I've got some airline track to install with rivnuts when I get time. Like how you added the loops to the standard holes.
Did you drill them out or use the standard size?
Ended up having to drill them all in the end
Look good!!! Would you recommend them ? We are looking for a bodyshop as our van has been scratched.
As I have mentioned before some sequential LED strips are voltage sensitive.
For example they work perfectly with 12V DC and then they misbehave with increased voltage of 14.4V DC (when engine is running).
Luckily these strips are very rare and majority of recent/modern strips cope very well with increased voltage.
Then there is another trap.
Indicator's pulses can be PWMed(Pulse Width Modulated) and this is controlled by BCM coding.
Almost all aftermarket LED strips don't like PWM and they won't work, especially when engine is running.
This is how indicator pulses look like when PWM is ON and engine is running.
And this is how indicator pulses look like when PWM is OFF and engine is running.
To deactivate indicator PWM the following VCDS coding modification needs to be applied.
09 BCM, (Byte 19, bit 3) = 0 (unticked)
See @Robert 's post in Vcds Tweaks. on 9th of March
Lights/DRLs
Byte 23 bit 1 - when ticked deactivates rear fog lights while high beam is ON
Byte 23 bit 2 - when ticked fog lights work as DRLs
Byte 23 bit 3 - when ticked low beam works as DRLs
Byte 23 bit 4 - when ticked DRLs turn OFF when hand brake is ON
Byte 23 bit 7 - when ticked DRL/DRLs turn OFF when blinker or emergency lights are activated
Winner !!!
Byte 27 - fixed the problem.
I've changed the coding t0 0011 1111 and the warning light has gone.
Many thanks for everyone's help.
Didn’t you have to drill holes in the roof for the rails though?Started to fit solar panels to the roof after I managed to get some low profile cross bars from here. Don't think I'm going to drill a hole in the roof for the cables (not got big enough balls) but just plug in and hang loose when being used.
Took the 2 middle rows seats out of my Caravelle - I had heard they are heavy but I didn't realise just how heavy. Phew
Then I pushed the table and rear seats forwards to allow room for 2 bikes in the back, then we went for a drive to a local cycle route to put the new seating arrangement to the test.
You think they're heavy, you should try the rear bench
I've taken the middle seats out plus the table and use it as a posh combi now, albeit with the bench right back when it's just people in it.
I know someone who can do that if there is a call for it.It’s a pity they don’t do one of these with the word “bike” substituted by the word “van”
My Biggest Fear T Shirt
Motorbikes are not cheap, so perhaps rather than spinning in your grave, you better fess up to your better half and let 'em know exactly how much you paid. Artwork copyright Push Merchandising Ltd.We are constantly striving for ethical improvements in the manufacture of all products and...www.shotdeadinthehead.com
