Got any photos of those Lazer lights?Best - Lazer lights
Worst - 'Transporter' wing sticker that I left on for all of 10 seconds.
There's a few in this thread Lazer LampsGot any photos of those Lazer lights?
Are there any good twin seat swivel mounts?Best - Renogy DCC50S charger
Worst - twin seat swivel - huge design flaws (many of them)
Brill. I will have a look on eBay at pricing.We much prefer our MS Craft swivel, compared to the Kiravans swivel that was fitted when we bought the van.
Been looking at this battery wondering if it will fit under a single seat base. Where’s yours stored?Renogy 170Ah Lifepo4 battery is performing amazingly and I have found this battery so reliable. No frills...... Just an internal BMS which does what it says on the tin:
12V 170Ah Lithium-Iron Phosphate Battery
The Renogy 12V 170AH Lithium-Iron Phosphate Battery is perfect for deep-cycle applications including cabins, solar/wind energy systems, UPS battery backups, telecommunication systems, medical equipment, and more.uk.renogy.com
Something that has performed worse than I had expected and I don't consider good value for money.
Orion-Tr Smart DC-DC Charger Isolated - Victron Energy
The Orion-Tr Smart DC-DC charger is a professional DC to DC adaptive 3-stage charger with built-in Bluetooth. For use in dual battery systems in...www.victronenergy.com
Under drivers seat together with a 30A DC-DC charger. Perfect fit.Been looking at this battery wondering if it will fit under a single seat base. Where’s yours stored?
Any chance of a picture @Samro ? I’m considering the renogy 170ah but it would need to lay on its side (as in the pictures I think) as I have a lowered seat base so I cant fit a standard spec/dimension battery upright.Under drivers seat together with a 30A DC-DC charger. Perfect fit.
Finished mine today:
Drivers side:
Renogy 170Ah lifepo4.
Victron 30A DC-DC
Bluesea Master fuse holder
Victron Smart Shunt (500A)
Victron Smartsense
(Relocated existing LED light controller, tow assist controller and numerous fuses.)
Passenger side:
Bluesea 70A breaker (For master feed-Excluding inverter feed)
Bluesea 200A breaker (For inverter)
Victron Battery Protect
Victron 1200W inverter
Victron Smartsolar 75/15 MPPT
Bluesea Maxibuses,
Bluesea negative Minibus and compact fuse block.
Solar isolation switch and circuit protection
Bluesea Isolation Switch. (Externally accessible when seats reinstated)
Raspberry Pi 3b with Victron Cerbo Software with USB cables to all available VE ports.
Power supply for Huwawai 4G router.
Distribution box with protection for inverter output.View attachment 136015
Thanks.Here you go:
I agree with the Eco Worthy monitor comment as its not really for campervans. I use it in my garage solar set up, but would not purchase it again.Best Van King bed and sliding tray.
Worst Eco Worthy battery monitor.
John.
My problem is getting it set up correctly as the coloured battery symbol does not light up and understanding the instructions is nigh impossible. I've managed to set it up as it reads the battery voltage only.I agree with the Eco Worthy monitor comment as its not really for campervans. I use it in my garage solar set up, but would not purchase it again.
Have you completely drained your battery then connected it up? but evidently it will eventually sort itself automatically. (they are pants) In the van I have a 200A shunt.My problem is getting it set up correctly as the coloured battery symbol does not light up and understanding the instructions is nigh impossible. I've managed to set it up as it reads the battery voltage only.
John.
I have the same with a charge isolator switch for cold weather, I drained the batteries to 10v and let it charge itself its now showing 134.2Ah @ 67%. (the instructions are pap) and its not really for a campervan as I feel its a little fragile, namely the hall monitor and wiring.I have two 100ah eco worthy lithium batteries but I haven’t completely discharged them they were about 60% charged when I connected the eco worthy battery monitor and then fully charged the batteries, but I’m stuck with it as I cut a hole in my panel to house the unit.
John
