VAS 5051 error codes
164354033P0051 Bank2-Probe 1, heating circuit Short circuit to ground
164364034P0052 Bank2-Probe 1, heating circuit Short circuit to positive
164404038P0056 Bank2-probe 2, heating circuit electrical fault
164414039P0057 Bank2-probe 2, heating circuit Short circuit to ground
16442403AP0058 Bank2-probe 2, heating circuit Short circuit to positive
164484040P0064 Bank2-Sonde3, heating circuit Short circuit to positive
164494041P0065 air control valve for injector N212 implausible signal
164504042P0066 air control valve for injector N212 short circuit to ground
164514043P0067 air control valve for injector N212 short circuit to positive
164524044P0068 Intake manifold pressure / air mass quantity <-> throttle angle deviation
164534045P0069 Intake manifold pressure <-> air pressure misallocation
164554047P0071 Temperature Sensor for Au.entemperatur -G17
164564048P0072 Temperature Sensor for Au.entemperatur -G17 signal too small
164574049P0073 Temperature Sensor for Au.entemperatur -G17 Signal too large.
16458404AP0074 Temperature Sensor for Au.entemperatur -G17, interruption
164734059P0089 valve for fuel metering implausible signal
16474405AP0090 valve for fuel metering electrical fault
16475405BP0091 valve for fuel metering short circuit to ground
16476405CP0092 valve for fuel metering short circuit to positive
164814061P0097 sender -2- for intake-G299 signal too small
164824062P0098 sender -2- for intake-G299 signal too large.
164834063P0099 sender -2- for intake-G299 no signal
164854065P0101 air mass meter-G70 Implausible signal
164864066P0102 air mass meter-G70 signal too small
164874067P0103 air mass meter-G70 signal too large.
164884068P0104 air mass meter-G70 no signal
164894069P0105 donors for intake manifold pressure G71-supply voltage
16490406AP0106 Intake manifold pressure / pressure => - G71 / -F96 Implausible signal
16491406BP0107 Intake manifold pressure / pressure => - G71 / -F96 Signal too low
16492406CP0108 Intake manifold pressure / pressure => - G71 / -F96 Signal too large.
16495406FP0111 donors for intake-G42 Implausible signal
164964070P0112 donors for intake-G42 signal too small
164974071P0113 donors for intake-G42 signal too large.
164984072P0114 donors for intake-G42 no signal
165004074P0116 donors for coolant temperature-G62 Implausible signal
165014075P0117 donors for coolant temperature-G62 signal too small
165024076P0118 donors for coolant temperature-G62 signal too large.
165044078P0120 Throttle-G69 electrical fault in the circuit
165054079P0121 Throttle-G69 Implausible signal
16506407AP0122 Throttle-G69 signal too small
16507407BP0123 Throttle-G69 signal too large.
16509407Dnot reached P0125 coolant temperature for lambda control
165124080P0128 valve for coolant circuit-N214 temperature below control range
165144082P0130 Bank1-Electrode1 electrical fault in the circuit
165154083P0131 Bank1-Electrode1 voltage too low
165164084P0132 Bank1-Electrode1 voltage too large.
165174085P0133 Bank1-Electrode1 signal too slow
165184086P0134 Bank1-Electrode1 no activity
165194087P0135 Bank1-Probe 1, heating circuit electrical fault
165204088P0136 Bank1-probe 2 Electrical fault in the circuit
165214089P0137 Bank1-probe 2 Voltage too low
16522408AP0138 Bank1-probe 2 Voltage too large.
16523408BP0139 bank 1-probe 2 signal too slow
16524408CP0140 Bank1-probe 2 No activity
16525408DP0141 Bank1-probe 2, heating circuit electrical fault
16526408EP0142 Bank1-Sonde3 elektr.Fehler in the circuit
16527408FP0143 Bank1-Sonde3 voltage too low
165284090P0144 Bank 1-Sonde3 voltage too high
165294091P0145 Bank 1-Sonde3 signal too slow
165304092P0146 Bank1-Sonde3 no activity
165314093P0147 Bank1-Sonde3, heating circuit elektr.Fehler
165334095P0149 fuel metering system (Bank 1) deviation of the injection time
165344096P0150 Bank2-Electrode1 electrical fault in the circuit
165354097P0151 Bank2-Electrode1 voltage too low
165364098P0152 Bank2-Electrode1 voltage too large.
165374099P0153 Bank2-Electrode1 signal too slow
16538409AP0154 Bank 2-Electrode1 no activity
16539409BP0155 Bank2-Probe 1, heating circuit electrical fault
16540409CP0156 Bank2-probe 2 Electrical fault in the circuit
16541409DP0157 Bank2-probe 2 Voltage too low
16542409EP0158 Bank2-probe 2 Voltage too large.
16543409FP0159 Bank2-probe 2 signal too slow
1654440A0P0160 Bank2-probe 2 No activity
1654540A1P0161 Bank2-probe 2, heating circuit electrical fault
1654640A2P0162 Bank2-Sonde3 elektr.Fehler in the circuit
1654740A3P0163 Bank2-Sonde3 voltage too low
1654840A4P0164 Bank2-Sonde3 voltage too high
1654940A5P0165 Bank 2-Sonde3 signal too slow
1655040A6P0166 Bank2-Sonde3 no activity
1655140A7P0167 Bank2-Sonde3, heating circuit elektr.Fehler
1655440AAP0170 Bank1, fuel metering system malfunction
1655540ABP0171 Bank1, fuel metering system System too lean
1655640ACP0172 Bank1, fuel metering system System too rich
1655740ADP0173 Bank2, fuel metering system malfunction
1655840AEP0174 Bank2, fuel metering system System too lean
1655940AFP0175 Bank2, fuel metering system System too rich
1656140B1P0177 donors for fuel quality G446 Implausible signal
1656240B2P0178 donors for fuel quality G446 falls below limit
1656340B3P0179 donors for fuel quality G446 exceeded limit
1656540B5P0181 donors for Kraftstofftemp.-G81 Implausible signal
1656640B6P0182 donors for fuel temperature G81 short circuit to ground
1656740B7P0183 donors for fuel temperature G81 interruption / short circuit to positive
1657040BAP0186 Encoder 2 for fuel temperature G248 Implausible signal
1657140BBP0187 Encoder 2 for fuel temperature G248 short circuit to ground
1657240BCP0188 Encoder 2 for fuel temperature-G248 Short circuit to positive
1657440BEP0190 donors for fuel pressure G247 electrical fault in the circuit
1657540BFP0191 donors for fuel pressure G247 Implausible signal
1657640C0P0192 donors for fuel pressure G247 short circuit to ground
1657740C1P0193 donors for fuel pressure G247 short circuit to positive
1657840C2P0194 encoder for fuel pressure interruption G247
1658040C4P0196 donors for oil temperature-G8 Implausible signal
1658140C5P0197 donors for oil temperature-G8 signal too small
1658240C6P0198 donors for oil temperature-G8 signal too large.
1658440C8P0200 injectors electrical fault in the circuit
1658540C9P0201 cylinder injection valve 1-N30 electrical fault in the circuit
1658640CAP0202 injector cylinder 2-N31 electrical fault in the circuit
1658740CBP0203 injector cylinder 3-N32 electrical fault in the circuit
1658840CCP0204 injection valve cylinder 4-N33 electrical fault in the circuit
1658940CDP0205 injector barrel 5-N83 electrical fault in the circuit
1659040CEP0206 injection valve cylinder 6-N84 electrical fault in the circuit
1659140CFP0207 cylinder injection valve 7-N85 electrical fault in the circuit
1659240D0P0208 injector cylinder 8-N86 electrical fault in the circuit
1659340D1P0209 injector cylinder 9-N299 electrical fault in the circuit
1659440D2P0210 injection valve cylinder 10 N300 electrical fault in the circuit
1659540D3P0211 injection valve cylinder 11-N301 electrical fault in the circuit
1659640D4P0212 injection valve cylinder 12 N302 electrical fault in the circuit
1659940D7P0215 fuel cut-N109 malfunction
1660040D8P0216 valve for commencement of injection-N108 malfunction
1660340DBexceeded P0219 maximum engine speed
1660540DDP0221 angle sensor 2 for DK-drive-G188 implausible signal
1660640DEP0222 angle sender 2 for DK-drive-G188 signal too small
1660740DFP0223 angle sender 2 for DK-drive-G188 signal too large.
1660940E1P0225 timer for pedal position G79 supply voltage
1661040E2P0226 Encoder 2.1 for pedal position G79 + G185 Implausible signal
1661140E3P0227 donors for accelerator pedal position-G79 signal too small
1661240E4P0228 donors for accelerator pedal position-G79 signal too large.
1661440E6P0230 fuel pump relay-J17 electrical fault in the circuit
1661840EAP0234 boost pressure control exceeded control limit
1661940EBP0235 boost pressure control Control limit exceeded
1662040ECP0236 donors for boost pressure implausible signal
1662140EDP0237 donors for boost pressure signal too small
1662240EEP0238 donors for boost pressure signal too large.
1662440F0P0240 Encoder 2 for boost pressure G447 Implausible signal
1662540F1P0241 Encoder 2 for boost pressure G447 signal too small
1662640F2P0242 Encoder 2 for boost pressure G447 signal too large.
1662740F3P0243 Solenoid valve for charge pressure control N75-open / short circuit to ground
1662940F5P0245 Solenoid valve for charge pressure control N75-short circuit to ground
1663040F6P0246 Solenoid valve for charge pressure control-N75 Short to positive
1663340F9P0249 solenoid valve 2 for charge pressure limitation-N274 short circuit to ground / interruption
1663440FAP0250 Solenoid 2 for charge pressure control-N274 short circuit to positive
1663540FBP0251 high-pressure pump defective
1663640FCP0252 Injection commencement control Control difference
166454105P0261 Injector cylinder 1-N30 Short circuit to ground
166464106P0262 Injector cylinder 1-N30 Short to positive
166474107P0263 differential injection amount cylinders 1
166484108P0264 Injector cylinder 2-N31 Short circuit to ground
166494109P0265 Injector cylinder 2-N31 Short to positive
16650410AP0266 differential injection amount cylinders 2
16651410BP0267 Injector cylinder 3-N32 Short circuit to ground
16652410CP0268 Injector cylinder 3-N32 Short to positive
16653410DP0269 differential injection amount cylinders 3
16654410EP0270 Injector cylinder 4-N33 Short circuit to ground
16655410FP0271 Injector cylinder 4-N33 Short to positive
166564110P0272 deviation injection quantity cylinder 4
166574111P0273 Injector cylinder 5-N83 Short circuit to ground
166584112P0274 Injector cylinder 5-N83 Short to positive
166594113P0275 differential injection amount Zyl.5
166604114P0276 Injector cylinder 6-N84 Short circuit to ground
166614115P0277 Injector cylinder 6-N84 Short to positive
166624116P0278 differential injection amount Zyl.6
166634117P0279 injection valve cylinder 7-N85 Short circuit to ground
166644118P0280 Injector cylinder 7-N85 Short to positive
166654119P0281 differential injection amount Zyl.7
16666411AP0282 injector cylinder 8 N86 short circuit to ground
16667411BP0283 Injector cylinder 8-N86 Short to positive
16668411CP0284 differential injection amount Zyl.8
16669411DP0285 Injector cylinder 9-N299 short circuit to ground
16670411EP0286 Injector cylinder 9-N299 short circuit to positive
166724120P0288 Injector cylinder 10-N300 short circuit to ground
166734121P0289 Injector cylinder 10-N300 short circuit to positive
166754123P0291 Injector cylinder 11-N301 short circuit to ground
166764124P0292 Injector cylinder 11-N301 short circuit to positive
166784126P0294 Injector cylinder 12-N302 short circuit to ground
166794127P0295 Injector cylinder 12-N302 short circuit to positive
16683412BP0299 boost pressure control Control limit exceeded
16684412CP0300 misfire detected
16685412DP0301 cylinder 1 misfire detected
16686412EP0302 cylinder 2 misfire detected
16687412FP0303 cylinder misfire detected 3
166884130P0304 Cylinder 4 misfires recognized
166894131P0305 cylinder 5 misfire detected
166904132P0306 cylinder 6 misfire detected
166914133P0307 cylinder misfire detected 7
166924134P0308 cylinder misfire detected 8
166934135P0309 cylinder 9 misfires recognized
166944136P0310 cylinder 10 misfires recognized
166954137P0311 cylinder misfire detected 11
166964138P0312 cylinder misfire detected 12
166974139P0313 misfire detected reason: lack of fuel
16698413AP0314 misfire single cylinder
16702413EP0318 Rough road info / motor target torque from ABS-SG electrical fault in the circuit
167054141P0321 donors for engine speed G28 Implausible signal
167064142P0322 donors for engine speed G28 no signal
167084144P0324 knock control malfunction
167094145P0325 knock sensor 1-G61 electrical fault in the circuit
167104146P0326 knock sensor 1 G61 implausible signal
167114147P0327 knock sensor 1 signal is too small G61
167124148P0328 knock sensor 1 G61 signal too large.
16715414BP0331 knock sensor 2-G66 implausible signal
16716414CP0332 knock sensor 2-G66 signal too small
16717414DP0333 Knock sensor 2-G66 signal too large.
16719414FP0335 donors for engine speed G28 malfunction
167204150P0336 donors for engine speed G28 missing tooth
167214151P0337 crankshaft position sensor => G4 encoder signal too small
167244154P0340 Camshaft position sensor malfunction
167254155P0341 Camshaft position sensor => donor-G40 Implausible signal
167264156P0342 Camshaft position sensor => donor-G40 signal too small
167274157P0343 Camshaft position sensor => donor-G40 signal too large.
167294159P0345 Camshaft position sensor => donor-G163 electrical fault
16730415AP0346 Camshaft position sensor => donor-G163 Implausible signal
16731415BP0347 Camshaft position sensor => donor-G163 short circuit to ground
16732415CP0348 Camshaft position sensor => donor-G163 Short circuit to positive
16735415FP0351 Zundansteuerung cylinder 1 malfunction
167364160P0352 Zundansteuerung cylinder 2 malfunction
167374161P0353 cylinder 3 Zundansteuerung malfunction
167384162P0354 Zundansteuerung cylinder 4 malfunction
167394163P0355 Zundansteuerung cylinder 5 malfunction
167404164P0356 Zundansteuerung cylinder 6 malfunction
167414165P0357 Zundansteuerung cylinder 7 malfunction
167424166P0358 Zundansteuerung cylinder 8 malfunction
167434167P0359 Zundansteuerung cylinder 9 malfunction
167444168P0360 Zundansteuerung cylinder 10 malfunction
167454169P0361 Zundansteuerung cylinder 11 malfunction
16746416AP0362 Zundansteuerung cylinder 12 malfunction
16749416DP0365 Camshaft position sensor => donor-G300 malfunction
16750416EP0366 Camshaft position sensor => donor-G300 Implausible signal
16751416FP0367 camshaft position sensor => donor-G300 signal too small
167524170P0368 Camshaft position sensor => donor-G300 signal too large.
16764417CP0380 glow plug-Q6 electrical fault in the circuit
167744186P0390 Camshaft position sensor => donor-G301 malfunction
167754187P0391 Camshaft position sensor => donor-G301 Implausible signal
167764188P0392 camshaft position sensor => donor-G301 signal too small
167774189P0393 camshaft position sensor => donor-G301 signal too large.
167844190P0400 Abgasruckfuhrungssystem malfunction
167854191P0401 Abgasruckfuhrungssystem throughput too small
167864192P0402 Abgasruckfuhrungssystem throughput too large.
167874193P0403 valve for exhaust gas recirculation-N18 malfunction
167884194P0404 Abgasruckfuhrungssystem control difference
167894195P0405 Temperature Sensor for exhaust gas recirculation-G98 signal too small
167904196P0406 Temperature Sensor for exhaust gas recirculation-G98 signal too large.
167914197P0407 potentiometer for exhaust gas recirculation-G212 signal too small
167924198P0408 potentiometer for exhaust gas recirculation-G212 signal too large.
16794419AP0410 secondary air injection malfunction
16795419BP0411 secondary air injection flow flawed
16796419CP0412 Sekundarlufteinblasventil-N112 electrical fault in the circuit
16797419DP0413 Sekundarlufteinblasventil-N112 interruption
16798419EP0414 Sekundarlufteinblasventil-N112 short circuit
16799419FP0415 Sekundarlufteinblasventil 2-N320 electrical fault in the circuit
1680041A0P0416 Sekundarlufteinblasventil 2-N320 interruption
1680141A1P0417 Sekundarlufteinblasventil 2-N320 short circuit
1680241A2P0418 relay for secondary air pump J299 malfunction
1680341A3P0419 relay for secondary air pump 2-J545 malfunction
1680441A4P0420 Bank1, catalyst system activity too low
1680541A5P0421 primary catalytic converter, bank 1 effect too low
1680641A6P0422 Bank1, main catalytic effect is too low
1681141ABP0427 Temperature Sensor 1 for Kat-G20 short circuit to ground
1681241ACP0428 Temperature Sensor 1 for Kat-G20 Open / short circuit to positive
1681441AEP0430 catalyst system Bank2 effect too low
1681541AFP0431 primary catalytic converter, bank 2 effect too low
1681641B0P0432 Bank 2, main catalytic effect is too low
1682041B4P0436 Temperature Sensor 2 for Kat-G132 Implausible signal
1682141B5P0437 Temperature Sensor 2 for Kat-G132 short circuit to ground
1682241B6P0438 Temperature Sensor 2 for Kat-G132 open / short circuit to positive
1682441B8P0440 Tankentluftungssystem malfunction
1682541B9P0441 Tankentluftungssystem throughput flawed
1682641BArecognized P0442 Tankentluftungssystem fine leak
1682741BBP0443 Tankentluftungsventil-N80 Electrical fault in the circuit
1682841BCP0444 Tankentluftungsventil-N80 interruption
1682941BDP0445 Tankentluftungsventil-N80 Short
1683341C1P0449 Tankentluftungssystem, solenoid valve 2 for activated carbon N115 electrical fault in the circuit
1683641C4P0452 pressure sensor for Tankentluftungssystem signal too small
1683741C5P0453 pressure sensor for Tankentluftungssystem signal too large.
1683941C7recognized P0455 Tankentluftungssystem major leak
1684041C8recognized P0456 Tankentluftungssystem Feinstleck
1684241CAP0458 Tankentluftungsventil-N80 Short circuit to ground
1684341CBP0459 Tankentluftungsventil-N80 Short to positive
1684541CDP0461 Fuel fuel level signal implausible signal
1684641CEP0462 donors for Fuel Storage G signal too small
1684741CFP0463 donors for Fuel Storage G signal too large.
