Ajyay would you be able to measure the two black studs which the bolts go through just behind the bumper for me if you get a chanceAs Spag suggests, try the other notch. I've got a 16" spare and it's held very securely.
Hi ayjay no the length of them I will send a picDo you mean the width between them or the size of the thread? Sorry for being thicker than usual but I'm an idiot on mechanical / engineering stuff. I'm just going out but will do the measurement later and let you know later this morning if you answer this. Cheers.
I posted this a while ago...the spline drive bolt is longer anyway!
Spare Wheel Theft.. Again.
It's happened again FFS, this time with an added locking bolt, exactly the same parking place as last time. I street park in London on a street opposite my gaff that has some big houses on it with 24 security eyeballs. Spoke to the guard and he saw nothing, wouldn't mind betting it's him at it...www.t6forum.com
My T6 Transporter has a rib bed fitted which is secured by a long bar underneath. I have a 235/55r17 spare wheel. When the spare wheel carrier is in the lowest position it has a space of 200mm to the rib bed bar. Does anyone know how I could lower the bracket further ? I need atleast 35mmOur converter has a Sportline 18" wheel which we were going to have as a spare, but he's just gone to fit it into the new spare wheel carrier, and he says it's too big. Is there any way to make it fit, or alternatively, is there another wheel that will fit in the spare wheel carrier, that will give the same rolling radius as our 17" Edition alloys? Ta!
Use longer bolt and carriers sometimes have 2 holes so you can extend down on pivot side. Cheers IanOur converter has a Sportline 18" wheel which we were going to have as a spare, but he's just gone to fit it into the new spare wheel carrier, and he says it's too big. Is there any way to make it fit, or alternatively, is there another wheel that will fit in the spare wheel carrier, that will give the same rolling radius as our 17" Edition alloys? Ta!
Morning. What size plate did you add to the original? Want to get this made for mine!View attachment 92020View attachment 92021View attachment 92022View attachment 92023
I extended my carrier as per photos.
I then threaded the pin to lock it in place with locking nuts.
wheel-size 235/55/17.
