But not the foam pads, without them you end up with a 10mm gap between the bumper support and the bumper and the bumper has to come off to fit them
This is what the geezer said from dolphin towbars has said regarding plastic support and foam, I’m a little bit baffled
Hi .
To supply and fit a Westfalia removable towbar with a dedicated 13 pin wiring kit inc coding inc vat is £510.00 .
If the van needs the plastic strip bumper support it adds £24.00 there are no foam supports needed , the foam used be instead of the strip , not as well as the strip and is no longer offered as the strip is a lot better . This strip will not be needed if the van has rear seats or is a factory camper .
It takes about 3 hours to do the job and we need 2 - 3 days notice . If you want to book please phone
01202 733130 during opening hours .
Regards Stuart
www.dolphintowbars.co.uk
01202 733130
Dolphin Towbars is a trading name of Dolphin Towbars and Trailers Limited registered in England & Wales - Number
8384027 - Registered Office 16H Chalwyn Industrial Estate , Old Wareham Road , Parkstone .Poole . BH12 4PE
On 2019-02-06 18:02,
Justkeepers@hotmail.co.uk wrote:
My Contact Form
February 6th, 2019, 18:02
Name:: Steve Phillips
Telephone::
07964052775
Email address:
Your message:: Hi
I’m after detachable Westfalia with full function 13 pin vehicle
specific electrics and coding done.
I would also like the plastic rail and foam inserts (for additional
under bumper support) May have that on my T6 if not I would like it
added
how long would you need it to fit ?
Could you quote me for the above and how long until you can fit my van
in? I’ve beem given your company from a fellow T6 forum member who has
had the same fitted to his T6
My van has barn doors the spare wheel is at the back underneath
Regards
Steve
How did you hear about Dolphin Towbars & Trailers?: Google search
IP address: 213.205.194.6
Host: 213.205.194.6
Screen resolution: 375x667