1685441D6P0470 pressure sensor 1 for exhaust G450 interruption
1685541D7P0471 pressure sensor 1 for exhaust implausible signal-G450
1685641D8P0472 pressure sensor 1 for exhaust-G450 short circuit to ground
1685741D9P0473 pressure sensor 1 for exhaust-G450 Short circuit to positive
1686441E0P0480 Kuhlerlufteransteuerung 1 electrical fault
1686541E1P0481 Kuhlerlufteransteuerung electrical fault 2
1687341E9P0489 Abgasruckfuhrungssteuerung short circuit to ground
1687441EAP0490 Abgasruckfuhrungssteuerung short circuit to positive
1687541EBP0491 secondary air injection bank 1 Flow too low
1687641ECP0492 Bank2, secondary air injection malfunction
1688241F2P0498 Tankentluftungssystem, solenoid valve 2 for activated carbon N115 signal too small
1688341F3P0499 Tankentluftungssystem, solenoid valve 2 for activated carbon N115 signal too large.
1688541F5P0501 vehicle speed signal implausible signal
1688641F6P0502 vehicle speed signal signal-to-low
1688741F7P0503 vehicle speed signal signal too large.
1688941F9P0505 idle speed control malfunction
1689041FAP0506 idling control speed below setpoint
1689141FBP0507 idling control over speed setpoint
1689441FEP0510 Idle switch F60 malfunction
168974201P0513 Incorrect immobilizer
169154213P0531 load signal from the implausible signal conditioner compressor
169164214P0532 pressure sensor for air conditioning-G65 signal too small
169174215P0533 pressure sensor for air conditioning-G65 signal too large.
169284220P0544 sensor 1 for exhaust gas temperature-G235 electrical fault
169294221P0545 sensor 1 for exhaust gas temperature-G235 short circuit to ground
169304222P0546 sensor 1 for exhaust gas temperature-G235 Short circuit to positive
169314223P0547 sensor 1 for exhaust gas temperature bank 2-G236 electrical fault
169324224P0548 sensor 1 for exhaust gas temperature bank 2-G236 short circuit to ground
169334225P0549 sensor 1 for exhaust gas temperature bank 2-G236 Short circuit to positive
169344226P0550 Power Steering Pressure control electrical fault
169354227P0551 Pressure switch / power steering F88 implausible signal
169444230P0560 power supply implausible signal
169454231P0561 power supply unstable
169464232P0562 power supply voltage too low
169474233P0563 power supply voltage too big.
169524238P0568 switches for GRA-E45 implausible signal
16955423BP0571 stop lamp switch signal Funplausibles
169814255P0597 thermostat for map-controlled engine cooling-F265 interruption
169824256P0598 thermostat for map-controlled engine cooling-F265 Short circuit to ground
169834257P0599 thermostat for map-controlled engine cooling-F265 Short circuit to positive
169844258P0600 data bus drive missing message
169854259P0601 Control unit defective
16986425AP0602 control units programming malfunction
16987425BP0603 Control unit defective
16988425CP0604 Control unit defective
16989425DP0605 Control unit defective
16990425EP0606 Control unit defective
16991425FP0607 control module implausible
169924260P0608 supply voltage sensors / actuators
169934261P0609 supply voltage 2 sensors / actuators
169944262P0610 engine control incorrect coding
169974265P0613 processor defective transmission control
169984266P0614 transmission control Incorrect software version
169994267P0615 control starter relay interruption
170004268P0616 control starter relay short circuit to ground
170014269P0617 control starter relay short circuit to positive
170114273P0627 relay for electric fuel pump 1 electrical failure / interruption
170124274P0628 Relay for electric fuel pump 1 short circuit to ground
170134275P0629 Relay for electric fuel pump 1 short circuit to positive
17018427AP0634 control unit temperature shutdown
17022427EP0638 Throttle valve control unit J338 implausible signal
17023427FP0639 throttle valve control unit 2-J544 implausible signal
170254281P0641 encoder reference voltage interruption -A-
170264282P0642 encoder reference voltage -A- too small
170274283P0643 encoder reference voltage -A- too large.
170294285P0645 air conditioning input / output
17034428AP0650 error lamp for self-diagnosis-K83 electrical fault in the circuit
17035428BP0651 encoder reference voltage interruption -B-
17036428CP0652 encoder reference voltage -B- too small
17037428DP0653 encoder reference voltage -B- too large.
17038428EP0654 output for engine speed electrical fault in the circuit
170404290P0656 Fuel consumption signal electrical fault in the circuit
170414291P0657 supply for engine components interruption
170424292P0658 supply for engine components too small
170434293to Groa P0659 supply for engine components
170444294P0660 Registersaugrohrumschaltung electrical fault
170454295P0661 Registersaugrohrumschaltung short circuit to ground
170464296P0662 Registersaugrohrumschaltung short circuit to positive
17051429BP0667 Internal temperature sensor implausible signal
17052429CP0668 Internal temperature sensor voltage too low
17053429DP0669 Internal temperature sensor voltage is too large.
17054429EP0670 Gluhzeitsteuergerat 1, Gluhstromkreis electrical fault in the circuit
17055429FP0671 glow plug cylinder 1-Q10 electrical fault in the circuit
1705642A0P0672 glow plug cylinder 2 Q11 electrical fault in the circuit
1705742A1P0673 glow plug cylinder 3-Q12 electrical fault in the circuit
1705842A2P0674 glow plug cylinder 4-Q13 electrical fault in the circuit
1705942A3P0675 glow plug cylinders 5-Q14 electrical fault in the circuit
1706042A4P0676 glow plug cylinder 6-Q15 electrical fault in the circuit
1706142A5P0677 glow plug cylinder 7-Q16 electrical fault in the circuit
1706242A6P0678 glow plug cylinder 8-Q17 electrical fault in the circuit
1706342A7P0679 glow plug cylinder 9-Q18 electrical fault in the circuit
1706442A8P0680 glow plug cylinder 10 Q19 electrical fault in the circuit
1706542A9P0681 glow plug cylinder 11 Q20 electrical fault in the circuit
1706642AAP0682 glow plug cylinder 12 Q21 electrical fault in the circuit
1706842ACP0684 Gluhzeitsteuergerat 1 => - J179 implausible signal
1706942ADP0685 main relay => - J271 interruption
1707042AEEither p0686 main relay => - J271 short circuit to ground
1707142AFP0687 main relay => - J271 Short circuit to positive
1707242B0P0688 main relay, open load => - J271 interruption
1707542B3P0691 Kuhlerlufteransteuerung 1 short circuit to ground
1707642B4P0692 Kuhlerlufteransteuerung 1 Short circuit to positive
1707742B5P0693 Kuhlerlufteransteuerung 2 short circuit to ground
1707842B6P0694 Kuhlerlufteransteuerung 2 short circuit to positive
1708142B9P0697 encoder reference voltage interruption -C-
1708242BAP0698 encoder reference voltage -C- too small
1708342BBP0699 encoder reference voltage -C- too large.
1708442BCP0700 Control unit defective
1708542BDP0701 Control unit defective
1708642BEP0702 Control unit defective
1708742BFP0703 Brake light switch-F electrical fault in the circuit
1708842C0P0704 Clutch pedal switch F36 implausible signal
1708942C1P0705 speed steps sensor => - F125 electrical fault in the circuit
1709042C2P0706 speed steps sensor => - F125 implausible signal
1709142C3P0707 speed steps sensor => - F125 signal too small
1709242C4P0708 speed steps sensor => - F125 signal too large.
1709442C6P0710 donors for Getriebeoltemperatur-G93 electrical fault in the circuit
1709542C7P0711 donors for Getriebeoltemperatur-G93 Implausible signal
1709642C8P0712 donors for Getriebeoltemperatur-G93 signal too small
1709742C9P0713 donors for Getriebeoltemperatur-G93 signal too large.
1709842CAP0714 donors for Getriebeoltemperatur-G93 interruption
1709942CBP0715 transmitter for transmission input speed-G182 electrical fault in the circuit
1710042CCP0716 transmitter for transmission input speed-G182 Implausible signal
1710142CDP0717 transmitter for transmission input speed-G182 no signal
1710442D0P0720 transmitter for transmission output speed-G195 electrical fault in the circuit
1710542D1P0721 transmitter for transmission output speed-G195 Implausible signal
1710642D2P0722 transmitter for transmission output speed-G195 no signal
1710942D5P0725 speed signal from the engine control electrical fault in the circuit
1711042D6P0726 speed signal from the engine control Implausible signal
1711142D7P0727 speed signal from a signal engine control
1711342D9P0729 6th gear wrong Uebersetzungsverhaltnis
1711442DAP0730 Gear / Ubersetzungsuberwachung wrong gear ratio
1711542DBP0731 1st gear wrong gear ratio
1711642DCP0732 2nd gear wrong gear ratio
1711742DDP0733 3rd gear wrong gear ratio
1711842DEP0734 4th gear wrong gear ratio
1711942DFP0735 5th gear wrong gear ratio
1712042E0P0736 reverse gear wrong Uebersetzungsverhaltnis
1712442E4P0740 clutch for mechanical failure Wandleruberbruckung
1712542E5P0741 clutch for Wandleruberbruckung no engine power distribution
1712742E7P0743 coupling for electrical fault Wandleruberbruckung
1713042EAP0746 pressure regulating valve 1 open / short circuit to ground
1713142EBP0747 Pressure control valve 1 Short circuit to positive
1713242ECP0748 pressure regulating valve 1 electrical fault in the circuit
1713342EDP0749 pressure control valve 1 Interruption
1713442EEP0750 switching valve 1 => solenoid valve 1-N88 dysfunction
1713542EFP0751 switching valve 1 => solenoid valve 1-N88 open / short circuit to ground
1713642F0P0752 switching valve 1 => solenoid valve 1-N88 Short to positive
1713742F1P0753 switching valve 1 => solenoid valve 1-N88 Electrical fault in the circuit
1714042F4P0756 switching valve 2 => Solenoid valve 2-N89 open / short circuit to ground
1714142F5P0757 switching valve 2 => Solenoid valve 2-N89 Short to positive
1714242F6P0758 switching valve 2 => Solenoid valve 2-N89 Electrical fault in the circuit
1714542F9P0761 switching valve 3 => solenoid valve 3-N90 open / short circuit to ground
1714642FAP0762 switching valve 3 => solenoid valve 3-N90 Short to positive
1714742FBP0763 switching valve 3 => solenoid valve 3-N90 Electrical fault in the circuit
1715042FEP0766 switching valve 4 => solenoid valve 4-N91 open / short circuit to ground
171524300P0768 switching valve 4 => solenoid valve 4-N91 Electrical fault in the circuit
171554303P0771 switching valve 5 => solenoid valve 5-N92 open / short circuit to ground
171574305P0773 switching valve 5 => solenoid valve 5-N92 Electrical fault in the circuit
171604308P0776 pressure regulating valve 2 open / short circuit to ground
171614309P0777 Pressure control valve 2 short circuit to positive
17162430AP0778 pressure control valve 2 of electrical fault in the circuit
17163430BP0779 pressure control valve 2 Interruption
17164430CP0780 Schaltungsuberwachung
17165430DP0781 Schaltungsuberwachung 1-2
17166430EP0782 Schaltungsuberwachung 2-3
17167430FP0783 Schaltungsuberwachung 3-4
171684310P0784 Schaltungsuberwachung 4-5
171694311P0785 magnetic switching time
171744316P0790 program switch-E122 electrical fault in the circuit
171754317P0791 Speed Sensor "" A "" for intermediate shaft Electrical fault
17180431CP0796 pressure control valve 3 open / short circuit to ground
17181431DP0797 pressure control valve 3 short circuit to positive
17182431EP0798 pressure regulating valve 3 of electrical fault in the circuit
17183431FP0799 pressure control valve 3 Interruption
17195432BP0811 strong clutch slip
17199432FP0815 switches for Tiptronic, high-F189 electrical fault in the circuit
172004330P0816 switches for Tiptronic, back-F189 electrical fault in the circuit
172014331P0817 starter interlock signal
172044334P0820 message of change lever and emergency operation
17213433DP0829 Schaltungsuberwachung 5-6
172244348P0840 encoder 1 for hydraulic pressure transmission electrical fault in the circuit
172254349P0841 encoder 1 for hydraulic pressure transmission implausible signal
17226434AP0842 encoder 1 for hydraulic pressure transmission Short circuit to ground
17227434BP0843 encoder 1 for hydraulic pressure transmission short circuit to positive
17228434CP0844 encoder 1 for hydraulic pressure transmission interruption
17229434DP0845 encoder 2 for hydraulic pressure transmission electrical fault in the circuit
17230434EP0846 encoder 2 for hydraulic pressure transmission implausible signal
17231434FP0847 encoder 2 for hydraulic pressure transmission Short circuit to ground
172324350P0848 encoder 2 for hydraulic pressure transmission short circuit to positive
172334351P0849 encoder 2 for hydraulic pressure transmission interruption
172344352P0850 signal for starter lock (P / N) short circuit to positive / interruption
172354353P0851 signal for starter lock (P / N) short circuit to ground
172364354P0852 signal for starter lock (P / N) Short-circuit to positive
17247435FP0863 communication transmission control electrical fault in the circuit
172484360P0864 communication implausible signal transmission control
172494361P0865 communication transmission control short circuit to ground
172524364P0868 Transmission Pressure adaptation at the stop
172684374P0884 power transmission control circuit / loose contact
172704376P0886 drive current supply relay for transmission control short circuit. to ground
172714377P0887 drive current supply relay for transmission control short circuit. to positive
172734379Replaced by P0889 power supply for the solenoid valve implausible signal
17274437AP0890 power supply for solenoid valve short circuit to ground
17275437BP0891 power supply for solenoid valve short circuit to positive
17276437CP0892 power supply for the solenoid valve stoppage
172814381P0897 transmission fluid deterioration
172884388P0904 switch for Tiptronic F189 electrical fault in the circuit
172894389P0905 switch for Tiptronic F189 implausible signal
17290438AP0906 switch for Tiptronic F189 Short circuit to ground
172984392P0914 selector lever electrical fault in the circuit
173034397P0919 selector lever error
1731343A1P0929 magnet for implausible signal selector lever lock
1731443A2P0930 magnet for selector lever lock short circuit to ground
1731543A3P0931 magnet for selector lever lock short circuit to positive
174084400P1000 injector cylinder 9-N299 electrical fault in the circuit
174094401P1001 injection valve cylinder 10 N300 electrical fault in the circuit
174104402P1002 injection valve cylinder 11-N301 electrical fault in the circuit
174114403P1003 injection valve cylinder 12 N302 electrical fault in the circuit
174124404exceeded P1004 torque difference cylinder 1 limit
174134405P1005 torque difference cylinder exceeded 2 limit
174144406P1006 torque difference cylinder exceeded 3 Limit
174154407P1007 torque difference cylinder exceeded 4 Limit
174164408P1008 air mass meter 1/2 implausible signal
174174409P1009 air mass meter 1/2 implausible signal from the load detecting
17418440AP1010 injector cylinder 9-N299 interruption
17419440BP1011 injection valve cylinder 10 N300 interruption
17420440CP1012 injection valve cylinder 11-N301 interruption
17421440DP1013 injection valve cylinder 12 N302 interruption
17422440EP1014 valve for bypass damper air filter N275 short circuit to positive
17423440FP1015 valve for bypass damper air filter N275 short circuit to ground
174244410P1016 valve for bypass damper air filter interruption N275
174254411P1017 Intake manifold 2 for airflow control Upper stop not reached
174264412P1018 Intake manifold 2 for airflow control Lower stop not reached
174274413P1019 donors for NOx G295 signal too slow
174284414P1020 fuel pressure control exceeded control limit
174294415Not reached P1021 Bank1 Nockenwellenspatverstellung target
174304416Not reached P1022 Bank1 Nockenwellenfruhverstellung target
174314417P1023 control valve for fuel pressure short circuit to ground
174324418P1024 control valve for fuel pressure interruption
174334419P1025 control valve for fuel pressure mechanical failure
17434441AP1026 control manifold flap for air flow control Short circuit to positive
17435441BP1027 control manifold flap for air flow control short circuit to ground
17436441CP1028 control manifold flap for air flow control interrupt
17437441Dnot reached P1029 valve for intake manifold, air flow control-N316 upper stop
17438441Enot reached P1030 valve for intake manifold, air flow control-N316 lower stop
17439441Fnot reached P1031 valve for intake manifold, air flow control-N316 setpoint
174404420P1032 donors for NOx G295 signal too large.
174414421P1033 donors for NOx G295 signal too small
174424422P1034 donors for NOx G295 signal au.erhalb tolerance
174434423P1035 donors for NOx G295 Implausible signal
174444424P1036 control heating timer for Nox short circuit to positive
174454425P1037 control heating timer for Nox short circuit to ground
174464426P1038 control heating timer for Nox interruption
174474427P1039 supply injector (e) A short circuit
174484428P1040 supply injection valve (s) A electrical fault in the circuit
174494429P1041 supply injector (s) B Short circuit
17450442AP1042 supply injection valve (s) B of electrical fault in the circuit
17451442BP1043 supply injector (s) C Short circuit
17452442CP1044 supply injection valve (s) C electrical fault in the circuit
17453442DP1045 supply injector (s) D Short circuit
17454442EP1046 supply injection valve (s) D electrical fault in the circuit
17455442FP1047 Bank1, valve for camshaft adjustment, outlet N318 electrical fault in the circuit
174564430P1048 Bank1, valve for camshaft adjustment, outlet N318 short circuit to positive
174574431P1049 Bank1, valve for camshaft adjustment, outlet N318 short circuit to ground
174584432P1050 Bank1, valve for camshaft adjustment, outlet interruption N318
174594433P1051 Bank2, valve for camshaft adjustment, outlet N319 electrical fault in the circuit
174604434P1052 Bank2, valve for camshaft adjustment, outlet N319 short circuit to positive
174614435P1053 Bank2, valve for camshaft adjustment, outlet N319 short circuit to ground
174624436P1054 Bank2, valve for camshaft adjustment, outlet interruption N319
174634437P1055 Bank1, camshaft adjustment, outlet short circuit to positive
174644438P1056 Bank1, camshaft adjustment, outlet Short circuit to ground
174654439P1057 Bank1, camshaft timing, interrupt outlet
17466443AP1058 Bank2, camshaft adjustment, outlet short circuit to positive
17467443BP1059 Bank2, camshaft adjustment, outlet Short circuit to ground
17468443CP1060 Bank2, camshaft timing, interrupt outlet
17469443DNot reached P1061 Bank2 Nockenwellenspatverstellung target
17470443EP1062 Bank2 not achieved Nockenwellenfruhverstellung target
17471443FP1063 fuel pressure control Control limit exceeded
174724440P1064 fuel pressure system mechanical failure
174734441P1065 fuel pressure control system deviation
174744442P1066 valve for Ansaugluftumschaltung-N335 short circuit to positive
174754443P1067 valve for Ansaugluftumschaltung-N335 short circuit to ground
174764444P1068 valve for Ansaugluftumschaltung-N335 interruption
174774445P1069 donors for NOx G295, heating control signal short circuit to ground
174784446P1070 donors for NOx G295, heating control signal short circuit to positive
174794447P1071 donors for NOx G295, heating control signal implausible signal
174804448P1072 donors for NOx G295, heating control signal electrical fault in the circuit
174814449P1073 air mass meter 2-G246 signal too small
17482444AP1074 air mass meter 2 G246 signal too large.
