Oh for goodness sake that is crazy, you don’t even have roof bars fitted!Well here we go again! I haven’t had the new velle a week and guess what, yes the boot is leaking in on the new one.
I can’t believe that this is happening again I must be cursed lol!
View attachment 21282 View attachment 21283
Off to the dealers tomorrow the saga continues!
Well that repair worked well then! Bloomin ridiculous. I’m starting to get annoyed on your behalf @RocaView attachment 21611 View attachment 21612 Off to the dealers again
Thanks for that will do.There is supposed to be a gasket that goes between the tailgate hinge and the van body. The bolts should be done up super tight but I’d ask them to check it’s got this gasket in place in both hinges just to rule that out.
I’m going to make a safe bet - it’s not fixed. Sorry.Update the velle has been in for a new tailgate seal and adjustment of the tailgate, are we taking bets if it’s been fixated or not?
The saga continues
Hello Northern Monkey! It seems that I have the same issue as you... Have you finally solved this? Thanks!Update the velle has been in for a new tailgate seal and adjustment of the tailgate, are we taking bets if it’s been fixated or not?
The saga continues
Went back another time to re adjust the tailgate and up to now it’s been ok fingers crossed.Hello Northern Monkey! It seems that I have the same issue as you... Have you finally solved this? Thanks!
