M Bridge-Wilkinson
Afternoon,
Removed the panel and all I see is a single wire into the white pin connector, a 4 pin connector (diagnostics?) and a large continuous loop of wire (bottom right of photo) going into the loom.
Am I right to assume that this loop of wire is for cutting and fitting of the temp sensor plug I have with the thermostat?
Differs from the instructions which cites a resistor. I cannot see a resistor or could that be inside the wrap?