17483444BP1075 lambda control exhaust system too lean Bank 3
17484444CP1076 lambda control exhaust bank 3 system to fat
17485444DP1077 lambda control exhaust system Bank 4 too lean
17486444EP1078 lambda control exhaust bank 4 system fat
17487444FP1079 lambda control exhaust bank 3 implausible control value
174884450P1080 lambda control Exhaust bank 4 implausible control value
174894451P1081 exhaust Bank3, mixture adaptation range below 1 lean limit
174904452below P1082 exhaust bank3, mixture adaptation range 2 lean limit
174914453P1083 exhaust Bank3, mixture adaptation range exceeded 1 rich limit
174924454P1084 exhaust bank3, mixture adaptation range exceeded 2 fat limit
174934455P1085 exhaust Bank4, mixture adaptation range below 1 lean limit
174944456below p1086 exhaust Bank4, mixture adaptation range 2 lean limit
174954457P1087 exhaust Bank4, mixture adaptation range exceeded 1 rich limit
174964458P1088 exhaust Bank4, mixture adaptation range exceeded 2 fat limit
174974459below P1089 Bank2, mixture adaptation range 1 lean limit
17498445Abelow p1090 Bank2, mixture adaptation range 2 lean limit
17499445BP1091 Bank2, mixture adaptation range exceeded 1 rich limit
17500445CP1092 Bank2, mixture adaptation range exceeded 2 rich limit
17501445DP1093 Bank 1, fuel metering system 2 malfunction
17502445EP1094 Bank2, fuel metering system 2 malfunction
17503445FP1095 potentiometer for intake manifold-G336 Short circuit to positive
175044460P1096 potentiometer for intake manifold-G336 short circuit to ground
175054461P1097 potentiometer for intake manifold-G336 interruption
175064462P1098 potentiometer for intake manifold-G336 open / short circuit to positive
175074463P1099 control manifold flap for air flow control electrical fault
175084464P1100 Bank1-probe 2, heating circuit capacity too low
175094465P1101 Bank1-Electrode1 voltage too low / leakage air
175104466P1102 Bank1-Probe 1, heating circuit Short circuit to positive
175114467P1103 Bank1-Probe 1, heating circuit capacity too low
175124468P1104 Bank1-probe 2 Voltage too low / leakage air
175134469P1105 Bank1-probe 2, heating circuit Short circuit to positive
17514446AP1106 Bank2-Electrode1 voltage too low / leakage air
17515446BP1107 Bank2-Probe 1, heating circuit Short circuit to positive
17516446CP1108 Bank 2-Electrode1, heating circuit capacity too low
17517446DP1109 Bank2-probe 2 Voltage too low / leakage air
17518446EP1110 Bank2-probe 2, heating circuit Short circuit to positive
17519446FP1111 lambda control (Bank 1) System too lean
175204470P1112 lambda control (Bank 1) System to fat
175214471P1113 Bank 1, probe 1 Internal resistance too great.
175224472P1114 Bank 1, probe 2 Internal resistance too great.
175234473P1115 Bank1-Probe 1, heating circuit Short circuit to ground
175244474P1116 Bank1-Probe 1, heating current interruption
175254475P1117 Bank1-probe 2, heating circuit Short circuit to ground
175264476P1118 Bank1-probe 2, heating current interruption
175274477P1119 Bank2-Probe 1, heating circuit Short circuit to ground
175284478P1120 Bank2-Probe 1, heating current interruption
175294479P1121 Bank2-probe 2, heating circuit Short circuit to ground
17530447AP1122 Bank2-probe 2, heating current interruption
17531447BP1123 Bank1, mixture adaptation air (add.) System to fat
17532447CP1124 Bank1, mixture adaptation air (add.) System too lean
17533447DP1125 Bank2, mixture adaptation air (add.) System to fat
17534447EP1126 Bank2, mixture adaptation air (add.) System too lean
17535447FP1127 Bank1, mixture adaptation (mult.) System to fat
175364480P1128 Bank1, mixture adaptation (mult.) System too lean
175374481P1129 Bank2, mixture adaptation (mult.) System to fat
175384482P1130 Bank2, mixture adaptation (mult.) System too lean
175394483P1131 Bank 2, probe 1 Internal resistance too great.
175404484P1132 Bank1 + 2 Electrode1, heating circuit Short circuit to positive
175414485P1133 Bank1 + 2-Probe 1, the heating circuit electrical fault
175424486P1134 Bank1 + 2 probe 2, heating circuit Short circuit to positive
175434487P1135 + 2 Bank1-probe 2, heater circuit electrical fault
175444488P1136 Bank1, mixture adaptation (add.) System too lean
175454489P1137 Bank1, mixture adaptation (add.) System to fat
17546448AP1138 Bank2, mixture adaptation (add.) System too lean
17547448BP1139 Bank2, mixture adaptation (add.) System to fat
17548448CP1140 Bank 2, probe 2 Internal resistance too great.
17549448DP1141 load detection implausible value
17550448EP1142 load detection limit exceeded
17551448FP1143 load detection limit exceeded
175524490P1144 air mass meter-G70 open / short circuit to ground
175534491P1145 air mass meter-G70 Short to positive
175544492P1146 air mass meter G70-supply voltage
175554493P1147 lambda control system Bank 2 to lean
175564494P1148 lambda control system Bank 2 to fat
175574495P1149 lambda control Bank 1 implausible control value
175584496P1150 Lambda control bank 2 implausible control value
175594497below P1151 Bank1, mixture adaptation range 1 lean limit
175604498below P1152 Bank1, mixture adaptation range 2 lean limit
175614499P1153 lambda probes reversed by Kat
17562449AP1154 Intake manifold malfunction
17563449BP1155 donors for intake manifold pressure G71 Short to positive
17564449CP1156 donors for intake manifold pressure G71-open / short circuit to ground
17565449DP1157 donors for intake manifold pressure G71-supply voltage
17566449EP1158 donors for intake manifold pressure-G71 Implausible signal
17567449FP1159 signal Luftmassenmesser1 / Luftmassenmesser2 implausible ratio
1756844A0P1160 donors for intake manifold-G72 short circuit to ground
1756944A1P1161 donors for intake manifold-G72 Open / short circuit to positive
1757044A2P1162 donors for fuel temperature G81 short circuit to ground
1757144A3P1163 donors for fuel temperature G81 interruption / short circuit to positive
1757244A4P1164 donors for fuel temperature-G81 Implausible signal
1757344A5P1165 Bank1, mixture adaptation range exceeded 1 rich limit
1757444A6P1166 Bank1, mixture adaptation range exceeded 2 rich limit
1757544A7P1167 air mass meter 2-G246 implausible signal
1757644A8P1168 air mass meter 2-G246 open / short circuit to ground
1757744A9P1169 air mass meter two-G246 Short circuit to positive
1757844AAP1170 air mass meter 2 G246 Power supply
1757944ABP1171 angle sender 2 for throttle valve drive-G188 Implausible signal
1758044ACP1172 angle sender 2 for throttle valve drive-G188 signal too small
1758144ADP1173 angle sender 2 for throttle valve drive-G188 signal too large.
1758244AEP1174 Bank 1, fuel metering system deviation of the injection time
1758344AFP1175 pilot off
1758444B0P1176 reached Bank1, lambda correction behind catalyst control limit
1758544B1P1177 reached Bank2, lambda correction behind catalyst control limit
1758644B2P1178 linear lambda probe / pump current cutting
1758744B3P1179 linear lambda probe / pump current short circuit to ground
1758844B4P1180 linear lambda probe / pump current short circuit to positive
1758944B5P1181 linear lambda probe / reference voltage interruption
1759044B6P1182 linear lambda probe / reference voltage Short circuit to ground
1759144B7P1183 linear lambda probe / reference voltage Short circuit to positive
1759244B8P1184 linear lambda probe / common ground line interruption
1759344B9P1185 linear lambda probe / common ground line short-circuit to ground
1759444BAP1186 linear lambda probe / common ground line short circuit to positive
1759544BBP1187 linear lambda sensor / compensation resistor interruption
1759644BCP1188 linear lambda sensor / compensation resistor short circuit to ground
1759744BDP1189 linear lambda sensor / compensation resistor short circuit to positive
1759844BEP1190 linear lambda probe / reference voltage implausible
1759944BFP1191 linear lambda probe upstream of the catalyst swapped
1760044C0P1192 donors for fuel pressure G247 Supply Voltage
1760144C1P1193 donors for fuel pressure G247 open / short circuit to positive
1760244C2P1194 control valve for fuel pressure N276 short circuit to positive
1760344C3P1195 control valve for fuel pressure N276 open / short circuit to ground
1760444C4P1196 Bank1-Probe 1, heating circuit electrical fault
1760544C5P1197 Bank2-Probe 1, heating circuit electrical fault
1760644C6P1198 Bank1-probe 2, heating circuit electrical fault
1760744C7P1199 Bank 2-probe 2, heating circuit electrical fault
1760844C8P1200 air recirculation valve for turbocharger N249 mechanical failure
1760944C9P1201 cylinder injection valve 1-N30 electrical fault in the circuit
1761044CAP1202 injector cylinder 2-N31 electrical fault in the circuit
1761144CBP1203 injector cylinder 3-N32 electrical fault in the circuit
1761244CCP1204 injection valve cylinder 4-N33 electrical fault in the circuit
1761344CDP1205 injector barrel 5-N83 electrical fault in the circuit
1761444CEP1206 injection valve cylinder 6-N84 electrical fault in the circuit
1761544CFP1207 cylinder injection valve 7-N85 electrical fault in the circuit
1761644D0P1208 injector cylinder 8-N86 electrical fault in the circuit
1761744D1P1209 inlet check valves for cylinder deactivation short circuit to ground
1761844D2P1210 inlet check valves for cylinder deactivation short circuit to positive
1761944D3P1211 inlet check valves for cylinder deactivation interruption
1762044D4P1212 cylinder deactivation, Bank 1
1762144D5P1213 Injector cylinder 1-N30 Short to positive
1762244D6P1214 Injector cylinder 2-N31 Short to positive
1762344D7P1215 Injector cylinder 3-N32 Short to positive
1762444D8P1216 Injector cylinder 4-N33 Short to positive
1762544D9P1217 Injector cylinder 5-N83 Short to positive
1762644DAP1218 Injector cylinder 6-N84 Short to positive
1762744DBP1219 injection valve cylinder 7-N85 Short to positive
1762844DCP1220 Injector cylinder 8-N86 Short to positive
1762944DDP1221 Auslasssperrventile cylinder deactivation short circuit to ground
1763044DEP1222 Auslasssperrventile cylinder deactivation short circuit to positive
1763144DFP1223 Auslasssperrventile cylinder deactivation interruption
1763244E0P1224 cylinder deactivation, Bank 2
1763344E1P1225 Injector cylinder 1-N30 Short circuit to ground
1763444E2P1226 Injector cylinder 2-N31 Short circuit to ground
1763544E3P1227 Injector cylinder 3-N32 Short circuit to ground
1763644E4P1228 Injector cylinder 4-N33 Short circuit to ground
1763744E5P1229 Injector cylinder 5-N83 Short circuit to ground
1763844E6P1230 Injector cylinder 6-N84 Short circuit to ground
1763944E7P1231 injection valve cylinder 7-N85 Short circuit to ground
1764044E8P1232 Injector cylinder 8-N86 Short circuit to ground
1764144E9P1233 load sensing malfunction
1764244EAP1234 lack of fuel supply
1764344EBP1235 exhaust Bank3, lambda correction reaches behind catalyst control limit
1764444ECP1236 exhaust Bank4, lambda correction reaches behind catalyst control limit
1764544EDP1237 cylinder injection valve 1-N30 interruption
1764644EEP1238 injector cylinder 2-N31 interruption
1764744EFP1239 injector cylinder 3-N32 interruption
1764844F0P1240 injection valve cylinder 4-N33 interruption
1764944F1P1241 injector barrel 5-N83 interruption
1765044F2P1242 injection valve cylinder 6-N84 interruption
1765144F3P1243 cylinder injection valve 7-N85 interruption
1765244F4P1244 injector cylinder 8-N86 interruption
1765344F5P1245 donors for needle stroke G80 short circuit to ground
1765444F6P1246 donors for needle lift-G80 Implausible signal
1765544F7P1247 donors for needle lift-G80 Open / short circuit to positive
1765644F8P1248 Injection commencement control Control difference
1765744F9P1249 Fuel consumption signal electrical fault in the circuit
1765844FAP1250 fuel Full level too low
1765944FBP1251 valve for commencement of injection-N108 short circuit to positive
1766044FCP1252 valve for injection start N108 open / short circuit to ground
1766144FDP1253 Fuel consumption signal Short circuit to ground
1766244FEP1254 Fuel consumption signal Short to positive
1766344FFP1255 donors for coolant temperature-G62 short circuit to ground
176644500P1256 donors for coolant temperature G62-open / short circuit to positive
176654501P1257 valve for coolant circuit-interruption N214
176664502P1258 valve for coolant circuit-N214 short circuit to positive
176674503P1259 valve for coolant circuit-N214 short circuit to ground
176684504P1260 valve for pump / nozzle cylinder 1 N240 implausible signal
176694505P1261 valve for pump / nozzle cylinder exceeded 1-N240 control limit
176704506P1262 valve for pump / nozzle cylinder below 1 N240 control limit
176714507P1263 valve for pump / nozzle cylinder 2 N241 implausible signal
176724508P1264 valve for pump / nozzle cylinder exceeded 2-N241 control limit
176734509below P1265 valve for pump / nozzle cylinder 2 N241 control limit
17674450AP1266 valve for pump / nozzle cylinder 3 N242 implausible signal
17675450BP1267 valve for pump / nozzle cylinder exceeded 3-N242 control limit
17676450Cbelow P1268 valve for pump / nozzle cylinder 3 N242 control limit
17677450DP1269 valve for pump / nozzle cylinder 4-N243 implausible signal
17678450EP1270 valve for pump / nozzle cylinder exceeded 4-N243 control limit
17679450FP1271 valve for pump / nozzle cylinder below 4 N243 control limit
176804510P1272 valve for pump / nozzle cylinder 5-N244 implausible signal
176814511P1273 valve for pump / nozzle cylinder exceeded 5-N244 control limit
176824512P1274 valve for pump / nozzle cylinder 5 below-N244 control limit
176834513P1275 valve for pump / nozzle cylinder 6-N245 implausible signal
176844514P1276 valve for pump / nozzle cylinder exceeded 6-N245 control limit
176854515P1277 valve for pump / nozzle cylinder below 6-N245 control limit
176864516P1278 valve for metering fuel-N290 short circuit to positive
176874517P1279 valve for metering fuel-N290 open / short circuit to ground
176884518P1280 air control valve for injector N212 throughput too small
176894519P1281 valve for metering fuel-N290 short circuit to ground
17690451AP1282 valve for metering fuel-N290 interruption
17691451BP1283 air control valve for injector N212 electrical fault in the circuit
17692451CP1284 air control valve for injector N212 interruption
17693451DP1285 air control valve for injector N212 short circuit to ground
17694451EP1286 air control valve for injector N212 short circuit to positive
17695451FP1287 air recirculation valve for turbocharger N249 interruption
176964520P1288 air recirculation valve for turbocharger N249 short circuit to positive
176974521P1289 air recirculation valve for turbocharger N249 short circuit to ground
176984522P1290 donors for coolant temperature-Kuhle output-G83 signal too large.
176994523P1291 donors for coolant temperature-Kuhle output-G83 signal too small
177004524P1292 thermostat for map-controlled engine cooling-F265 interruption
177014525P1293 thermostat for map-controlled engine cooling-F265 Short circuit to positive
177024526P1294 thermostat for map-controlled engine cooling-F265 Short circuit to ground
177034527P1295 Bypass turbocharger throughput flawed
177044528P1296 fault in the cooling system
177054529P1297 connection charger throttle pressure drop
17706452AP1298 donors for coolant temperature-Kuhle output-G83 Implausible signal
17707452BP1299 valve for metering fuel-N290 malfunction
17708452CP1300 misfire detected reason: lack of fuel
17709452DP1301 knock control cylinder reaches 9 Control limit
17710452EP1302 knock control cylinder reaches 10 control limit
17711452FP1303 knock control cylinder reaches 11 control limit
177124530P1304 knock control cylinder reaches 12 control limit
177134531P1305 Zundansteuerung cylinder 9 interruption
177144532P1306 Zundansteuerung cylinder 9 short circuit to positive
177154533P1307 Zundansteuerung cylinder 9 short circuit to ground
177164534P1308 Zundansteuerung interruption cylinder 10
177174535P1309 Zundansteuerung cylinder 10 Short circuit to positive
177184536P1310 Zundansteuerung cylinder 10 Short circuit to ground
177194537P1311 Zundansteuerung interruption cylinder 11
177204538P1312 Zundansteuerung cylinder 11 Short circuit to positive
177214539P1313 Zundansteuerung cylinder 11 Short circuit to ground
17722453AP1314 Zundansteuerung interruption cylinder 12
17723453BP1315 Zundansteuerung cylinder 12 Short circuit to positive
17724453CP1316 Zundansteuerung cylinder 12 short circuit to ground
17725453DP1317 knock control cylinder reaches 13 control limit
17726453EP1318 knock control cylinder reaches 14 control limit
17727453FP1319 knock sensor 1-G61 short circuit to ground
177284540P1320 Knock sensor 2-G66 short circuit to ground
177294541P1321 knock sensor 3 G198 signal too small
177304542P1322 Knock Sensor 3 G198 signal too large.
177314543P1323 knock sensor 4-G199 signal too small
177324544P1324 knock sensor 4-G199 signal too large.
