I like your seats! Are they trimmed or just covers?Finally added the lower dash after changing it's colour, although it's kind of hard to tell from the picture.
Cheers will check it outebay... VW T6 GTI Tartan Gear Gaiter, Blue Red,Orange,Grey Yellow | eBay
wanted to try it out and see if i liked it. i think i do. can never have enough tartan.
Thanks! They've been re-trimmedI like your seats! Are they trimmed or just covers?
Be aware of the front flaps as they either touch the door or are very close , I have the same ones on my work van and both doors are now rusting as they have rubbed the paint off , you may be able to shave some plastic off so this doesn't happen I wouldn't want the same to happen to yoursHi @BenR - they came from Mr Bezos! Shorty mud flaps
Good point @Leehoops - I should have said to @BenR that I'd read this somewhere else on here (may even have been you @Leehoops). I trimmed mine back to make sure they don't rub on the bottom edge of the doors. Also gave them a squirt of ACF 50 to try to keep the rust monster at bay.Be aware of the front flaps as they either touch the door or are very close , I have the same ones on my work van and both doors are now rusting as they have rubbed the paint off , you may be able to shave some plastic off so this doesn't happen I wouldn't want the same to happen to yours
Same here, can’t believe it’s nearly 3 years oldTook it for its’ first MOT today. Passed with no probs.
Great feeling that.Took it for its’ first MOT today. Passed with no probs.
Might treat it to a remap ....Great feeling that.
Braver than me leaving it at 102...Might treat it to a remap ....![]()
Well, I did my previous van that was a 102 and Pendle mapped it and it transformed it into such a nicer flexible drive. So hoping a Pendle on this 150 DSG will do the same.Braver than me leaving it at 102...
Agreed - some of the quotes on here are ridiculous for what is actually a fairly simple job to do. Very good access once the air cleaner box has been removed. If you turned up at a VW dealer with your T6 on the back of a flatbed after the valves and pistons had been smacking seven shades of $~@$ out of each other two weeks after you fitted a belt you had bought over the counter from them, I'd be very surprised if their immediate reaction was to order in a new long engine and fit it f.o.c. Belt failure is usually secondary to something else such as a seized water pump or debris thrown up from the road which has taken out the aux belt and then the timing belt. The tensioner design on these makes it difficult not to tension them up correctly so anyone who has done timing belts on other vehicles will probably find these a joy to work on.
If anyone is twitchy about timing belt failures, have a look under your engine to see if it came with a full under tray (I believe many vans came without these). If you can see your sump you might want to have a look to get hold of a T5 / T6 under tray. It could be the best £50 quid you spend on your van (although if it does it's job properly, you'll never actually know!). Look up 7E0805685A
