Webasto Thermo Top Evo Diesel pipe
gonze
I have a Webasto Thermo Top Evo fitted to my caravelle with no over head controller or key fob. I want to install a diesel van heater for use when camping. Will the webasto have a suitable fuel pipe I can T into for the new heater supply diesel feed or will I still need to lower the vans fuel tank and add the additional take off?
Yes, you can Tee off the same feed. I cannot find a link to the quick connect tee that you can use but you can just use an ordinary tee in the fuel line to your current heater.
Yes, BUT you will need a 8mm to 5mm reducer for the heater line. There is a tee like that that has the take off @ 5mm rather than that 8mm but I cannot find a link to it anymore.
