It's not a silly question if you don't know the answer.This may be a silly question -
I have a 2022 T32 with original 17inch alloys and tyres 215/60 R17 109. Need some new tyres, can I put crossclimate 2 235/65 R17 108 on it?
I don't think the width and offset matter for calculating the rolling circumference - they're used for determining wheel position within the wheel arch (i.e. wheel tuck and poke)Cheers but I'm not sure what wheel width or offset input is in this calculator![]()
Hi. The tyres should fit fine with standard wheels, unless van as seriously lowered.This may be a silly question -
T32 std steel wheels, and just put 235/65 17 108's on no issue, Falken Wild thingy's on a t5.1 Caravelle (I think lowered 20mm)This may be a silly question -
im running 17" devonports with 235/55/17 cross climate 2, thats an OEM size so wont throw the speedo out. and reason you want larger 235/65?This may be a silly question -
they come in 103 XL 875kg so more than enough for t32im running 17" devonports with 235/55/17 cross climate 2, thats an OEM size so wont throw the speedo out. and reason you want larger 235/65?
65 are cheaper that's all. Not sure what that number means I could go for 60 so matching existing??im running 17" devonports with 235/55/17 cross climate 2, thats an OEM size so wont throw the speedo out. and reason you want larger 235/65?
The first of the two numbers is the nominal section width of the tyre. It is given in millimetres and defines the distance between the inner and outer sidewall of the tyre. For example, 205 means that your tyre is nominally 205 mm wide.65 are cheaper that's all. Not sure what that number means I could go for 60 so matching existing??![]()
Job doneHelp..... Newbie here and I know nothing about tyres. We have a 69 plate T32 Highline DSG - purchased earlier this year as a panel van and now fully converted. It went in to VW this week to have the ACC looked at and they noticed that our tyres aren't even commercial tyres - came to us with a new MOT in January so I can only think the guy we bought it off changed them after the MOT was done....grrr. It currently has 4 x 215 / 60R17 96H and we're off to France next week so need to get this sorted.
Our tyre man has said "There isn’t a great deal of choice in the 104/102 and as the 98H or V are insufficient then it might be worth looking at a higher rated tyre like the 109/107. We can get….. Continental VC200 £158.60 + vat per tyre, Goodyear EGrip Cargo 2 £157.20 + vat per tyre, Avon AV12 £137.60 + vat per tyre, Uniroyal Rainmax 5 £138.50 + vat per tyre. If you wanted an ALL SEASON tyre we can get…. Uniroyal £156.55 + vat per tyre, Goodyear Vector 4 Season Cargo £193.42 + vat per tyre. Alternatively Goodyear Vector 4 Seasons Cargo in a 104/102H at £154.00 + vat per tyre or I can also get a Kumho in a 104/102T at £108.00 + vat per tyre"
Trying to get the best solution for the least cost - any advice please?
Thanks for the reply. These are substantially more £££ - are you saying the ones our contact has suggested are not suitable?Job done
Michelin Agilis CrossClimate 215/60 R17 at Blackcircles.com
Buy tyres online and get them fitted locally with Blackcircles. Lifetime Guarantee now on all car, van & SUV tyres. Peace of mind, at no extra cost.www.blackcircles.com
there's 10% off & the price includes VAT, so works out cheaper than some of your prices. They are a very good tyre. For further tyre info, try the search function.Thanks for the reply. These are substantially more £££ - are you saying the ones our contact has suggested are not suitable?
Is there any disadvantage to going for a higher-rated load - ie 109 rather than 103/104?
