Evening all!
So just got back from a recent Bank Holiday camping trip. Absolutely superb couple of days at Shambala Festival near Coventry. Our 9th year of going, for my money best festival in the UK! But I digress.
One thing I was curious to see was that the Victron Solar controller (in my case the 100/20 MPPT) wasn't charging even on a bright sunny day!
The battery readout for the Lifos 105AH was running at 13.1volt (which I believe is approx 40% remaining charge?)
Curious about this I checked the Victron app. I noted that it says that one reason for no controller activity is due to the panel needing to be running at 5volts or greater than the Battery to begin the charging process.
Now I appreciate the need for this buffer, but I can't help but think this is a little bit odd?
Firstly, because that would require the Panel to be running at around 18volts or higher to charge my Lifos when at 13V or less. Which is a bit strange given that my 160w semi flexible panel runs at Max power Voltage 20.2V (if memory serves correctly)
Secondly, I've never noticed this 5v threshold requirement before? Does anyone know if it's a recent addition or Firmware update? Because the panel as always seemed to kick in wherever the battery is anything less than 100%, keeping it nicely topped up at 14.4 almost constantly?
If anyone can shed any light on what might be going on here I'd be incredibly grateful.
As the king of all things electrical, @Dellmassive I would be interested to know what you think in particular
Cheers fellas
Cheers fellas