177334545P1325 knock control cylinder reaches one control limit
177344546P1326 knock control cylinder reaches 2 Control limit
177354547P1327 knock control cylinder reaches 3 control limit
177364548P1328 knock control cylinder reaches 4 Control limit
177374549P1329 knock control cylinder reaches 5 Control limit
17738454AP1330 knock control cylinder reaches 6 Control limit
17739454BP1331 knock control cylinder reaches 7 control limit
17740454CP1332 knock control cylinder reaches 8 control limit
17741454DP1333 knock control cylinder reaches 15 control limit
17742454EP1334 knock control cylinder reaches 16 control limit
17743454FP1335 Motormomentenuberwachung exceeded 2 Control limit
177444550exceeded P1336 Motormomentenuberwachung control limit
177454551P1337 Bank1, camshaft position sensor => - G40 short circuit to ground
177464552P1338 Bank1, camshaft position sensor => - G40 Open / short circuit to positive
177474553P1339 crankshaft position / engine speed sensor swapped
177484554P1340 Nockenwellenpos.-G40 / Kurbelwellenpos.-sen-G28 misallocation
177494555P1341 Zundausgang 1 short circuit to ground
177504556P1342 Zundausgang 1 Short circuit to positive
177514557P1343 Zundausgang 2 short circuit to ground
177524558P1344 Zundausgang 2 short circuit to positive
177534559P1345 Zundausgang 3 short circuit to ground
17754455AP1346 Zundausgang 3 short circuit to positive
17755455BP1347 Bank 2, Nockenwellenpos.-G163 / Kurbelwellenpos.-Sens.-G28 misallocation
17756455CP1348 Zundausgang 1 Interruption
17757455DP1349 Zundausgang 2 Interruption
17758455EP1350 Zundausgang 3 Interruption
17759455FP1351 Bank1, camshaft position sensor => - G40 Implausible signal at start
177604560not reached P1352 Bank1, camshaft adjustment target position
177624562P1354 transmitter for modulating piston movement sender-G149 electrical fault in the circuit
177634563P1355 Zundansteuerung cylinder 1 Interruption
177644564P1356 Zundansteuerung cylinder 1 Short circuit to positive
177654565P1357 Zundansteuerung cylinder 1 short circuit to ground
177664566P1358 Zundansteuerung cylinder 2 Interruption
177674567P1359 Zundansteuerung cylinder 2 short circuit to positive
177684568P1360 Zundansteuerung cylinder 2 short circuit to ground
177694569P1361 Zundansteuerung cylinder 3 interruption
17770456AP1362 Zundansteuerung cylinder 3 short circuit to positive
17771456BP1363 Zundansteuerung cylinder 3 short circuit to ground
17772456CP1364 Zundansteuerung cylinder 4 Interruption
17773456DP1365 Zundansteuerung cylinder 4 short circuit to positive
17774456EP1366 Zundansteuerung cylinder 4 short circuit to ground
17775456FP1367 Zundansteuerung cylinder 5 Interruption
177764570P1368 Zundansteuerung cylinder 5 Short circuit to positive
177774571P1369 Zundansteuerung cylinder 5 short circuit to ground
177784572P1370 Zundansteuerung cylinder 6 interrupt
177794573P1371 Zundansteuerung cylinder 6 Short circuit to positive
177804574P1372 Zundansteuerung cylinder 6 Short circuit to ground
177814575P1373 Zundansteuerung cylinder 7 break
177824576P1374 Zundansteuerung cylinder 7 Short circuit to positive
177834577P1375 Zundansteuerung cylinder 7 short circuit to ground
177844578P1376 Zundansteuerung cylinder 8 interruption
177854579P1377 Zundansteuerung cylinder 8 Short circuit to positive
17786457AP1378 Zundansteuerung cylinder 8 short circuit to ground
17787457BP1379 cylinder 13 misfires recognized
17788457CP1380 cylinder 14 misfires recognized
17789457Drecognized P1381 cylinder 15 misfires
17790457EP1382 cylinder 16 misfires recognized
177924580P1384 engine control unit 2 faulty
177934581P1385 Control unit defective
177944582P1386 Control unit defective
177954583P1387 Control unit defective
177964584P1388 Control unit defective
177974585P1389 Control unit defective 2 for diesel direct injection-J494
177994587P1391 Bank2, camshaft position sensor => - G163 short circuit to ground
178004588P1392 Bank2, camshaft position sensor => - G163 open / short circuit to positive
178014589P1393 Zundausgang 1 electrical fault in the circuit
17802458AP1394 Zundausgang 2 electrical fault in the circuit
17803458BP1395 Zundausgang 3 electrical fault in the circuit
17804458CP1396 donors for engine speed G28 missing tooth
17805458DP1397 sender wheel for engine speed Adaption limit reached
17806458EP1398 engine speed signal TD short circuit to ground
17807458FP1399 engine speed signal TD Short circuit to positive
178084590P1400 valve for exhaust gas recirculation-N18 electrical fault in the circuit
178094591P1401 valve for exhaust gas recirculation-N18 Short circuit to ground
178104592P1402 valve for exhaust gas recirculation-N18 Short to positive
178114593P1403 Abgasruckfuhrungssystem control difference
178124594not carried out P1404 Abgasruckfuhrungssystem default
178134595P1405 valve 2 for exhaust gas recirculation-N213 malfunction
178144596P1406 Temperature Sensor for exhaust gas recirculation-G98 Implausible signal
178154597P1407 Temperature Sensor for exhaust gas recirculation-G98 signal too small
178164598P1408 Temperature Sensor for exhaust gas recirculation-G98 signal too large.
178174599P1409 Tankentluftungsventil-N80 Electrical fault in the circuit
17818459AP1410 Tankentluftungsventil-N80 Short to positive
17819459BP1411 Bank2, secondary air injection rate too small
17820459CP1412 pressure sensor for exhaust gas recirculation signal too small
17821459DP1413 pressure sensor for exhaust gas recirculation signal too large.
17822459EP1414 Bank 2, secondary air injection leak detected
17823459FP1415 valve for exhaust gas recirculation-N18, characteristic curve adaptation exceeded low limit
1782445A0P1416 valve for exhaust gas recirculation-N18, characteristic curve adaptation exceeded the upper limit value
1782545A1P1417 donors for Fuel Storage G signal too small
1782645A2P1418 donors for Fuel Storage G signal too large.
1782745A3P1419 changeover valve 2 for radiator exhaust gas recirculation-N381 short circuit to positive
1782845A4P1420 Sekundarlufteinblasventil-N112 electrical fault in the circuit
1782945A5P1421 Sekundarlufteinblasventil-N112 short circuit to ground
1783045A6P1422 Sekundarlufteinblasventil-N112 short circuit to positive
1783145A7P1423 Bank 1, secondary air injection rate too small
1783245A8P1424 Bank1, secondary air injection leak detected
1783345A9P1425 Tankentluftungsventil-N80 Short circuit to ground
1783445AAP1426 Tankentluftungsventil-N80 interruption
1783545ABP1427 control vacuum pump for brake Short circuit to positive
1783645ACP1428 control vacuum pump for brake Short circuit to ground
1783745ADP1429 drive vacuum pump for brake interruption
1783845AEP1430 control vacuum pump for brake open / short circuit to positive
1783945AFP1431 drive vacuum pump for brake circuit / short circuit to ground
1784045B0P1432 Sekundarlufteinblasventil-N112 interruption
1784145B1P1433 relay for secondary air pump J299 interruption
1784245B2P1434 relay for secondary air pump J299 Short circuit to positive
1784345B3P1435 relay for secondary air pump J299 short circuit to ground
1784445B4P1436 relay for secondary air pump J299 electrical fault in the circuit
1784545B5P1437 valve 2 for exhaust gas recirculation-N213 short circuit to positive
1784645B6P1438 valve 2 for exhaust gas recirculation N213-circuit / short circuit to ground
1784745B7P1439 potentiometer for exhaust gas recirculation-G212 errors in default
1784845B8P1440 valve for exhaust gas recirculation-N18 interruption
1784945B9P1441 valve for exhaust gas recirculation N18-circuit / short circuit to ground
1785045BAP1442 potentiometer for exhaust gas recirculation-G212 signal too large.
1785145BBP1443 potentiometer for exhaust gas recirculation-G212 signal too small
1785245BCP1444 potentiometer for exhaust gas recirculation-G212 Implausible signal
1785345BDP1445 Temperature Sensor 2 for catalyst G132 implausible signal
1785445BEP1446 Temperature Sensor 1 for catalyst G20 Short circuit to ground
1785545BFP1447 Temperature Sensor 1 for catalyst G20-circuit / short circuit to positive
1785645C0P1448 Temperature Sensor 2 for catalyst G132 Short circuit to ground
1785745C1P1449 Temperature Sensor 2 for catalyst G132 open / short circuit to positive
1785845C2P1450 secondary air injection Short circuit to positive
1785945C3P1451 secondary air injection short circuit to ground
1786045C4P1452 secondary air injection interruption
1786145C5P1453 sensor 1 for exhaust gas temperature-G235 open / short circuit to positive
1786245C6P1454 sensor 1 for exhaust gas temperature-G235 short circuit to ground
1786345C7P1455 encoder 1 for exhaust gas temperature-G235 Implausible signal
1786445C8P1456 exhaust gas temperature control bank achieved one control limit
1786545C9P1457 encoder 1 for exhaust gas temperature bank 2-G236 open / short circuit to positive
1786645CAP1458 sensor 1 for exhaust gas temperature bank 2-G236 short circuit to ground
1786745CBP1459 sensor 1 for exhaust gas temperature bank 2-G236 Implausible signal
1786845CCP1460 exhaust gas temperature control bank reached two control limit
1786945CDP1461 exhaust gas temperature control bank 1 Implausible signal
1787045CEP1462 exhaust gas temperature control bank 2 implausible signal
1787145CFP1463 secondary air injection, 3 Bank malfunction
1787245D0P1464 secondary air injection, Bank 4 malfunction
1787345D1P1465 pump for additive particle-V135 short circuit to positive
1787445D2P1466 pump for particulate additive-V135 open / short circuit to ground
1787545D3P1467 Solenoid 2 for activated carbon N115 short circuit to positive
1787645D4P1468 Solenoid 2 for activated carbon N115 short circuit to ground
1787745D5P1469 solenoid valve 2 for activated carbon interruption N115
1787845D6P1470 leak diagnosis pump Tankentluftungssystem electrical fault in the circuit
1787945D7P1471 leak diagnosis pump Tankentluftungssystem short circuit to positive
1788045D8P1472 leak diagnosis pump Tankentluftungssystem short circuit to ground
1788145D9P1473 leak diagnosis pump interruption Tankentluftungssystem
1788245DAP1474 Solenoid 2 for activated carbon N115 electrical fault in the circuit
1788345DBP1475 leak diagnosis pump Tankentluftungssystem malfunction / no signal
1788445DCP1476 leak diagnosis pump Tankentluftungssystem too low malfunction / vacuum
1788545DDP1477 leak diagnosis pump Tankentluftungssystem malfunction
1788645DEp1478 detected leak diagnosis pump Tankentluftungssystem hose without passage
1788745DFP1479 underpressure system brake mechanical failure
1788845E0P1480 vacuum pump for brake
1788945E1P1481 relay for secondary air pump 2-J545 interruption
1789045E2P1482 relay for secondary air pump 2-J545 Short circuit to positive
1789145E3P1483 relay for secondary air pump 2-J545 short circuit to ground
1789245E4P1484 relay for secondary air pump 2-J545 electrical fault in the circuit
1789345E5P1485 Sekundarlufteinblasventil 2-N320 interruption
1789445E6P1486 Sekundarlufteinblasventil 2-N320 electrical fault in the circuit
1789545E7P1487 Sekundarlufteinblasventil 2-N320 short circuit to ground
1789645E8P1488 Sekundarlufteinblasventil 2-N320 short circuit to positive
1789745E9P1489 Tankentluftungsventil 2-N333 short circuit to positive
1789845EAP1490 Tankentluftungsventil 2-N333 short circuit to ground
1789945EBP1491 Tankentluftungsventil 2-N333 interruption
1790045ECP1492 Tankentluftungsventil 2-N333 electrical fault in the circuit
1790145EDP1493 vacuum pump for brake output too low
1790245EEP1494 Tankentluftungssystem 2 Throughput faulty
1790345EFP1495 changeover valve for radiator exhaust gas recirculation N345-open / short circuit to ground
1790445F0P1496 changeover valve for radiator exhaust gas recirculation-N345 short circuit to positive
1790545F1P1497 secondary air injection, bank 3 Flow error
1790645F2P1498 secondary air injection, Bank 4 Flow error
1790745F3P1499 switching valve 2 for radiator exhaust gas recirculation N381-circuit / short circuit to ground
1790845F4P1500 fuel pump relay-J17 electrical fault in the circuit
1790945F5P1501 fuel pump relay-J17 short circuit to ground
1791045F6P1502 fuel pump relay-J17 Short circuit to positive
1791145F7P1503 load signal Implausible of alternator terminal DF signal
1791245F8P1504 air intake system leak detected
1791345F9P1505 idle switch-F60 not schlie.t / interruption
1791445FAP1506 Idle switch F60 not opened / short circuit to ground
1791545FBP1507 idling system learning value reaches lower limit
1791645FCP1508 idling system learning value reaches upper limit
1791745FDP1509 valve for idling stabilization-N71 electrical fault in the circuit
1791845FEP1510 valve for idle stabilization-N71 Short to positive
1791945FFP1511 valve Registersaugrohrumschaltung-N156 electrical fault in the circuit
179204600P1512 valve Registersaugrohrumschaltung-N156 short circuit to positive
179214601P1513 valve 2 for Registersaugrohrumschaltung-N261 short circuit to positive
179224602P1514 valve 2 for Registersaugrohrumschaltung-N261 short circuit to ground
179234603P1515 valve Registersaugrohrumschaltung-N156 short circuit to ground
179244604P1516 valve Registersaugrohrumschaltung-N156 interruption
179254605P1517 main relay => - J271 electrical fault in the circuit
179264606P1518 main relay => - J271 Short circuit to positive
179274607P1519 Bank1, camshaft adjustment Malfunction
179284608P1520 valve 2 for Registersaugrohrumschaltung-N261 interruption
179294609P1521 valve 2 for Registersaugrohrumschaltung-N261 electrical fault in the circuit
17930460AP1522 Bank2, camshaft adjustment Malfunction
17931460BP1523 crash signal from implausible signal airbag control unit
17932460CP1524 fuel pump relay-J17 open / short circuit to ground
17933460DP1525 Bank1, camshaft adjustment => - N205 electrical fault in the circuit
17934460EP1526 Bank1, camshaft adjustment => - N205 short circuit to positive
17935460FP1527 Bank1, camshaft adjustment => - N205 short circuit to ground
179364610P1528 Bank 1, camshaft adjustment => - N205 interruption
179374611P1529 camshaft adjustment Short circuit to positive
179384612P1530 camshaft adjustment short circuit to ground
179394613P1531 camshaft adjustment interruption
179404614P1532 idle speed control lean operation speed below setpoint
179414615P1533 Bank2, camshaft adjustment => - N208 electrical fault in the circuit
179424616P1534 Bank2, camshaft adjustment => - N208 short circuit to positive
179434617P1535 Bank2, camshaft adjustment => - N208 short circuit to ground
179444618P1536 Bank2, camshaft adjustment => - N208 interruption
179454619P1537 fuel cut-N109 malfunction
17946461AP1538 fuel cut N109 open / short circuit to ground
17947461BP1539 Clutch pedal switch F36 implausible signal
17948461CP1540 vehicle speed signal signal too large.
17949461DP1541 fuel pump relay interruption J17
17950461EP1542 angle encoder for DK-drive-G187 Implausible signal
17951461FP1543 angle encoder for DK-drive-G187 signal too small
179524620P1544 angle encoder for DK-drive-G187 signal too large.
179534621P1545 Throttle Control Malfunction
179544622P1546 Solenoid valve for charge pressure control-N75 Short to positive
179554623P1547 Solenoid valve for charge pressure control N75-short circuit to ground
179564624P1548 Solenoid valve for charge pressure control N75-break
179574625P1549 Solenoid valve for charge pressure control N75-open / short circuit to ground
179584626P1550 boost pressure control difference
179594627P1551 High encoder F96 Short circuit to positive
179604628P1552 High encoder F96 open / short circuit to ground
179614629P1553 Signal High transmitter / intake manifold pressure ratio Implausible
17962462Anot met P1554 Throttle valve control unit J338 conditions for basic setting
17963462Bexceeded P1555 maximum boost pressure
17964462CP1556 boost pressure control Control limit exceeded
17965462DP1557 boost pressure control Control limit exceeded
17966462EP1558 throttle valve drive-G186 electrical fault in the circuit
17967462FP1559 Throttle valve control unit J338 errors in default
179684630exceeded P1560 maximum engine speed
179694631P1561 Quantity adjuster N146-control difference
179704632P1562-quantity adjuster N146 upper stop value
179714633P1563 Quantity adjuster N146-lower stop value
179724634P1564 Throttle valve control unit J338 undervoltage at default
179734635P1565 Throttle valve control unit J338 lower stop is not reached
179744636P1566 Load signal from the air conditioning compressor implausible signal
179754637P1567 Load signal from a signal conditioner compressor
179764638P1568 Throttle valve control unit J338 mechanical failure
179774639P1569 switch for GRA-E45 implausible signal
17978463AP1570 engine control disabled
17979463BP1571 valve left for engine storage-N144 short circuit to positive
17980463CP1572 valve left for engine storage-N144 short circuit to ground
17981463DP1573 valve for the left engine mount-N144 interruption
17982463EP1574 valve left for engine storage-N144 electrical fault in the circuit
17983463FP1575 valve right for engine storage-N145 short circuit to positive
179844640P1576 valve right for engine storage-N145 short circuit to ground
179854641P1577 valve right for engine storage-N145 interruption
179864642P1578 valve right for engine storage-N145 electrical fault in the circuit
179874643not started P1579 Throttle valve control unit J338 adaptation
179884644P1580 throttle valve drive bank 1 malfunction
179894645P1581 Throttle valve control unit J338 basic setting not performed
179904646P1582 Idle control Adaptation limit reached
179914647P1583 valves for transmission mounting-N262 / 263 Short circuit to positive
179924648P1584 valves for transmission mounting-N262 / 263 Short circuit to ground
179934649P1585 valves for transmission mounting-N262 / 263 interrupt
17994464AP1586 valves for engine storage-N144 / 145 Short circuit to positive
17995464BP1587 valves for engine storage-N144 / 145 short circuit to ground
17996464CP1588 valves for engine storage-N144 / 145 break
17997464DP1589 potentiometer knob temperature selection-G267 short circuit to ground
17998464EP1590 potentiometer knob temperature dial interruption G267
17999464FP1591 Solenoid valve for charge pressure control N75-no function
180004650P1592 Signal High transmitter / boost pressure sensor implausible ratio
180014651P1593 High adaptation signal au.erhalb tolerance
180024652P1594 donors for oil temperature, camshaft adjustment-G277 Short circuit to positive
180034653P1595 donors for oil temperature, camshaft adjustment-G277 open / short circuit to ground
180044654P1596 bus drive implausible message of the level of regulatory SG-J197
180054655P1597 data bus drive missing message of the level of regulatory SG-J197
180064656P1598 donors for oil temperature, camshaft adjustment-G277 Implausible signal
180074657P1599 idling control lean operation speed over setpoint
180084658P1600 voltage supply terminal 15 voltage too low
180094659P1601 Relay for voltage supply terminal 30 J317 implausible signal
18010465AP1602 voltage supply terminal 30 voltage too low
18011465BP1603 Control unit defective
18012465CP1604 Control unit defective
18013465DP1605 of rough / acceleration sensor electrical fault in the circuit
18014465EP1606 Rough road info / motor target torque of the ABS control unit electrical fault in the circuit
18015465FP1607 speed signal error message from the instrument cluster
180164660P1608 steering angle signal error message from the steering angle sensor
180174661P1609 Crash shut-off has been drawn
180184662P1610 Control unit defective
180194663P1611 requirement error lamp short circuit to ground
180204664P1612 engine control unit incorrectly coded
180214665P1613 request error lamp a disconnection / short circuit to positive
180224666P1614 request error lamp an implausible signal
180234667P1615 donors for oil temperature-G8 implausible signal
180244668P1616 control lamp for Vorgluhzeit-K29 Short circuit to positive
180254669P1617 control lamp for Vorgluhzeit-K29 open / short circuit to ground
18026466AP1618 relay for glow plugs-J52 Short circuit to positive
18027466BP1619 relay for glow plugs-J52 open / short circuit to ground
18028466CP1620 signal for coolant temperature open / short circuit to positive
18029466DP1621 signal for coolant temperature short circuit to ground
18030466EP1622 signal for coolant temperature implausible signal
18031466FP1623 bus drive no communication
180324670P1624 requirement error lamp actively
180334671P1625 bus drive implausible message from gearbox control unit
180344672P1626 data bus drive missing message of the transmission control unit
180354673P1627 data bus drive missing message of the injection pump control unit
180364674P1628 data bus drive missing message of the sender for steering angle
180374675P1629 data bus drive missing message of ADR control unit
180384676P1630 donors for accelerator pedal position-G79 signal too small
180394677P1631 donors for accelerator pedal position-G79 signal too large.
