Vw t6 sliding door contact issue. Open when closed and closed when open
djmeeg
Tailgater
Hi everyone, I just wondered if anyone had ever had this issue.
I have vcds system as for some reason when my rear sliding door was closed it shows in the message blocks on the vcds as open when closed and closed when the door is open. When push the contact on the door it changes to open rather than closed ? I removed the contact but don’t see an easy way in to try perhaps switch the wires around. I was wondering if there’s anywhere to switch this round using the vcds but don’t see an obvious option. I have had to disable the door in the vcds in order to stop the door open icon appearing on the dash but would be good to have it working correctly. Any help or advice is welcome. Photo enclosed of the contact.
