder 1 for hydraulic pressure transmission interruption
17229434DP0845 encoder 2 for hydraulic pressure transmission electrical fault in the circuit
17230434EP0846 encoder 2 for hydraulic pressure transmission implausible signal
17231434FP0847 encoder 2 for hydraulic pressure transmission Short circuit to ground
172324350P0848 encoder 2 for hydraulic pressure transmission short circuit to positive
172334351P0849 encoder 2 for hydraulic pressure transmission interruption
172344352P0850 signal for starter lock (P / N) short circuit to positive / interruption
172354353P0851 signal for starter lock (P / N) short circuit to ground
172364354P0852 signal for starter lock (P / N) Short-circuit to positive
17247435FP0863 communication transmission control electrical fault in the circuit
172484360P0864 communication implausible signal transmission control
172494361P0865 communication transmission control short circuit to ground
172524364P0868 Transmission Pressure adaptation at the stop
172684374P0884 power transmission control circuit / loose contact
172704376P0886 drive current supply relay for transmission control short circuit. to ground
172714377P0887 drive current supply relay for transmission control short circuit. to positive
172734379Replaced by P0889 power supply for the solenoid valve implausible signal
17274437AP0890 power supply for solenoid valve short circuit to ground
17275437BP0891 power supply for solenoid valve short circuit to positive
17276437CP0892 power supply for the solenoid valve stoppage
172814381P0897 transmission fluid deterioration
172884388P0904 switch for Tiptronic F189 electrical fault in the circuit
172894389P0905 switch for Tiptronic F189 implausible signal
17290438AP0906 switch for Tiptronic F189 Short circuit to ground
172984392P0914 selector lever electrical fault in the circuit
173034397P0919 selector lever error
1731343A1P0929 magnet for implausible signal selector lever lock
1731443A2P0930 magnet for selector lever lock short circuit to ground
1731543A3P0931 magnet for selector lever lock short circuit to positive
174084400P1000 injector cylinder 9-N299 electrical fault in the circuit
174094401P1001 injection valve cylinder 10 N300 electrical fault in the circuit
174104402P1002 injection valve cylinder 11-N301 electrical fault in the circuit
174114403P1003 injection valve cylinder 12 N302 electrical fault in the circuit
174124404exceeded P1004 torque difference cylinder 1 limit
174134405P1005 torque difference cylinder exceeded 2 limit
174144406P1006 torque difference cylinder exceeded 3 Limit
174154407P1007 torque difference cylinder exceeded 4 Limit
174164408P1008 air mass meter 1/2 implausible signal
174174409P1009 air mass meter 1/2 implausible signal from the load detecting
17418440AP1010 injector cylinder 9-N299 interruption
17419440BP1011 injection valve cylinder 10 N300 interruption
17420440CP1012 injection valve cylinder 11-N301 interruption
17421440DP1013 injection valve cylinder 12 N302 interruption
17422440EP1014 valve for bypass damper air filter N275 short circuit to positive
17423440FP1015 valve for bypass damper air filter N275 short circuit to ground
174244410P1016 valve for bypass damper air filter interruption N275
174254411P1017 Intake manifold 2 for airflow control Upper stop not reached
174264412P1018 Intake manifold 2 for airflow control Lower stop not reached
174274413P1019 donors for NOx G295 signal too slow
174284414P1020 fuel pressure control exceeded control limit
174294415Not reached P1021 Bank1 Nockenwellenspatverstellung target
174304416Not reached P1022 Bank1 Nockenwellenfruhverstellung target
174314417P1023 control valve for fuel pressure short circuit to ground
174324418P1024 control valve for fuel pressure interruption
174334419P1025 control valve for fuel pressure mechanical failure
17434441AP1026 control manifold flap for air flow control Short circuit to positive
17435441BP1027 control manifold flap for air flow control short circuit to ground
17436441CP1028 control manifold flap for air flow control interrupt
17437441Dnot reached P1029 valve for intake manifold, air flow control-N316 upper stop
17438441Enot reached P1030 valve for intake manifold, air flow control-N316 lower stop
17439441Fnot reached P1031 valve for intake manifold, air flow control-N316 setpoint
174404420P1032 donors for NOx G295 signal too large.
