Which spacers - Clayton 235/70/16 ET51
Alexzeat
Hi which spacers are you using in your van? 25? 30? front? rear? where you bought it? Thanks , also please post a pictures
I'm interested in this as well but I guess any answers also needs to include wheel / tyre details to make a meaningful comparison.
Ditto, I measured the distance between the edge of the tyres and the wheel arch. It looks like it could take 15mm up front and 25mm at the back. Not sure if this equates to 15/25mm spacers though.
I have 235/70/16 of All terrain ko2 View attachment 76510
Have a look at this thread:
If you run 235 width tyre then at least 10mm is needed to avoid arch rub at full lock assuming the tyre is clean. We run standard height 20mm all round, Watfields spacers are very well engineered and come with decent bolts. Tyres 235 65 17 will fit T6 T32 with about 10mm clearance at the back of the rear arch so very coarse gravel in the tread might catch sometimes.
