Has your inverter got a ve-direct port?,have you got a pic of the set upI would like to use my SBP65 to switch off my inverter via the remote switch. I've used the wiring diagram from the SBP manual but it won't switch off the inverter when low voltage is triggered by the SBP. All the other circuits are automatically switched off by the SBP.
Any ideas?
Thanks for your help. I was already thinking about a resistor but I will contact Victron technical. I've ordered a clamp meter which is arriving today. I'll try and find the source of a possible back drain tomorrow. I'll post back when I find a solution.
Make sure all devices are full up to date regards to firmware