174414421P1033 donors for NOx G295 signal too small
174424422P1034 donors for NOx G295 signal au.erhalb tolerance
174434423P1035 donors for NOx G295 Implausible signal
174444424P1036 control heating timer for Nox short circuit to positive
174454425P1037 control heating timer for Nox short circuit to ground
174464426P1038 control heating timer for Nox interruption
174474427P1039 supply injector (e) A short circuit
174484428P1040 supply injection valve (s) A electrical fault in the circuit
174494429P1041 supply injector (s) B Short circuit
17450442AP1042 supply injection valve (s) B of electrical fault in the circuit
17451442BP1043 supply injector (s) C Short circuit
17452442CP1044 supply injection valve (s) C electrical fault in the circuit
17453442DP1045 supply injector (s) D Short circuit
17454442EP1046 supply injection valve (s) D electrical fault in the circuit
17455442FP1047 Bank1, valve for camshaft adjustment, outlet N318 electrical fault in the circuit
174564430P1048 Bank1, valve for camshaft adjustment, outlet N318 short circuit to positive
174574431P1049 Bank1, valve for camshaft adjustment, outlet N318 short circuit to ground
174584432P1050 Bank1, valve for camshaft adjustment, outlet interruption N318
174594433P1051 Bank2, valve for camshaft adjustment, outlet N319 electrical fault in the circuit
174604434P1052 Bank2, valve for camshaft adjustment, outlet N319 short circuit to positive
174614435P1053 Bank2, valve for camshaft adjustment, outlet N319 short circuit to ground
174624436P1054 Bank2, valve for camshaft adjustment, outlet interruption N319
174634437P1055 Bank1, camshaft adjustment, outlet short circuit to positive
174644438P1056 Bank1, camshaft adjustment, outlet Short circuit to ground
174654439P1057 Bank1, camshaft timing, interrupt outlet
17466443AP1058 Bank2, camshaft adjustment, outlet short circuit to positive
17467443BP1059 Bank2, camshaft adjustment, outlet Short circuit to ground
17468443CP1060 Bank2, camshaft timing, interrupt outlet
17469443DNot reached P1061 Bank2 Nockenwellenspatverstellung target
17470443EP1062 Bank2 not achieved Nockenwellenfruhverstellung target
17471443FP1063 fuel pressure control Control limit exceeded
174724440P1064 fuel pressure system mechanical failure
174734441P1065 fuel pressure control system deviation
174744442P1066 valve for Ansaugluftumschaltung-N335 short circuit to positive
174754443P1067 valve for Ansaugluftumschaltung-N335 short circuit to ground
174764444P1068 valve for Ansaugluftumschaltung-N335 interruption
174774445P1069 donors for NOx G295, heating control signal short circuit to ground
174784446P1070 donors for NOx G295, heating control signal short circuit to positive
174794447P1071 donors for NOx G295, heating control signal implausible signal
174804448P1072 donors for NOx G295, heating control signal electrical fault in the circuit
174814449P1073 air mass meter 2-G246 signal too small
17482444AP1074 air mass meter 2 G246 signal too large.
17483444BP1075 lambda control exhaust system too lean Bank 3
17484444CP1076 lambda control exhaust bank 3 system to fat
17485444DP1077 lambda control exhaust system Bank 4 too lean
17486444EP1078 lambda control exhaust bank 4 system fat
17487444FP1079 lambda control exhaust bank 3 implausible control value
174884450P1080 lambda control Exhaust bank 4 implausible control value
174894451P1081 exhaust Bank3, mixture adaptation range below 1 lean limit
174904452below P1082 exhaust bank3, mixture adaptation range 2 lean limit
174914453P1083 exhaust Bank3, mixture adaptation range exceeded 1 rich limit
174924454P1084 exhaust bank3, mixture adaptation range exceeded 2 fat limit
174934455P1085 exhaust Bank4, mixture adaptation range below 1 lean limit
174944456below p1086 exhaust Bank4, mixture adaptation range 2 lean limit
174954457P1087 exhaust Bank4, mixture adaptation range exceeded 1 rich limit
174964458P1088 exhaust Bank4, mixture adaptation range exceeded 2 fat limit
174974459below P1089 Bank2, mixture adaptation range 1 lean limit
17498445Abelow p1090 Bank2, mixture adaptation range 2 lean limit
17499445BP1091 Bank2, mixture adaptation range exceeded 1 rich limit
17500445CP1092 Bank2, mixture adaptation range exceeded 2 rich limit
17501445DP1093 Bank 1, fuel metering system 2 malfunction
17502445EP1094 Bank2, fuel metering system 2 malfunction
17503445FP1095 potentiometer for intake manifold-G336 Short circuit to positive
175044460P1096 potentiometer for intake manifold-G336 short circuit to ground
175054461P1097 potentiometer for intake manifold-G336 interruption
175064462P1098 potentiometer for intake manifold-G336 open / short circuit to positive
175074463P1099 control manifold flap for air flow control electrical fault
175084464P1100 Bank1-probe 2, heating circuit capacity too low
175094465P1101 Bank1-Electrode1 voltage too low / leakage air
175104466P1102 Bank1-Probe 1, heating circuit Short circuit to positive
175114467P1103 Bank1-Probe 1, heating circuit capacity too low
175124468P1104 Bank1-probe 2 Voltage too low / leakage air
175134469P1105 Bank1-probe 2, heating circuit Short circuit to positive
17514446AP1106 Bank2-Electrode1 voltage too low / leakage air
17515446BP1107 Bank2-Probe 1, heating circuit Short circuit to positive
17516446CP1108 Bank 2-Electrode1, heating circuit capacity too low
17517446DP1109 Bank2-probe 2 Voltage too low / leakage air
17518446EP1110 Bank2-probe 2, heating circuit Short circuit to positive
17519446FP1111 lambda control (Bank 1) System too lean
175204470P1112 lambda control (Bank 1) System to fat
175214471P1113 Bank 1, probe 1 Internal resistance too great.