180404678P1632 donors for accelerator pedal position-G79 Supply Voltage
180414679P1633 Encoder 2 for accelerator pedal position-G185 signal too small
18042467AP1634 Encoder 2 for accelerator pedal position-G185 signal too large.
18043467BP1635 data bus drive missing message of the climate control unit
18044467CP1636 data bus drive missing message of the airbag control unit
18045467DP1637 data bus drive missing message of electronic central electrics
18046467EP1638 data bus drive missing message of the clutch control unit
18047467FP1639 Encoder 2.1 for pedal position G79 + G185 Implausible signal
180484680P1640 Control unit defective
180494681Read P1641 Please fault memory of the climate control unit
180504682Read P1642 Please fault memory of the airbag control unit
180514683Read P1643 Please fault memory of electronic central electrics
180524684Read P1644 Please fault memory of the clutch control unit
180534685P1645 data bus drive missing message of all-wheel electronics
180544686Read P1646 Please fault memory of the all-wheel electronics
180554687TESTING P1647 encoding / variants of the control units in the drive train
180564688P1648 Drivetrain data bus defective
180574689P1649 data bus drive missing message of the ABS control unit
18058468AP1650 data bus drive missing message of the instrument cluster
18059468BP1651 data bus drive missing messages
18060468CRead P1652 Please fault memory of the transmission control unit
18061468DRead P1653 Please fault memory of the ABS control unit
18062468ERead P1654 Please fault memory of the instrument cluster
18063468FRead P1655 Please fault memory of ADR control unit
180644690P1656 air conditioning input / output short circuit to ground
180654691P1657 air conditioning input / output short circuit to positive
180664692P1658 bus drive implausible message of ADR control unit
180674693P1659 Kuhlerlufteransteuerung 1 Short circuit to positive
180684694P1660 Kuhlerlufteransteuerung 1 short circuit to ground
180694695P1661 Kuhlerlufteransteuerung 2 short circuit to positive
180704696P1662 Kuhlerlufteransteuerung 2 short circuit to ground
180714697P1663 control valves pump / nozzle short circuit to positive
180724698P1664 control valves pump / nozzle of electrical fault in the circuit
180734699P1665 control valves pump / nozzle mechanical failure
18074469AP1666 valve for pump / nozzle cylinder 1 N240 electrical fault in the circuit
18075469BP1667 valve for pump / nozzle cylinder 2 N241 electrical fault in the circuit
18076469CP1668 valve for pump / nozzle cylinder 3 N242 electrical fault in the circuit
18077469DP1669 valve for pump / nozzle cylinder 4-N243 electrical fault in the circuit
18078469EP1670 valve for pump / nozzle cylinder 5-N244 electrical fault in the circuit
18079469FP1671 valve for pump / nozzle cylinder 6-N245 electrical fault in the circuit
1808046A0P1672 Kuhlerlufteransteuerung 1 open / short circuit to ground
1808146A1P1673 speed signal error message from ABS control unit
1808246A2P1674 bus drive implausible message from instrument cluster
1808346A3P1675 bus drive implausible message from injection-SG
1808446A4P1676 fault lamp for electric throttle actuation-K132 electrical fault in the circuit
1808546A5P1677 fault lamp for electric throttle actuation-K132 Short circuit to positive
1808646A6P1678 fault lamp for electric throttle actuation-K132 short circuit to ground
1808746A7P1679 error lamp for electrical gas actuating interruption-K132
1808846A8P1680 Reset Fixed emergency operation active
1808946A9not finished P1681 control units programming Programming
1809046AAP1682 bus drive implausible message from ABS-SG
1809146ABP1683 bus drive implausible message from airbag SG
1809246ACP1684 control units programming errors in data transmission
1809346ADP1685 bus drive implausible message from the sender for steering angle
1809446AEP1686 control unit faulty programming error
1809546AFP1687 bus drive implausible message of climate-SG
1809646B0P1688 bus drive implausible message of all-wheel electronics
1809746B1P1689 bus drive implausible message of electronic central electrics
1809846B2P1690 fault lamp for self-diagnosis-K83 electrical fault in the circuit
1809946B3P1691 fault lamp for self-diagnosis-K83 interruption
1810046B4P1692 fault lamp for self-diagnosis-K83 Short circuit to ground
1810146B5P1693 fault lamp for self-diagnosis-K83 Short circuit to positive
1810246B6P1694 error lamp for self-diagnosis-K83 open / short circuit to ground
1810446B8P1696 bus drive implausible message of Lenksaulenelektronik
1810546B9P1697 Please fault memory of the encoder read for steering angle
1810646BARead P1698 Please fault memory of Lenksaulenelektronik
1810746BBP1699 data bus drive missing message of Lenksaulenelektronik
1810846BCP1700 brake pressure switch F270 implausible signal
1810946BDP1701 transmission control disabled
1811046BEP1702 error can not draw lots replacement control units function as another error with the same priority exists
1811146BFP1703 emergency because control unit reset
1811246C0P1704 kick-down switch F8 electrical fault in the circuit
1811346C1P1705 Gear / Uebersetzungsuberwachung adaptation limit reached
1811446C2P1706 transmission defective
1811546C3P1707 disorder in mechatronics unit
1811946C7P1711 wheel speed signal 1 => Fuhler front left-G47 Implausible signal
1812446CCP1716 wheel speed signal 2 => Fuhler front right-G45 Implausible signal
1812946D1P1721 wheel speed 3 => Fuhler rear left-G46 Implausible signal
1813146D3P1723 signal for starter interlock interruption
1813246D4P1724 signal for starter interlock short circuit to ground
1813446D6P1726 wheel speed 4 => Fuhler rear right-G44 Implausible signal
1813646D8P1728 Different speeds Rader Implausible signal
1813746D9P1729 signal for starter interlock short circuit to positive
1814146DDP1733 switches for Tiptronic, back-F189 Short circuit to ground
1814546E1P1737 encoder 1 for hydraulic pressure transmission circuit / short circuit to positive
1814646E2P1738 encoder 2 for hydraulic pressure transmission circuit / short circuit to positive
1814746E3P1739 switches for Tiptronic, high-F189 Short circuit to ground
1814846E4P1740 Kupplungstemperaturuberwachung
1814946E5P1741 clutch pressure adaptation Adaptation limit reached
1815046E6P1742 clutch torque adaptation Adaptation limit reached
1815146E7P1743 Kupplungsschlupfuberwachung signal too large.
1815246E8P1744 switch for Tiptronic, recognition-F189 Short circuit to ground
1815346E9P1745 Supply voltage for solenoid valves short circuit to positive
1815446EAP1746 Supply voltage for solenoid valves electrical fault in the circuit
1815546EBP1747 Supply voltage for solenoid valves open / short circuit to ground
1815646ECP1748 Control unit defective
1815746EDP1749 control unit for automatic incorrect coding
1815846EEP1750 power supply voltage too low
1815946EFP1751 power supply voltage too big.
1816046F0P1752 power supply implausible signal
1816146F1P1753 switches for Tiptronic, -F189 Implausible signal
1816246F2P1754 switch for Tiptronic, high-F189 Open / short circuit to positive
1816346F3P1755 switches for Tiptronic, back-F189 Open / short circuit to positive
1816446F4P1756 switches for Tiptronic, recognition-F189 Open / short circuit to positive
1816546F5P1757 power supply interruption
1816646F6P1758 voltage supply terminal 15 interrupt
1816746F7P1759 Getriebeoltemperatur exceeded several times
1816846F8P1760 shift lock => solenoid-N110 electrical fault in the circuit
1816946F9P1761 shift lock => solenoid-N110 short circuit to ground
1817046FAP1762 shift lock => solenoid-N110 short circuit to positive
1817146FBP1763 shift lock => solenoid-N110 interruption
1817246FCP1764 Getriebetemperaturuberwachung
1817346FDP1765 Encoder 2 for hydraulic pressure G194 reaches Adaptation limit
1817446FEP1766 throttle signal from the engine control unit Open / short circuit to positive
1817546FFP1767 throttle signal from the engine control unit short circuit to ground
181764700P1768 encoder 2 for hydraulic pressure G194 signal too large.
181774701P1769 encoder 2 for hydraulic pressure signal G194 too small
181784702P1770 load signal from implausible signal motor control unit
181794703P1771 Load signal from the engine control unit Open / short circuit to positive
181804704P1772 Load signal from the engine control unit short circuit to ground
181814705P1773 encoder 1 for hydraulic pressure G193 signal too large.
181824706P1774 encoder 1 for hydraulic pressure signal G193 too small
181834707P1775 encoder 1 for hydraulic pressure G193 reaches Adaptation limit
181844708P1776 encoder 1 for hydraulic pressure G193 implausible signal
181854709P1777 encoder 2 for hydraulic pressure G194 implausible signal
18186470AP1778 valve 7 electrical fault in the circuit
18188470CP1780 moment repossession flawed
18189470DP1781 signal for torque reduction circuit / short circuit to ground
18190470EP1782 signal for torque reduction Short circuit to positive
18191470FP1783 clutch torque adaptation reaches 2 Adaptation limit
181924710P1784 high / reverse switching line disconnection / short circuit to ground
181934711P1785-up / pull switch line short circuit to positive
181944712P1786 signal for rearview light intercepting
181954713P1787 signal for rear-view light short circuit to ground
181964714P1788 signal for rear-view light short circuit to positive
181974715P1789 Idle speed influencing error message from engine-control unit
181984716P1790 signal for selection range display interrupt
181994717P1791 signal for elective indication Short circuit to ground
182004718P1792 signal for elective indication Short circuit to positive
182014719P1793 encoder 2 for transmission output speed-G196 no signal
18203471BP1795 signal for driving speed interrupt
18204471CP1796 signal for driving speed short circuit to ground
18205471DP1797 signal for driving speed short circuit to positive
18206471EP1798 encoder 2 for transmission output speed-G196 Implausible signal
18207471FP1799 encoder 2 for transmission output speed-G196 speed too high
182084720P1800 valve for hydraulic plate-N331 electrical fault in the circuit
182094721P1801 beep activation short circuit to positive
182104722P1802 clutch pedal switch F194 implausible signal
182114723P1803 Planetennachschaltstufe mechanical failure
182124724P1804 displacement sensor for hydraulic regulator G302-electrical fault in the circuit
182134725exceeded P1805 displacement sensor for hydraulic regulator G302-upper limit
182144726P1806 displacement sensor for hydraulic regulator G302-lower limit exceeded
182154727P1807 displacement sensor for hydraulic regulator G302-off or incorrect basic setting / adaption
182164728P1808 displacement sensor for hydraulic regulator-G302 Implausible signal
182174729P1809 hydraulic pump for additional shift-V190 electrical fault in the circuit
18221472DP1813 pressure regulating valve 1-N215 electrical fault in the circuit
18222472EP1814 pressure regulating valve 1-N215 open / short circuit to ground
18223472FP1815 Pressure control valve 1 N215 short circuit to positive
182264732P1818 pressure control valve 2 N216 electrical fault in the circuit
182274733P1819 pressure control valve 2 N216 open / short circuit to ground
182284734P1820 Pressure control valve 2-N216 short circuit to positive
182314737P1823 pressure control valve 3 N217 electrical fault in the circuit
182324738P1824 pressure control valve 3 N217 open / short circuit to ground
182334739P1825 pressure control valve 3-N217 short circuit to positive
18236473CP1828 pressure control valve 4 N218 electrical fault in the circuit
18237473DP1829 pressure control valve 4 N218 open / short circuit to ground
18238473EP1830 Pressure control valve 4 N218 short circuit to positive
182414741P1833 pressure control valve 5 N233 electrical fault in the circuit
182424742P1834 pressure control valve 5 N233 open / short circuit to ground
182434743P1835 Pressure control valve 5 N233 short circuit to positive
182464746P1838 pressure regulating valve 6-N371 electrical fault in the circuit
182474747P1839 pressure regulating valve 6-N371 open / short circuit to ground
182484748P1840 Pressure control valve 6 N371 short circuit to positive
182494749P1841 engine / transmission control versions do not match
18250474ARead P1842 Please fault memory of the instrument cluster
18251474BRead P1843 Please fault memory of ADR control unit
18252474CRead P1844 Please fault memory of electronic central electrics
18253474DRead P1845 Please fault memory of Lenksaulenelektronik-J527
18255474FRead P1847 Please fault memory of the ABS control unit
182564750Read P1848 Please fault memory of engine control unit-
182574751Read P1849 Please fault memory of the transmission control unit
182584752P1850 data bus drive missing message of the engine control unit
182594753P1851 data bus drive missing message of the ABS control unit
182604754P1852 bus drive implausible message of motor control unit
182614755P1853 bus drive implausible message from ABS control unit
182624756P1854 bus drive Hardware defective
182634757P1855 bus drive Softwarestandsuberwachung
182644758P1856 Throttle-G69 error message from engine-control unit
182654759P1857 Load signal Fault message from engine control unit
18266475AP1858 speed signal from the engine control unit fault message from engine-control unit
18267475BP1859 Brake light switch-F error message from engine-control unit
18268475CP1860 kick-down switch F8 error message from engine-control unit
18269475DP1861 donors for accelerator pedal position-G79 error message from engine control unit
18270475EP1862 data bus drive missing message of the instrument cluster
18271475FP1863 data bus drive missing message of the sender for steering angle
182724760P1864 data bus drive missing message of ADR control unit
182734761P1865 data bus drive missing message of electronic central electrics
182744762P1866 data bus drive missing messages
182754763P1867 data bus drive missing messages of Lenksaulenelektronik-J527
182764764P1868 valve left for transmission mounting-N262 short circuit to positive
182774765P1869 valve left for transmission mounting-N262 short circuit to ground
182784766P1870 valve left for transmission interruption storage N262
182794767P1871 valve right for transmission mounting-N263 short circuit to positive
182804768P1872 valve right for transmission mounting-N263 short circuit to ground
182814769P1873 valve right for transmission mounting-N263 interruption
18282476AP1874 valve for torque Stutz bearing short circuit to positive
18283476BP1875 valve for torque Stutz bearing short circuit to ground
18284476CP1876 valve for torque Stutz bearing interruption
18285476DP1877 control Kuhlkeislauf transmission interruption J696
18286476EP1878 control Kuhlkeislauf gearbox J696 Short circuit to positive
18287476FP1879 Kuhlkeislauf driving gear J696 Short circuit to ground
182884770P1880 data missing message of the diagnostic interface SG
182894771P1881 Signal target acceleration missing message
182904772P1882 data bus drive missing message of the SG Electric parking brake
182914773P1883 signal for starter lock (P / N) implausible signal
182924774P1884 signal for rear-view light short circuit to ground
182934775P1885 signal for rear-view light short circuit to positive
182944776P1886 signal for rearview light intercepting
182954777P1887 speed signal Implausible wheel speed signal from Bremsensteuergerat
182964778P1888 shut-off valve for coolant-N82 Short to positive
182974779P1889 shut-off valve for coolant-N82 Short to earth / interruption
183084784P1900 Kuhlerlufteransteuerung 2 open / short circuit to ground
183094785P1901 control unit for Kuhlerlufternachlauf-J138 Short circuit to positive
183104786P1902 control unit for Kuhlerlufternachlauf-J138 Open / short circuit to ground
183114787P1903 valve for Lufter coolant-N313 short circuit to positive
183124788P1904 valve for Lufter coolant-N313 open / short circuit to ground
183134789P1905 relays for pump Ladeluftkuhlung-J536 Short circuit to positive
18314478AP1906 relays for pump Ladeluftkuhlung-J536 Open / short circuit to ground
18315478BP1907 bus engine / motor defective
18316478CP1908 bus engine / motor Softwarestandsuberwachung
18317478DP1909 bus engine / motor missing message from engine control unit 1
18318478EP1910 bus engine / motor missing message from engine control unit 2
18319478FP1911 synchronization line engine / motor electrical fault in the circuit
183204790P1912 pressure sensor for brake booster-G294 Short circuit to positive
183214791P1913 pressure sensor for brake booster-G294 short circuit to ground
183224792P1914 pressure sensor for brake booster-G294 Implausible signal
183234793P1915 relay for Kuhlmittelnachlauf-J151 Short circuit to positive
183244794P1916 relay for Kuhlmittelnachlauf-J151 short circuit to ground
183254795P1917 relay for Kuhlmittelnachlauf-J151 interruption
183264796P1918 load signal from alternator terminal DF open / short circuit to positive
183274797P1919 load signal from alternator terminal DF short circuit to ground
183284798P1920 valves for engine storage-N144 / 145 Open / short circuit to ground
183294799P1921 Temperature Sensor 2 for Au.entemperatur-G249 short circuit to ground
18330479AP1922 Temperature Sensor 2 for Au.entemperatur-G249 open / short circuit to positive
18331479BRead P1923 Please fault memory of engine control unit 2
18332479CP1924 Steuergeratepincodierung implausible signal
18333479DP1925 relay for Kuhlmittelzusatzpumpe-J496 Short circuit to positive
18334479EP1926 relay for Kuhlmittelzusatzpumpe-J496 short circuit to ground
18335479FP1927 relay for Kuhlmittelzusatzpumpe-J496 interruption
1833647A0P1928 Wegfahrsperrenabfrage not performed
1833747A1P1929 Lufter for coolant-V7 interruption
1833847A2P1930 Lufter 2 for coolant-V177 interruption
1833947A3P1931 control unit for Lufter for coolant-J293 malfunction
1834047A4P1932 bus drive implausible message of Steuerg.f.Zugang and Startber.
