VW T6 Multivan Traction Control Error, Esp error
vnimat
Hello,
I own the VW Multivan T6 4 motion model from 2018 DSG 150 hp
I have the following problem.
When I accelerate from a standstill, in D2 speed at 3000 revs, the traction control and wheel pressure errors appear.
Errors appear in VCDS:
- Engine error
- CAN error - does not communicate with the car
- Error Implausible data received from Esp control module
- ABS error
I changed the angle of the steering wheel.
Some mechanic says to change the CAN
Has anyone had this problem?
Hello,
I own the VW Multivan T6 4M model from 2018 DSG 150 HP
When I accelerate from a standstill, in D2 speed at 3000 revs, the traction control and wheel pressure errors appear. The error occurs only when the engine reaches a temperature of 90 degrees. Below 90 degrees the errors do not appear.
On dashboard the traction control and tire pressure error are present
Code:
01-Engine -- Status: Malfunction 1010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (2D2D2-CXFA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KF    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 5953
   Revision: 23002001
   Coding: 0025401C433601080000
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KF 004014
   ROD: EV_ECM20TDI03004L906056JS_004.rod
   VCID: 7BF542EBF2E5695E5E-802E
1 Fault Found:
25126 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 124516 km
                    Date: 2071.01.08
                    Time: 18:56:59
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 86 ∞C
                    Intake air temperature: 10 ∞C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 13.031 V
                    Unlearning counter according OBD: 40
                    Acceleration: 0.000 m/s≤
                    Cruise Control System (CCS): status: Initializing
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake function status-ABS intervention: No
                    Drivetrain coordinator: brake function status-ESP intervention: No
                    Drivetrain coordinator: brake function status-EDL intervention: No
                    Drivetrain coordinator: brake function status-ASR intervention: No
                    Drivetrain coordinator: brake function status-MSR intervention: No
                    Drivetrain coordinator: brake function status-Driver braking: No
                    Drivetrain coordinator: brake function status-HDC active: No
                    Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
                    Drivetrain coordinator: brake function status-EPB active: No
                    Drivetrain coordinator: brake function status-ASP intervention: No
                    Drivetrain coordinator: brake function status-ADS intervention: No
                    Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
                    Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
                    Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
                    Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
                    Drivetrain coordinator: brake function status-ACC stopping distance control active: No
                    Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
                    Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
                    Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
                    Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
                    Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
                    Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
                    Drivetrain coordinator: brake fault status-Brake light implausible: No
Readiness: N/A
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0BT 300 012 C    HW: 0BH 927 711 G
   Component: DSG DQ500-7A  H11 5301
   Revision: 00H11V01
   Coding: 0018
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_001_VW36.rod
   VCID: 2F6DA6BB761D45FEA2-807A
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 60068000000923
   Coding: 307E8098656384820C780179A68A2193780000
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 3F8DF6FBA67DB57E32-806A
3 Faults Found:
0166 - Steering angle sensor
          B1168 31 [008] - No Signal
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 124515 km
                    Date: 2024.04.18
                    Time: 18:56:30
0167 - Databus
          U1122 00 [008] - Implausible Message
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 124515 km
                    Date: 2024.04.18
                    Time: 18:56:30
8340 - Databus
          U1200 00 [008] - Defective
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 124515 km
                    Date: 2024.04.18
                    Time: 18:56:30
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 30081304651314
   Coding: 01
   ASAM Dataset: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34BFFE1F77C7679-802A
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 AB    HW: 7E0 907 047 AB
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaT5Basis.rod
   VCID: 6ADB77AF8D7FE0D6B5-803E
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 002180639
   Coding: 3AA8393A0A61341281284F602CEB8FD4C0847389604579603304003F0860
   Shop #: WSC 02739 022 99501
   VCID: 2B55B2AB4A0539DE8E-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 201217 04  47  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 7E0 959 801 N    HW: 7E0 959 801 N  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  004 0653
   Serial number: KU0KU010011880100640
   Coding: 0400A1
   Subsystem 3 - Part No SW: 7E0 959 802 R    HW: 7E0 959 802 R  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  005 0653
   Serial number: KU0KU006121773404769
   Coding: 1400A1