175224472P1114 Bank 1, probe 2 Internal resistance too great.
175234473P1115 Bank1-Probe 1, heating circuit Short circuit to ground
175244474P1116 Bank1-Probe 1, heating current interruption
175254475P1117 Bank1-probe 2, heating circuit Short circuit to ground
175264476P1118 Bank1-probe 2, heating current interruption
175274477P1119 Bank2-Probe 1, heating circuit Short circuit to ground
175284478P1120 Bank2-Probe 1, heating current interruption
175294479P1121 Bank2-probe 2, heating circuit Short circuit to ground
17530447AP1122 Bank2-probe 2, heating current interruption
17531447BP1123 Bank1, mixture adaptation air (add.) System to fat
17532447CP1124 Bank1, mixture adaptation air (add.) System too lean
17533447DP1125 Bank2, mixture adaptation air (add.) System to fat
17534447EP1126 Bank2, mixture adaptation air (add.) System too lean
17535447FP1127 Bank1, mixture adaptation (mult.) System to fat
175364480P1128 Bank1, mixture adaptation (mult.) System too lean
175374481P1129 Bank2, mixture adaptation (mult.) System to fat
175384482P1130 Bank2, mixture adaptation (mult.) System too lean
175394483P1131 Bank 2, probe 1 Internal resistance too great.
175404484P1132 Bank1 + 2 Electrode1, heating circuit Short circuit to positive
175414485P1133 Bank1 + 2-Probe 1, the heating circuit electrical fault
175424486P1134 Bank1 + 2 probe 2, heating circuit Short circuit to positive
175434487P1135 + 2 Bank1-probe 2, heater circuit electrical fault
175444488P1136 Bank1, mixture adaptation (add.) System too lean
175454489P1137 Bank1, mixture adaptation (add.) System to fat
17546448AP1138 Bank2, mixture adaptation (add.) System too lean
17547448BP1139 Bank2, mixture adaptation (add.) System to fat
17548448CP1140 Bank 2, probe 2 Internal resistance too great.
17549448DP1141 load detection implausible value
17550448EP1142 load detection limit exceeded
17551448FP1143 load detection limit exceeded
175524490P1144 air mass meter-G70 open / short circuit to ground
175534491P1145 air mass meter-G70 Short to positive
175544492P1146 air mass meter G70-supply voltage
175554493P1147 lambda control system Bank 2 to lean
175564494P1148 lambda control system Bank 2 to fat
175574495P1149 lambda control Bank 1 implausible control value
175584496P1150 Lambda control bank 2 implausible control value
175594497below P1151 Bank1, mixture adaptation range 1 lean limit
175604498below P1152 Bank1, mixture adaptation range 2 lean limit
175614499P1153 lambda probes reversed by Kat
17562449AP1154 Intake manifold malfunction
17563449BP1155 donors for intake manifold pressure G71 Short to positive
17564449CP1156 donors for intake manifold pressure G71-open / short circuit to ground
17565449DP1157 donors for intake manifold pressure G71-supply voltage
17566449EP1158 donors for intake manifold pressure-G71 Implausible signal
17567449FP1159 signal Luftmassenmesser1 / Luftmassenmesser2 implausible ratio
1756844A0P1160 donors for intake manifold-G72 short circuit to ground
1756944A1P1161 donors for intake manifold-G72 Open / short circuit to positive
1757044A2P1162 donors for fuel temperature G81 short circuit to ground
1757144A3P1163 donors for fuel temperature G81 interruption / short circuit to positive
1757244A4P1164 donors for fuel temperature-G81 Implausible signal
1757344A5P1165 Bank1, mixture adaptation range exceeded 1 rich limit
1757444A6P1166 Bank1, mixture adaptation range exceeded 2 rich limit
1757544A7P1167 air mass meter 2-G246 implausible signal
1757644A8P1168 air mass meter 2-G246 open / short circuit to ground
1757744A9P1169 air mass meter two-G246 Short circuit to positive
1757844AAP1170 air mass meter 2 G246 Power supply
1757944ABP1171 angle sender 2 for throttle valve drive-G188 Implausible signal
1758044ACP1172 angle sender 2 for throttle valve drive-G188 signal too small
1758144ADP1173 angle sender 2 for throttle valve drive-G188 signal too large.
