Removed from my t28 panel van.
Go caught up in the whole van lowering phase, but realise that I prefer my van with stock suspension for my usage.
Only had it fitted for a few months. Shame but not for me the lowered stance.
The kit made a Hugh difference in driving on normal roads. Little to...
Looking to buy a set of H&R 40mm lowering springs for my ex RAC T 32 but not sure if I’m right in selecting kit D? Also is there anywhere people can suggest that doesn’t charge £16 delivery like Vanstyle? Thanks
40mm Cobra Lowering Springs, removed from a brand new Leighton T6.1 T32, according to their website they’re one size fits all but would recommend checking if you have a T28/T30. They’re £200 + Postage on their site.
£150 posted anywhere in mainland Uk or collection from the Buckingham area...
H&R 40mm lowering springs, please see label in pictures for the spec.
I've attached a picture of the van (T32 4 motion) with them fitted, they looked great but we regularly tow with high nose weight trailer and the back sat too low once loaded.
They were fitted for literally 2 weeks so are as...
These have been on my van, T6 T28 for less than 100 miles, before i swapped them out for slightly longer ones just to lift the back end slightly, (personal choice). They are in near perfect condition, slight bit of paint rubbed off on the tight coil ends, that all. I'm asking £50 for the pair+...
Great condition full koni/H&R suspension kit for T28/30 T5/T6.
- Koni Adjustable Sports Shocks Front and Rear
- H&R 40mm lowering springs Front and rear kit 2
Front Spring - 29270-2 VA
Rear Spring - 29270-2 HA
This set, 29270-2, is suitable for a van with front axle weight from 1501kg and...
Removed from my van due to upgrading to coilovers. They’ve covered approximately 18k, there’s a little paint flake and surface rust as expected.
Price - £80
Collection from NE13 (Newcastle)
Selling a set of 40mm H&R lowering springs.
Been on the van a couple of years, upgraded to coilovers. (Thanks Steve @CRS Performance)
Fronts have a bit of the coating missing from being on the van. Very slight marks on the rear springs..
Looking for £100, but happy to listen to offers...
I've just bought an ex rac t6.
I've been told the rac t32s have uprated Suspension. Not sure if that's springs and dampers.
The ride is awful. Very boaty and the steering seems really light.
It's going to be a work van but won't be carrying no more than 100kgs at time.
I'd like it a bit lower...
Have a T6.1 2020 T32 Kombi when purchased was lowered 40mm, has 20s with 40 profile roads tyres at moment.
Go on a lot of Wet Grass and Mud, really want to switch to an All Terrain tyre and wheels package like a General Grabber AT3 (5x120 18"j et45 235/55/18 profile), or go to 17 if can't fit...
Hi Guys, picked up my 2016 SWB kombi on sat. Love it but it needs to be lower to make it more of a ‘car feel’ and obviously the aesthetics too.
I’ve got £500 to spend. I know b14s etc are ideal but it’s just not happening from a budget point of view.
What would you do? I want to go about...
I've now picked the alloys and dimensions but what tyre brand are people using on 20’s
Been quoted on accelera which was really cheap and may go down this route initially but normally stick to main brands, yoko, Pirelli and Michelin etc
Brand new set of H&R lowering springs (-40mm)
Kit 3: 29270-3 (Front < 1500kg, Rear > 1561kg)
Perfect setup for a full camper layout. Heavy rear springs allows for the added weight.
See link below for more info:
H&R Lowering Springs for Transporter T5 / T5.1 / T6 - 1.9 / 2.0 / 2.5 TDI (~40mm)...
T32 Koni Active Shocks with H&R 40mm lowering springs.
Supplied and subsequently removed by Steve at CRS Performance. Covered less than 8k miles. These are a great upgrade and in full working order.
They were reluctantly removed after 12 months as I wanted to go lower.
Looking for £550...
See link below for more info...
For sale H&R 40mm lowering springs .
Springs were removed yesterday by @CRS Performance from my T28
They were installed last October i believe by the previous owner
£100? Collection preferred from NW London
Could get a postage quote if required
Hi All. Getting my t32 kombi lowered.
been offered 20” wheels and 40m lowered at leighton vans
dont Carry much weight in the rear.
any of you guys recommend this or advise against ?
Hi I have a brand new T32 Kombi 4M 204 SWB and I'm looking at lowering keeping factory 17 Devonports with springs only.
Has anyone done this and can comment on ride quality? I don't carry much unless we go away camping.....I'm thinking lowering 40mm max.
Any other advice appreciated.
Cheers...
I have a t28 t6.1 highline 150dsg and I've just checked tyres at 9300 miles and all 4 are worn to the point that they all need replacing. One (rear off) is at legal limit so need to change ASAP.
I'm currently running the bridgestone weather control a005 245/45/18 100y
Any ideas as to what...
Hey all, looking to get a stitches & steel look to my LWB T32, including adding some 19mm pepper pot wheels.
Would simply adding some 40mm springs to the oem shocks do the trick? This van will primarily be used for work shifting heavy items in flight cases, so conscious that I don't want to...
