Wi-Fi on move
I have an mr2100 netgear thing, the £300 one…. Should have got the 6…. If that’s aerial would help it then I’m all for it
Remember you're in a metal box - in physics we call that a Faraday cage and it's an excellent way of shielding anything inside it from radio waves (hence why all the antenna on the vehicle are outside it)
An Omni directional antenna will not in itself improve reception, it just means you can move the antenna to somewhere there is good reception instead of the whole device. Not in the pictures the antenna is dangling by a window...
Directional antenna will improve the signal level, but you have to know where the cell tower is so really only worth it on buildings.
Cable loses between the antenna and the device also mount up quickly, it's almost never worth going over 4m on a passive antenna. Also the coax cable must always follow gentle bends.
First thing if you're having issues is to move your M2100 around, try it in the windows, try it in different orientations, try it outside under the awning. When you know what works then you can decide if an antenna will help, you might just need a clamp type phone mount and stick it to a window.
I use a phone mount on a window in the narrowboat or hang it under the Cratch Cover (the one at the front) so it's outside the big metal box.
I have admittingly not cheap circa £700 Netgear Nighthawk M6, partnered with its relatively inexpensive add on Ariel.
Nighthawk M6 WiFi 6 Mobile Hotspot 5G Router - MR6150 - NETGEAR
Since I have had it we have not had issues getting decent signal anywhere when we have been away (Places we have been since getting it: Lake District, Yorkshire Moors, North and South Wales, and remote parts of Perthshire). This includes a number of times when our phones have not had signal yet this thing has produced more than 20mbps minimum. Seen it produce over 300mbps on 4G and over 700mbps on 5G.
It uses a thing called Carrier Aggregation which is a technique used to increase the data rate per user, whereby multiple frequency mobile blocks are assigned to the same user. Meaning using one sim card it asks for the same data across multiple frequencies and then combines them together, to give increased reliability and ultimately speed.
I keep the main M6 in cupboard velcroid to the side out of the way, the add on Ariel then sits on top between cupboard and upper bed board, Occasional if the signal is not great I have let the Ariel hang down vertically over the cupboard, as signals are directional. This change has then resulted in improved coverage.
Originally I had planned to get a roof mounted GSM shark fin, but do not see the need now, as the current setup has performed without flaw.
The kids stream as we are driving and not had any drop out the whole time we have used it, and drive through a lot of black spots. I have used the M6 on its own on the train from Aberdeen to London for work, and noticed no issues- normally have issues using just hotspot on phone or using the train wifi.
In it I use one if the pre-paid preloaded sim cards - which over the time equates to about £12/m for unlimited data.
Have you tried to see what coverage is like with the antenna unplugged? I’m just about to press the button on one.
The antenna does help, but the M6 will work without it, when use it on the train I don’t take the antenna with me.
Worth check as have seen NETGEAR to have deals where it is cheaper to buy the M6 with antenna than it is without it.
Thanks, I might try without first.
I got a decent deal via o2 on an upgrade with unlimited data.
If the sub for starlink was half the price then no question, starlink
I have a mifi netgear on ee and it works but a lot of the sites I goto have crap signal
Starlink would sort that, mini dish coming out soon for it also
I had a Teams meeting this morning with someone who was working from their camper in Switzerland surrounded by stunning scenery.
He was using Starlink Mini and the connection was flawless - better than others who were office based.
If you were staying in the van for extended periods overseas then I can see that starlink would be excellent, if it can replace your home broadband when you're not in the van that offsets the cost by £20 a month or so.
I'll make do with my 4g router and 50GB of data with smarty for £8 a month :D
One advantage is that you only pay for starling for the months you use it. Switch it on and off as you need to
