I don’t like the vw jack either and got a bottle jack which would lift the van high enough to change a wheel which works well for routine maintenance but realised that with a flat tyre it wouldn’t fit under the jacking point. Solution was to use a smaller 2 ton bottle jack on a suitable point which would lift the van body enough to get the bigger jack in place. Seemed like a bit of overkill carrying 2 jacks but actually the 2 bottle jacks take up less space than the vw original and a lot safer.
I think that is my next move. Use the one I have to lift high enough to get a bigger one under. I'm happy that if I had a puncture I'd find something to drive the flat wheel onto (wood,stone,kerb etc) to get the van high enough to get the jack under.
I use one of these Heyner scissor jacks after having the standard jack spit out the side and hit the wall behind me whilst changing a wheel last year.Bought a bottle jack first but struggled to get the lift on some surfaces !
Amazon.co.uk
I took one look at the VW supplied jack, decided not too trust it and now carry a bottle jack in the front seat compartment. That one is about 1cm too tall to go under the van when the tyre is fully flat but fingers crossed that if I do get a puncture it won't be a big hole and I'll be able to get a little bit of air into the tyre to enable enough head room for the jack to go in. My Audi Q5 came with a 'conventional' scissor jack which I have more confidence in then the T6 one - mind you, the steel used in the Audi jack is also twice a thick as the other one!
PS. Where I said the bottle jack was about 1cm too high that's because I also have a piece cut from an 3cm oak plank which I can put it on if the surface is wrong.
What’s the difference between a bottle Jack and the heyner scissor type? I only have the VW Jack and sounds like dodgy if need to change a wheel etc at roadside?
Anyone fancy dropping a link to any recommended jacks? This would live in the van for emergencies, not for home maintenance etc. cheers all
Just got mine back from having the auxiliary belt tensioner replaced. Turns out the cause was the pulley on the alternator. The garage couldn't get the pulley off, so had to have a new alternator too. Lesson learned, I didn't take it too my VW specialist as thought it was an easy job and could save a few quid taking it to the local garage. I'm pretty sure that the specialist would have been able to get the pulley off and would have saved me the cost of a new alternator!
Also turns out the problem has existed since I got the van in June 24. A rumbling noise at low revs when accelerating has now gone, the noise got louder over the last few weeks and was joined by squeak. Overall I'm pleased it's sorted though
That's an interesting trading model the garage has - "we're not competent, therefore you pay more". :rolleyes:
Maybe I should rephrase that, I can't be sure the specialist would have been able to split the pulley I just think they would have had a better chance with experience and specialist tools.
Amazon.co.uk
Like the look of this but as it's only rated for 2000kg is it not rated strong enough to lift a Transporter? Or am I being thick because essentially you're only lifting one corner of the van to change a tyre so the weight to lift is actually less than 2000kg?
I went with "you are only lifting one corner " :) and side by side it looked a hell of a lot sturdier built than the VW one !
the ratchet handle is so much better to lift with as well ,not dragging your knuckles on the ground all the time.
And if u want a good wheel brace this is great
Down to personal preference I think .Both do the job ,personally I found that unless you carried a heavy duty bottle jack ,the ones I tried didnt quiet give me enough lift and I needed to carry a bit of wood with me to be a bit more stable on the ground
I have this one:-
Totally overkill at 5 tonne and I didn't really think about the 'only lifting one corner' logic applied above - so could have probably saved myself a few buttons and got the 2 tonne version!!
The 2 tonne version of yours is what I bought first, the range of lift was 168-316 which sounded all right but in practice only just got it off the ground once the suspension dropped with the lift! Whereas your 5 tonne one is much better at 207-402 ,just a bit bulkier to store in my van ,so went with the scissor jack which so far has been great as it goes from 95 up to 442 and surprisingly very stable !!
I ha
I have tried using the VW jack a couple of times, and just don't trust it at all :( I will be purchasing a bottle jack for changing flat tyres etc after seeing this post (I use a trolley jack and axle stands in the garage for everything else)
I have a couple of trolley jacks for routine maintenance but these are the bottle jacks I carry in the van. The small 2 ton I already had but got the 5 ton specifically for the van. 5 ton is more capacity than I need but it is the lifting range that matters and this jack will get a wheel clear of the ground and it is still quite compact. As above the small jack is just to raise the body a bit if the tyre is flat. Agree that a plank, rock etc would do but I just know that when I get a flat I will be halfway down Glen Torridon sideways rain blowing a hoolie in the dark and I will just want to get the job done. ( and probably my ocd as well).
Realised the problem with the vw original jack on a snowy winter’s day when went to assist another motorist stranded in a lay-by with a flat. When the car was lifted as soon as the wheel started to clear the ground the car slide sideways off the jack. Eventually got the driver to manoeuvre his car so the wheels opposite the flat were tight up against the verge which got the job done. Still felt quite sketchy though so not quite an F1 pit stop but not far off it.IMG_0387.jpeg
Does that give you required clearance to change a wheel?
Is it compact enough for storage?
I notice a 10tonne version hahahha
TBH given the range of suspension heights wheel/tyre sizes etc you will probably have to measure your own set up to be sure what jack would work. To see if a jack would fit under the jacking point with a flat measure the gap and then deduct the height of the sidewall to your tyre, not exact but close enough. To get the lifting range I jacked up the van with a trolley jack till the wheel was clear of the ground and then measured the height of the jacking point from the ground.
