Thats a good days work, and a good price too. How on earth are main agents charging £1100 ?
Only if there is code "1D7" on configuration sticker (under the dash at driver's seat). If so, there is a black 8-pin connector in left D-pillar.Will my t6 trend line 2017 panel van have the extended wiring for the westfalia kit to plug into it? Or do I need to buy the toe bar vehicle electrics and extended loom for it?
Great thank youYes, if that's your build sticker then you have towbar prep
Hi did the fitting go ok I'm in deal Kent looking for a mobile tow bar fitting service been quoted £600 supply & fit sounds a lot but this is all new to me.....cheers mickHad my tow bar fitted by PF JONES mobile fitting 2weeks ago
Had the Westfalia tow bar and vw wiring and coding done took the bloke about 5 hours outside my house (Essex area ) ..
The easy bit that you can do from the comfort of your chair: Have a look at the PFJones install manual online….it will show you the plug that should exist (often behind rear quarter panel on passenger side) if you have pre-wiring!Does my 2016 T6 Caravelle come pre fitted with all necessary parts to enable me to fit a removable tow bar?