1758244AEP1174 Bank 1, fuel metering system deviation of the injection time
1758344AFP1175 pilot off
1758444B0P1176 reached Bank1, lambda correction behind catalyst control limit
1758544B1P1177 reached Bank2, lambda correction behind catalyst control limit
1758644B2P1178 linear lambda probe / pump current cutting
1758744B3P1179 linear lambda probe / pump current short circuit to ground
1758844B4P1180 linear lambda probe / pump current short circuit to positive
1758944B5P1181 linear lambda probe / reference voltage interruption
1759044B6P1182 linear lambda probe / reference voltage Short circuit to ground
1759144B7P1183 linear lambda probe / reference voltage Short circuit to positive
1759244B8P1184 linear lambda probe / common ground line interruption
1759344B9P1185 linear lambda probe / common ground line short-circuit to ground
1759444BAP1186 linear lambda probe / common ground line short circuit to positive
1759544BBP1187 linear lambda sensor / compensation resistor interruption
1759644BCP1188 linear lambda sensor / compensation resistor short circuit to ground
1759744BDP1189 linear lambda sensor / compensation resistor short circuit to positive
1759844BEP1190 linear lambda probe / reference voltage implausible
1759944BFP1191 linear lambda probe upstream of the catalyst swapped
1760044C0P1192 donors for fuel pressure G247 Supply Voltage
1760144C1P1193 donors for fuel pressure G247 open / short circuit to positive
1760244C2P1194 control valve for fuel pressure N276 short circuit to positive
1760344C3P1195 control valve for fuel pressure N276 open / short circuit to ground
1760444C4P1196 Bank1-Probe 1, heating circuit electrical fault
1760544C5P1197 Bank2-Probe 1, heating circuit electrical fault
1760644C6P1198 Bank1-probe 2, heating circuit electrical fault
1760744C7P1199 Bank 2-probe 2, heating circuit electrical fault
1760844C8P1200 air recirculation valve for turbocharger N249 mechanical failure
1760944C9P1201 cylinder injection valve 1-N30 electrical fault in the circuit
1761044CAP1202 injector cylinder 2-N31 electrical fault in the circuit
1761144CBP1203 injector cylinder 3-N32 electrical fault in the circuit
1761244CCP1204 injection valve cylinder 4-N33 electrical fault in the circuit
1761344CDP1205 injector barrel 5-N83 electrical fault in the circuit
1761444CEP1206 injection valve cylinder 6-N84 electrical fault in the circuit
1761544CFP1207 cylinder injection valve 7-N85 electrical fault in the circuit
1761644D0P1208 injector cylinder 8-N86 electrical fault in the circuit
1761744D1P1209 inlet check valves for cylinder deactivation short circuit to ground
1761844D2P1210 inlet check valves for cylinder deactivation short circuit to positive
1761944D3P1211 inlet check valves for cylinder deactivation interruption
1762044D4P1212 cylinder deactivation, Bank 1
1762144D5P1213 Injector cylinder 1-N30 Short to positive
1762244D6P1214 Injector cylinder 2-N31 Short to positive
1762344D7P1215 Injector cylinder 3-N32 Short to positive
1762444D8P1216 Injector cylinder 4-N33 Short to positive
1762544D9P1217 Injector cylinder 5-N83 Short to positive
1762644DAP1218 Injector cylinder 6-N84 Short to positive
1762744DBP1219 injection valve cylinder 7-N85 Short to positive
1762844DCP1220 Injector cylinder 8-N86 Short to positive
1762944DDP1221 Auslasssperrventile cylinder deactivation short circuit to ground
1763044DEP1222 Auslasssperrventile cylinder deactivation short circuit to positive
1763144DFP1223 Auslasssperrventile cylinder deactivation interruption
1763244E0P1224 cylinder deactivation, Bank 2
1763344E1P1225 Injector cylinder 1-N30 Short circuit to ground
1763444E2P1226 Injector cylinder 2-N31 Short circuit to ground
1763544E3P1227 Injector cylinder 3-N32 Short circuit to ground
1763644E4P1228 Injector cylinder 4-N33 Short circuit to ground
1763744E5P1229 Injector cylinder 5-N83 Short circuit to ground
1763844E6P1230 Injector cylinder 6-N84 Short circuit to ground
1763944E7P1231 injection valve cylinder 7-N85 Short circuit to ground
1764044E8P1232 Injector cylinder 8-N86 Short circuit to ground
