So i have the door card off, and this shows me exactly where the water is coming from - at the bottom of the alu panel that is bolted & riveted into the door. The drain holes seem to work though so im not understanding the issue.. They are definitely not blocked.
I have added the extra door seal to make it quieter but this is well out of the way of the drain holes - these are right at the bottom of the door!
Water is not coming in from the top - all dry there.
I have replaced the seal on the window (7e0837703) on both sides. same issue this am after rain last night. Seals contact windows on both sides.
any ideas? im going crazy with this.. bloody van isnt water tight..
@Base1388 did you find the solution?
