150PS Remap done - what are your opinions?
Not surprised to see Martin at Pendle being his usual self.
He took quite a bit of stick over on the T5 forum then left.
He does know he’s stuff and has probably remapped your van within safety limitations but there are other remapped out there. I’d leave your van as it is as the graph looks fine to me.
Martin at Pendle is very good at what he does, but is a firm believer in saying it as it is with no regard for a customers feelings. That said he has always been my go to for remaps and turbo problems. He will only do what is best for your vehicle as it is presented to him.
Carista has arrived . It says soot content is 24.60g. Is that high? Would that have much effect on performance ?
The soot level travels between 5-24 grams, or 8-30 grams depending on engine software. The min value you get just after DPF regeneration. The max when DPF regen is triggered.
Those max soot value don't affect engine performance - to better analyze someone :geek: certainly should measure pressure loss over the DPF...
I'm curious to see "Detailed ECU info"-report (under Carista Service menu) - please.
Code:
DETAILED ECU INFO
ECU info obtained with Carista 631099 for iOS:
VIN: WV1ZZZ7HZHH05****
Engine
Part #: 04L906056KL
Component: R4 2.0l TDI
Software version: 3802
ASAM/ODX identifier: EV_ECM20TDI03004L906056KL
Coding: [none]
[No fault codes]
ABS
Part #: 7E0907379P
Component: ESC
Software version: 0133
ASAM/ODX identifier: EV_Brake1ESCCONTIVN75XGP2
Coding: [none]
[No fault codes]
Instrument cluster
Part #: 7E0920970S
Component: KOMBI
Software version: 1104
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: [none]
Fault codes:
13654544 Manufacturer-specific code
Airbags
Part #: 7E0959655G
Component: VW10Airbag021
Software version: 0018
ASAM/ODX identifier: EV_AirbaVW10BPAVW12X
Coding: [none]
[No fault codes]
Steering angle
Part #: 6R0959654
Component: LENKW.SENSOR
Software version: 0070
ASAM/ODX identifier: EV_LWSKLOVW25X
Coding: [none]
[No fault codes]
Parking/steering assist
Part #: 7E0919475T
Component: PARKHILFE 4K
Software version: 0212
ASAM/ODX identifier: EV_VW75XParkAssis4K
Coding: [none]
[No fault codes]
Heater & air conditioning
Part #: 7E0907047AK
Component: Climatic-T5
Software version: 0708
ASAM/ODX identifier: EV_ClimaticT5
Coding: [none]
[No fault codes]
Radio
[ECU not present]
Central electronics
Part #: 7E0937090B
Component: BCM PQ25 Max4
Software version: 0744
ASAM/ODX identifier: [none]
Coding: [none]
Fault codes:
03303 Feedback Locked-Position rear-left
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Coding: [none]
Fault codes:
01314 Engine Control Module (ECM)
03158 Control Module for Information Electronics 1 (J794)
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: [none]
[No fault codes]
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: [none]
[No fault codes]
Infotainment system
[ECU not present]
Obtained with Carista 631099 for iOS.
Download app: ‎Carista OBD2
Facebook: Log in to Facebook
Reactions: mmi
Does everything look as it should?
Engine
Part #: 04L906056KL
Hmmm... for some reason remappers do not want to identify themselves by changing software identifiers to their unique ones- it seems to be the same here - no change.
However, the base software version "3802" is the factory installed one in 2017 for this engine. Since then all T6 engine softwares have been updated, and there is an update also for this engine. The update cured quite a few nuisances.
I wasn’t impressed with my revo map either. Couldn’t really tell much difference .
For Carista dongle there is also another Android app - VAG DPF Free - for monitoring just DPF soot level and regeneration status (on/off/duration). This app launches much faster than Carista as it does only this one thing.
More here:
Thanks for that info. How do I go about updating the software ? Is it a Vw garage thing? Will it cost me?
On a 150? Mine was so different!
This is what I’d heard, I don’t know what I was expecting but I can honestly say there is hardly any difference , but I heard people say there’s were sluggish where as mines always pulled really well, I just wonder if it already had a remap by the previous owner?
  • Wow
Reactions: mmi
My van is late 2017 and has not had any software updates. Earlier this year I specifically asked VW if an update was available and they told me they could not advise as it had to be inspected by a dealer. I booked it in and was told no updates were necessary as the van is not throwing up any error codes. They also said that only a very small number of vans in early 2017 required an update.
The software update will wipe the remap. I'm a bit surpised the remap was done over old software - without checking possible updates?
Anyways, if you haven't had issues this far why update...
As @DXX pointed out earlier your engine made 153.9 hp before the remap so there can’t be much wrong with it surely??
Hmm possibly had one before! Mine was much stronger low down and then actually revved, useful power up to say 4k now where as before it was all noise after 2.5k
