@CRS Performance Steve if I wanted to do a mild 30-40 mm drop on a T30 T6.1 LWB panel van that is empty at the moment but will slowly be converted would kit B be the best solution. The getting the suspension fully sorted when conversion finished?
If you look at most rear springs for a transporter they all have a few coils that are coiled tightly and sit on each other under normal use , Its not because they are cheap and nasty at all it how they get the car low with out the danger of the spring jumping out of position when the van is lifted off the ground ( Safety issue) , There are tons of cheap and nasty products out there but this isnt one of them i have to say . The touching coils dont make a noise on the H&R lowering springs as they are parallel anyway . The touching coils on a tapered spring can sometimes make noises . ( not on a Transporter )I had the 40mm springs hr fitted on my t28 and these was fitted with new cups the coils where nearly touching at the top hence the knocking I just think cheap and nasty
Yes the B kit will be the longest front spring so should give approx 40 mm the B rear spring will be fine with an empty van but after conversion will need to be changed to a D rear ( also the longer spring)@CRS Performance Steve if I wanted to do a mild 30-40 mm drop on a T30 T6.1 LWB panel van that is empty at the moment but will slowly be converted would kit B be the best solution. The getting the suspension fully sorted when conversion finished?
Getting the right spring simply means getting the height where you want it ,. H and R offer 4 springs which gives the correct height depending on the weight of your van ,
Things that affect weight Are. Motor size , auto box. 4 motion , twin sliding doors , California or caravelle , camper and pop top accessories , all this will throw out the axle weights so it isn’t a good thing to only work on the axle weights .
the really important thing when fitting springs only. Is the condition of the shocks , the standard shocks are not that good. And don’t like lowering springs particularly if they have done miles. Shocks don’t last forever and are a serviceable part of the car , if your van has bigger wheels You will not get a great ride with lowering springs on the standard shocks .
the answer is to fit a proper performance shock to the H and R springs , this you can do later if you find the result isn’t as good as you hoped .
to advice on the best spring to use we would need a little more info , if you call us we can assist .
Take the measure from wheel centre to arch for SteveThank you, going off the axel weight the kit 4 matches up, I do have twin sliding doors on the kombi, 2 + 1 seats in the back and a double dog cage permanently in the van. When I measure the current set up the results are as below running on 18” sport line alloys. I’m guessing as the weight is always in the van kit4 would be the best to try first? Would you recommend changing the rubber first as last to minimise and risk and issues.
Yep, that should give @CRS Performance a chance
Assuming the tape is in the center of the wheel center cap. The van looks to be standard height
The -40 spring will fit the van but the drop won’t be 40 mm. I would think 30 mm.
If you want 40 plus I would recommend -1 kit.
remember on standard shocks and lowering springs the ride isn’t great
Sport shocks and lowering springs are the ultimate answer
The 50 mm spring is shorter than the 40 mm spring so you will get to the 40 you needThank you, would the 50mm kit be the same issue or should I go for the kit 1 with 50mm h&r springs aswell? Cheers
Ash , I don't rate Stance at all we pull lots of those out of vans here . Corrosion and spring sag is really bad with time .Brilliant thank you, which of the two
Options would be the best option for myself please?
H&r 50mm springs only standard shocks
Stance+ Street coilovers
Cheers Ash
That’s great thanks Steve.Ash , I don't rate Stance at all we pull lots of those out of vans here . Corrosion and spring sag is really bad with time .
I would say get the H&R springs first and then save up for the KONI sport dampers , this will blow you away .
steve
steve
