Hey @saxoboy , does your kit connect to the door open sensor from the lock, like others'? Just thinking, if so, there isn't a canbus lamp monitor like there is for the other lights, as the factory electrics don't expect that door sensor line to be used drive a lamp?Hi @Superowls they are indeed bud.....so I have the good lamps again.....but as of this weekend I have upgraded the kit with relays and fuses.....it pushes the cost up to £47.72 inc postage, but these are the daddies.....obviously can do the old kit too......but this ones better, totally removes the power from the light and saves minimal power to the LED....still canbus proof.....
Mine cause radio interference while the doors are open, I think the light units are electronically noisy and create the interference.@Mick Robson all sorted now, I took the passenger side door card off again this morning, & after re checking the wires, I did find the brown black wire. In my defence, the brown stripe on the wire was very thin & hard to make out.
Anyway, re connected to the right wire & hey presto DAB back.
One strange minor problem, when I open either door, I do lose the signal for a short time, which is not a major problem.
I do have on my list of "needs" is a DAB aerial, & I don't drive with the door open!!
Sorry, I don’t know what that wire could be for.@Broadside, I have just posted in another thread, that when I put the t tap onto the yellow brown, & then removed it, I may have damaged it which might be causing the issue.
I don't want to cut & re join that wire until I know what it feeds, & that I won't damage something else, have you any clue as to what the yellow brown wire feeds?
Make sure the t taps are connected properly, sometimes the bit that pushes into the crimp on the wire, doesn't connect properly.
I haven’t actually! I’ll get on that tomorrow and see what’s whatHave you tried the other light fitting in the side that isn't working?
