Why won't they do it........have they tried and said it's to far out of limits or they just don't want to bother?Hi all, have recently fitted a set of stance coilovers to my t6 and was looking to get my 4 wheel alignment done, been to a few places and been told they can't do it,anyone had similar problems and found somewhere that would do it? Glasgow areaView attachment 68175
Get yourself to a garage with a hunter alignment system, but insist they use the “no load” settings. That will ensure that the system allows for the fact that your van is lowered.Hi all, have recently fitted a set of stance coilovers to my t6 and was looking to get my 4 wheel alignment done, been to a few places and been told they can't do it,anyone had similar problems and found somewhere that would do it? Glasgow areaView attachment 68175
I went to a hunters alignment and they wouldn't do it because i had adaptive cruise control fittedGet yourself to a garage with a hunter alignment system, but insist they use the “no load” settings. That will ensure that the system allows for the fact that your van is lowered.
Only problem is it will give the setting for a van at standard height. If you have lowered it the settings will not be correct.This what our local tyre place has
It’s from Italy, drive on and it reads your reg number and finds your settings
Lazors then read the chassis and tells the mechanic what to adjust
Recalibrated it self every time a new car drives on
Pretty impressive
Andy
Went to kwik fit told me that it only would give you settings for a standard set up. So does the hunter system work out the settings even if van is lowerd?Get yourself to a garage with a hunter alignment system, but insist they use the “no load” settings. That will ensure that the system allows for the fact that your van is lowered.
No, you have to tell them to over ride the settings and do a no load setup. This is one of the reasons Kwik Fit wont do lowered vans.Went to kwik fit told me that it only would give you settings for a standard set up. So does the hunter system work out the settings even if van is lowerd?
Wow. That is impressive. I work in a garage and we have old supertracker gauges. But they are next level. Need to speak to my boss tell him to get his finger oot!This what our local tyre place has
Pretty impressive
Andy
Pretty impressive
Andy
No, but lowering the van alters lots of the suspension settings. Look at the wheels of a low van, or one that is aired out and you can see the angles are very different.Possibly the height is not the problem
You only want the wheels to go straight in a line
Even hunter doesn’t alter the canver of the wheel
Ah I see, to be honest the guy in kwik fit was a bit of a fanny, don't think he could be bothered, maybe try another depot. Thanks for your helpNo, you have to tell them to over ride the settings and do a no load setup. This is one of the reasons Kwik Fit wont do lowered vans.
Inform you of what?Yeah possibly
Maybe some one with the knowledge can inform us
