I've had a 'discussion' with VW about the poor update service of the sat nav maps. Germany say that the maps are updated twice a year but when challenged about the January 2018 date on the current offering on the website they passed the book to VW UK. VW UK now say that the next update should be available in the summer of 2019!
My initial query / concern was that the maps had not been updated for the French national speed limit change. Now I guess the same will apply to the Spanish changes.
To me that is a disgusting service for a product that costs so much!
My guess/hope is yes but with VW who knows!That's interesting, I'd not looked at the German site.
When I look at Volkswagen Map & Softwareupdates I see a date 10/1/18 and English text.
Should I be reading this as a American site with the day & month reversed?
Did you format the card before updating? You need to.Hi
Trying to update the maps on the official vw sd card but after waiting hours for the download, 14gb which I can normal download in a few minutes .. I had an error message not enough space on the card!
Anyone else with similar or known problems? Whole map of Europe BTW.
Edit..
The updater now says no Official vw card!!
Hmm! I've never been able to get the Discover update utility to work & have done it "Old Skool" i.e.I have tried both options, letting the discover programme do everything and also downloading the map on its own and then extracting to the card after formatting.
If I format and then check validity of the card in the discover program it says no vw card installed.
If I self install the maps to the card and check in the discover program it also says no vw card installed.
If I put the original backup on its fine and recognised as a vw card.
I'm pretty computer literate so bit confused
I think the updates are around May & NovemberThat discover update program really is a load of rubbish, I can never get it to work so I also do it the ‘old fashioned’ way. Had a quick look at the maps and it is still the same old ones from last year - not sure when new ones are out.
result!No. Idea if there is an update, just found the card has never been Updated.
Edit: it works!!! I. Used the download from the discover programme and winzip to extract to The card. Using the download and the recommended programme failed for me.