1764144E9P1233 load sensing malfunction
1764244EAP1234 lack of fuel supply
1764344EBP1235 exhaust Bank3, lambda correction reaches behind catalyst control limit
1764444ECP1236 exhaust Bank4, lambda correction reaches behind catalyst control limit
1764544EDP1237 cylinder injection valve 1-N30 interruption
1764644EEP1238 injector cylinder 2-N31 interruption
1764744EFP1239 injector cylinder 3-N32 interruption
1764844F0P1240 injection valve cylinder 4-N33 interruption
1764944F1P1241 injector barrel 5-N83 interruption
1765044F2P1242 injection valve cylinder 6-N84 interruption
1765144F3P1243 cylinder injection valve 7-N85 interruption
1765244F4P1244 injector cylinder 8-N86 interruption
1765344F5P1245 donors for needle stroke G80 short circuit to ground
1765444F6P1246 donors for needle lift-G80 Implausible signal
1765544F7P1247 donors for needle lift-G80 Open / short circuit to positive
1765644F8P1248 Injection commencement control Control difference
1765744F9P1249 Fuel consumption signal electrical fault in the circuit
1765844FAP1250 fuel Full level too low
1765944FBP1251 valve for commencement of injection-N108 short circuit to positive
1766044FCP1252 valve for injection start N108 open / short circuit to ground
1766144FDP1253 Fuel consumption signal Short circuit to ground
1766244FEP1254 Fuel consumption signal Short to positive
1766344FFP1255 donors for coolant temperature-G62 short circuit to ground
176644500P1256 donors for coolant temperature G62-open / short circuit to positive
176654501P1257 valve for coolant circuit-interruption N214
176664502P1258 valve for coolant circuit-N214 short circuit to positive
176674503P1259 valve for coolant circuit-N214 short circuit to ground
176684504P1260 valve for pump / nozzle cylinder 1 N240 implausible signal
176694505P1261 valve for pump / nozzle cylinder exceeded 1-N240 control limit
176704506P1262 valve for pump / nozzle cylinder below 1 N240 control limit
176714507P1263 valve for pump / nozzle cylinder 2 N241 implausible signal
176724508P1264 valve for pump / nozzle cylinder exceeded 2-N241 control limit
176734509below P1265 valve for pump / nozzle cylinder 2 N241 control limit
17674450AP1266 valve for pump / nozzle cylinder 3 N242 implausible signal
17675450BP1267 valve for pump / nozzle cylinder exceeded 3-N242 control limit
17676450Cbelow P1268 valve for pump / nozzle cylinder 3 N242 control limit
17677450DP1269 valve for pump / nozzle cylinder 4-N243 implausible signal
17678450EP1270 valve for pump / nozzle cylinder exceeded 4-N243 control limit
17679450FP1271 valve for pump / nozzle cylinder below 4 N243 control limit
176804510P1272 valve for pump / nozzle cylinder 5-N244 implausible signal
176814511P1273 valve for pump / nozzle cylinder exceeded 5-N244 control limit
176824512P1274 valve for pump / nozzle cylinder 5 below-N244 control limit
176834513P1275 valve for pump / nozzle cylinder 6-N245 implausible signal
176844514P1276 valve for pump / nozzle cylinder exceeded 6-N245 control limit
176854515P1277 valve for pump / nozzle cylinder below 6-N245 control limit
176864516P1278 valve for metering fuel-N290 short circuit to positive
176874517P1279 valve for metering fuel-N290 open / short circuit to ground
176884518P1280 air control valve for injector N212 throughput too small
176894519P1281 valve for metering fuel-N290 short circuit to ground
17690451AP1282 valve for metering fuel-N290 interruption
17691451BP1283 air control valve for injector N212 electrical fault in the circuit
17692451CP1284 air control valve for injector N212 interruption
17693451DP1285 air control valve for injector N212 short circuit to ground
17694451EP1286 air control valve for injector N212 short circuit to positive
17695451FP1287 air recirculation valve for turbocharger N249 interruption
176964520P1288 air recirculation valve for turbocharger N249 short circuit to positive
176974521P1289 air recirculation valve for turbocharger N249 short circuit to ground
176984522P1290 donors for coolant temperature-Kuhle output-G83 signal too large.
