No problem Pauly, going to have my local mechanic look at it whilst fitting the ABT body kit.... at bloody lastI have part numbers/prices but they are at the office (and i am not)
You also need to prise the trim panel off the front of the inside door handle with a trim tool, there are 2 torx screws underneathYes you have to remove the door card,remove the window switch first then there is two quarter turn clips at the bottom and I think from memory two screws at the top .
Then the rest is panel clips
Wing Mirror RemovalGunna be having a go at replacing the metal swivel bracket inside the mirror which snapped off recently, any advice? Doesn't seem to be any guides on how to do this, I take it the door cards have to come off in order to get the morrow wires out, how do I go about removing the mirror casing?
Do you know what parts you need ?
I have an exploded view diagram of the mirror if you want it
Every part is available separately but the metal guts form the largest part and include most of the fixings/clips etc and is the most expensive by far
Give me a shout if you want anything sourced or I can send you the part numbers if required
