£17 a litre?!!Bilt Hamber Auto Wheel is so much better
Agreed I use this exclusively on my wheels.Bilt Hamber Auto Wheel is so much better
Without a doubt the best on the market ....its not cheap but you get what you pay for !
That's why I use Fairy Liquid, not the cheap stuff!Without a doubt the best on the market ....its not cheap but you get what you pay for !
Search ‘Dragons Blood’ on eBay there’s plenty of similar products for much less moneyI got given some of this stuff for Christmas and have found it fantastic.
Problem is I have nearly run out and have only used it on 2 washes!
It's £18 a bottle! I would have been a bit more sparing if I'd known. I think I'll go back to spending an extra few minutes washing with conventional car soap and wax, as that is mental.
Shame because it's fun to use. Check out all that muck turning purple! Got to love that but not at the thick end of £9 a wash!
Meguiar's G180124EU Ultimate All Wheel Cleaner Iron Remover 709ml, Changes colour as it cleans! https://www.amazon.co.uk/dp/B06WP6PY68/ref=cm_sw_r_cp_api_glt_i_HWRRFMPA0VA8FYQZS22Z
£17
Yeah lasts t
Yeah but worth it, the best way to use this is to rinse and snowfoam first, then spray this on your wheels so your only removing the left over iron, this way you don't use as much. Bilt Hamber is also PH neutral.£17 a litre?!!
PH neutral and will still remove the horrible brake dust etc? I always rinse the wheels first - after all, there's no point in wasting cleaner on stuff that will just hose off!Yeah but worth it, the best way to use this is to rinse and snowfoam first, then spray this on your wheels so your only removing the left over iron, this way you don't use as much. Bilt Hamber is also PH neutral.
If you want a good iron out remover for the paintwork follow the same process but then use Bilt Hamber Korosol, you'll be surprised at how much iron is embedded in the paint.
Is not the same …Bilt gear clings to the wheels it’s gel like …dragons blood runs too quick !Search ‘Dragons Blood’ on eBay there’s plenty of similar products for much less money
AgreedIs not the same …Bilt gear clings to the wheels it’s gel like …dragons blood runs too quick !
That's what it says on the tinPH neutral and will still remove the horrible brake dust etc? I always rinse the wheels first - after all, there's no point in wasting cleaner on stuff that will just hose off!
Perfect! I've just ordered 5 litres of the stuff for £52! That's well under half the cost of this Meguiars stuff! That's much more like it!Bilt Hamber Auto Wheel is so much better
What were you doing searching “Rim cleaners”?!!!
@JOG = w anker.What were you doing searching “Rim cleaners”?!!!
Surprising what you can order on Amazon mate.What were you doing searching “Rim cleaners”?!!!
This is true! Both my boys are IVF!!!@JOG = w anker.