176994523P1291 donors for coolant temperature-Kuhle output-G83 signal too small
177004524P1292 thermostat for map-controlled engine cooling-F265 interruption
177014525P1293 thermostat for map-controlled engine cooling-F265 Short circuit to positive
177024526P1294 thermostat for map-controlled engine cooling-F265 Short circuit to ground
177034527P1295 Bypass turbocharger throughput flawed
177044528P1296 fault in the cooling system
177054529P1297 connection charger throttle pressure drop
17706452AP1298 donors for coolant temperature-Kuhle output-G83 Implausible signal
17707452BP1299 valve for metering fuel-N290 malfunction
17708452CP1300 misfire detected reason: lack of fuel
17709452DP1301 knock control cylinder reaches 9 Control limit
17710452EP1302 knock control cylinder reaches 10 control limit
17711452FP1303 knock control cylinder reaches 11 control limit
177124530P1304 knock control cylinder reaches 12 control limit
177134531P1305 Zundansteuerung cylinder 9 interruption
177144532P1306 Zundansteuerung cylinder 9 short circuit to positive
177154533P1307 Zundansteuerung cylinder 9 short circuit to ground
177164534P1308 Zundansteuerung interruption cylinder 10
177174535P1309 Zundansteuerung cylinder 10 Short circuit to positive
177184536P1310 Zundansteuerung cylinder 10 Short circuit to ground
177194537P1311 Zundansteuerung interruption cylinder 11
177204538P1312 Zundansteuerung cylinder 11 Short circuit to positive
177214539P1313 Zundansteuerung cylinder 11 Short circuit to ground
17722453AP1314 Zundansteuerung interruption cylinder 12
17723453BP1315 Zundansteuerung cylinder 12 Short circuit to positive
17724453CP1316 Zundansteuerung cylinder 12 short circuit to ground
17725453DP1317 knock control cylinder reaches 13 control limit
17726453EP1318 knock control cylinder reaches 14 control limit
17727453FP1319 knock sensor 1-G61 short circuit to ground
177284540P1320 Knock sensor 2-G66 short circuit to ground
177294541P1321 knock sensor 3 G198 signal too small
177304542P1322 Knock Sensor 3 G198 signal too large.
177314543P1323 knock sensor 4-G199 signal too small
177324544P1324 knock sensor 4-G199 signal too large.
177334545P1325 knock control cylinder reaches one control limit
177344546P1326 knock control cylinder reaches 2 Control limit
177354547P1327 knock control cylinder reaches 3 control limit
177364548P1328 knock control cylinder reaches 4 Control limit
177374549P1329 knock control cylinder reaches 5 Control limit
17738454AP1330 knock control cylinder reaches 6 Control limit
17739454BP1331 knock control cylinder reaches 7 control limit
17740454CP1332 knock control cylinder reaches 8 control limit
17741454DP1333 knock control cylinder reaches 15 control limit
17742454EP1334 knock control cylinder reaches 16 control limit
17743454FP1335 Motormomentenuberwachung exceeded 2 Control limit
177444550exceeded P1336 Motormomentenuberwachung control limit
177454551P1337 Bank1, camshaft position sensor => - G40 short circuit to ground
177464552P1338 Bank1, camshaft position sensor => - G40 Open / short circuit to positive
177474553P1339 crankshaft position / engine speed sensor swapped
177484554P1340 Nockenwellenpos.-G40 / Kurbelwellenpos.-sen-G28 misallocation
177494555P1341 Zundausgang 1 short circuit to ground
177504556P1342 Zundausgang 1 Short circuit to positive
177514557P1343 Zundausgang 2 short circuit to ground
177524558P1344 Zundausgang 2 short circuit to positive
177534559P1345 Zundausgang 3 short circuit to ground
17754455AP1346 Zundausgang 3 short circuit to positive
17755455BP1347 Bank 2, Nockenwellenpos.-G163 / Kurbelwellenpos.-Sens.-G28 misallocation
17756455CP1348 Zundausgang 1 Interruption
17757455DP1349 Zundausgang 2 Interruption
17758455EP1350 Zundausgang 3 Interruption
17759455FP1351 Bank1, camshaft position sensor => - G40 Implausible signal at start