1834147A5P1933 Throttle Control 2 malfunction
1834247A6P1934 Temperature Sensor for drive circuit Kuhlerlufter-G382 signal too small
1834347A7P1935 Temperature Sensor for drive circuit Kuhlerlufter-G382 signal too large.
1834447A8P1936 generator shutdown circuit / short circuit to ground
1834547A9P1937 generator shutdown Short circuit to positive
1834647AAP1938 relay for Kuhlmittelzusatzpumpe-J496 Open / short circuit to ground
1834747ABP1939 data bus drive missing message of Steuerg.f.Zugang and Startber.
1834847ACP1940 data bus drive missing message v.Steuergerat f.Batterieuberwachung
1834947ADP1941 bus drive implausible message v.Steuerg.f.Batterieuberwachung
1835047AEP1942 data bus drive missing message of control unit for level control
1835147AFP1943 bus drive implausible message from control unit for level control
1835247B0P1944 control unit 1 for Kuhlerlufter overtemperature
1835347B1P1945 control unit for Kuhlerlufter 1, Lufteransteuerung short
1835447B2P1946 control unit 1 defective for Kuhlerlufter
1835547B3P1947 control unit 2 for Kuhlerlufter overtemperature
1835647B4P1948 control unit for Kuhlerlufter 2, Lufteransteuerung short
1835747B5P1949 Control unit defective 2 for Kuhlerlufter
1835847B6P1950 Lufter for coolant-V7 schwergangig / blocked
1835947B7P1951 Lufter 2 for coolant-V177 schwergangig / blocked
1836047B8P1952 control unit defective 1 for turbocharger
1836147B9P1953 control unit defective 2 for turbocharger
1836247BAP1954 Gluhzeitsteuergerat 2, Gluhstromkreis electrical fault in the circuit
1836347BBP1955 Gluhzeitsteuergerat 2-J703 implausible signal
1836447BCP1956 Encoder 2 for exhaust gas temperature bank 1-G448 electrical fault
1836547BDP1957 Encoder 2 for exhaust gas temperature bank 1-G448 short circuit to ground
1836647BEP1958 Encoder 2 for exhaust gas temperature bank 1-G448 Short circuit to positive
1836747BFP1959 Encoder 2 for exhaust gas temperature bank 1-G448 Implausible signal
1836847C0P1960 exhaust gas temperature control exhaust bank exceeded 3 control limit
1836947C1P1961 Encoder 2 for exhaust gas temperature bank 2-G449 electrical fault
1837047C2P1962 Encoder 2 for exhaust gas temperature bank 2-G449 short circuit to ground
1837147C3P1963 Encoder 2 for exhaust gas temperature bank 2-G449 Short circuit to positive
1837247C4P1964 Encoder 2 for exhaust gas temperature bank 2-G449 Implausible signal
1837347C5P1965 exhaust gas temperature control exhaust bank exceeded 4 Control limit
1837447C6P1966 relay for secondary air pump 3-J704 interruption
1837547C7P1967 relay for secondary air pump 3-J704 Short circuit to positive
1837647C8P1968 relay for secondary air pump 3-J704 short circuit to ground
1837747C9P1969 relay for secondary air pump 3-J704 electrical fault in the circuit
1837847CAP1970 relay for secondary air pump 4-J705 interruption
1837947CBP1971 relay for secondary air pump 4-J705 Short circuit to positive
1838047CCP1972 relay for secondary air pump 4-J705 short circuit to ground
1838147CDP1973 relay for secondary air pump 4-J705 electrical fault in the circuit
1838247CEP1974 Sekundarlufteinblasventil 3-N384 electrical fault in the circuit
1838347CFP1975 Sekundarlufteinblasventil 3-N384 short circuit to ground
1838447D0P1976 Sekundarlufteinblasventil 3-N384 short circuit to positive
1838547D1P1977 Sekundarlufteinblasventil 3-N384 interruption
1838647D2P1978 Sekundarlufteinblasventil 4-N385 electrical fault in the circuit
1838747D3P1979 Sekundarlufteinblasventil 4-N385 short circuit to ground
1838847D4P1980 Sekundarlufteinblasventil 4-N385 short circuit to positive
1838947D5P1981 Sekundarlufteinblasventil 4-interruption N385
1839047D6P1982 exhaust gas temperature control exhaust bank 3 implausible
1839147D7P1983 exhaust gas temperature control exhaust bank 4 implausible
1839247D8P1984 Lufter 3 for coolant-V284 schwergangig / blocked
1839347D9P1985 control unit 2 for Lufter for coolant-J671 malfunction
1839447DAP1986 control unit for Kuhlerlufter 3, Lufteransteuerung short
1839547DBP1987 Funktionseinschrankung by brake temperature
1839647DCP1988 relay for Kuhlmittellufter 3-J752 interruption
1839747DDP1989 relay for Kuhlmittellufter 3-J752 Short circuit to positive
1839847DEP1990 relay for Kuhlmittellufter 3-J752 short circuit to ground
1839947DFP1991 Control unit defective
1840047E0P1992 potentiometer 2 for exhaust gas recirculation-G466 errors in default
1840147E1P1993 potentiometer 2 for exhaust gas recirculation-G466 signal too large.
1840247E2P1994 potentiometer 2 for exhaust gas recirculation-G466 signal too small
1840347E3P1995 Signal Tur not detected on
1840447E4P1996 friction too high code E1
1840547E5P1997 friction too high Code A1
1840647E6P1998 friction too high Code E2
1840747E7P1999 friction too high Code E2
184344802P2002 particulate filter bank 1 malfunction
184354803P2003 particulate filter bank 2 malfunction
184364804P2004 Intake manifold for air flow control bank 1 hangs open
184374805P2005 Intake manifold for air flow control bank 2 hangs open
184384806P2006 Intake manifold for air flow control bank 1 depends closed
184394807P2007 Intake manifold for air flow control bank 2 depends closed
184404808P2008 Intake manifold for air flow control electrical fault
184414809P2009 Intake manifold for air flow control short circuit to ground
18442480AP2010 Intake manifold for air flow control Short circuit to positive
18443480BP2011 Intake manifold 2 for airflow control electrical fault
18444480CP2012 Intake manifold 2 for airflow control short circuit to ground
18445480DP2013 Intake manifold 2 for airflow control Short circuit to positive
18446480EP2014 donors Saugrohrklappenstellung electrical fault in the circuit
18447480FP2015 donors Saugrohrklappenstellung implausible signal
184484810P2016 donors Saugrohrklappenstellung short circuit to ground
184494811P2017 donors Saugrohrklappenstellung short circuit to positive
184514813P2019 encoder Saugrohrklappenstellung intake manifold 2 of electrical fault in the circuit
184524814P2020 encoder Saugrohrklappenstellung intake manifold 2 implausible signal
184534815P2021 donors Saugrohrklappenstellung intake manifold 2 short circuit to ground
184544816P2022 donors Saugrohrklappenstellung intake manifold 2 short circuit to positive
18463481FP2031 Encoder 2 for exhaust gas temperature elektricher error
184644820P2032 Encoder 2 for exhaust gas temperature short circuit to ground
184654821P2033 Encoder 2 for exhaust gas temperature short circuit to positive
184664822P2034 Encoder 2 exhaust gas temperature bank 2 for electrical fault in the circuit
184674823P2035 Encoder 2 for exhaust gas temperature bank 2 short circuit. to ground
184684824P2036 Encoder 2 for exhaust gas temperature bank 2 short circuit. to positive
185024846P2070 variable intake depends open
185034847P2071 variable intake depends closed
18507484BP2075 donors for Schaltsaugrohrposition electrical fault
18508484CP2076 for donors Schaltsaugrohrposition implausible signal
18509484DP2077 donors for Schaltsaugrohrposition short circuit to ground
18510484EP2078 donors for Schaltsaugrohrposition short circuit to positive
18511484FP2079 donors for Schaltsaugrohrposition interruption
185124850P2080 encoder 1 for exhaust gas temperature-G235 Implausible signal
185144852P2082 encoder 1 for exhaust gas temperature bank 2-G236 Implausible signal
185164854P2084 Encoder 2 for exhaust gas temperature implausible signal
185184856P2086 Encoder 2 for exhaust gas temperature bank 2 implausible signal
185204858P2088 Bank 1, camshaft adjustment short circuit to ground
185214859P2089 Bank1, camshaft adjustment Short circuit to positive
18522485AP2090 Bank1, camshaft adjustment, outlet Short circuit to ground
18523485BP2091 Bank1, camshaft adjustment, outlet short circuit to positive
18524485CP2092 Bank2, camshaft adjustment short circuit to ground
18525485DP2093 Bank2, camshaft adjustment Short circuit to positive
18526485EP2094 Bank2, camshaft adjustment, outlet Short circuit to ground
18527485FP2095 Bank2, camshaft adjustment, outlet short circuit to positive
185284860exceeded P2096 Bank1, lambda correction lean behind cat Control limit
185294861exceeded P2097 Bank1, lambda correction fat behind cat Control limit
185304862exceeded P2098 Bank2, lambda correction lean behind cat Control limit
185314863exceeded p2099 Bank 2, lambda correction fat behind cat Control limit
18554487AP2122 donors for accelerator pedal position-G79 signal too small
18555487BP2123 donors for accelerator pedal position-G79 signal too large.
18559487FP2127 Encoder 2 for accelerator pedal position-G185 signal too small
185604880P2128 Encoder 2 for accelerator pedal position-G185 signal too large.
18570488AP2138 Encoder 2.1 for pedal position G79 + G185 Implausible signal
185784892P2146 supply injection valve (s) A break
185794893P2147 supply injector (e) A short circuit to ground
185804894P2148 supply injector (e) A short circuit to positive
185814895P2149 supply injection valve (s) B interruption
185824896P2150 supply injection valve (s) B Short circuit to ground
185834897P2151 supply injector (s) B Short circuit to positive
1860948B1P2177 Bank1, fuel metering system System too lean at idle speed
1861048B2P2178 Bank1, fuel metering system System too rich from idle speed
1861148B3P2179 Bank2, fuel metering system System too lean at idle speed
1861248B4P2180 Bank2, fuel metering system System too rich from idle speed
1861348B5P2181 fault in the cooling system
1861548B7P2183 donors for coolant temperature-Kuhle output-G83 Implausible signal
1861648B8P2184 donors for coolant temperature-Kuhle output-G83 signal too small
1861748B9P2185 donors for coolant temperature-Kuhle output-G83 signal too large.
1861948BBP2187 Bank1, fuel metering system System too lean at idle speed
1862048BCP2188 Bank1, fuel metering system System too rich at idle speed
1862148BDP2189 Bank2, fuel metering system System too lean at idle speed
1862248BEP2190 Bank2, fuel metering system System too rich at idle speed
1862348BFP2191 Bank1, fuel metering system System too lean at full load
1862448C0P2192 Bank1, fuel metering system System too rich at full load
1862548C1P2193 Bank2, fuel metering system System too lean at full load
1862648C2P2194 Bank 2, fuel metering system System too rich at full load
1862748C3P2195 lambda Sonde1- Bank1 signal to lean
1862848C4P2196 lambda Sonde1- Bank1 signal to fat
1862948C5P2197 lambda probe 1 Bank 2 signal to lean
1863048C6P2198 lambda probe 1 Bank 2 signal to fat
1863148C7for P2199 donor intake 1 <> 2 Deviation
1866348E7P2231 lambda probe 1 bank 1 short-circuit the heating circuit
1866448E8P2232 lambda probe 2 bank 1 short-circuit the heating circuit
1866548E9P2233 lambda probe 3 Bank 1 Short circuit for heating circuit
1866648EAP2234 Oxygen sensor 1 Bank 2 Short circuit for heating circuit
1866748EBP2235 lambda probe 2 Bank 2 Short circuit for heating circuit
1866848ECP2236 lambda probe 3 Bank 2 Short circuit for heating circuit
1866948EDP2237 lambda probe 1 Bank 1, pump current cutting
1867048EEP2238 Lambda probe 1 bank 1, pump current short circuit to ground
1867148EFP2239 lambda probe 1 bank 1, pump current short circuit to positive
1867248F0P2240 lambda probe 1 Bank 2, pump current cutting
1867348F1P2241 lambda probe 1 Bank 2, pump current short circuit to ground
1867448F2P2242 lambda probe 1 bank 2, pump current short circuit to positive
1867548F3P2243 lambda probe 1 Bank 1, reference voltage interruption
1867648F4P2244 lambda probe 1 Bank 1, reference voltage implausible signal
1867748F5P2245 lambda probe 1 bank 1, reference voltage short circuit to ground
1867848F6P2246 lambda probe 1 bank 1, reference voltage short circuit to positive
1867948F7P2247 lambda probe 1 Bank 2, reference voltage interruption
1868048F8P2248 lambda probe 1 Bank 2, reference voltage implausible signal
1868148F9P2249 lambda probe 1 Bank 2, reference voltage Short circuit to ground
1868248FAP2250 lambda probe 1 bank 2, reference voltage short circuit to positive
1868348FBP2251 lambda probe 1 Bank 1, ground line interruption
1868448FCP2252 lambda probe 1 bank 1, ground line short circuit to ground
1868548FDP2253 lambda probe 1 bank 1, ground line short circuit to positive
1868648FEP2254 lambda probe 1 Bank 2, ground line interruption
1868748FFP2255 lambda probe 1 Bank 2, the ground line short-circuit to ground
186884900P2256 Lambda probe 1 bank 2, ground line short circuit to positive
186894901P2257 relay for secondary air pump J299 short circuit to ground
186904902P2258 relay for secondary air pump J299 Short circuit to positive
186934905P2261 air recirculation valve for turbocharger N249 mechanical failure
18702490EP2270 lambda probe 2 Bank 1 signal to lean
18703490FP2271 lambda probe 2 Bank 1 signal to fat
187044910P2272 lambda probe 2 Bank 2 signal to lean
187054911P2273 lambda probe 2 Bank 2 signal to fat
187064912P2274 lambda probe 3 Bank 1 signal to lean
187074913P2275 lambda probe 3 Bank 1 signal to fat
187084914P2276 lambda probe 3 Bank 2 signal to lean
187094915P2277 lambda probe 3 Bank 2 signal to fat
187114917P2279 leakage air in the intake system
187254925P2293 control valve for fuel pressure mechanical failure
187264926P2294 control valve for fuel pressure interruption
187274927P2295 control valve for fuel pressure short circuit to ground
187284928P2296 control valve for fuel pressure short circuit to positive
187294929exceeded P2297 exhaust Bank 1, probe 1, lambda probe signal voltage during coasting, control limit
18730492Aexceeded P2298 exhaust bank 2, probe 1, lambda probe signal voltage during coasting, control limit
18732492CP2300 control Ignition coil 1 short circuit. to ground
18733492DP2301 control Ignition coil 1 short circuit. to positive
18734492EP2302 secondary circuit Ignition coil 1 Malfunction
18735492FP2303 control Ignition coil 2 short circuit. to ground
187364930P2304 control Ignition coil 2 short circuit. to positive
187374931P2305 Ignition coil secondary circuit malfunction 2
187384932P2306 control Ignition coil 3 short circuit. to ground
187394933P2307 control Ignition coil 3 short circuit. to positive
187404934P2308 Ignition coil secondary circuit 3 malfunction
187414935P2309 control Ignition coil 4 short circuit. to ground
187424936P2310 control Ignition coil 4 short circuit. to positive
187434937P2311 Ignition coil secondary circuit malfunction 4
187444938P2312 control Ignition coil 5 short circuit. to ground
187454939P2313 control Ignition coil 5 short circuit. to positive
18746493AP2314 Ignition coil secondary circuit 5 malfunction
18747493BP2315 Ignition coil control 6 short circuit. to ground
18748493CP2316 Ignition coil control 6 short circuit. to positive
18749493DP2317 Ignition coil secondary circuit 6 malfunction
18750493EP2318 control Ignition coil 7 short circuit. to ground
18751493FP2319 control Ignition coil 7 short circuit. to positive
187524940P2320 secondary circuit Ignition coil 7 malfunction
187534941P2321 control Ignition coil 8 short circuit. to ground
187544942P2322 control Ignition coil 8 short circuit. to positive
187554943P2323 Ignition coil secondary circuit 8 malfunction
187564944P2324 control Ignition coil 9 short circuit. to ground
187574945P2325 control Ignition coil 9 short circuit. to positive
187584946P2326 Ignition coil secondary circuit 9 malfunction
187594947P2327 Ignition coil control 10 short circuit. to ground
187604948P2328 Ignition coil control 10 short circuit. to positive
187614949P2329 Ignition coil secondary circuit 10 malfunction
18762494AP2330 Ignition coil control 11 short circuit. to ground
18763494BP2331 Ignition coil control 11 short circuit. to positive
18764494CP2332 Ignition coil secondary circuit 11 malfunction
18765494DP2333 Ignition coil control 12 short circuit. to ground
18766494EP2334 Ignition coil control 12 short circuit. to positive
18767494FP2335 Ignition coil secondary circuit 12 malfunction
187684950P2336 knock control cylinder reaches one control limit
187694951P2337 knock control cylinder reaches 2 Control limit
187704952P2338 knock control cylinder reaches 3 control limit
187714953P2339 knock control cylinder reaches 4 Control limit
187724954P2340 knock control cylinder reaches 5 Control limit
187734955P2341 knock control cylinder reaches 6 Control limit
187744956P2342 knock control cylinder reaches 7 control limit
187754957P2343 knock control cylinder reaches 8 control limit
187764958P2344 knock control cylinder reaches 9 Control limit
187774959P2345 knock control cylinder reaches 10 control limit
18778495AP2346 knock control cylinder reaches 11 control limit
18779495BP2347 knock control cylinder reaches 12 control limit
188324990P2400 Tankentluftungssyst., Drive diagnosis pump f.Tankleckage electrical failure / interruption
188334991P2401 Tankentluftungssyst., Drive diagnosis pump f.Tankleckage short circuit. to ground
188344992P2402 Tankentluftungssyst., Drive diagnosis pump f.Tankleckage short circuit. to positive
188354993P2403 Tankentluftungssystem, sensor diagnosis pump for tank leakage, electrical failure / interruption
188364994P2404 Tankentluftungssystem, sensor diagnosis pump for tank leakage, implausible signal
18845499DP2413 fault in Abgasruckfuhrungssystem
18846499EP2414 Bank1-Electrode1 voltage too low / leakage air
18847499FP2415 Bank2-Electrode1 voltage too low / leakage air
1884849A0P2416 exhaust bank 1 lambda probes before and after reversed Hauptkat
1884949A1P2417 exhaust bank 2 lambda probes before and after reversed Hauptkat
1885349A5P2420 Tankentluftungssystem, solenoid valve 2 for activated carbon N115 constantly open
1885449A6P2421 Tankentluftungssystem, solenoid valve 2 for activated carbon N115 constantly closed
1885749A9P2425 valve for exhaust gas recirculation interruption Cooling
1885849AAP2426 valve for exhaust gas recirculation Cooling short circuit to ground
1885949ABP2427 valve for exhaust gas recirculation Cooling short circuit to positive
1888449C4P2452 diesel particulate filter differential pressure transmitter electrical fault
1888549C5P2453 diesel particulate filter differential pressure transmitter implausible signal
1888649C6P2454 diesel particulate filter differential pressure transducer short circuit. to ground
1888749C7P2455 diesel particulate filter differential pressure transducer short circuit. to positive
189654A15P2533 Zundanlassschloss circuit short circuit to ground / interruption
189674A17P2535 Zundanlassschloss Circuit Short to positive
189714A1BP2539 encoder for fuel pressure, low pressure interruption G410
189724A1CP2540 donors for fuel pressure, low pressure G410 Implausible signal
189734A1DP2541 donors for fuel pressure, low pressure G410 short circuit to ground
189744A1EP2542 donors for fuel pressure, low pressure G410 short circuit to positive
189754A1FP2543 donors for fuel pressure, low pressure G410 pulsating signal
189954A33P2563 position sensor for charging pressure plate implausible signal
189964A34P2564 position sensor for charging pressure plate signal too small
189974A35P2565 position sensor for charging pressure plate signal too large.
