Winter Interior Insulation Covers For Pop Tops
I
Would this work if I made it to wrap around the outside of the poptop similar to a rainbow screen for example ?
If it's water resistant it should work, this is basically what our Pucer Screen is. Have a look at their site. Massive improvement in insulation in cold weather.
Reactions: Ozi
If you have stitched a waterproof cover over the insulation the stitched seam needs to be water tight.
An internal cover seems like a far better option unless you are 7’6” tall and don’t mind standing in the rain.
View attachment 29140 View attachment 29141
No problem, we cut 3 pieces roughly the shape of the front & sides, making sure they were oversize. Then we pressed the insulation against the sides, pressing it into the top & bottom of the roof, then went around the edge with a sharpie. Cut along the outsides of the line & refit into the roof, tweak the shape & trim to ensure a tight fit. Do the same for the front. Use gaffer tape to make the front corners. You now have a 3 sided shape to fit the sides & front. Use the Wilko sprung loaded curtain poles in the front vertical corners, use a couple of shorter ones along the sides to keep it in place. Make a small piece up for the rear.
Looks good and thinking of doing similar. Any thoughts on wether stick on Velcro would work for this and the pop top and remove the need for the poles?
What did you do to hold the poles at the bottom, given the angle they are at?