177604560not reached P1352 Bank1, camshaft adjustment target position
177624562P1354 transmitter for modulating piston movement sender-G149 electrical fault in the circuit
177634563P1355 Zundansteuerung cylinder 1 Interruption
177644564P1356 Zundansteuerung cylinder 1 Short circuit to positive
177654565P1357 Zundansteuerung cylinder 1 short circuit to ground
177664566P1358 Zundansteuerung cylinder 2 Interruption
177674567P1359 Zundansteuerung cylinder 2 short circuit to positive
177684568P1360 Zundansteuerung cylinder 2 short circuit to ground
177694569P1361 Zundansteuerung cylinder 3 interruption
17770456AP1362 Zundansteuerung cylinder 3 short circuit to positive
17771456BP1363 Zundansteuerung cylinder 3 short circuit to ground
17772456CP1364 Zundansteuerung cylinder 4 Interruption
17773456DP1365 Zundansteuerung cylinder 4 short circuit to positive
17774456EP1366 Zundansteuerung cylinder 4 short circuit to ground
17775456FP1367 Zundansteuerung cylinder 5 Interruption
177764570P1368 Zundansteuerung cylinder 5 Short circuit to positive
177774571P1369 Zundansteuerung cylinder 5 short circuit to ground
177784572P1370 Zundansteuerung cylinder 6 interrupt
177794573P1371 Zundansteuerung cylinder 6 Short circuit to positive
177804574P1372 Zundansteuerung cylinder 6 Short circuit to ground
177814575P1373 Zundansteuerung cylinder 7 break
177824576P1374 Zundansteuerung cylinder 7 Short circuit to positive
177834577P1375 Zundansteuerung cylinder 7 short circuit to ground
177844578P1376 Zundansteuerung cylinder 8 interruption
177854579P1377 Zundansteuerung cylinder 8 Short circuit to positive
17786457AP1378 Zundansteuerung cylinder 8 short circuit to ground
17787457BP1379 cylinder 13 misfires recognized
17788457CP1380 cylinder 14 misfires recognized
17789457Drecognized P1381 cylinder 15 misfires
17790457EP1382 cylinder 16 misfires recognized
177924580P1384 engine control unit 2 faulty
177934581P1385 Control unit defective
177944582P1386 Control unit defective
177954583P1387 Control unit defective
177964584P1388 Control unit defective
177974585P1389 Control unit defective 2 for diesel direct injection-J494
177994587P1391 Bank2, camshaft position sensor => - G163 short circuit to ground
178004588P1392 Bank2, camshaft position sensor => - G163 open / short circuit to positive
178014589P1393 Zundausgang 1 electrical fault in the circuit
17802458AP1394 Zundausgang 2 electrical fault in the circuit
17803458BP1395 Zundausgang 3 electrical fault in the circuit
17804458CP1396 donors for engine speed G28 missing tooth
17805458DP1397 sender wheel for engine speed Adaption limit reached
17806458EP1398 engine speed signal TD short circuit to ground
17807458FP1399 engine speed signal TD Short circuit to positive
178084590P1400 valve for exhaust gas recirculation-N18 electrical fault in the circuit
178094591P1401 valve for exhaust gas recirculation-N18 Short circuit to ground
178104592P1402 valve for exhaust gas recirculation-N18 Short to positive
178114593P1403 Abgasruckfuhrungssystem control difference
178124594not carried out P1404 Abgasruckfuhrungssystem default
178134595P1405 valve 2 for exhaust gas recirculation-N213 malfunction
178144596P1406 Temperature Sensor for exhaust gas recirculation-G98 Implausible signal
178154597P1407 Temperature Sensor for exhaust gas recirculation-G98 signal too small
178164598P1408 Temperature Sensor for exhaust gas recirculation-G98 signal too large.
178174599P1409 Tankentluftungsventil-N80 Electrical fault in the circuit
17818459AP1410 Tankentluftungsventil-N80 Short to positive
17819459BP1411 Bank2, secondary air injection rate too small
17820459CP1412 pressure sensor for exhaust gas recirculation signal too small
17821459DP1413 pressure sensor for exhaust gas recirculation signal too large.
