we got ours from here > way cheaper than the £600 factory option.
Home page | VAG-TEC E-shop
shipped in from poland, all OEM kit. took a few days to arrive.
we got this one >
Genuine OEM Retrofit Kit - Rear Camera - Twin Barn Doors - T6 Transporter
Genuine Volkswagen OEM Retrofit Kit - Rear View Camera - VW T6 | VAG-TEC E-shop
NEW VW T6 - Rear View Camera KIT - With Guidance Lines - Retrofit -
See behind your car with rear view camera.
A camera at the back of your car shows you what's behind to make reversing safer and easier. Or rear view camera lets you spot any obstacles behind your car - even moving ones - quickly and easily, thanks to the rear view camera.
The camera starts working as soon as you put your car into reverse gear. It shows the area behind your car on your radio or radio navigation system display offering you a clear reversing image with easy-to-follow guidelines. Superimposed graphic lines guide you to the optimal steering lock, guaranteeing fuss-free, smooth parking.
Using the rear view camera means you'll be able to manoeuvre quickly and easily, even into the most difficult parking space. It also alerts you to low-down obstacles which parking sensors cannot always detect. The reversing camera is also a great help when you're hitching up a trailer.
Compatible with Head Unit:
Composition Media
Discover Media
Discover Media Plus
Note:
After installation you need to code the system.
Please contact your local VW dealer or workshop with diagnostic software ( VCDS or ODIS ).
Availability:In stock
Estimated Shipping: 1-2 Days
Weight: 1.5 kg
Installation Time: 3 Hours
Item Condition: New
Fitting Instructions: Available
Required Fitting Expertise: Medium - Some Fitting Skills Required
Warranty Period: 12 months
It come with a new rear plastic cover with the camera already mounted. but we have colour coded plastics, so we plan to fit the camera in our painted part - still yet to do this bit.
The loom come complete, even with the pins ready to be connected to the rear ISO block on the Nav.
Edit -
the cable run was ok doing a bit of fishing here and here.
remove the rear door panel, run cable through existing door loom boot.
fish cable from behind rear light up to upper tailgate hinge cover.
fish cable above roof lining with existing loom all the way to the front.
fish cable across cab roof lining and down A-pillar.
fish cable behind glovebox to rear of nav.
Genuine VW T6 Tailgate Rear View Camera Retrofit Upgrade Kit
What rear doors do you have ? I have one tailgate kit in stock that can dispatch tomorrow for Friday delivery, it’s a LWB setup but just means you will have a few hundred mm of extra cable
we got this one >
Composition Media
Discover Media
Discover Media Plus
Note:
Weight: 1.5 kg
Item Condition: New
Edit -
I have barn doors but mine is a lwb.Genuine VW T6 Tailgate Rear View Camera Retrofit Upgrade Kit
I would echo this, have had dealings with them and they are awful, they will lie to you and pretend to be in the UK etc etc, they are not, all they want is your money and they will not help if theres any issuesBe a little cautious of this company Vagtec. I used to deal with them years ago under a different name. They are crooks and will never resolve any of your problems. Also not sure where they source there stuff from. His name is Tom.WARNING
The top one where you ordered your stuff from, Tom the t**t
