Made our own with a roll of insulation from Screwfix & some expanding curtain poles from Wilko. Works fine, cost about £30
No problem, we cut 3 pieces roughly the shape of the front & sides, making sure they were oversize. Then we pressed the insulation against the sides, pressing it into the top & bottom of the roof, then went around the edge with a sharpie. Cut along the outsides of the line & refit into the roof, tweak the shape & trim to ensure a tight fit. Do the same for the front. Use gaffer tape to make the front corners. You now have a 3 sided shape to fit the sides & front. Use the Wilko sprung loaded curtain poles in the front vertical corners, use a couple of shorter ones along the sides to keep it in place. Make a small piece up for the rear.That sounds interesting -got any pictures? or a bit more info how you did it please?
Which particular Screwfix insulation role did you use please?Made our own with a roll of insulation from Screwfix & some expanding curtain poles from Wilko. Works fine, cost about £30
Can’t remember off hand, it was 10m long by 1m wide iircWhich particular Screwfix insulation role did you use please?
Just been into Toolstation today, they have a very similar, if not identical roll of insulation that Screwfix had. About £20 a roll.Can’t remember off hand, it was 10m long by 1m wide iirc
Any pictured please I'm thinking of doing this.Made our own with a roll of insulation from Screwfix & some expanding curtain poles from Wilko. Works fine, cost about £30
We find it makes a huge difference to heat retention/sound/how hard the Webasto works etc. We’re going to have a go at the MK2 version for next winter, as I cut the originals a tad too small.Salty Spuds has posted pictures above. We did something similar for the windows for a recent ski trip. Double layered them as only used half a roll. They worked a treat.
View attachment 29140 View attachment 29141
Actually off thread and late but hoping not too late to ask how you managed to create the cool map on the bed base in the photos?View attachment 29140 View attachment 29141
It’s a vinyl wrap. We searched for ages on the ‘net trying to find the map of our dreams. We wanted high res. Topographic details along with major roads & towns and shading for the ocean depths. We eventually found a company in Cornwall called Maps in Minutes who would create you any map you wanted. They created the image file (vector) and emailed it to Dirty Weekender who had it printed onto a vinyl wrap.Actually off thread and late but hoping not too late to ask how you managed to create the cool map on the bed base in the photos?
I am quite keen to do something similar and have been looking for suitable fabric etc.
Would this work if I made it to wrap around the outside of the poptop similar to a rainbow screen for example ?View attachment 29140 View attachment 29141
Dunno, ask me a football questionWould this work if I made it to wrap around the outside of the poptop similar to a rainbow screen for example ?
