The Ovano stores a lot more tools than i thought it would. Just need to tidy the back of my van!Ok so it’s not taken on Wednesday, in fact it was earlier in the summer but I only just found this thread
Here is the Kombi about ready for a kitchen install…
The bigger tools were in the middle with the seats out…
I do love the Ovano![]()
Where did you get the side pillar decals/trims from please, and would you rate them?
Got them from ebay ....quite a fiddle to fit but worth it !Where did you get the side pillar decals/trims from please, and would you rate them?
Nah - he'd be posting even more if he'd retired.Welcome back @Dellmassive , thought you’d retired
never !!!Welcome back @Dellmassive , thought you’d retired
Work van has been waiting for a replacement battery so has been parked up…
Today is that day!
Uprated and installed, transport plugs left in until installation, of course.
So I see it's clamped in, is there a reason you can't just put the terminals on, tighten the bolts and drive it? (I'm going to need to know at some point with a 4 year old battery!)
2 main reasons:
1: The battery will move around causing wear to the casing and potentially damage the casing causing an acid leak or damaging the area around the battery.
2: With the battery being free to move and the positive terminal being on the side closest to the inner wing, that could lead to the battery shorting on the metal and that definitely wouldn’t be good.
Also, as the terminals will be taking the strain of trying to stop the battery from moving, that could break the terminal off the battery or damage the connectors/wiring.
So, it’s strongly advised to clamp the battery down to avoid the above or other issues.