189984A36P2566 position sensor for charging pressure plate no signal
190324A58P2600 pump for coolant interruption
190334A59P2601 pump for coolant implausible signal
190344A5AP2602 pump for coolant short circuit to ground
190354A5BP2603 pump for coolant short circuit to positive
190584A72P2626 linear oxygen sensor, exhaust Bank1 / calibration line pump current cutting
190614A75P2629 linear oxygen sensor, exhaust Bank2 / calibration line pump current cutting
190644A78P2632 Relay for electric fuel pump 2-J49 interruption
190654A79P2633 Relay for electric fuel pump 2-J49 short circuit to ground
190664A7AP2634 Relay for electric fuel pump 2-J49 Short circuit to positive
190694A7DP2637 motor torque signal A
191404AC4P2708-off valve 6 => solenoid valve 6-N93 Short to positive
191434AC7P2711 implausible gear shifting sequence
191464ACAP2714 pressure control valve 4 open / short circuit to ground
191474ACBP2715 Pressure control valve 4 short circuit to positive
191484ACCP2716 pressure control valve 4 electrical fault in the circuit
191494ACDP2717 pressure control valve 4 Interruption
191554AD3P2723 pressure control valve 5 open / short circuit to ground
191564AD4P2724 Pressure control valve 5 Short circuit to positive
191574AD5P2725 pressure control valve 5 electrical fault in the circuit
191584AD6P2726 pressure control valve 5 Interruption
191644ADCP2732 pressure regulating valve 6 open / short circuit to ground
191654ADDP2733 Pressure control valve 6 Short circuit to positive
191664ADEP2734 pressure regulating valve 6 of electrical fault in the circuit
191674ADFP2735 pressure regulating valve 6 interrupt
192194B13P2787 clutch overtemperature
192214B15P2789 clutch adaptation at the stop
194564C00P3000 control lamp for Vorgluhzeit-K29 error message from the instrument cluster
194574C01P3001 working speed control system deviation
194584C02P3002 kick-down switch F8 implausible signal
194594C03P3003 Relay for low heating-J359 Short circuit to positive
194604C04P3004 Relay for low heating-J359 Open / short circuit to ground
194614C05P3005 relay for gro.e heating-J360 Short circuit to positive
194624C06P3006 relay for gro.e heating-J360 Open / short circuit to ground
194634C07P3007 Camshaft position sensor-G40 no signal
194644C08P3008 camshaft position sensor signal G40 au.erhalb tolerance
194654C09P3009 relays for pump Kraftstoffkuhlung-J445 short circuit to positive
194664C0AP3010 relays for pump Kraftstoffkuhlung J445-circuit / short circuit to ground
194674C0BP3011 Relay for electric fuel pump 2-J49 short circuit to positive
194684C0CP3012 relay for electric fuel pump 2 J49 open / short circuit to ground
194694C0DP3013 valve 2 for charge pressure control-N274 short circuit to positive
194704C0EP3014 valve 2 for charge pressure limitation N274-circuit / short circuit to ground
194714C0FP3015 valve for fuel bypass N312 short circuit to positive
194724C10P3016 valve for fuel bypass N312 open / short circuit to ground
194734C11P3017 valve for exhaust flap 1-N321 short circuit to positive
194744C12P3018 valve for exhaust flap 1-N321 short circuit to ground
194754C13P3019 valve for exhaust flap 1-N321 interruption
194764C14P3020 valve for exhaust flap 1-N321 electrical fault in the circuit
194774C15P3021 valve for exhaust flap 2-N322 short circuit to positive
194784C16P3022 valve for exhaust flap 2-N322 short circuit to ground
194794C17P3023 valve for exhaust flap 2-N322 interruption
194804C18P3024 valve for exhaust flap 2-N322 electrical fault in the circuit
194814C19P3025 angle sensor 1 for driving DK-2-G297 implausible signal
194824C1AP3026 angle sensor 1 for driving DK-2-G297 signal too small
194834C1BP3027 angle sensor 1 for driving DK-2-G297 signal too large.
194844C1CP3028 angle sensor 2 for drive DK-2-G298 implausible signal
194854C1DP3029 angle sender 2 for DK-drive 2-G298 signal too small
194864C1EP3030 angle sender 2 for DK-drive 2-G298 signal too large.
194874C1FP3031 throttle valve drive 2-G296 electrical fault in the circuit
194884C20P3032 throttle control unit 2 J544 errors in default
194894C21P3033 Encoder 2 for intake-G299 signal too small
194904C22P3034 Encoder 2 for intake-G299 signal too large.
194914C23P3035 throttle valve control unit 2-J544 mechanical failure
194924C24P3036 throttle control unit 2 J544 undervoltage at default
194934C25P3037 throttle valve control unit not started 2-J544 adaptation
194944C26P3038 throttle control unit 2 J544 lower stop is not reached
194954C27P3039 gear requesting torque reduction implausible
194964C28P3040 gear ratios implausible
194974C29P3041 bus drive implausible engine temperature message from combi
194984C2AP3042 heating control Implausible signal
194994C2BP3043 fuel pump mechanical failure
195004C2CP3044 Fuel pump short circuit
195014C2DP3045 fuel pump electronics defective
195024C2EP3046 starter relay 1 elektr.Fehler the circuit (glued relay / not activated)
195034C2FP3047 control starter relay 2 short circuit to positive
195044C30P3048 control starter relay 2 short circuit to ground
195054C31P3049 control starter relay 2 Interruption
195064C32P3050 starter relay 2 elektr.Fehler the circuit (glued relay / not activated)
195074C33P3051 Starter control, jerk message terminal 50 Implausible signal
195084C34P3052 Starter control, jerk message terminal 50 Short circuit to positive
195094C35P3053 starter control, jerk message terminal 50 to ground short circuit / disconnection
195104C36P3054 starter turns not mechanically blocked or electrical failure
195114C37P3055 pressure sensor 2 for exhaust interruption
195124C38P3056 pressure sensor 2 for exhaust short circuit to ground
195134C39P3057 pressure sensor 2 for exhaust short circuit to positive
195144C3AP3058 Abgasruckfuhrungssystem 2 Throughput too small
195154C3BP3059 Abgasruckfuhrungssystem 2 Throughput too large.
195164C3CP3060 valve for Kuhlungsbypass, exhaust gas recirculation-N386 electrical fault
195174C3DP3061 valve 2 for Kuhlungsbypass, exhaust gas recirculation-N387 electrical fault
195184C3EP3062 boost pressure control 2 boost pressure is too great.
195194C3FP3063 boost pressure control 2 boost pressure too small
195204C40P3064 valve 3 for boost pressure control-N388 electrical fault
195214C41P3065 valve 3 for boost pressure control-N388 short circuit to ground
195224C42P3066 valve 3 for charge pressure control-N388 short circuit to positive
195234C43P3067 valve 4 for boost pressure control-N389 electrical fault
195244C44P3068 valve 4 for boost pressure control-N389 short circuit to ground
195254C45P3069 valve 4 for charge pressure control-N389 short circuit to positive
195264C46defective P3070 pump for additive particle-V135
195274C47P3071 additive tank for particulate empty
195284C48P3072 power supply relay electrical fault in the circuit
195294C49P3073 fuel pump electrical fault in the circuit
195304C4AP3074 fuel pump 2 electrical fault in the circuit
195314C4BP3075 balancing turbocharger reaches 1.2 adaptation limits
195324C4CP3076 engine control errors in coding
195334C4DP3077 fuel pump electronics power supply electrical fault
195344C4EP3078 throttle valve control air flow idle too low
195354C4FP3079 relay for fuel booster pump cold start-J748 Short circuit to positive
195364C50P3080 relay for fuel booster pump cold start-J748 short circuit to ground / interruption
195374C51P3081 Engine Temperature
195384C52P3082 donors for clutch position-G476 Implausible signal
195394C53P3083 donors for fuel additive tank particulate filter G504 electrical fault in the circuit
195404C54P3084 air recirculation valve for turbocharger, Bank 2 mechanical fault
195414C55P3085 controlling intake manifold 2 for airflow control electrical fault
195424C56not carried out P3086 Intake manifold 2 for air flow control default
195434C57P3087 supply relay for engine components electrical fault in the circuit
195444C58P3088 Starter relay electrical fault in the circuit
195454C59P3089 fuel pump electronics signal line electrical fault
195464C5Anot recognized P3090 signal from heater
195474C5BP3091 detected signal from auxiliary heater permanently
195484C5CP3092 Control unit defective
195494C5DP3093 Control unit defective
195504C5EP3094 Control unit defective
195514C5FP3095 Control unit defective
195524C60P3096 Control unit defective
195534C61P3097 Control unit defective
195544C62P3098 Control unit defective
195554C63P3099 Control unit defective
195564C64P3100 engine for Saugrohklappe-V157 short circuit to positive
195574C65P3101 Motor for intake manifold flap-V157 Open / short circuit to ground
195584C66P3102 Motor for intake manifold flap-V157 no signal
195594C67defective P3103 engine for intake manifold flap-V157
195604C68P3104 changeover valve for intake manifold flap-N239 short circuit to positive
195614C69P3105 changeover valve for intake manifold flap N239-open / short circuit to ground
195624C6AP3106 valve for pump / nozzle cylinder 7 N303 implausible signal
195634C6BP3107 valve for pump / nozzle cylinder exceeded 7-N303 control limit
195644C6CP3108 valve for pump / nozzle cylinder below 7-N303 control limit
195654C6DP3109 valve for pump / nozzle cylinder 7 N303 electrical fault in the circuit
195664C6EP3110 valve for pump / nozzle cylinder 8-N304 implausible signal
195674C6FP3111 valve for pump / nozzle cylinder exceeded 8-N304 control limit
195684C70P3112 valve for pump / nozzle cylinder below 8-N304 control limit
195694C71P3113 valve for pump / nozzle cylinder 8-N304 electrical fault in the circuit
195704C72P3114 valve for pump / nozzle cylinder 9-N305 implausible signal
195714C73exceeded P3115 valve for pump / nozzle cylinder 9-N305 control limit
195724C74below P3116 valve for pump / nozzle cylinder 9-N305 control limit
195734C75P3117 valve for pump / nozzle cylinder 9-N305 electrical fault in the circuit
195744C76P3118 valve for pump / nozzle cylinder 10 N306 implausible signal
195754C77P3119 valve for pump / nozzle cylinder exceeded 10-N306 control limit
195764C78below P3120 valve for pump / nozzle cylinder 10 N306 control limit
195774C79P3121 valve for pump / nozzle cylinder 10 N306 electrical fault in the circuit
195784C7AP3122 valve for pump / nozzle cylinder 11-N307 implausible signal
195794C7BP3123 valve for pump / nozzle cylinder exceeded 11-N307 control limit
195804C7CP3124 valve for pump / nozzle cylinder below 11-N307 control limit
195814C7DP3125 valve for pump / nozzle cylinder 11-N307 electrical fault in the circuit
195824C7EP3126 valve for pump / nozzle cylinder 12 N308 implausible signal
195834C7FP3127 valve for pump / nozzle cylinder exceeded 12-N308 control limit
195844C80P3128 valve for pump / nozzle Zylinder12-N308 control limit below
195854C81P3129 valve for pump / nozzle cylinder 12 N308 electrical fault in the circuit
195864C82exceeded P3130 exhaust jerk vehicle system control limit
195874C83below P3131 exhaust jerk vehicle system control limit
195884C84P3132 Gluhzeitsteuergerat 2, Gluhstromkreis electrical fault in the circuit
195894C85P3133 Gluhzeitsteuergerat 2-J609 implausible signal
195904C86P3134 Intake manifold for air flow control Upper stop not reached
195914C87P3135 Intake manifold for air flow control Lower stop not reached
195924C88P3136 Intake manifold for air flow control setpoint is not reached
195934C89not carried out P3137 Intake manifold for air flow control default
195944C8AP3138 Intake manifold for air flow control system deviation
195954C8BP3139 Intake manifold for air flow control signal au.erhalb tolerance
195964C8CP3140 valve for tank empty start Nxxx open / short circuit to ground
195974C8DP3141 valve for tank empty start Nxxx short circuit to positive
195984C8EP3142 exhaust bank 2, probe 1, lambda probe signal implausible lean
195994C8FP3143 exhaust bank 2, probe 1, lambda probe signal implausible fat
196004C90P3144 exhaust bank3, Electrode1, lambda probe signal implausible lean
196014C91P3145 exhaust bank3, Electrode1, lambda probe signal implausible fat
196024C92P3146 exhaust Bank4, Electrode1, lambda probe signal implausible lean
196034C93P3147 exhaust Bank4, Electrode1, lambda probe signal implausible fat
196044C94P3148 exhaust bank 3, lambda probe before Kat, heating current control at the upper stop
196054C95P3149 exhaust bank 3, lambda probe before Kat, heating current control at the lower stop
196064C96P3150 exhaust bank 4, lambda probe before Kat, heating current control at the upper stop
196074C97P3151 exhaust bank 4, lambda probe before Kat, heating current control at the lower stop
196084C98P3152 exhaust bank 3, probe 1 Internal resistance implausible
196094C99P3153 exhaust bank 4, probe 1 Internal resistance implausible
196104C9AP3154 exhaust bank 2-1 probe voltage too low / air leakage
196114C9BP3155 exhaust bank3-Electrode1 voltage too low / leakage air
196124C9CP3156 exhaust Bank4-Electrode1 voltage too low / leakage air
196134C9DP3157 exhaust Bank 1, probe 1, lambda probe signal voltage at pushing too low
196144C9EP3158 exhaust bank 2, probe 1, lambda probe signal voltage at pushing too low
196154C9FP3159 exhaust bank3, Electrode1, oxygen sensor signal voltage at pushing too low
196164CA0P3160 exhaust Bank4, Electrode1, oxygen sensor signal voltage at pushing too low
196174CA1P3161 linear oxygen sensor, exhaust Bank1 / calibration line pump current cutting
196184CA2P3162 linear oxygen sensor, exhaust Bank2 / calibration line pump current cutting
196194CA3P3163 linear oxygen sensor, exhaust Bank3 / calibration line pump current cutting
196204CA4P3164 linear oxygen sensor, exhaust Bank4 / calibration line pump current cutting
196214CA5exceeded P3165 exhaust bank3, lambda correction lean behind cat Control limit
196224CA6exceeded P3166 exhaust bank3, lambda correction fat behind cat Control limit
196234CA7exceeded P3167 exhaust Bank4, lambda correction lean behind cat Control limit
196244CA8exceeded P3168 exhaust Bank4, lambda correction fat behind cat Control limit
196254CA9P3169 exhaust bank3, main catalytic effect is too low
196264CAAP3170 exhaust Bank4, main catalytic effect is too low
196274CABP3171 exhaust Bank 1, mixture adaptation range below 3 lean limit
196284CACP3172 exhaust Bank 1, mixture adaptation range exceeded 3 fat limit
196294CADP3173 exhaust bank 2, mixture adaptation range below 3 lean limit
196304CAEP3174 exhaust bank 2, mixture adaptation range exceeded 3 fat limit
196314CAFP3175 exhaust bank3, mixture adaptation range below 3 lean limit
196324CB0P3176 exhaust bank3, mixture adaptation range exceeded 3 fat limit
196334CB1P3177 exhaust Bank4, mixture adaptation range below 3 lean limit
196344CB2P3178 exhaust Bank4, mixture adaptation range exceeded 3 fat limit
196354CB3P3179 injector Zyl.13-N390 short circuit to ground
196364CB4P3180 injector Zyl.13-N390 short circuit to positive
196374CB5P3181 injector Zyl.13-N390 interruption
196384CB6P3182 injector Zyl.14-N391 short circuit to ground
196394CB7P3183 injector Zyl.14-N391 short circuit to positive
196404CB8P3184 injector Zyl.14-N391 interruption
196414CB9P3185 injector Zyl.15-N392 short circuit to ground
196424CBAP3186 injector Zyl.15-N392 short circuit to positive
196434CBBP3187 injector Zyl.15-N392 interruption
196444CBCP3188 injector Zyl.16-N393 short circuit to ground
196454CBDP3189 injector Zyl.16-N393 short circuit to positive
196464CBEP3190 injector Zyl.16-N393 interruption
196474CBFP3191 Intake manifold for air flow control Grundeinst.bei canceled mechanical stop open
196484CC0P3192 Intake manifold for air flow control Grundeinst.bei mechan.Anschlag geschl.abgebrochen
196494CC1P3193 Intake manifold for air flow control open stop au.erhalb gultigem area
196504CC2P3194 air mass meter 3 G456 signal too small
196514CC3P3195 air mass meter three-G456 signal too large.
196524CC4P3196 air mass meter 4-G457 signal too small
196534CC5P3197 air mass meter 4-G457 signal too large.
196544CC6P3198 control manifold flap for air flow control Implausible signal
196554CC7P3199 controlling intake manifold 2 for airflow control Implausible signal
196564CC8P3200 exhaust bank3-Probe 1, heating circuit Short circuit to ground
196574CC9P3201 exhaust bank3-Probe 1, heating circuit Short circuit to positive
196584CCAP3202 exhaust Bank3-Probe 1, heating current interruption
196594CCBP3203 exhaust bank3-Probe 1, heating circuit electrical fault
196604CCCP3204 exhaust bank3-Probe 1 Internal resistance too great.
