Its well known that across the VAG range that Adaptive cruise eats rear discs / pads.
axle_diff
axle_diff
in order to show the signal betterI'd of said the obvious option is the brakes are binding either calipers not release properly or the handbrake mechanism is jammed. That's where I'd start before anything electronic.
@Nutexa Frictions any guidance?
I found the rear pads (and discs) wore down quicker on my T5.1. The sticking handbrake cables was the most likely reason. Also the fronts are vented and larger, so have a higher "capacity" for braking, even though they probably do more braking effort.Also check the handbrake cables aren't frayed and causing the to stick rather than sliding in and out of the outer housing, check they have free movement throughout their run, handbrake should be adjusted to 3 to 6 clicks. Lower than 3 the pads won't retract enough causing the pads to drag more than 6 the handbrake won't be effective
The rears are vented too on my T6/32I found the rear pads (and discs) wore down quicker on my T5.1. The sticking handbrake cables was the most likely reason. Also the fronts are vented and larger, so have a higher "capacity" for braking, even though they probably do more braking effort.
There’s only one pot on the rears & it’s the pad on the pot that wears, dunno if that’s significant.The rears are vented too on my T6/32
Wait, do they really go through disks at the same rate as pads?!?I'm pretty sure the rear discs and pads on my Caravelle are the originals, the pads have about 10% or less left and the discs will need replacing at the same time, it's done 45k miles.
These days it seems that discs wear out quite quickly. Some blame surface corrosion which forms as vehicles are being used less frequently, others say brakes reach higher temperatures than previously due to changes in driving styles (more reliance on friction brakes rather than engine braking), increase vehicle weights, higher speeds, other systems such as traction control using the brakes, etc.Wait, do they really go through disks at the same rate as pads?!?
I was expecting to get at least 100k out of a set of disks...
That sounds more like the rate I was expecting. Given VW costs I maybe need to get the gear to do my own, being a bit safety critical it's always a line I've not crossed but it seems dealers are more and more playing on that instinct to get work.I tend to replace discs every second pad change. I do my own brake pad and disc changes.
Did my rears last week. Pretty straightforward with minimum basic tools:-That sounds more like the rate I was expecting. Given VW costs I maybe need to get the gear to do my own, being a bit safety critical it's always a line I've not crossed but it seems dealers are more and more playing on that instinct to get work.
I bought axle stands, bottle jack, new sockets and the special long hex key for the calipers, a torrque wrench and performance discs and pads for the front. And the whole cost was much cheaper than getting VW to do them.That sounds more like the rate I was expecting. Given VW costs I maybe need to get the gear to do my own, being a bit safety critical it's always a line I've not crossed but it seems dealers are more and more playing on that instinct to get work.
That sounds like the rears to me are a floating calliper and it isn't quite 'floating' as freely as it should.There’s only one pot on the rears & it’s the pad on the pot that wears, dunno if that’s significant.
It is a floating calliper & they were free/greased/corrosion freeThat sounds like the rears to me are a floating calliper and it isn't quite 'floating' as freely as it should.
