Wheel-Arch access panels for lights
RattyMcClelland
Chipsaway - South Nottingham
T6 Legend
In the n/s arch lining, the fog light cover hole access thingy magiggy is missing.
Can't figure out what's it's called so I can buy a new one.
Anyone have a part number?
They are identical, pop the one of the other side and the part number will be stamped on it
Hi guys, just noticed that this plastic cover is missing.. did a search but can’t seem to find any! Does anyone know where to purchase or part number please?
Tia :thumbsup:
There was a velle posted recently for spare n repairs.. I 100% say that has some on it still.. Someone might be able to get the link for you.. try forsale page
Hi
Can anyone help me source a replacement trim item?
I've lost the cover flap that goes over fog light inside the n/s wheel arch.
Any help greatfully received
Some scrot has helped themselves to the "trap doors" inside my front wheel arch liners which give me access to the fog light bulbs
Is the stealer the only place to buy these or can anyone suggest a more reasonable source ???
Part numbers would be useful if anyone has them
7E0809967
Threads merged.
A length of 2x1 timber will be required with 20inch wheel on full lock inwards to press the last section of the cover on to get a satisfying click or you will be missing it shortly after driving took nearly 40 mins with no timber to press it on and it wouldn't click in - only a few mins with the timber a thumbs not wide enough to press the last sections in its a bugger to get on with the wheel on or when the vans not lifted as you can't get the pressure on the plastic without the bit of timber to press it home the curvature of the arch works against you on hand pressure a lone but it won't come off once clicked nicely in
Just a tip.for those considering trimming the hole to.make.it fit
For reference the edge of the 2x1 is pushed against the lip edge of the cover hard to force it home it gives much more pressure to the edge than your hand ever could
