Cheers Niknak, do you know where the drain is located/how to access it to unblock it?Possible blocked ac drain
Is it normal for water to come out of there never noticed until I saw a puddle todayThey normally are flattered to stop things getting into it that’s why they get gummed up sometimes
Hi. We have a t6 recently converted. Just had a new resistor fitted and blower working again. But ... have had the aircon on for 45 mins to check it out and have a puddle already.... whilst driving. Also feels like water behind glove box. Is this normal? Any suggestions? ThanksYes if you run the AC it will drip inside the engine bay and will accumulate a little on the floor when you park up
Sorry for delay responding! I am trying to remove the black plastic facia panel to see what’s going on behind … but don’t want to just tug and can’t see any obvious clips or screws. Any help gratefully received before I go in heavy handed!Checked the drain/outlet isn’t blocked
Hope it’s ok to join this thread; I’ve got a hole in this rubber hose/ grommet just inside the van. Do you know how or where I might be able to source a new one? I can’t find one anywhere online.Has it got a rubber hose onto the bottom of unit if so take it off and poke a bit of wire through towards the bulk head gently if you have a pipe cleaner poke up into the matrix nothing too hard though
