[@Paul Morley Perhaps it means that you can see BETTER in other than daylight.![]()
Yes they they are, and you get extra daytime running lights so you get 4 x H7. I have them, they are pretty good, and have commented a couple of times that the L+V Plus pack gives you decent lights for £900 less than the LED'sI don't know if this is of interest, but when ordering my Highline, I took the option of the lights and vision plus pack.....hopefully this is indeed the H7 lights.
Exactly what I went for. Clearly not as awesome as full LED package but perfectly acceptable.Yes they they are, and you get extra daytime running lights so you get 4 x H7. I have them, they are pretty good, and have commented a couple of times that the L+V Plus pack gives you decent lights for £900 less than the LED's
Not to sure yet we will have to see what happens during the fit I would prefer not to drill anything but this may Have to be the caseWhat's the plan @Paul Morley, you going to drill the rear light cover and mount the extra bits in the engine bay somewhere? There's enough space especially for the passenger side.
Be very interesting to see the results of this.
I'm happy for now with the 150+ bulbs, but if funds don't allow for a full headlight swap then this is the route I may have to go.
Where did you get your H4 Philips Luxeons from, because mine brought up bulb failure lights on the dash, love to know if yours work ok[
may not need to spend two hours in a dark room now before i go out at night DPD has just been and they have arrived will be fitting in the next few days
View attachment 4761 View attachment 4762 View attachment 4763
Mine came from here H4 Hi/Lo Philips LUXEON ZES Headlight Kit - 4000 Lumens havent had chance to fit yet as got central heating problems but hoping to do them next weekWhere did you get your H4 Philips Luxeons from, because mine brought up bulb failure lights on the dash, love to know if yours work ok
I dont know how long you have had them, but honestly 5 min job to test, use the passengers side, take off the dust cover pull the lead off the back off the H4 bulb and plug it into the Philips unit, just let it sit on the bonnet slam panel, try hi/lo beam and see if you get a bulb failure light, then do the same to the other philips unit, if ok, great fit them another day, if not send em back, let me know how you get onMine came from here H4 Hi/Lo Philips LUXEON ZES Headlight Kit - 4000 Lumens havent had chance to fit yet as got central heating problems but hoping to do them next week
How did you report?Hello Chaps.. I've just reported to DVSA too
Test them first, before trying to fit them, I fitted mine and then had to take them out because of bulb failure light on the dash, just take the conection of the back of the H4 bulb on the near side as you have a bit more room, plug the philips/Led/ Hid units in one at a time, just leave them sitting on bonnet slam panel, try them on hi/lo and flash, and see if you have warning lights on dash, let me know how you get on. Make sure the VW plug connections don,t go to earth they are a bit exposedMine have just arrived, I'm pretty poor at fiddly jobs (podgy fingers!) so hope Spud can enlighten us on 'how to'.
Could be a good solution to us H4 sufferers.
Assuming they don't upset the canbus, do they fit OK ?