196614CCDP3205 exhaust bank3-Electrode1 voltage too low
196624CCEP3206 exhaust bank3-Electrode1 voltage too large.
196634CCFP3207 exhaust bank3-Electrode1 electrical fault in the circuit
196644CD0P3208 exhaust bank3-Electrode1 no activity
196654CD1P3209 exhaust bank3-Electrode1 signal too slow
196664CD2P3210 exhaust bank3-Probe 1, heating circuit capacity too low
196674CD3P3211 exhaust bank 1-probe 1 heater feedback
196684CD4P3212 exhaust bank 2-Electrode1 heater feedback
196694CD5P3213 exhaust bank3-Electrode1 heater feedback
196704CD6P3214 exhaust Bank4-Electrode1 heater feedback
196714CD7P3215 exhaust bank3-probe 2, heating circuit Short circuit to ground
196724CD8P3216 exhaust bank3-probe 2, heating circuit Short circuit to positive
196734CD9P3217 exhaust Bank3-probe 2, heating current interruption
196744CDAP3218 exhaust bank3-probe 2, heating circuit electrical fault
196754CDBP3219 exhaust bank3-probe 2 Internal resistance too great.
196764CDCP3220 exhaust bank3-probe 2 Voltage too low
196774CDDP3221 exhaust bank3-probe 2 Voltage too large.
196784CDEP3222 exhaust bank3-probe 2 Electrical fault in the circuit
196794CDFP3223 exhaust bank3-probe 2 No activity
196804CE0P3224 exhaust bank3-probe 2 signal too slow
196814CE1achieved P3225 exhaust Bank3, lambda correction behind catalyst control limit
196824CE2achieved P3226 exhaust Bank4, lambda correction behind catalyst control limit
196834CE3P3227 exhaust Bank 1, probe 1, single cylinder control probe dynamics too low
196844CE4P3228 exhaust Bank 1, probe 1, lambda probe signal implausible lean
196854CE5P3229 exhaust Bank 1, probe 1, lambda probe signal implausible fat
196864CE6P3230 exhaust Bank4-Probe 1, heating circuit Short circuit to ground
196874CE7P3231 exhaust Bank4-Probe 1, heating circuit Short circuit to positive
196884CE8P3232 exhaust Bank4-Probe 1, heating current interruption
196894CE9P3233 exhaust Bank4-Probe 1, heating circuit electrical fault
196904CEAP3234 exhaust Bank4-Probe 1 Internal resistance too great.
196914CEBP3235 exhaust Bank4-Electrode1 voltage too low
196924CECP3236 exhaust Bank4-Electrode1 voltage too large.
196934CEDP3237 exhaust Bank4-Electrode1 electrical fault in the circuit
196944CEEP3238 exhaust Bank4-Electrode1 no activity
196954CEFP3239 exhaust Bank4-Electrode1 signal too slow
196964CF0P3240 exhaust Bank4-Probe 1, heating circuit capacity too low
196974CF1P3241 Intake manifold for air flow control temperature too high
196984CF2P3242 Intake manifold 2 for airflow control temperature too high
196994CF3P3243 control throttle control unit electrical fault
197004CF4P3244 control throttle valve control unit 2 electrical fault
197014CF5P3245 exhaust Bank4-probe 2, heating circuit Short circuit to ground
197024CF6P3246 exhaust Bank4-probe 2, heating circuit Short circuit to positive
197034CF7P3247 exhaust Bank4-probe 2, heating current interruption
197044CF8P3248 exhaust Bank4-probe 2, heating circuit electrical fault
197054CF9P3249 exhaust Bank4-probe 2 Internal resistance too great.
197064CFAP3250 exhaust Bank4-probe 2 Voltage too low
197074CFBP3251 exhaust Bank4-probe 2 Voltage too large.
197084CFCP3252 exhaust Bank4-probe 2 Electrical fault in the circuit
197094CFDP3253 exhaust Bank4-probe 2 No activity
197104CFEP3254 exhaust Bank4-probe 2 signal too slow
197114CFFP3255 Bank 1, lambda probe upstream of the catalyst, heating current control at the upper stop
197124D00P3256 Bank 1, lambda probe upstream of the catalyst, heating current control at the lower stop
197134D01P3257 Bank 2, lambda probe upstream of the catalyst, heating current control at the upper stop
197144D02P3258 Bank 2, lambda probe upstream of the catalyst, heating current control at the lower stop
197154D03P3259 auxiliary fuel pump for engine start malfunctioning
197164D04P3260 exhaust bank 1/2 lambda probes reversed before catalyst
197174D05P3261 exhaust bank 3/4 lambda probes reversed before catalyst
197184D06P3262 exhaust bank 1/2 lambda probes reversed after catalyst
197194D07P3263 exhaust bank 3/4 lambda probes reversed after catalyst
197204D08P3264 primary catalytic converter, Abgasbank3 effect too low
197214D09P3265 primary catalytic converter, Abgasbank4 effect too low
197224D0AP3266 Bank 1, probe 1 Internal resistance implausible
197234D0BP3267 Bank 2, probe 1 Internal resistance implausible
197244D0CP3268 linear oxygen sensor, exhaust bank 2 / pump current cutting
197254D0DP3269 linear oxygen sensor, exhaust bank 2 / pump current short circuit to ground
197264D0EP3270 linear oxygen sensor, exhaust bank 2 / pump current short circuit to positive
197274D0FP3271 linear oxygen sensor, exhaust bank 2 / reference voltage interruption
197284D10P3272 linear oxygen sensor, exhaust bank 2 / reference voltage Short circuit to ground
197294D11P3273 linear oxygen sensor, exhaust bank 2 / reference voltage short circuit to positive
197304D12P3274 linear oxygen sensor, exhaust bank 2 / reference voltage implausible
197314D13P3275 linear oxygen sensor, exhaust bank 2 / common ground line interruption
197324D14P3276 linear oxygen sensor, exhaust bank 2 / common ground line short-circuit to ground
197334D15P3277 linear oxygen sensor, exhaust bank 2 / common ground line short circuit to positive
197344D16P3278 linear oxygen sensor, exhaust Bank 3 / pump current cutting
197354D17P3279 linear oxygen sensor, exhaust Bank 3 / pump current short circuit to ground
197364D18P3280 linear oxygen sensor, exhaust bank 3 / pump current short circuit to positive
197374D19P3281 linear oxygen sensor, exhaust Bank 3 / reference voltage interruption
197384D1AP3282 linear oxygen sensor, exhaust Bank 3 / reference voltage Short circuit to ground
197394D1BP3283 linear oxygen sensor, exhaust bank 3 / reference voltage short circuit to positive
197404D1CP3284 linear oxygen sensor, exhaust Bank 3 / reference voltage implausible
197414D1DP3285 linear oxygen sensor, exhaust Bank 3 / common ground line interruption
197424D1EP3286 linear oxygen sensor, exhaust Bank 3 / common ground line short-circuit to ground
197434D1FP3287 linear oxygen sensor, exhaust Bank 3 / common ground line short circuit to positive
197444D20P3288 linear oxygen sensor, exhaust bank 4 / pump current cutting
197454D21P3289 linear oxygen sensor, exhaust bank 4 / pump current short circuit to ground
197464D22P3290 linear oxygen sensor, exhaust bank 4 / pump current short circuit to positive
197474D23P3291 linear oxygen sensor, exhaust bank 4 / reference voltage interruption
197484D24P3292 linear oxygen sensor, exhaust bank 4 / reference voltage Short circuit to ground
197494D25P3293 linear oxygen sensor, exhaust bank 4 / reference voltage Short circuit to positive
197504D26P3294 linear oxygen sensor, exhaust bank 4 / reference voltage implausible
197514D27P3295 linear oxygen sensor, exhaust bank 4 / common ground line interruption
197524D28P3296 linear oxygen sensor, exhaust bank 4 / common ground line short-circuit to ground
197534D29P3297 linear oxygen sensor, exhaust bank 4 / common ground line short circuit to positive
197544D2AP3298 catalyst system, exhaust bank3 effect too low
197554D2BP3299 catalyst system, exhaust Bank4 effect too low
197564D2CP3300 Bank1, camshaft position sensor, outlet => - G300 short circuit to ground
197574D2DP3301 Bank1, camshaft position sensor, outlet => - G300 open / short circuit to positive
197584D2EP3302 Bank2, camshaft position sensor, outlet => - G301 short circuit to ground
197594D2FP3303 Bank2, camshaft position sensor, outlet => - G301 open / short circuit to positive
197604D30P3304 Bank1, outlet Nockenwellenpos.-G300 / Kurbelwellenpos.sens.-G28 misallocation
197614D31P3305 Bank2, outlet Nockenwellenpos.-G301 / Kurbelwellenpos.sens.-G28 misallocation
197624D32P3306 Zundansteuerung cylinder 13 short circuit to ground
197634D33P3307 Zundansteuerung cylinder 13 Short circuit to positive
197644D34P3308 Zundansteuerung interruption cylinder 13
197654D35P3309 Zundansteuerung cylinder 14 short circuit to ground
197664D36P3310 Zundansteuerung cylinder 14 Short circuit to positive
197674D37P3311 Zundansteuerung interruption cylinder 14
197684D38P3312 Zundansteuerung cylinder 15 short circuit to ground
197694D39P3313 Zundansteuerung cylinder 15 Short circuit to positive
197704D3AP3314 Zundansteuerung interruption cylinder 15
197714D3BP3315 Zundansteuerung cylinder 16 Short circuit to ground
197724D3CP3316 Zundansteuerung cylinder 16 Short circuit to positive
197734D3DP3317 Zundansteuerung interruption cylinder 16
197744D3EP3318 relay 2 for glow plugs-J495 Short circuit to positive
197754D3FP3319 relay 2 for glow plugs-J495 Open / short circuit to ground
197764D40P3320 control valves 2 pump / nozzle short circuit to positive
197774D41P3321 control valves 2 pump / nozzle electrical fault in Stromkrreis
197784D42P3322 relay 2 for Spannungsvers.-terminal 30-J689 implausible signal
197794D43P3323 voltage supply terminal 15 voltage too big.
197804D44P3324 voltage supply terminal 15 interrupt
197814D45P3325 voltage supply terminal 15 implausible
197824D46P3326 changeover valve for intake manifold 2-N394 short circuit to positive
197834D47P3327 switching valve for intake manifold 2-N394 open / short circuit to ground
197844D48P3328 engine intake manifold for two-V275 short circuit to positive
197854D49P3329 engine for intake manifold 2-V275 open / short circuit to ground
197864D4AP3330 engine intake manifold for two-V275 no signal
197874D4Bdefective P3331 engine for intake manifold 2 -V275
197884D4CP3332 combustion detection in overrun
197894D4DP3333 control unit 1 for turbocharger, implausible message
197904D4EP3334 control unit 2 for turbocharger, implausible message
197914D4FP3335 control unit 1 for turbocharger, missing message
197924D50P3336 control unit 2 for turbocharger, missing message
197934D51P3337 bus engine / motor implausible message
197944D52P3338 control Gluhzeitsteuergerat 1 electrical fault in the circuit
197954D53P3339 control Gluhzeitsteuergerat 2 electrical fault in the circuit
197964D54P3340 relay for Lufter Ladeluftkuhlung-J712 Short circuit to positive
197974D55P3341 relay for Lufter Ladeluftkuhlung-J712 short circuit to ground
197984D56P3342 relay for Lufter Ladeluftkuhlung-J712 interruption
197994D57P3343 control unit for turbocharger 1-J724 temperature too high
198004D58P3344 control unit for turbocharger 1-J724 supply voltage au.erhalb the permissible range
198014D59P3345 controller for turbocharger 2-J725 temperature too high
198024D5AP3346 control unit for turbocharger 2-J725 supply voltage au.erhalb the permissible range
198034D5BP3347 relay for glow plugs electrical fault
198044D5CP3348 drive control unit for turbocharger 1-J724 electrical fault in the circuit
198054D5DP3349 drive control unit for turbocharger 2-J725 electrical fault in the circuit
198064D5EP3350 gas mixture adaptation range 1 below
198074D5FP3351 gas mixture adaptation range 1 exceeded
198084D60P3352 mixture adaptation range 2 gas below
198094D61P3353 mixture adaptation exceeded gas range 2
198104D62P3354 mixture adaptation gas sector 3 below
198114D63exceeded P3355 mixture adaptation gas sector 3
198124D64P3356 catalyst system gas operating bank one effect too low
198134D65P3357 Lamdasondenkorrektur achieved in gas mode control limit
198144D66P3358 probe 1 bank 1 too slow signal gas operation
198154D67P3359 exhaust bank 1-probe 1 in gas mode heater feedback
198164D68P3360 exhaust bank 1-probe 1 No activity in gas mode
198174D69recognized P3361 gas operation misfire
198184D6AP3362 gas operation detected Cyl.1 misfire
198194D6BP3363 gas operation Cyl.2 misfires recognized
198204D6CP3364 gas operation detected Cyl.3 misfire
198214D6DP3365 gas operation Cyl.4 misfires recognized
198224D6EP3366 system pressure gas too high
198234D6FP3367 system pressure gas too low
198244D70P3368 lambda probe 1-Bank3 signal to lean
198254D71P3369 lambda probe 1-Bank3 signal to fat
198264D72P3370 lambda probe 1-Bank4 signal to lean
198274D73P3371 lambda probe 1-Bank4 signal to fat
198284D74P3372 switching valve for switching suction short circuit to positive
198294D75P3373 switching valve for switching suction open / short circuit to ground
198304D76P3374 changeover valve for variable intake manifold 2 short circuit to positive
198314D77P3375 switching valve for switching suction 2 open / short circuit to ground
198324D78P3376 Encoder 3 for intake-G520 signal too small
198334D79P3377 Encoder 3 for intake-G520 signal too large.
198354D7BP3379 shut-off valve for gas pressure regulator N372 interruption
198364D7CP3380 shut-off valve for gas pressure regulator N372 short circuit to positive
198374D7DP3381 shut-off valve for gas pressure regulator N372 short circuit to ground
198384D7EP3382 encoder for high-pressure gas pressure interruption G400
198394D7FP3383 transmitter for gas pressure high pressure G400 short circuit to positive
198404D80P3384 transmitter for gas pressure high pressure G400 short circuit to ground
198414D81P3385 transmitter for gas low pressure G401 interruption
198424D82P3386 transmitter for gas low pressure G401 short circuit to positive
198434D83P3387 transmitter for gas low pressure G401 short circuit to ground
198444D84P3388 gas injection valve 1-N366 interruption
198454D85P3389 gas injection valve 1 N366 short circuit to positive
198464D86P3390 gas injection valve 1 N366 short circuit to ground
198474D87P3391 gas injection valve 2 N367 interruption
198484D88P3392 gas injection 2-N367 short circuit to positive
198494D89P3393 gas injection 2-N367 short circuit to ground
198504D8AP3394 gas injection valve 3 N368 interruption
198514D8BP3395 gas injection valve 3 N368 short circuit to positive
198524D8CP3396 gas injection valve 3 N368 short circuit to ground
198534D8DP3397 gas injection valve 4 interruption N369
198544D8EP3398 gas injection valve 4 N369 short circuit to positive
198554D8FP3399 gas injection valve 4 N369 short circuit to ground
286737001U0001 bus drive defective
28700701CU0028 communication bus drive
287727064U0100 engine control no communication
287737065U0101 control unit for transmission no communication
287757067U0103 selector lever no communication
287767068U0104 cruise control no communication
28783706FU0111 control unit for battery energy manager no communication
287877073U0115 engine control slave no communication
287937079U0121 control unit for ABS brake no communication
28795707BU0123 yaw rate sensor no communication
28798707EU0126 steering angle sensor no communication
288007080U0128 SG Electric parking brake No communication
288187092U0146 diagnostic interface SG No communication
288237097U0151 control unit for airbag no communication
28827709BU0155 control unit for the dash panel insert No communication
2883670A4U0164 control unit for air no communication
2890770EBU0235 distance distance control no communication
28974712EU0302 control unit for transmission software incompatible
28987713BU0315 control unit for ABS software incompatible
28989713DU0317 Electric parking brake control unit software incompatible
289937141U0321 leveling wrong software version
290767194U0404 selector lever implausible signal
290777195U0405 cruise control Implausible signal
29087719FU0415 control unit for implausible signal ABS
2908971A1U0417 control unit Electric parking brake Implausible message
2909371A5U0421 level control Implausible signal
296967400U1000 Zentralsteuergerat for comfort systems-J393 No communication
296977401U1001 Zentralsteuergerat for implausible signal Komfortsysteme-J393
296987402U1002 Zentralsteuergerat for comfort systems-J393 read Please fault memory
296997403U1003 control unit for Anhangererkennung-J345 No communication
297007404U1004 control unit for Anhangererkennung-J345 implausible signal
297017405U1005 control unit for Anhangererkennung-J345 read Please fault memory
297027406U1006 NOX sensor 1 Bank 1 no communication
297037407U1007 control unit for Batterieuberwachung read Please fault memory
297047408U1008 diagnostic interface for data bus J533 read Please fault memory
297057409U1009 diagnostic interface for data bus J533 implausible message
29706740AU1010 Electric parking brake control unit fault memory read request
65280FF00Development Code 1
65281FF01Development Code 2
65282FF02Development Code 3
65283FF03Development Code 4
65284FF04Development Code 5
65285FF05Development code 6
65286FF06Development Code 7
65287FF07Development Code 8
65288FF08Development Code 9
65289FF09Development Code 10
65290FF0ADevelopment Code 11
65291FF0BDevelopment code 12
65292FF0CDevelopment code 13
65293FF0DDevelopment Code 14
65294FF0EDevelopment Code 15
65295FF0FDevelopment code 16
65296FF10Development Code 17
65297FF11Development Code 18
65298FF12Development Code 19
65299FF13Development code 20
65300FF14Development code 21
65301FF15Development code 22
65302FF16Development code 23
65303FF17Development code 24
65304FF18Development Code 25
65305FF19Development code 26
65306FF1ADevelopment Code 27
65307FF1BDevelopment Code 28
65308FF1CDevelopment Code 29
65309FF1DDevelopment code 30
65310FF1EDevelopment Code 31
65311FF1FDevelopment Code 32
65312FF20Development Code 33
65313FF21Development Code 34
65314FF22Development Code 35
65315FF23Development Code 36
65316FF24Development Code 37
65317FF25Development Code 38
65318FF26Development Code 39
65319FF27Development Code 40
65320FF28Development Code 41
65321FF29Development Code 42
65322FF2ADevelopment Code 43
65323FF2BDevelopment Code 44
65324FF2CDevelopment Code 45
65325FF2DDevelopment Code 46
65326FF2EDevelopment Code 47
65327FF2FDevelopment Code 48
65328FF30Development Code 49
65329FF31Development code 50
65535FFFFControl unit faulty
