Hi Ando. I really like these wheels also. However I’ve just received an email direct off Inovitstating that these wheels are only loaded upto 735kg. See below that I’ve copied and pasted
The Inovit Turbine wheel is rated to 735KG and is cast into the back of each wheel as well as JIL & VIA certifications. Please let me know if I can be of help with anything else.
Wow, ok. I think they may need to get their story straight then. For comparison, I have cut & paste the entire email trail, below:
________________________________
Sir,
Yes all of the wheels are JIL and VIA certified (which is cast into each wheel). Also the weight load rating of 800 KG is cast into the back of the wheel as well.
On Mon, Jul 30, 2018 at 12:29 PM,
@yahoo.com> wrote:
Hi Mike,
Many thanks for your response. To clarify, do the 20” have the 800kg load rating stamped on the inside of them, as is required by our licensing regulations here in the UK?
Regards,
308mate (changed)
Sent from my iPhone
On 30 Jul 2018, at 18:24, Mike Dang <
mike@inovit.com> wrote:
Sir,
Your are correct that each wheel has a maximum weight load rating fo 800 KG (1764 LBS). Please let me know if I can be of help with any other questions you may have. Thank you!
Name
308mate
E-mail
@yahoo.com
Message
I am very keen on fitting a set of staggered 20” Turbines to my VW T6 T28 van. However it looks like they do not come with a high enough load rating (800kg). Can you tell me if have understood correctly?
Regards,
308mate
INOVIT Inc
3630 Cypress Ave,
El Monte, CA 91731
United States
W:
www.inovit.com
T:
+1 (626) 444-4775
F:
+1 (626) 444-4810
Mike Dang
Inovit, Inc.
3630 Cypress Avenue
El Monte, CA 91731
(626)444-4775 Office
Perhaps it’s a size discrepancy or they meant that 735 is covered by the 800 rating?