   Subsystem 4 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Coding: 000000
   Subsystem 5 - Part No SW: 7E0 959 442     HW: 7E0 959 442
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39170002736350117506
   Coding: B1FFFF
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231733602280
   Coding: 118108
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71E960C3A0A9130EF4-8024
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 H    HW: 7E0 959 655 H
   Component: VW10Airbag01R H08 0018
   Revision: --------    Serial number: 003V4004BKH4
   Coding: 000000000000000000000000000000003152
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3B7582EBB265A95E1E-806E
   Crash sensor for side airbag: driver side:
   Serial number: 3495ZRB400A5BNBGR0SE
   Crash sensor for side airbag: front passenger side:
   Serial number: 3505ZRB40105BOJEE0NT
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 870 S    HW: 7E0 920 870 S
   Component: KOMBI         H03 1107
   Serial number: 00000000000000
   Coding: 140F010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 397998E3B8599B4E0C-806C
1 Fault Found:
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 124515 km
                    Date: 2024.04.18
                    Time: 18:56:31
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 272 B    HW: 7E0 963 273 A
   Component: STH-T5GP2     003 0009
   Coding: 5901
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 2B55B2AB420539DE8E-807E
   Remote Control Auxiliary Heater:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0402
   Serial number: 00000000000000379545
1 Fault Found:
0266 - Databus
          U1121 00 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 155
                    Mileage: 124475 km
                    Date: 2024.04.18
                    Time: 15:11:16
                    Operating condition of parking heater: OFF
                    71
                    Coolant temperature of parking heater: 80 ∞C
                    Coolant temperature: 81 ∞C
                    Engine running status: not recognized
                    Fuel level: 33 l
                    Heater output: 0 W
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 042205
   VCID: 68DF0DA79B73D2C6A3-803C
1 Fault Found:
01314 - Engine Control Module
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 124515 km
                    Time Indication: 0
                    Date: 2018.09.09
                    Time: 18:56:33
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 040400E200000000000000
   ASAM Dataset: EV_HighBeamAssisAU316 001004
   ROD: EV_HighBeamAssisAU316.rod
   VCID: 2D51BCB37C1137EE90-8078
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0AY 907 554 L    HW: 0CQ 525 130 A
   Component: Haldex4Motion H53 7620
   Serial number: HA1-00006.11.17
   Coding: 0501
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 54A7C9573FFB4626FF-8000
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 1107
   Serial number:
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: --------------
   Coding: 0FCA020001000000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A7B87EFBD5F905605-806E
1 Fault Found:
13705475 - Databus
          U1121 00 [008] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 124504 km
                    Date: 2024.04.18
                    Time: 16:43:08
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   Part No SW: 5K7 035 200 L    HW: 5K7 035 200 L
   Component: MU-S--ER      H41 0478
   Serial number: VWZAZ2U0553338
   Coding: 06570000BE00000011110001000808001F0100C40020010003
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW32.rod
1 Fault Found:
1555 - Check Software Version Management
          B201A 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 155
                    Mileage: 124475 km
                    Date: 2024.04.18
                    Time: 15:11:16
                    Voltage terminal 30: 12.2 V
                    Status_Software_Version_Management-module_name:
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 330B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Component: J367-BDMConti  H03 1050
   Serial number: 758857000017103106DB
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000464829400
   Coding: 410D000103000000
   VCID: 326BAFCF6D2F6816CD-8066
End-------------------------(Elapsed Time: 03:49)--------------------------
Most of the errors are generic and referencing other faults in others modules (missing message) and some of them don’t add up like saying a module can’t be reached when it now shows as present and fault free
Wipe it clear the errors and start again and see what comes back
The errors were deleted but reappear in the same situation
As always - a complete VCDS Auto-Scan is appreciated - now e.g. mileage when Auto-Scan was performed is missing.
Anyways,
what exactly you mean by the "errors"? A text message on dash? But no warning lights? A picture would be helpful.
8340 - Databus U1200 00 [008] - Defective
- Confirmed -
Anyways, I think the culprit is the above - the powertrain CANbus - a dodgy wiring perhaps? Any work done recently in engine bay or under dasf?
8340 - Databus - U1200 00 [008] - Defective - [ACAN: too many Bus Off events]
Can you communicate directly with all the controllers by using VCDS. Especially 01-Engine, 03-ABS, 04-Steering angle
VCDS > Select control module > Adv. Meas. Values > Tick a couple of items
Do the all controllers respond without any glitches? Especially the 04-Steering angle?
Take it for another ride having the VCDS hooked in and displaying the real time data.
That's because VCDS cable is not capable (=too old) of fully interrogating new UDS protocol based controllers thus we are missing partially the information here. Only the current interfaces HEX-V2 and HEX-NET have the capability.