17822459EP1414 Bank 2, secondary air injection leak detected
17823459FP1415 valve for exhaust gas recirculation-N18, characteristic curve adaptation exceeded low limit
1782445A0P1416 valve for exhaust gas recirculation-N18, characteristic curve adaptation exceeded the upper limit value
1782545A1P1417 donors for Fuel Storage G signal too small
1782645A2P1418 donors for Fuel Storage G signal too large.
1782745A3P1419 changeover valve 2 for radiator exhaust gas recirculation-N381 short circuit to positive
1782845A4P1420 Sekundarlufteinblasventil-N112 electrical fault in the circuit
1782945A5P1421 Sekundarlufteinblasventil-N112 short circuit to ground
1783045A6P1422 Sekundarlufteinblasventil-N112 short circuit to positive
1783145A7P1423 Bank 1, secondary air injection rate too small
1783245A8P1424 Bank1, secondary air injection leak detected
1783345A9P1425 Tankentluftungsventil-N80 Short circuit to ground
1783445AAP1426 Tankentluftungsventil-N80 interruption
1783545ABP1427 control vacuum pump for brake Short circuit to positive
1783645ACP1428 control vacuum pump for brake Short circuit to ground
1783745ADP1429 drive vacuum pump for brake interruption
1783845AEP1430 control vacuum pump for brake open / short circuit to positive
1783945AFP1431 drive vacuum pump for brake circuit / short circuit to ground
1784045B0P1432 Sekundarlufteinblasventil-N112 interruption
1784145B1P1433 relay for secondary air pump J299 interruption
1784245B2P1434 relay for secondary air pump J299 Short circuit to positive
1784345B3P1435 relay for secondary air pump J299 short circuit to ground
1784445B4P1436 relay for secondary air pump J299 electrical fault in the circuit
1784545B5P1437 valve 2 for exhaust gas recirculation-N213 short circuit to positive
1784645B6P1438 valve 2 for exhaust gas recirculation N213-circuit / short circuit to ground
1784745B7P1439 potentiometer for exhaust gas recirculation-G212 errors in default
1784845B8P1440 valve for exhaust gas recirculation-N18 interruption
1784945B9P1441 valve for exhaust gas recirculation N18-circuit / short circuit to ground
1785045BAP1442 potentiometer for exhaust gas recirculation-G212 signal too large.
1785145BBP1443 potentiometer for exhaust gas recirculation-G212 signal too small
1785245BCP1444 potentiometer for exhaust gas recirculation-G212 Implausible signal
1785345BDP1445 Temperature Sensor 2 for catalyst G132 implausible signal
1785445BEP1446 Temperature Sensor 1 for catalyst G20 Short circuit to ground
1785545BFP1447 Temperature Sensor 1 for catalyst G20-circuit / short circuit to positive
1785645C0P1448 Temperature Sensor 2 for catalyst G132 Short circuit to ground
1785745C1P1449 Temperature Sensor 2 for catalyst G132 open / short circuit to positive
1785845C2P1450 secondary air injection Short circuit to positive
1785945C3P1451 secondary air injection short circuit to ground
1786045C4P1452 secondary air injection interruption
1786145C5P1453 sensor 1 for exhaust gas temperature-G235 open / short circuit to positive
1786245C6P1454 sensor 1 for exhaust gas temperature-G235 short circuit to ground
1786345C7P1455 encoder 1 for exhaust gas temperature-G235 Implausible signal
1786445C8P1456 exhaust gas temperature control bank achieved one control limit
1786545C9P1457 encoder 1 for exhaust gas temperature bank 2-G236 open / short circuit to positive
1786645CAP1458 sensor 1 for exhaust gas temperature bank 2-G236 short circuit to ground
1786745CBP1459 sensor 1 for exhaust gas temperature bank 2-G236 Implausible signal
1786845CCP1460 exhaust gas temperature control bank reached two control limit
1786945CDP1461 exhaust gas temperature control bank 1 Implausible signal
1787045CEP1462 exhaust gas temperature control bank 2 implausible signal
1787145CFP1463 secondary air injection, 3 Bank malfunction
1787245D0P1464 secondary air injection, Bank 4 malfunction
1787345D1P1465 pump for additive particle-V135 short circuit to positive
1787445D2P1466 pump for particulate additive-V135 open / short circuit to ground
1787545D3P1467 Solenoid 2 for activated carbon N115 short circuit to positive
